2 Replies Latest reply on Apr 30, 2006 7:58 AM by Newsgroup_User
    sendAndLoad flash player 8
    Level 7
      I just created a dynamic flash jigsaw puzzle that uses a sendAndLoad to
      read in the fastest time info from my database and then write to the
      database if a new record is set. Since I'm using the bitmap api, my swf
      requires the 8 player and works great with 8,0,24,0. However, some users
      said that they didn't see my high score info in the swf. After some
      testing, we discovered that the sendAndLoad isn't working in at the
      8,0,22,0 player.
      Can some of you check my swf with earlier versions of flash player 8 and
      see if it works?
      http://www.flashpuzzlezone.com/jigsaw.asp?id=8 or
      http://www.flashpuzzlezone.com/jigsaw.asp?id=16. The high score and time
      should show under the puzzle picture.
      Thanks!
      Chris...
        • 1. Re: sendAndLoad flash player 8
          Peter Lorent Level 2
          Works in 8,0,22,0 on a Mac.
          • 2. Re: sendAndLoad flash player 8
            Level 7
            Windows XP FireFox 1.5.0.2 Flash Player 8,0,22,0
            Could see Fastest Time: 2:02 by SheSoHot! for the second one and also
            saw a Fastest time for the first.
            >>After some testing, we discovered that the sendAndLoad isn't working in at
            >>the 8,0,22,0 player.
            More specifics of your testing environment might help, but a possible one
            that occurs is assigning the onLoad handler before the sendAndLoad. It is
            possible, remotely, if you have it the other way the sendAndLoad completes
            before AS reaches the onLoad handler assignment.
            Lon Hosford
            www.lonhosford.com
            May many happy bits flow your way!
            "Chris" <nospam@comcast.net> wrote in message
            news:e2ufn8$bdh$1@forums.macromedia.com...
            8,0,22,0 player.
            see if it works?
            Thanks!
            Chris...
