It downloads all the way and then says the Installation failed.
At first I thought it was because I just upgraded to Windows 10. Went back to 7 and Photoshop still won't install. Uninstalled photoshop and Creative Cloud, reinstalled Creative Cloud, Photoshop won't install. I've been going through the motions of trouble shooting and checking forums but any time I do something suggested to fix one thing, it just says the other.
The 160 Error gives this text when I click for more information (this was the last one I attempted, I don't have the other message):
Exit Code: 160
-------------------------------------- Summary --------------------------------------
- 2 fatal error(s), 0 error(s), 2 warnings(s)
FATAL: Error (Code = 160) executing in command 'SetRegistryValueCommand' for package: 'AdobePhotoshop17-Core_x64', version:17.0.1.159
FATAL: Error occurred in install of package (Name: AdobePhotoshop17-Core_x64 Version: 17.0.1.159). Error code: '160'
WARN: target folder 'C:\Program Files\Adobe\Adobe Photoshop CC 2015.5\Required\PDF\Settings' does not exist, treating package 'AdobePhotoshop17-en_US_x64' as uninstalled
WARN: Error Setting Registry - Start 64-bit:1 root:2 key:SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Photoshop.exe name:Default type:REG_SZ data:C:\Program Files\Adobe\Adobe Photoshop CC 2015.5\Photoshop.exe. Check for Registry permissions. (Error: Error 5 Access is denied.)
using a browser that allows popups and cookies, contact adobe support during pst business hours by clicking here and, when available, click 'still need help', http://helpx.adobe.com/x-productkb/global/service-ccm.html
uninstall everything cc including the cc desktop app, Uninstall the Adobe Creative Cloud desktop application
clean your computer of cc files per http://www.adobe.com/support/contact/cscleanertool.html
restart your computer (don't skip this)
reinstall the cc desktop app, https://creative.adobe.com/products/creative-cloud
use the desktop app to install your cc programs/trials
I've done that multiple times. Creative Cloud will reinstall but Photoshop will not.
I am getting the same error when I try to install update. I wonder if it is the version of windows. This computer has version 7 premier and is getting the error while my laptop which is version 8.1 updated correctly. I have been using this on both computer for over a year and never had this problem before.
I keep getting requests to update Photoshop CC on my Windows 10 machine from Creative Cloud and every time I get a message about " unable to write the registry value" and the explanation talks about error 160.
Strange thing is Photoshop tells ne I have the latest version 2015.5.1 so why is it trying to update?
Worked fine on my iMac and it shows the same version number
As kglad has adviced
using a browser that allows popups and cookies, contact adobe support during pst business hours by clicking here and, when available, click 'still need help', http://helpx.adobe.com/x-productkb/global/service-ccm.html​
These guys have did some magic with registry permissions (in my case ownership of the computer has been moved to the wrong account) and applied Full Control to Everyone permission and it worked. Connect with them.
Hi
the Problem is in the registry. Not correct set Permissions.
If you are using Win 7, SP 1, you might do the following:
Open registry
Browse to
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Photoshop.exe
May be you want to save it first....
Make a rightclick on Photoshop.exe
Permissions
Add the current User your are logged in and grant him all permissions you can grant. May also check on extended permission and make sure.
You then should be able to install the upgrade.
Thats what the support just did with my PC.
Thank you philippm.
Based on your information I managed to fix this problem on my Windows 10 PC. Here is what I changed:
(These instructions are for people who know what they are doing with registry editing. Follow at your own risk!)
After following these steps I re-tried the Photoshop update and it succeeded.
Tried that and didn't work.. Not sure what I did wrong.
I clicked the 'Advanced' button and at the top of the dialog box which openned, I clicked 'Change' next to the owner. I changed the owner to my Windows username. Now I was able to apply my edit to the permissions.
Please make sure that you have administrative permission on this computer.
PSTOOLS. run psexec.exe -i -s C:\Windows\regedit.exe and use instrcuction Footleg
Perfect, this ist the right way and realy easy
This worked for me! Thank you very much!
