12 Replies Latest reply on Jun 15, 2017 11:17 AM by clutch-cargo
    VBscript how to select a custom preset
    clutch-cargo Level 1
      Can someone show me how to select a custom trace preset in VBscript?  I have a single image loaded in Illustrator CS6 which I then need to trace.  I have tried several variations of:
      Set DocRef = App.ActiveDocument
      DocRef.TracingOptions.LoadFromPreset("simwest trace 1")
      Any help would be most appreciated.
        • 1. Re: VBscript how to select a custom preset
          I thought it best to include my script for anyone who can help.  It's at around line 22 that's the issue.
          Set App = CreateObject("Illustrator.Application")
          Set FSO = CreateObject("Scripting.FileSystemObject")
          Set SourceFolder = FSO.GetFolder("S:\SOCAL\Section_14\Veg TIFFs")
          Set TIFFfile = SourceFolder.Files
          Dim FileRef
          For Each FileRef In SourceFolder.Files
              Set AutoCADOpenOptions = App.Preferences.AutoCADFileOptions
                  AutoCADOpenOptions.MergeLayers = false
                  CurrentInteractionLevel = App.UserInteractionLevel
                  App.UserInteractionLevel = -1 ' aiDontDisplayAlerts
                  Set myDoc = App.Open(FileRef.Path,2)
                  App.UserInteractionLevel = CurrentInteractionLevel
                  App.DoScript "AutoVeg1", "Auto Veg TIFF-2-DXF"
                  DocRef.TracingOptions.LoadFromPreset("SimwestTrace")
                  ' I have also tried the following without success:
                  ' App.Tracing.TracingOptions.LoadFromPreset("SimwestTrace")
                  App.DoScript "Auto Veg2", "Auto Veg TIFF-2-DXF"
                  App.DoScript "SaveVegTIFF-2-DXF", "SavingFiles"
                  MyDoc.Close(2)
          Next
          • 2. Re: VBscript how to select a custom preset
            CarlosCanto Adobe Community Professional & MVP
            preset property is read only and I haven't had any luck loading presets from file...the only way I have made it work is by Recording an Action to trace using my preset, then the script can play such action.
            • 3. Re: VBscript how to select a custom preset
              Interesting, as that is what I originally did.   But I was seeing no difference between the default and my custom.  But I think I will try again as you said you have gotten it to work in the past.  So I guess Adobe documented the preset options but did not implement them in the code?
              On a side note, you have such great experience with vbscript... could I pm or email you with a different issue?
              • 4. Re: VBscript how to select a custom preset
                Tried several attempts to record a custom action but it only plays back as the default trace.
                I did find inside my Illustrator program a JavaScript which is for tracing.  If Carlos (or anyone who can help), could either:
                1.  Convert the tracing part of the script to VBscript and/or
                2.  Show me how one can add and run a JavaScript inside my VBscript.
                Maybe one of those ways might work?
                Here's from the JavaScript:
                // Trace the files by placing them in the document.
                                        // Add a document in the app
                                        var doc = app.documents.add();
                                        // Add a placed item
                                        var p = doc.placedItems.add();
                                        p.file = new File(fileList[i]);
                                        // Trace the placed item
                                        var t = p.trace();
                                        t.tracing.tracingOptions.loadFromPreset(tracingPresets[3]);
                                        app.redraw();
                Thanks for helping....
                • 5. Re: VBscript how to select a custom preset
                  great, didn't remember the default tracing script was there, I had tried getting the app.tracingPresetsList before without success, it always returned "undefined"...and after trying the vbs boom!! it works in javascript as well...weird.
                  anyway, after you add your preset manually, it will be added at the bottom of the presetsList, then you can get it from the list with
                  illustrator.Application.TracingPresetsList(18) 'in my list 18 corresponds to myB&W preset
                  now to get what number myB&W preset has, you can get the last number in the array with
                  ubound(illustrator.Application.TracingPresetsList)
                  or you can go thru the list with
                  illustrator.Application.TracingPresetsList(0)
                  illustrator.Application.TracingPresetsList(1)
                  illustrator.Application.TracingPresetsList(2)
                  etc
                  to play a line of javascript or some short code you can cram in a line, you can use
                  Function DoJavaScript(JavaScriptCode As String, [Arguments], [ExecutionMode]) As String
                  or if your javascript code is in a file, you could use
                  Function DoJavaScriptFile(JavaScriptFile As String, [Arguments], [ExecutionMode]) As String
                  • 6. Re: VBscript how to select a custom preset
                    THx Carlos,
                    but I must be thick in the head because nothing is working for me.  Here's my script. You can see the line you suggested added:
                    Set SourceFolder = FSO.GetFolder("C:\SOCAL\Section_12\Veg TIFFs")
                    Dim FileRef
                      App.DoScript "Auto Veg1", "Auto Veg TIFF-2-DXF 1m"
                      Illustrator.Application.TracingPresetsList(13)
                      MyDoc.Close(2)
                    Next
                    In this way I get the error "object Illustrator required"
                    So I tried
                    App.TracingPresetsList(13)
                    and I get "unspecified error, source null"
                    What am I messing up?
                    • 7. Re: VBscript how to select a custom preset
                      oh, first you need to get the whole preset list, then you have to trace your object (this will get done with defaults) then you can apply your preset
                      this is VBA, but you get the idea, create a new document, add a linked jpg before running this snippet
                      Sub usingTracingPreset()
                          Dim iapp As New Illustrator.Application
                          Dim idoc As Illustrator.Document
                          Dim iplaced As Illustrator.PlacedItem
                          Dim itraced As Illustrator.PluginItem
                          Set idoc = iapp.ActiveDocument
                          presets = iapp.TracingPresetsList
                          Set iplaced = idoc.PlacedItems(1)
                          Set itraced = iplaced.Trace
                          itraced.Tracing.TracingOptions.LoadFromPreset (presets(13))
                          Set itraced = Nothing
                          Set iplaced = Nothing
                          Set idoc = Nothing
                          Set iapp = Nothing
                      End Sub
                      • 8. Re: VBscript how to select a custom preset
                        Well, I gave her a go with your script, editing as best I know to vbscript but I am getting  the error "ActiveX component can't create object:", on the four top lines under 'Sub'.  If I comment out one the next line throws the error.  So this is beyond my knowledge.  Here my altered script from yours:
                            Dim idoc : idoc = CreateObject("Illustrator.Document")
                            Dim iplaced : iplaced = CreateObject("Illustrator.PlacedItem")
                            Dim itraced : itraced = CreateObject("Illustrator.PluginItem")
                            Set idoc = App.ActiveDocument
                            presets = App.TracingPresetsList
                            itraced.Tracing.TracingOptions.LoadFromPreset(presets(13))
                            Set idoc = Nothing
                            Set App = Nothing
                        End Sub
                        • 9. Re: VBscript how to select a custom preset
                          what's that? C#? I wouldn't know how to declare or assign the object references.
                          • 10. Re: VBscript how to select a custom preset
                            Oh-oh.  It's supposed to be VBscript!  I know I am new at scripting but is it that bad?  You said yours is in VBA.  Am I just supposed to run it as is?  I couldn't.
                            • 11. Re: VBscript how to select a custom preset
                              to run VBA you copy the code I posted, open Excel/Word/Access/Outlook, create a Module, paste the code...add a reference to Illustrator...run the code as is.
                              VBS, needs a little tweaking, vbs does not support "dim" and other declarations
                              • 12. Re: VBscript how to select a custom preset
                                Hi Carlos, it's been about a year since I last addressed this post (hopefully you will see this).  Back then I gave up as not fully understanding what needed to be done.  But now it is becoming crucial I solve this as I have to perform 100's of custom presets making manual selections no longer a viable option.
                                So I am taking my time, re-reading all above.  It sounds like the answer is there but I am just not there on how to implement it?
                                1. You suggest creating a VBS module and link to the tif image.  Does that mean I have to run the module outside of my VBscript or the module is somehow placed inside the VBscript?  Goal is to run entire process once started on its own without interaction.
                                2. You mentioned the vbs worked for you but then you say "vbs does not support "dim" and other declarations".  But you have it in the code above so I am a bit lost on this?  The code works as is above or not?
                                3.  So if I am reading the process correctly:
                                     A. Start Illustrator and load image
                                     B. Get a presets list
                                     C. Let Illustrator perform a "default" trace
                                     D. declare a presets list
                                     E. Apply my preset based on the list's number I want.
                                Here is what I have for my code so far.  The App.DoScript simply uses AI Actions to load the image and apply the default trace.
                                Set SourceFolder = FSO.GetFolder("S:\SOCAL\Section_31\Land Cover")
                                Dim FileRef
                                        ubound(App.TracingPresetsList)
                                        App.DoScript "LandCover-1", "Land Cover Auto"
