11 Replies Latest reply on Aug 11, 2016 4:48 AM by Obi-wan Kenobi
    Play with Layers! …
    Obi-wan Kenobi Level 5
      Hi all,
      Here's the beginning of my script:
      var myLayer_0 = "Headers_0";
      var myLayer_1 = myDoc.layers.item("Headers_1");
      if (myLayer_1.isValid == true)
          myDoc.layers.item(myLayer_1).remove();
      var myLayer_1 = myDoc.layers.item(myLayer_0).duplicate();
      myLayer_1.name = "Headers_1";
      myDoc.layers.item(myLayer_0).visible = false;
      myDoc.layers.item(myLayer_1).visible = true;
      The idea is simple:
      If "Headers_1" already exists, the script removes it, duplicates "Headers_0", calls it "Headers_1" and makes it visible.
      If "Headers_1" doesn't exist, the script duplicates "Headers_0", calls it "Headers_1" and makes it visible.
      … But this doesn't work!
      Thanks in advance!
        • 1. Re: Play with Layers! …
          csm_phil Level 4
          Hi Kenobi,
          I just modified your code, If its work my understanding is correct, otherwise please explain I'll check and update once again!.
              myLayer_1.remove();
              myDoc.layers.item(myLayer_0).visible=true;
              myDoc.layers.item(myLayer_0).locked=false;
              try{myDoc.layers.item(myLayer_1).visible == true}catch(e){};
          else{
              try{myDoc.layers.item("Headers_1").visible = true;}catch(e){};
          thx,
          csm_phil
          • 2. Re: Play with Layers! …
            tpk1982 Level 4
            try..catch method will be useful
            • 3. Re: Play with Layers! …
              Cool! It works fine! Thanks Phil!
              Last step: I would like to apply the method "detach()" to the content of the "Header_1" layer (myLayer_1)
              But only on the current pages, not the master pages!
              myDoc.pageItems.everyItem().layers.item(myLayer_1).everyItem().detach();
              … Of course, no result!
              • 4. Re: Play with Layers! …
                Kai Rübsamen Level 4
                First of all, why so complicated?
                var myLayer_0 = myDoc.layers.itemByName("Headers_0");
                var myLayer_1 = myDoc.layers.itemByName("Headers_1");
                if (myLayer_1.isValid) {
                  myLayer_1.remove();
                myLayer_1 = myLayer_0.duplicate();
                myLayer_0.visible = false;
                myLayer_1.visible = true;
                Second: I do not understand the new question? If you remove the layer before, every page items that belong to this layer are removed too.
                • 5. Re: Play with Layers! …
                  Best result! … but I can't find the code to only catch the "Header_1" layer items!
                  The script catches the "Header_0" layer items too!!!
                  var myVariable = "Header";
                      myLayer_1.remove();
                  else{
                      var i, l, page;
                      for (i = 0, l = myDoc.pages.length; i < l; i++) {
                          page = myDoc.pages[i];
                          if (page.appliedMaster !== null) {
                              for (j = 0, k = page.appliedMaster.pageItems.length; j < k; j++) {
                                  try {
                                      page.appliedMaster.pageItems[j].override(page);
                                  } catch(e) {}
                          page.pageItems.everyItem().detach();
                          page.pageItems.everyItem().textVariableInstances.everyItem(myVariable).convertToText();
                  • 6. Re: Play with Layers! …
                    Kai, you're right! More simple!
                    About the second point, I want to detach the items of the "Header_1" layer on the current page and only them after I (re)create it.
                    With my script last version, I'm not really sure to finally need to duplicate the "Header_0" layer because its content on the master pages is not touched!
                    What I finally need is first, if I have some items on the "Header_0" layer on the current pages, remove them, then detach the content of the "Header_0" layer on the current pages. And finally, convert the variable "Header" to text!.
                    • 7. Re: Play with Layers! …
                      Michel, but we remove Header_1 ? I would suggest, provide a example, with steps (1,2,3) before / after.
                      • 8. Re: Play with Layers! …
                        Something is missing!
                        I can't convert the variable [its parent frame is on "Header_1" layer] to text on the current pages!  [tired brain!]
                        var myLayer_0 = myDoc.layers.itemByName("Header_0");
                        var myLayer_1 = myDoc.layers.itemByName("Header_1");
                          myLayer_1.remove();
                        myLayer_1.name = "Header_1";
                        var TotalPages = (myDoc.pages.count());
                        for(var CurrentPage=0; CurrentPage < TotalPages; CurrentPage++) {
                             OverrideMasterItems();
                        function OverrideMasterItems() {
                            var myLayer = myDoc.layers.item("Header_1");
                            var allItems = myDoc.pages[CurrentPage].appliedMaster.pageItems.everyItem().getElements();
                            for(var i=0;i<allItems.length;i++){
                                try{
                                    if (allItems[i].itemLayer == myLayer) {
                                        allItems[i].override(myDoc.pages[CurrentPage]);
                                        }  // End if
                                }  // End try
                                catch(e){}
                            }  // End For
                        }  // End Function
                        }  // End For
                        for(0; CurrentPage < TotalPages; CurrentPage++) {
                            myDoc.pages[CurrentPage].textVariableInstances.everyItem(myVariable).convertToText();
                        • 9. Re: Play with Layers! …
                          Kai,
                          This version seems to work!
                            myLayer_1.remove();
                              var i, l, page;
                                          try {
                                          } catch(e) {}
                          I've not tested in real situations but, associated to another script [ Cross-reference paragraph number! …  ], we can do that:
                          I mean: with 1 click, generate headers with auto-numbering and active grep styles!  Cool!
                          • 10. Re: Play with Layers! …
                            1. It seems that your indents are a bit messed up > use better spaces instead of tabs
                            2. Your for-loop is wrong > 3 arguments, not 4
                            3. Since you did not provide a test-doc, I have no time to built a doc and test your result. Sorry.
                            • 11. Re: Play with Layers! …
                              Hi all,
                              Thanks to Phil and Kai for their answers that fix the first part of this topic!
                              Waiting for someone who could give you a global answer that I eventually could mark as "correct", you could take a look at my post#9 where you could find something that could work! At your own risks!
