10 Replies Latest reply on May 11, 2017 2:29 PM by justing53277757
    Crashing on Export
    jalleystudios Level 1
      Well, this is frustrating day.
      I have the latest Lightroom CC, I believe it's 6.6.1 operating on El Capitan 10.11.6.  iMac 5k.  Most of my photos and my library/catalog are on external TB2 8TB Gtech drive.  I upgraded RAM through OWC from 16GB to 64GB
      I've been trying to export 81 photos from LR.  For the last 2 days.
      Before this started, I had no issues.  Same workflow, same computer.  I could export until the cows come home.  I did the CC update to 6.6.1, thinking that might solve some bugs.  But it didn't.
      This is what I know so far:
      *I can be in LR, and it doesn't crash.  Mainly just when I export, and approx half way thru.
      *When it does crash, mouse is unresponsive, black screen for a second then the white error text on black screen and iMac restarts to login window.
      *Last time I had console up as the crash happened and Console crashed first.
      *I've done disk repair on HD and external drive.  (no errors reported on HD, it seemed to repair something on external, or it just took a while)
      *This happens whether I startup with TB drive attached or not.
      *Yesterday (prior to updating LR CC to current version) the iMac was sleeping to a black screen that would then become unresponsive when in LR (or Premiere).  Apple genius looked through code and couldn't find anything immediate, and it doesn't seem to happen when it's NOT connected to an external drive.
      *I changed out the TB cables, I unchecked "put hard drives to sleep" and the sleep to black doesn't seem to happen now, but it's still crashing on export.
      Anyone experiencing anything like this?  My next step will to be try to use another computer and see if it does the same thing when I load up that library and hard drive.
      Thanks...
        • 1. Re: Crashing on Export
          dj_paige Level 10
          When the entire computer restarts, this is almost always a hardware problem, or a bad video driver.
          So, re-install your video driver. Run diagnostics on the CPU, memory and hard disk. Visually check to be sure the fans in the computer case are actually running.
          • 2. Re: Crashing on Export
            You may be onto something here -- LR does actually export (yahhh) using the same catalog, with the same drive, just using a different computer.
            Apple did testing on it yesterday, curious to know why wouldn't they have found the error in the video driver during their diagnostics?  Isn't that the whole point?
            • 3. Re: Crashing on Export
              dj_paige Level 10
              I don't know what Apple checked, the recommendation is to test all of your hardware, as well as to reinstall the video driver. And I also want to point out that I also suggested checking the fans in the computer case, did Apple check that?
              • 4. Re: Crashing on Export
                Evening update:
                So -- I replaced my entire iMac with brand new iMac.  Did not do a migration, instead downloaded CC and then installed LR and Premiere, etc.
                AND As I go again to export, on number 36 of 81 to export JPEGS....crash.  Now this time it didn't crash the computer, just the software.  This was literally the first time opening LR, after downloading fresh copy.
                I'm flabbergasted.
                I'm trying now to isolate the problem.  It seems I can export 59 images as a catalog fine to another catalog..on the desktop.  I'm now trying to see if that catalog will export JPGS without crashing LR.
                Okay - So, I'm getting somewhere.  I can copy over the 59 images to a catalog file, and it opens fine but I cannot export them as JPEGS.  Also, it's crashing to restart, going through black screen with text.  Nothing else is on this machine except dropbox and Premiere (not running though)
                Here is the Log for that first crash up above:
                Process:               Adobe Lightroom [2263]
                Path:                  /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                Identifier:            com.adobe.Lightroom6
                Version:               Adobe Lightroom [1083169] (6.6.1)
                Code Type:             X86-64 (Native)
                Parent Process:        ??? [1]
                Responsible:           Adobe Lightroom [2263]
                User ID:               501
                Date/Time:             2016-08-10 22:09:44.762 -0700
                OS Version:            Mac OS X 10.11.4 (15E65)
                Report Version:        11
                Anonymous UUID:        49A5FC3A-B706-C00D-6EA4-45DF559E0645
                Sleep/Wake UUID:       FB8DD66A-3F05-433D-A438-ED8917DFB884
                Time Awake Since Boot: 3000 seconds
                Time Since Wake:       670 seconds
                System Integrity Protection: enabled
                Crashed Thread:        19  Worker Thread
                Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
                Exception Codes:       KERN_INVALID_ADDRESS at 0x000000000000006f
                Exception Note:        EXC_CORPSE_NOTIFY
                VM Regions Near 0x6f:
                    __TEXT                 000000010d717000-000000010d725000 [   56K] r-x/rwx SM=COW  /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                Global Trace Buffer (reverse chronological seconds):
                31.253838                              0xffffffff09fe8447 Format not found
                31.358157                              0xffffffff09fe8323 Format not found
                31.358231                              0xffffffff09fe6ced Format not found
                31.358444                              0xffffffff0a0755c7 Format not found
                31.436620                              0xffffffff09fe5fbf Format not found
                62.430410                              0xffffffff09fe8447 Format not found
                62.525733                              0xffffffff09fe8323 Format not found
                62.525845                              0xffffffff09fe6ced Format not found
                62.526118                              0xffffffff0a0755c7 Format not found
                62.578280                              0xffffffff09fe5fbf Format not found
                91.141732                              0xffffffff11029a11 Format not found
                91.141737                              0xffffffff11029a11 Format not found
                91.141765                              0xffffffff11029a11 Format not found
                91.141781                              0xffffffff11029a11 Format not found
                91.141836                              0xffffffff11029a11 Format not found
                91.141878                              0xffffffff11029a11 Format not found
                Thread 0:: Dispatch queue: com.apple.main-thread
                0   libsystem_kernel.dylib        0x00007fff8324ef72 mach_msg_trap + 10
                1   libsystem_kernel.dylib        0x00007fff8324e3b3 mach_msg + 55
                2   com.apple.CoreFoundation      0x00007fff8498f1c4 __CFRunLoopServiceMachPort + 212
                3   com.apple.CoreFoundation      0x00007fff8498e68c __CFRunLoopRun + 1356
                4   com.apple.CoreFoundation      0x00007fff8498ded8 CFRunLoopRunSpecific + 296
                5   com.apple.HIToolbox           0x00007fff845c7935 RunCurrentEventLoopInMode + 235
                6   com.apple.HIToolbox           0x00007fff845c776f ReceiveNextEventCommon + 432
                7   com.apple.HIToolbox           0x00007fff845c75af _BlockUntilNextEventMatchingListInModeWithFilter + 71
                8   com.apple.AppKit              0x00007fff8b9a8efa _DPSNextEvent + 1067
                9   com.apple.AppKit              0x00007fff8b9a832a -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
                10  com.apple.AppKit              0x00007fff8b99ce84 -[NSApplication run] + 682
                11  com.apple.AppKit              0x00007fff8b96646c NSApplicationMain + 1176
                12  com.adobe.Lightroom6          0x000000010d7190c8 main + 952
                13  libdyld.dylib                 0x00007fff8dd635ad start + 1
                Thread 1:
                0   libsystem_kernel.dylib        0x00007fff832555e2 __workq_kernreturn + 10
                1   libsystem_pthread.dylib       0x00007fff8e33e578 _pthread_wqthread + 1283
                2   libsystem_pthread.dylib       0x00007fff8e33c341 start_wqthread + 13
                Thread 2:: Dispatch queue: com.apple.libdispatch-manager
                0   libsystem_kernel.dylib        0x00007fff83255efa kevent_qos + 10
                1   libdispatch.dylib             0x00007fff8e12f165 _dispatch_mgr_invoke + 216
                2   libdispatch.dylib             0x00007fff8e12edcd _dispatch_mgr_thread + 52
                Thread 3:: Worker Thread Dispatcher
                0   libsystem_kernel.dylib        0x00007fff83254db6 __psynch_cvwait + 10
                1   libsystem_pthread.dylib       0x00007fff8e33f728 _pthread_cond_wait + 767
                2   com.adobe.ag.kernel           0x000000010d759dd4 AgConditionLock_wait + 38
                3   com.adobe.ag.kernel           0x000000010d753857 AgTransitQueue_dequeueToLuaState + 91
                4   com.adobe.ag.kernel           0x000000010d7542f9 0x10d733000 + 135929
                5   com.adobe.ag.kernel           0x000000010d73ce15 0x10d733000 + 40469
                6   com.adobe.ag.kernel           0x000000010d74b55d 0x10d733000 + 99677
                7   com.adobe.ag.kernel           0x000000010d73d0e1 0x10d733000 + 41185
                8   com.adobe.ag.kernel           0x000000010d7350f1 lua_call + 37
                9   com.adobe.ag.substrate        0x000000010d88dc7d AgLua_callWithAutoReleasePool + 85
                10  com.adobe.ag.kernel           0x000000010d73ce15 0x10d733000 + 40469
                11  com.adobe.ag.kernel           0x000000010d74b55d 0x10d733000 + 99677
                12  com.adobe.ag.kernel           0x000000010d73d0e1 0x10d733000 + 41185
                13  com.adobe.ag.kernel           0x000000010d73c77e 0x10d733000 + 38782
                14  com.adobe.ag.kernel           0x000000010d73d33d 0x10d733000 + 41789
                15  com.adobe.ag.kernel           0x000000010d735172 lua_pcall + 100
                16  com.adobe.ag.substrate        0x000000010d881389 0x10d86f000 + 74633
                17  com.apple.Foundation          0x00007fff85635d64 __NSThread__start__ + 1351
                18  libsystem_pthread.dylib       0x00007fff8e33e99d _pthread_body + 131
                19  libsystem_pthread.dylib       0x00007fff8e33e91a _pthread_start + 168
                20  libsystem_pthread.dylib       0x00007fff8e33c351 thread_start + 13
                Thread 4:: cr_scratch
                2   com.adobe.ag.AgImageIO        0x000000011278934b 0x112590000 + 2069323
                3   com.adobe.ag.AgImageIO        0x0000000112995a6b 0x112590000 + 4217451
                4   com.adobe.ag.AgImageIO        0x00000001127526d1 0x112590000 + 1844945
                5   libsystem_pthread.dylib       0x00007fff8e33e99d _pthread_body + 131
                6   libsystem_pthread.dylib       0x00007fff8e33e91a _pthread_start + 168
                7   libsystem_pthread.dylib       0x00007fff8e33c351 thread_start + 13
                Thread 5:: Queue Processor - AgPhotoAvailability
                6   com.adobe.ag.kernel           0x000000010d73d0d0 0x10d733000 + 41168
                7   com.adobe.ag.kernel           0x000000010d7350f1 lua_call + 37
                8   com.adobe.ag.substrate        0x000000010d88dc7d AgLua_callWithAutoReleasePool + 85
                9   com.adobe.ag.kernel           0x000000010d73ce15 0x10d733000 + 40469
                10  com.adobe.ag.kernel           0x000000010d74b55d 0x10d733000 + 99677
                11  com.adobe.ag.kernel           0x000000010d73d0e1 0x10d733000 + 41185
                12  com.adobe.ag.kernel           0x000000010d73c77e 0x10d733000 + 38782
                13  com.adobe.ag.kernel           0x000000010d73d33d 0x10d733000 + 41789
                14  com.adobe.ag.kernel           0x000000010d735172 lua_pcall + 100
                15  com.adobe.ag.kernel           0x000000010d736ec6 0x10d733000 + 16070
                16  com.adobe.ag.kernel           0x000000010d73ce15 0x10d733000 + 40469
                17  com.adobe.ag.kernel           0x000000010d73d0d0 0x10d733000 + 41168
                18  com.adobe.ag.kernel           0x000000010d7350f1 lua_call + 37
                19  com.adobe.ag.substrate        0x000000010d88dc7d AgLua_callWithAutoReleasePool + 85
                20  com.adobe.ag.kernel           0x000000010d73ce15 0x10d733000 + 40469
                21  com.adobe.ag.kernel           0x000000010d74b55d 0x10d733000 + 99677
                22  com.adobe.ag.kernel           0x000000010d73d0e1 0x10d733000 + 41185
                23  com.adobe.ag.kernel           0x000000010d73c77e 0x10d733000 + 38782
                24  com.adobe.ag.kernel           0x000000010d73d33d 0x10d733000 + 41789
                25  com.adobe.ag.kernel           0x000000010d735172 lua_pcall + 100
                26  com.adobe.ag.substrate        0x000000010d881389 0x10d86f000 + 74633
                27  com.apple.Foundation          0x00007fff85635d64 __NSThread__start__ + 1351
                28  libsystem_pthread.dylib       0x00007fff8e33e99d _pthread_body + 131
                29  libsystem_pthread.dylib       0x00007fff8e33e91a _pthread_start + 168
                30  libsystem_pthread.dylib       0x00007fff8e33c351 thread_start + 13
                Thread 6:: AsyncDataServer
                2   com.adobe.ag.kernel           0x000000010d759e68 AgConditionLock_wait + 186
                Thread 7:: com.apple.NSURLConnectionLoader
                5   com.apple.CFNetwork           0x00007fff8a01b111 +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
                6   com.apple.Foundation          0x00007fff85635d64 __NSThread__start__ + 1351
                7   libsystem_pthread.dylib       0x00007fff8e33e99d _pthread_body + 131
                8   libsystem_pthread.dylib       0x00007fff8e33e91a _pthread_start + 168
                9   libsystem_pthread.dylib       0x00007fff8e33c351 thread_start + 13
                Thread 8:: com.apple.NSEventThread
                5   com.apple.AppKit              0x00007fff8bafee99 _NSEventThread + 149
                6   libsystem_pthread.dylib       0x00007fff8e33e99d _pthread_body + 131
                7   libsystem_pthread.dylib       0x00007fff8e33e91a _pthread_start + 168
                8   libsystem_pthread.dylib       0x00007fff8e33c351 thread_start + 13
                Thread 9:: com.apple.CFSocket.private
                0   libsystem_kernel.dylib        0x00007fff8325507a __select + 10
                1   com.apple.CoreFoundation      0x00007fff849cc4fa __CFSocketManager + 762
                2   libsystem_pthread.dylib       0x00007fff8e33e99d _pthread_body + 131
                3   libsystem_pthread.dylib       0x00007fff8e33e91a _pthread_start + 168
                4   libsystem_pthread.dylib       0x00007fff8e33c351 thread_start + 13
                Thread 10:: Preview Server
                Thread 11:: Queue Processor - PreviewFileStore
                Thread 12:
                2   com.adobe.headlights.LogSessionFramework 0x000000011c20f2dc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
                3   com.adobe.headlights.LogSessionFramework 0x000000011c20db9e boost::this_thread::hiden::sleep_until(timespec const&) + 78
                4   com.adobe.headlights.LogSessionFramework 0x000000011c1b6911 RealTimeProcessor::Sleep(int) + 243
                5   com.adobe.headlights.LogSessionFramework 0x000000011c1b4d9d RealTimeProcessor::WorkerThread() + 2157
                6   com.adobe.headlights.LogSessionFramework 0x000000011c20cbfa boost::(anonymous namespace)::thread_proxy(void*) + 138
                Thread 13:: Queue Processor - NegativeQueue
                Thread 14:: Queue Processor - HistogramQueue
                Thread 15:: Queue Processor - RenderQueue_Render
                Thread 16:: Queue Processor - RenderQueue_ReadPreview
                Thread 17:: Queue Processor - RenderQueue_Video
                Thread 18:: Queue Processor - RenderQueue_Face
                Thread 19 Crashed:: Worker Thread
                0   com.adobe.ag.AgImageIO        0x0000000112996015 0x112590000 + 4218901
                1   com.adobe.ag.AgImageIO        0x0000000112995de2 0x112590000 + 4218338
                2   com.adobe.ag.AgImageIO        0x0000000112994698 0x112590000 + 4212376
                3   com.adobe.ag.AgImageIO        0x00000001129947de 0x112590000 + 4212702
                4   com.adobe.ag.AgImageIO        0x00000001126bd345 0x112590000 + 1233733
                5   com.adobe.ag.AgImageIO        0x00000001125b13fd 0x112590000 + 136189
                6   com.adobe.ag.AgImageIO        0x00000001125b0be9 0x112590000 + 134121
                7   com.adobe.ag.AgImageIO        0x00000001125b1558 0x112590000 + 136536
                8   com.adobe.ag.AgImageIO        0x0000000112757e12 0x112590000 + 1867282
                9   com.adobe.ag.AgImageIO        0x0000000112765fbe 0x112590000 + 1925054
                10  com.adobe.ag.AgImageIO        0x0000000112592912 0x112590000 + 10514
                11  com.adobe.ag.AgImageIO        0x00000001125926b3 0x112590000 + 9907
                12  com.adobe.ag.AgImageIO        0x00000001125c3d0c 0x112590000 + 212236
                13  com.adobe.ag.kernel           0x000000010d73ce15 0x10d733000 + 40469
                14  com.adobe.ag.kernel           0x000000010d74b55d 0x10d733000 + 99677
                15  com.adobe.ag.kernel           0x000000010d73d0e1 0x10d733000 + 41185
                16  com.adobe.ag.kernel           0x000000010d73c77e 0x10d733000 + 38782
                17  com.adobe.ag.kernel           0x000000010d73d33d 0x10d733000 + 41789
                18  com.adobe.ag.kernel           0x000000010d735172 lua_pcall + 100
                19  com.adobe.ag.kernel           0x000000010d736ec6 0x10d733000 + 16070
                26  com.adobe.ag.kernel           0x000000010d736ec6 0x10d733000 + 16070
                27  com.adobe.ag.kernel           0x000000010d73ce15 0x10d733000 + 40469
                28  com.adobe.ag.kernel           0x000000010d74b55d 0x10d733000 + 99677
                29  com.adobe.ag.kernel           0x000000010d73d0e1 0x10d733000 + 41185
                30  com.adobe.ag.kernel           0x000000010d73c77e 0x10d733000 + 38782
                31  com.adobe.ag.kernel           0x000000010d73d33d 0x10d733000 + 41789
                32  com.adobe.ag.kernel           0x000000010d735172 lua_pcall + 100
                33  com.adobe.ag.kernel           0x000000010d736ec6 0x10d733000 + 16070
                34  com.adobe.ag.kernel           0x000000010d73ce15 0x10d733000 + 40469
                35  com.adobe.ag.kernel           0x000000010d73d0d0 0x10d733000 + 41168
                36  com.adobe.ag.kernel           0x000000010d7350f1 lua_call + 37
                37  com.adobe.ag.substrate        0x000000010d88dc7d AgLua_callWithAutoReleasePool + 85
                38  com.adobe.ag.kernel           0x000000010d73ce15 0x10d733000 + 40469
                39  com.adobe.ag.kernel           0x000000010d74b55d 0x10d733000 + 99677
                40  com.adobe.ag.kernel           0x000000010d73d0e1 0x10d733000 + 41185
                41  com.adobe.ag.kernel           0x000000010d73c77e 0x10d733000 + 38782
                42  com.adobe.ag.kernel           0x000000010d73d33d 0x10d733000 + 41789
                43  com.adobe.ag.kernel           0x000000010d735172 lua_pcall + 100
                44  com.adobe.ag.substrate        0x000000010d881389 0x10d86f000 + 74633
                45  com.apple.Foundation          0x00007fff85635d64 __NSThread__start__ + 1351
                46  libsystem_pthread.dylib       0x00007fff8e33e99d _pthread_body + 131
                47  libsystem_pthread.dylib       0x00007fff8e33e91a _pthread_start + 168
                48  libsystem_pthread.dylib       0x00007fff8e33c351 thread_start + 13
                Thread 20:: Worker Thread
                0   libsystem_kernel.dylib        0x00007fff83254de6 __psynch_mutexwait + 10
                1   libsystem_pthread.dylib       0x00007fff8e33ee4a _pthread_mutex_lock_wait + 89
                2   libsystem_pthread.dylib       0x00007fff8e33c5f5 _pthread_mutex_lock_slow + 300
                3   com.adobe.ag.AgImageIO        0x00000001127891cd 0x112590000 + 2068941
                4   com.adobe.ag.AgImageIO        0x00000001126bdac9 0x112590000 + 1235657
                5   com.adobe.ag.AgImageIO        0x00000001126a699a 0x112590000 + 1141146
                6   com.adobe.ag.AgImageIO        0x00000001126a7d59 0x112590000 + 1146201
                7   com.adobe.ag.AgImageIO        0x0000000112818d4a 0x112590000 + 2657610
                8   com.adobe.ag.AgImageIO        0x00000001126a7d59 0x112590000 + 1146201
                9   com.adobe.ag.AgImageIO        0x00000001126abc3b 0x112590000 + 1162299
                10  com.adobe.ag.AgImageIO        0x00000001126b4a3c 0x112590000 + 1198652
                11  com.adobe.ag.AgImageIO        0x00000001126b4c22 0x112590000 + 1199138
                12  com.adobe.ag.AgImageIO        0x00000001126ad262 0x112590000 + 1167970
                13  com.adobe.ag.AgImageIO        0x00000001126aeb49 0x112590000 + 1174345
                14  com.adobe.ag.AgImageIO        0x00000001126b029d 0x112590000 + 1180317
                15  com.adobe.ag.AgImageIO        0x0000000112664993 0x112590000 + 870803
                16  com.adobe.ag.AgImageIO        0x0000000112821f09 0x112590000 + 2694921
                17  com.adobe.ag.AgImageIO        0x0000000112839e69 0x112590000 + 2793065
                18  com.adobe.ag.AgImageIO        0x0000000112596576 0x112590000 + 25974
                19  com.adobe.ag.AgImageIO        0x00000001125b9dd3 0x112590000 + 171475
                Thread 21:
                0   libsystem_kernel.dylib        0x00007fff83254fba __recvfrom + 10
                1   VulcanMessage5.dylib          0x0000000126ef4386 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
                2   VulcanMessage5.dylib          0x0000000126ef35fd vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 21
                3   VulcanMessage5.dylib          0x0000000126ef29b8 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 82
                4   VulcanMessage5.dylib          0x0000000126ef28ee vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
                5   VulcanMessage5.dylib          0x0000000126eed498 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 46
                6   VulcanMessage5.dylib          0x0000000126eed936 vcfoundation::io::Serializer::InternalDeserialize() + 30
                7   VulcanMessage5.dylib          0x0000000126eed8dd vcfoundation::io::Serializer::Deserialize() + 9
                8   VulcanMessage5.dylib          0x0000000126ef1762 vcfoundation::ncomm::Connection::ReadIn() + 22
                9   VulcanMessage5.dylib          0x0000000126ef1489 vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 37
                10  VulcanMessage5.dylib          0x0000000126ef110a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
                11  VulcanMessage5.dylib          0x0000000126ef105d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
                12  VulcanMessage5.dylib          0x0000000126ee3e66 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
                13  VulcanMessage5.dylib          0x0000000126ee491f adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 1005
                14  VulcanMessage5.dylib          0x0000000126ef2288 vcfoundation::thread::AbstractThread::Run() + 50
                15  VulcanMessage5.dylib          0x0000000126ef3da9 vcfoundation::thread::Thread::ThreadProc(void*) + 9
                16  libsystem_pthread.dylib       0x00007fff8e33e99d _pthread_body + 131
                17  libsystem_pthread.dylib       0x00007fff8e33e91a _pthread_start + 168
                18  libsystem_pthread.dylib       0x00007fff8e33c351 thread_start + 13
                Thread 22:: Worker Thread
                8   com.adobe.ag.kernel           0x000000010d73c77e 0x10d733000 + 38782
                9   com.adobe.ag.kernel           0x000000010d73d33d 0x10d733000 + 41789
                10  com.adobe.ag.kernel           0x000000010d735172 lua_pcall + 100
                11  com.adobe.ag.kernel           0x000000010d736ec6 0x10d733000 + 16070
                12  com.adobe.ag.kernel           0x000000010d73ce15 0x10d733000 + 40469
                13  com.adobe.ag.kernel           0x000000010d73d0d0 0x10d733000 + 41168
                14  com.adobe.ag.kernel           0x000000010d7350f1 lua_call + 37
                15  com.adobe.ag.substrate        0x000000010d88dc7d AgLua_callWithAutoReleasePool + 85
                17  com.adobe.ag.kernel           0x000000010d74b55d 0x10d733000 + 99677
                18  com.adobe.ag.kernel           0x000000010d73d0e1 0x10d733000 + 41185
                19  com.adobe.ag.kernel           0x000000010d73c77e 0x10d733000 + 38782
                20  com.adobe.ag.kernel           0x000000010d73d33d 0x10d733000 + 41789
                21  com.adobe.ag.kernel           0x000000010d735172 lua_pcall + 100
                22  com.adobe.ag.substrate        0x000000010d881389 0x10d86f000 + 74633
                23  com.apple.Foundation          0x00007fff85635d64 __NSThread__start__ + 1351
                24  libsystem_pthread.dylib       0x00007fff8e33e99d _pthread_body + 131
                25  libsystem_pthread.dylib       0x00007fff8e33e91a _pthread_start + 168
                26  libsystem_pthread.dylib       0x00007fff8e33c351 thread_start + 13
                Thread 23:: Worker Thread
                Thread 24:: Worker Thread
                Thread 25:: Worker Thread
                Thread 26:
                2   com.apple.CoreServices.CarbonCore 0x00007fff8d1b28ac TSWaitOnCondition + 108
                3   com.apple.CoreServices.CarbonCore 0x00007fff8d1b2aab TSWaitOnConditionTimedRelative + 171
                4   com.apple.CoreServices.CarbonCore 0x00007fff8d18b012 MPWaitOnQueue + 192
                5   com.adobe.dvacore.framework   0x000000011fbd9e48 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()> > >&, int) + 152
                6   com.adobe.dvacore.framework   0x000000011fbd71a8 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 152
                7   com.adobe.dvacore.framework   0x000000011fbd3b8e dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 158
                8   com.adobe.boost_threads.framework 0x000000011646d755 boost::(anonymous namespace)::thread_proxy(void*) + 133
                9   libsystem_pthread.dylib       0x00007fff8e33e99d _pthread_body + 131
                10  libsystem_pthread.dylib       0x00007fff8e33e91a _pthread_start + 168
                11  libsystem_pthread.dylib       0x00007fff8e33c351 thread_start + 13
                Thread 27:
                0   libsystem_kernel.dylib        0x00007fff83255eca kevent + 10
                1   com.adobe.dvatransport.framework 0x00000001165099a1 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 241
                2   com.adobe.dvatransport.framework 0x000000011650957c boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 284
                3   com.adobe.dvatransport.framework 0x00000001165090e8 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 568
                4   com.adobe.dvatransport.framework 0x00000001164f7112 SkyConnectionEnv::MainLoop() + 162
                5   com.adobe.dvatransport.framework 0x00000001164f6aa9 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
                6   com.adobe.boost_threads.framework 0x000000011646d755 boost::(anonymous namespace)::thread_proxy(void*) + 133
                Thread 28:
                2   com.adobe.dvatransport.framework 0x000000011650961b boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 443
                4   com.adobe.dvatransport.framework 0x0000000116508e8a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 42
                5   com.adobe.dvatransport.framework 0x000000011650a0f3 boost_asio_detail_posix_thread_function + 19
                Thread 29:
                Thread 30:
                Thread 31:
                Thread 32:
                Thread 33:
                Thread 34:
                Thread 35:
                Thread 19 crashed with X86 Thread State (64-bit):
                  rax: 0x00007f9e03c224d0  rbx: 0x00007f9de82aecf0  rcx: 0x0000000001e45f60  rdx: 0x0000000000a17520
                  rdi: 0x0000000000000063  rsi: 0x000000010dc62e00  rbp: 0x0000700000c4e630  rsp: 0x0000700000c4e620
                   r8: 0x0000000000000001   r9: 0x00007f9de6b54400  r10: 0x000000002aadf488  r11: 0x00007f9deb000000
                  r12: 0x000000000000000c  r13: 0x00007f9de7ba15b0  r14: 0x0000700000c4e660  r15: 0x00007f9dfd9b5cd0
                  rip: 0x0000000112996015  rfl: 0x0000000000010202  cr2: 0x000000000000006f
                Logical CPU:     1
                Error Code:      0x00000004
                Trap Number:     14
                Binary Images:
                       0x10d717000 -        0x10d724ff7 +com.adobe.Lightroom6 (Adobe Lightroom [1083169] - 6.6.1) <D2464959-3886-3878-A043-02DA17464305> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                       0x10d733000 -        0x10d768ff7 +com.adobe.ag.kernel (AgKernel Version 1.0 - 1.0) <1629EE41-D5DC-33C4-8105-E44829C74986> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgKernel.framework/Versions/A/AgKernel
                       0x10d77b000 -        0x10d824fff +com.adobe.ag.ui (views version 0.0.1d1 - 0) <0EDF91F6-F9B1-3F02-8C54-0733799C543D> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgUI.framework/Versions/A/AgUI
                       0x10d86f000 -        0x10d8a6fff +com.adobe.ag.substrate (com.adobe.ag.substrate 6.6.1 - 1.0) <5CDD991A-D5C0-30B7-9796-39BFD15F0A75> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgSubstrate.framework/Versions/A/AgSubstrate
                       0x10d8cd000 -        0x10d9d4ff7 +com.adobe.amtlib (9.0.0.437 - 9.0.0.437) <585448D3-D96D-3DD8-B2B4-CF73973E0783> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                       0x10d9e9000 -        0x10dc27ff7 +com.adobe.wichitafoundation (com.adobe.wichitafoundation 6.6.1 - 1.0) <1430FE6A-8432-307B-8F3A-04C866774940> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/WichitaFoundation.agtoolkit/Versions/A/WichitaFoundatio n
                       0x10df56000 -        0x10df56fff +com.adobe.lightroom.AdobeCrashReporter (1.0) <512B169C-015F-3CA2-89FF-7C7ED1BEB52C> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/Adobe Crash Reporter.bundle/Contents/MacOS/Adobe Crash Reporter
                       0x10df5b000 -        0x10df5efff +com.adobe.AdobeCrashReporter (7.1 - 7.1.4) <A33546D9-3E26-38A2-88FE-C7C46B4CD989> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashRepor ter
                       0x110116000 -        0x110157ff7 +com.adobe.ag.bridgetalk (com.adobe.ag.bridgetalk 6.6.1 - 1.0) <B86133F4-AAC9-3B04-A82C-AB61216A899F> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/BridgeTalk.agtoolkit/Contents/MacOS/BridgeTalk
                       0x110191000 -        0x110234ff7 +com.adobe.ag.imageanalysis (com.adobe.ag.imageanalysis 6.6.1 - 1.0) <1D426ABE-F8BF-30DE-A0CA-B789960A58B1> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/ImageAnalysis.agtoolkit/Contents/MacOS/ImageAnalysis
                       0x110244000 -        0x110318fff +com.adobe.CIT (2.3.0.33236 - 2.3.0.33236) <5CC0D600-30F2-3A3C-9515-CAF5B3DA4B39> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CIT.framework/Versions/A/CIT
                       0x110328000 -        0x11032cff7 +com.adobe.CITThreading (2.3.0.33236 - 2.3.0.33236) <2E66E0A3-A60C-388A-8552-C5F3B9755AD7> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
                       0x110aed000 -        0x110af2ff7 +com.adobe.lightroom.import (com.adobe.ag.import 6.6.1 - 1.0) <EE3C775A-A304-3E0F-8457-C734721CB827> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/Import.lrmodule/Contents/MacOS/Import
                       0x110ec6000 -        0x111011fff +IMSLib.dylib (10.0.0.8 - 10.0.0.8) <FA4C11DB-00BB-32E6-A53D-1E39A24745CF> /Library/Application Support/Adobe/*/IMSLib.dylib
                       0x111274000 -        0x1112b4ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 9.0.0.15 - 9.0.0.15) <777D69DE-E701-3DAE-AF9C-7B7B48C0189C> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifi cations
                       0x112539000 -        0x11253aff7 +com.adobe.ag.xml (com.adobe.ag.xml 6.6.1 - 1.0) <E3B3EC7E-499F-3761-9034-9C805D2DB752> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/XML.agtoolkit/Contents/MacOS/XML
                       0x112590000 -        0x11511dff3 +com.adobe.ag.AgImageIO (com.adobe.ag.AgImageIO 6.6.1 - 1.0.0d1) <B452661B-1893-3F5C-9ACF-F71F2A1D4FE0> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CameraRaw.lrtoolkit/CameraRaw
                       0x1153c2000 -        0x115476fff  com.apple.AMDRadeonX4000GLDriver (1.42.6 - 1.4.2) <F5F98355-9AC6-3823-962B-13A9BB3AF74D> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLD river
                       0x11548e000 -        0x1158dffff  ATIRadeonX4000SCLib.dylib (1.42.6) <EE374535-CFE4-3187-B0DD-88EBCADE24AA> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCL ib.dylib
                       0x115ee2000 -        0x115eedff7 +com.adobe.ag.video-toolkit (com.adobe.ag.video_toolkit 6.6.1 - 1) <83E1F2E3-CC29-3337-BBF4-7BBB58BE4EE6> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/video_toolkit.agtoolkit/Contents/MacOS/video_toolkit
                       0x115f8a000 -        0x115fcafff  com.apple.glut (3.6.3 - GLUT-3.6.3) <C04090D4-CC28-3768-985B-65F5B3BE4A30> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
                       0x11642e000 -        0x11643afff +com.adobe.boost_signals.framework (8.0.0 - 8.0.0.0) <88D7109B-FA74-3F98-AADD-96009AB9B583> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                       0x116448000 -        0x11644dff7 +com.adobe.boost_system.framework (8.0.0 - 8.0.0.0) <20B6A3B5-2E0E-329E-92AD-D4B2F504CF46> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                       0x116455000 -        0x11645dff7 +com.adobe.boost_date_time.framework (8.0.0 - 8.0.0.0) <AC8F9542-BDD5-3680-868F-B3773CC9E484> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                       0x11646c000 -        0x11647aff7 +com.adobe.boost_threads.framework (8.0.0 - 8.0.0.0) <41D4349D-3FFF-3971-B2B3-FD42C16FD6F0> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                       0x11648a000 -        0x1164bdff7 +com.adobe.dvamediatypes.framework (8.0.0 - 8.0.0.0) <96272E32-466F-3EAD-A09E-26572C69E884> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                       0x1164dd000 -        0x11654afff +com.adobe.dvatransport.framework (8.0.0 - 8.0.0.0) <F32B1B82-E19C-356C-9D21-7BC29286E841> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                       0x116597000 -        0x1165c5fff +com.adobe.dvamarshal.framework (8.0.0 - 8.0.0.0) <926EC24E-B2C5-320F-BFB2-9CF29995F018> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                       0x1165eb000 -        0x116604fff  libexpat.1.dylib (12.40.1) <405B65BE-42E4-36FA-AA41-5B717CB3F5E7> /usr/lib/libexpat.1.dylib
                       0x116758000 -        0x11685aff7  com.apple.AMDMTLBronzeDriver (1.42.6 - 1.4.2) <99D1FF9E-9C02-390D-904D-9812858E569E> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
                       0x117634000 -        0x11796afff +com.adobe.mediacoreif.framework (8.0.0 - 8.0.0.0) <8EA0BF31-97E5-3FBD-8078-D0C4BA7919A7> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/mediacoreif.framework/mediacoreif
                       0x117b59000 -        0x117b81ff7 +com.adobe.dvaunittesting.framework (8.0.0 - 8.0.0.0) <AC0BD9AF-0EF4-31B5-BC06-65C030F09814> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                       0x117ba7000 -        0x117c41fff +com.adobe.dvaaudiodevice.framework (8.0.0 - 8.0.0.0) <315A80A5-9DDA-3D8B-838B-F0D59CCD5F90> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                       0x117d51000 -        0x117d95ff7 +com.adobe.dvanet.framework (8.0.0 - 8.0.0.0) <246BF854-DC16-3546-8292-6182E9BA0812> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
                       0x117ea6000 -        0x117ebefff +com.adobe.ag.help (com.adobe.ag.help 6.6.1 - 1.0) <1ADA36E1-6F4A-3495-A4ED-689F3D3A3585> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/AdobeHelpClient.lrmodule/Contents/MacOS/AdobeHelpClient
                       0x117fc8000 -        0x117fcbff7 +com.adobe.ag.headlights (com.adobe.ag.Headlights 6.6.1 - 1.0) <B7A8D984-972A-333F-B23C-C74CA3CBE1DC> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/AdobeHeadlights.lrmodule/Contents/MacOS/AdobeHeadlights
                       0x117fd2000 -        0x11800cfff +com.adobe.pip (7.3.1.61) <5371E762-F32A-3330-BF9D-D090A074E2F3> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                       0x118016000 -        0x11803ffff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/LogSession.framework/Resources/libSLCacheWrapper.dylib
                       0x118051000 -        0x118054ff7 +com.adobe.ag.discburning (com.adobe.ag.discburning 6.6.1 - 1.0) <2F500353-3F18-3C1A-9F24-DAD9C1EE2E8A> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/DiscBurning.agtoolkit/Contents/MacOS/DiscBurning
                       0x11805b000 -        0x118080ff7  com.apple.DiscRecordingUI (9.0.1 - 9010.4.3) <BA343D04-0E6B-3461-B9F5-82B3525051B9> /System/Library/Frameworks/DiscRecordingUI.framework/Versions/A/DiscRecordingUI
                       0x1180a2000 -        0x1180a7ff7 +com.adobe.ag.email (com.adobe.ag.email 6.6.1 - 1.0) <33E71551-2731-32E3-AD8E-70EBBF574B4E> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/Email.lrmodule/Contents/MacOS/Email
                       0x1180b7000 -        0x1180d6fff +com.adobe.BIB (AdobeBIB 1.2.03.34488 - 1.2.03.34488) <644F8DE0-3E61-374D-B17D-44ED3BD10D60> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                       0x1180de000 -        0x118104ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <3318FE3E-8AB8-3821-A1FB-8A8D62C20303> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                       0x1187b5000 -        0x118877ff7 +com.adobe.dvaplayer.framework (8.0.0 - 8.0.0.0) <2059242D-0818-3F47-858D-966D79A5FA93> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
                       0x1189f5000 -        0x1189f5fe7 +cl_kernels (???) <A7686C20-11CE-4599-95C7-9FE6071D773D> cl_kernels
                       0x11c12b000 -        0x11c267fff +com.adobe.headlights.LogSessionFramework (7.3.1.61) <D633CDB7-C235-328A-98E5-11FE46B3D179> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/LogSession.framework/LogSession
                       0x11fae3000 -        0x11fd90fff +com.adobe.dvacore.framework (8.0.0 - 8.0.0.0) <9CD8A439-F9C2-38B1-81E7-2B66E683E604> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                       0x11fec4000 -        0x12012dfff +com.adobe.dynamiclink.framework (8.0.0 - 8.0.0.0) <2B6B6604-7E09-3C67-B281-FDEDB7978747> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                       0x1203f7000 -        0x12043eff7 +com.adobe.ag.cef-toolkit (com.adobe.ag.cef_toolkit 6.6.1 - 1.0) <1A2B4DDE-8674-337E-B394-7CFEC52FE941> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/cef_toolkit.agtoolkit/Contents/MacOS/cef_toolkit
                       0x12045a000 -        0x123fe7f1f +libcef.dylib (31523.6.11) <7E427337-65A2-3B49-AD70-9C9BE02F4C01> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/Chromium Embedded Framework.framework/Versions/A/libcef.dylib
                       0x124377000 -        0x1243aefff  com.apple.audio.midi.CoreMIDI (1.10 - 88) <51E79766-51D8-3A95-A7FD-18E7E11528F3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
                       0x1243d7000 -        0x124451ff7  com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                       0x124adc000 -        0x125008fff +com.adobe.ag.coretech-toolkit (com.adobe.ag.coretech_toolkit 6.6.1 - 1.0) <E944FF33-FF28-3427-AEC7-72516F7A55BD> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CoreTechToolkit.agtoolkit/Contents/MacOS/CoreTechToolki t
                       0x125224000 -        0x125568ff7 +com.adobe.AGM (AdobeAGM 4.30.51.34488 - 4.30.51.34488) <AAD59EC2-F2F0-37A3-BB93-FE9F3B8DF205> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                       0x1255d6000 -        0x1258fbfff +com.adobe.CoolType (AdobeCoolType 5.15.00.34488 - 5.15.00.34488) <83E40C9D-DD09-3FEF-B984-AB834D72C32A> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                       0x125943000 -        0x125a91ff7 +com.adobe.ACE (AdobeACE 2.20.02.34488 - 2.20.02.34488) <DCD064B8-A43A-3D41-B499-15E602F69CDA> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                       0x125aa5000 -        0x125bd3fff +com.winsoft.wrservices (WRServices 7.0.0 - 7.0.0) <0853A41B-A14A-37B7-B27F-457F87865EAD> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                       0x125c30000 -        0x125d2cfff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.34478 - 3.8.0.34478) <45773819-98F5-33BB-9DA3-50B9909E91C5> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                       0x126ea6000 -        0x126eb4ff7 +com.adobe.ag.AgNetClient (com.adobe.ag.AgNetClient 6.6.1 - 1.0.0d1) <DABF1E5F-1645-3344-A4D6-DA8E2B4D5F54> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgNetClient.agtoolkit/AgNetClient
                       0x126ecc000 -        0x126eceff7 +com.adobe.ag.vulcan (com.adobe.ag.vulcan 6.6.1 - 1.0) <A00AA479-5F6E-3857-B5CF-988E7BC390FA> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/Vulcan.agtoolkit/Contents/MacOS/Vulcan
                       0x126ed6000 -        0x126f0eff7 +VulcanMessage5.dylib (5.2.0.35 - 5.2.0.35 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <4B0B878A-02F8-3EB1-89D5-4071034EDD0D> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/VulcanMessaging.framework/Versions/A/VulcanMessage5.dyl ib
                       0x127d46000 -        0x127d46fff +com.adobe.ag.catalogconverters (com.adobe.ag.catalogconverters 6.6.1 - 1.0) <87D6AB28-CDE8-3030-A9EE-E32EFC5FC2DD> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CatalogConverters.agtoolkit/Contents/MacOS/CatalogConve rters
                       0x1283db000 -        0x1283f6fff  com.apple.security.csparser (3.0 - 57337.40.85) <ACA30E1D-B53E-3A56-9E5D-E5C419102CA9> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/cspa rser
                       0x13007f000 -        0x130080ff7 +cl_kernels (???) <9B85A292-D5BF-4752-A3BC-989EBFDBC6FE> cl_kernels
                    0x7fff6aae3000 -     0x7fff6ab1a0d7  dyld (360.21) <D9B236BC-4AC1-325F-B3EF-3F06DBDA7119> /usr/lib/dyld
                    0x7fff801b2000 -     0x7fff801b3ff7  libodfde.dylib (23) <F84CB160-D638-3190-B6F5-A262E9AF09F6> /usr/lib/libodfde.dylib
                    0x7fff801f9000 -     0x7fff80205ff7  com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                    0x7fff80206000 -     0x7fff80392ff7  libGLProgrammability.dylib (12.0.40.6) <F5AE40EB-A28B-3F3B-8E4C-0C0D73E47EDB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                    0x7fff803e9000 -     0x7fff803eeff7  com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
                    0x7fff803ef000 -     0x7fff803f8ff7  com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                    0x7fff803f9000 -     0x7fff803faff3  com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                    0x7fff803fb000 -     0x7fff80425ff7  GLRendererFloat (12.0.40.6) <4063015F-BC8F-308D-9065-685F89659F2C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
                    0x7fff80426000 -     0x7fff80428fff  libCVMSPluginSupport.dylib (12.0.40.6) <4AA6710A-6267-3062-BFF2-27DB5E6B5892> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                    0x7fff80429000 -     0x7fff80439fff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
                    0x7fff8043a000 -     0x7fff8043afff  libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
                    0x7fff80473000 -     0x7fff80484ff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
                    0x7fff80485000 -     0x7fff816d0feb  com.apple.CoreGraphics (1.600.0 - 957) <8C9F8E1A-274C-36CE-93FB-49906A9B9EE2> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                    0x7fff81715000 -     0x7fff81936ff7  com.apple.CoreImage (11.4.0 - 366.4.19) <6EE4A686-50C8-3D77-A036-BE8AA0F8A2FD> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                    0x7fff8198b000 -     0x7fff81994ff7  com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                    0x7fff81995000 -     0x7fff81be1ff7  com.apple.AddressBook.framework (9.0 - 1679.9) <8879002B-C87B-3595-9CD2-B672F10DD156> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
                    0x7fff81bed000 -     0x7fff81bfeff7  libsystem_trace.dylib (201.10.3) <25104542-5251-3E8D-B14A-9E37207218BC> /usr/lib/system/libsystem_trace.dylib
                    0x7fff81c4a000 -     0x7fff82046fff  libLAPACK.dylib (1162.2) <987E42B0-5108-3065-87F0-9DF7616A8A06> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                    0x7fff821b0000 -     0x7fff821c1fff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
                    0x7fff821f1000 -     0x7fff8223cff7  com.apple.CoreMediaIO (703.0 - 4791) <B974A225-61C6-34DD-AC2A-495BD6A393B3> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                    0x7fff8223d000 -     0x7fff8244afff  libicucore.A.dylib (551.51) <35315A29-E21C-3CC5-8BD6-E07A3AE8FC0D> /usr/lib/libicucore.A.dylib
                    0x7fff82dbb000 -     0x7fff82dd3fef  libcompression.dylib (28) <E7601B62-1053-369D-8A9E-91CF86239220> /usr/lib/libcompression.dylib
                    0x7fff82dd4000 -     0x7fff82f52fff  com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                    0x7fff82f53000 -     0x7fff82ff7fff  com.apple.Bluetooth (4.4.4 - 4.4.4f4) <BCF89EFE-853D-3AEA-AE31-DC8293C7284F> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                    0x7fff83111000 -     0x7fff83140ffb  libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
                    0x7fff83141000 -     0x7fff8315cfff  com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
                    0x7fff8315d000 -     0x7fff831ccfff  com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                    0x7fff831cd000 -     0x7fff831cfff7  libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
                    0x7fff83209000 -     0x7fff8323dff7  com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                    0x7fff8323e000 -     0x7fff8325cff7  libsystem_kernel.dylib (3248.40.184) <88C17B7F-1CD8-3979-A1A9-F7BDB4FCE789> /usr/lib/system/libsystem_kernel.dylib
                    0x7fff8325d000 -     0x7fff8329fff7  com.apple.Metal (56.6 - 56.6) <7DCBE573-B713-3C50-A16E-2F33A84C3CFB> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                    0x7fff832a0000 -     0x7fff832affe7  com.apple.AppleFSCompression (81.20.2 - 1.0) <2FE122A9-5265-320A-9600-FFC5CE4DE197> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                    0x7fff832b0000 -     0x7fff8333ffff  com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                    0x7fff83340000 -     0x7fff83340ff7  libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
                    0x7fff8356e000 -     0x7fff83692fff  libsqlite3.dylib (216.4) <280D67B8-F93D-3587-A146-19F36C817548> /usr/lib/libsqlite3.dylib
                    0x7fff83693000 -     0x7fff837efff3  com.apple.WebKitLegacy (11601 - 11601.5.17.1) <BEF2ACE7-5D6F-32A2-93BA-BF78D126465F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
                    0x7fff837f0000 -     0x7fff83845fff  com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                    0x7fff83846000 -     0x7fff83849fff  libspindump.dylib (197.1) <48F4C673-9F0C-38BE-B550-88241E812518> /usr/lib/libspindump.dylib
                    0x7fff8384a000 -     0x7fff83876fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <1318B6A5-FFC3-3615-914D-95CBFE5BA727> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdminis tration
                    0x7fff83877000 -     0x7fff83882ff7  libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
                    0x7fff83883000 -     0x7fff838baff7  com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                    0x7fff838bb000 -     0x7fff838f5ff7  com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                    0x7fff8396b000 -     0x7fff839e2ff7  com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                    0x7fff839fb000 -     0x7fff83a03fff  libGFXShared.dylib (12.0.40.6) <1CDE5AEF-3E44-3547-879E-BB490EE7702C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                    0x7fff83a6e000 -     0x7fff83b19fff  com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                    0x7fff83b1a000 -     0x7fff83b6cfff  com.apple.CloudDocs (1.0 - 383.12) <1388C0E5-9B2F-372B-A005-043EB049AAA3> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                    0x7fff83bd1000 -     0x7fff83ccdff7  libFontParser.dylib (158.5) <62796E99-36B7-36B6-8D33-5349F88014C3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                    0x7fff83cce000 -     0x7fff83cd6fff  libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
                    0x7fff83d29000 -     0x7fff83d29fff  libmetal_timestamp.dylib (600.0.44.1) <6576F284-BACA-332A-A6E7-FA1C347636E3> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
                    0x7fff83d2a000 -     0x7fff83e38ff3  com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                    0x7fff83e39000 -     0x7fff83e3ffff  com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                    0x7fff83e40000 -     0x7fff83e6ffff  com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                    0x7fff83e78000 -     0x7fff83e9cfff  libJPEG.dylib (1444) <AECB826C-8B14-3D04-8DEC-33EE85F5150D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                    0x7fff83ea3000 -     0x7fff83ec5fff  com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                    0x7fff83ec6000 -     0x7fff83ec7fff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                    0x7fff83ec8000 -     0x7fff83f3ffeb  libcorecrypto.dylib (335.40.8) <9D300121-CAF8-3894-8774-DF38FA65F238> /usr/lib/system/libcorecrypto.dylib
                    0x7fff83f40000 -     0x7fff84462fff  com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                    0x7fff8456b000 -     0x7fff84594ff7  libxslt.1.dylib (14.1) <27DE3F2E-CE96-3327-A563-788EE3E2775B> /usr/lib/libxslt.1.dylib
                    0x7fff84597000 -     0x7fff8488cfff  com.apple.HIToolbox (2.1.1 - 807.2) <871E5223-5D03-3649-98AF-9CCA3B41E307> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                    0x7fff8488d000 -     0x7fff8488fff7  com.apple.SafariServices.framework (11601 - 11601.5.17.1) <396E2233-E2DC-391C-84D2-991F636A941B> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
                    0x7fff84890000 -     0x7fff84904ff3  com.apple.securityfoundation (6.0 - 55126) <1F6BDF18-3CF0-3E85-8D9B-0663599B9949> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                    0x7fff84905000 -     0x7fff84d7bfff  com.apple.CoreFoundation (6.9 - 1258.1) <943A1383-DA6A-3DC0-ABCD-D9AEB3D0D34D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                    0x7fff84ec6000 -     0x7fff84fb1ff7  com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                    0x7fff84fdf000 -     0x7fff84fe4fff  com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                    0x7fff850a3000 -     0x7fff850bcfff  com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                    0x7fff850dc000 -     0x7fff850e3ff7  libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
                    0x7fff851b9000 -     0x7fff851d4ff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
                    0x7fff851d5000 -     0x7fff8520dff7  com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                    0x7fff85216000 -     0x7fff85220fff  com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                    0x7fff85255000 -     0x7fff85268fff  com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                    0x7fff852f9000 -     0x7fff852fbfff  com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                    0x7fff852fc000 -     0x7fff85305fff  com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
                    0x7fff85306000 -     0x7fff85347ff7  libGLU.dylib (12.0.40.6) <C56DDF90-CF6D-30D2-A3E6-89288BE69DCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                    0x7fff85348000 -     0x7fff85402fff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                    0x7fff85600000 -     0x7fff85954fff  com.apple.Foundation (6.9 - 1258) <51833143-6CAE-3E1C-9FBA-BCDEB48D4ADF> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                    0x7fff85b45000 -     0x7fff85b61ff7  libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
                    0x7fff85fd8000 -     0x7fff85fd9fff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
                    0x7fff85fda000 -     0x7fff85fe3ff3  libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
                    0x7fff85fe9000 -     0x7fff85ff4fff  com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                    0x7fff86f22000 -     0x7fff86f2dfff  libGPUSupportMercury.dylib (12.0.40.6) <CC8F3ED8-72FE-3041-A0F2-D8F17DBE2347> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                    0x7fff87511000 -     0x7fff87518ff7  com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
                    0x7fff87576000 -     0x7fff87585ffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                    0x7fff87599000 -     0x7fff875deff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                    0x7fff8761a000 -     0x7fff8762bfff  libSparseBLAS.dylib (1162.2) <EBEB3848-3468-342A-91A6-5C47F2369CD9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                    0x7fff8762c000 -     0x7fff8765fff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                    0x7fff87660000 -     0x7fff876c0fff  com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                    0x7fff877f0000 -     0x7fff87840ff7  com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                    0x7fff88118000 -     0x7fff88120fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                    0x7fff88854000 -     0x7fff88862fff  com.apple.IntlPreferences (2.0 - 192) <61F62126-0902-3324-BB1D-8B93297ED899> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
                    0x7fff88892000 -     0x7fff88892fff  com.apple.CoreServices (728.9 - 728.9) <78CB3EAC-A66E-3FD9-A1DF-A9CF227ED3C3> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                    0x7fff88893000 -     0x7fff888a8fff  com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                    0x7fff888af000 -     0x7fff888d8fff  libc++abi.dylib (125) <DCCC8177-3D09-35BC-9784-2A04FEC4C71B> /usr/lib/libc++abi.dylib
                    0x7fff888d9000 -     0x7fff888dcfff  libsystem_sandbox.dylib (460.40.33) <30671DCC-265F-325A-B33D-11CD336B3DA3> /usr/lib/system/libsystem_sandbox.dylib
                    0x7fff889e5000 -     0x7fff889e8fff  libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                    0x7fff889f0000 -     0x7fff889f2ff7  com.apple.securityhi (9.0 - 55006) <A4CEFD45-C51C-381C-A57B-FF75D90C680F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                    0x7fff88eee000 -     0x7fff88efcfff  com.apple.opengl (12.0.40 - 12.0.40) <AEA28993-BA3E-3E0F-A2F5-88C312ABB634> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                    0x7fff88efd000 -     0x7fff88f08fff  libkxld.dylib (3248.40.184) <6F776D34-D06C-3C48-B753-D0FB375A4A8A> /usr/lib/system/libkxld.dylib
                    0x7fff88f09000 -     0x7fff88f0bff7  libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
                    0x7fff88f0c000 -     0x7fff88f0efff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
                    0x7fff88f0f000 -     0x7fff88f13fff  libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
                    0x7fff88f14000 -     0x7fff88f7fff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                    0x7fff88f80000 -     0x7fff890c5fff  com.apple.QTKit (7.7.3 - 2943.3) <88AA19A7-7170-3798-8CBA-B1B8D4763ADB> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                    0x7fff8917c000 -     0x7fff893e9fff  com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                    0x7fff893ea000 -     0x7fff894d0fef  unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
                    0x7fff894d1000 -     0x7fff894d2ffb  libSystem.B.dylib (1226.10.1) <CD307E99-FC5C-3575-BCCE-0C861AA63124> /usr/lib/libSystem.B.dylib
                    0x7fff89516000 -     0x7fff8951efff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                    0x7fff8951f000 -     0x7fff89bbeff7  com.apple.JavaScriptCore (11601 - 11601.5.17) <E12A9CB4-C807-3602-8357-6037579F6A13> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                    0x7fff89bbf000 -     0x7fff89d6bfff  com.apple.avfoundation (2.0 - 1046.9.11) <DE524245-B7EF-3E9D-8AA1-3D99A3304EF4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                    0x7fff89d6c000 -     0x7fff89d95fff  com.apple.ProtectedCloudStorage (1.0 - 1) <4850F751-E61B-30C0-B89A-B313601D3DB5> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                    0x7fff89d99000 -     0x7fff89e7fff7  libcrypto.0.9.8.dylib (59.40.2) <2486D801-C756-3488-B519-1AA6807E8948> /usr/lib/libcrypto.0.9.8.dylib
                    0x7fff89e80000 -     0x7fff89f30fe7  libvMisc.dylib (563.5) <6D73C20D-D1C4-3BA5-809B-4B597C15AA86> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                    0x7fff89f31000 -     0x7fff89f44fff  com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersis tence
                    0x7fff89fa9000 -     0x7fff8a00fff7  libsystem_network.dylib (583.40.20) <269E5ADD-6922-31E2-8D55-7B777263AC0D> /usr/lib/system/libsystem_network.dylib
                    0x7fff8a013000 -     0x7fff8a29aff7  com.apple.CFNetwork (760.4.2 - 760.4.2) <24C4A390-3079-358A-8D51-75A3E818A6DF> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                    0x7fff8a29b000 -     0x7fff8a2a6ff7  libcommonCrypto.dylib (60075.40.2) <B9D08EB8-FB35-3F7B-8A1C-6FCE3F07B7E7> /usr/lib/system/libcommonCrypto.dylib
                    0x7fff8a2ad000 -     0x7fff8a2b5ffb  libsystem_dnssd.dylib (625.40.20) <86A05653-DCA0-3345-B29F-F320029AA05E> /usr/lib/system/libsystem_dnssd.dylib
                    0x7fff8a2b6000 -     0x7fff8a325fff  com.apple.datadetectorscore (7.0 - 460) <8EF4EECC-4FF1-36DF-84CF-65545555A225> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                    0x7fff8a326000 -     0x7fff8a33afe3  libCGInterfaces.dylib (317.9) <5079DE4F-3717-32FF-B76A-77F53236D17D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                    0x7fff8a36d000 -     0x7fff8a382fff  com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
                    0x7fff8a383000 -     0x7fff8a6e5f3f  libobjc.A.dylib (680) <7489D2D6-1EFD-3414-B18D-2AECCCC90286> /usr/lib/libobjc.A.dylib
                    0x7fff8a6e6000 -     0x7fff8a79fff7  com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                    0x7fff8a828000 -     0x7fff8a918fff  libJP2.dylib (1444) <27371567-A122-3217-ADA0-3A446EF6A3E9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                    0x7fff8a919000 -     0x7fff8a93dfff  com.apple.MultitouchSupport.framework (304.10.2 - 304.10.2) <CE75EDA3-2B22-3968-834E-550EA870ECC8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                    0x7fff8a93e000 -     0x7fff8aaa5fff  libBLAS.dylib (1162.2) <A1398FE0-39D2-33EA-9A0F-B2644EEA29A0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                    0x7fff8aaa6000 -     0x7fff8aac0ff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
                    0x7fff8aac1000 -     0x7fff8aac1fff  com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                    0x7fff8aac5000 -     0x7fff8aaecfff  com.apple.shortcut (2.16 - 93) <2BA6DF3E-04C7-39C8-B311-3413E9FC9022> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                    0x7fff8acfe000 -     0x7fff8ad94fff  com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                    0x7fff8ad95000 -     0x7fff8aedfff7  com.apple.coreui (2.1 - 366.1) <A3868F31-ACF4-3EA5-9E75-79ED44FA7F06> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                    0x7fff8aee0000 -     0x7fff8af4eff7  com.apple.ApplicationServices.ATS (377 - 394.3) <847DBFBA-8D6B-367B-99FD-C6CAA8C05C65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                    0x7fff8af7f000 -     0x7fff8afceff7  com.apple.opencl (2.7.0 - 2.7.0) <307263BA-0368-38C9-A7FB-25920343D0DF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                    0x7fff8afcf000 -     0x7fff8b000ff7  libtidy.A.dylib (15.17) <6859415D-7A43-384E-ABDD-AA6B2AA9FDCD> /usr/lib/libtidy.A.dylib
                    0x7fff8b02f000 -     0x7fff8b049fff  com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                    0x7fff8b2db000 -     0x7fff8b37bfff  com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                    0x7fff8b3ac000 -     0x7fff8b413fff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                    0x7fff8b414000 -     0x7fff8b419fff  com.apple.TCC (1.0 - 1) <50F7EC60-5B21-3B9B-BF2F-F037EA7B12FB> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                    0x7fff8b41a000 -     0x7fff8b4d2ff7  com.apple.CoreDuet (1.0 - 1) <058EAEDE-156F-309C-AB61-34C61B93D967> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
                    0x7fff8b4d3000 -     0x7fff8b568fff  com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                    0x7fff8b569000 -     0x7fff8b65bff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
                    0x7fff8b65c000 -     0x7fff8b802ff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <082319FC-59F2-3D36-AC9B-94759724E302> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                    0x7fff8b847000 -     0x7fff8b876ff7  com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                    0x7fff8b877000 -     0x7fff8b8dafff  libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
                    0x7fff8b8db000 -     0x7fff8b8dbfff  com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                    0x7fff8b903000 -     0x7fff8b934fff  com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                    0x7fff8b935000 -     0x7fff8b94cfff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
                    0x7fff8b960000 -     0x7fff8c589fff  com.apple.AppKit (6.9 - 1404.46) <2492D315-76B6-320B-B542-231FCA44CA48> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                    0x7fff8c58a000 -     0x7fff8c5d0ff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
                    0x7fff8c5d1000 -     0x7fff8c5d6ff7  libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
                    0x7fff8c5d7000 -     0x7fff8c5d7fff  com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                    0x7fff8cb64000 -     0x7fff8cb68fff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
                    0x7fff8cbbd000 -     0x7fff8cbe8ff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
                    0x7fff8cdd0000 -     0x7fff8cdd3ff3  libCGXCoreImage.A.dylib (957) <D561A978-8876-3C15-998A-5C6A4827B680> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A. dylib
                    0x7fff8cf3b000 -     0x7fff8cf3bfff  libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
                    0x7fff8cf3c000 -     0x7fff8d102fe7  com.apple.ImageIO.framework (3.3.0 - 1444) <54F18254-F31B-3464-BB51-BAF9E9620419> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                    0x7fff8d10c000 -     0x7fff8d10cfff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <054DFE32-737D-3211-9A14-0FC5E1A880E3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                    0x7fff8d10d000 -     0x7fff8d3f2ffb  com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                    0x7fff8d450000 -     0x7fff8d474fff  com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                    0x7fff8d476000 -     0x7fff8d4ffff7  com.apple.PerformanceAnalysis (1.0 - 1) <608E8C50-6F59-3FEB-B822-D9B02F328716> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                    0x7fff8dd60000 -     0x7fff8dd63ffb  libdyld.dylib (360.21) <8390E026-F7DE-3C32-9486-3DFF6BD131B0> /usr/lib/system/libdyld.dylib
                    0x7fff8ddb2000 -     0x7fff8ddbafff  libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
                    0x7fff8de59000 -     0x7fff8de75fff  com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                    0x7fff8de76000 -     0x7fff8de7afff  com.apple.LoginUICore (3.2 - 3.2) <5524E4BC-4700-39F4-AF06-E53322712EE0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore. framework/Versions/A/LoginUICore
                    0x7fff8de7b000 -     0x7fff8e121ff7  com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                    0x7fff8e122000 -     0x7fff8e126fff  libGIF.dylib (1444) <D3F44A33-355E-3154-A465-1C732AAC5F75> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                    0x7fff8e127000 -     0x7fff8e154fff  libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
                    0x7fff8e155000 -     0x7fff8e1a7fff  com.apple.AppleVAFramework (5.0.32 - 5.0.32) <FC1AED2C-B3E2-31D9-B163-37989CD8A073> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                    0x7fff8e1a8000 -     0x7fff8e1b0fff  com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                    0x7fff8e1c2000 -     0x7fff8e20effb  com.apple.HIServices (1.22 - 549) <E4E1BD10-F475-3E19-9E0B-A5071D158F47> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                    0x7fff8e22b000 -     0x7fff8e33afe7  libvDSP.dylib (563.5) <9AB6CA3C-4F0E-35E6-9184-9DF86E7C3DAD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                    0x7fff8e33b000 -     0x7fff8e344ff7  libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
                    0x7fff8e345000 -     0x7fff8e3f5fff  com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                    0x7fff8e3ff000 -     0x7fff8e444ff3  libFontRegistry.dylib (155.1) <F3355C6E-ED33-3506-B10E-2F6995D34BC1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                    0x7fff8e5a5000 -     0x7fff8e5e2ff3  com.apple.bom (14.0 - 193.7) <9B8AE30B-24A3-37AB-B04E-4CE67AED4775> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                    0x7fff8e602000 -     0x7fff8e80dfff  libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
                    0x7fff8e80e000 -     0x7fff8e82bff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <F4AF2363-B28E-3097-AB1E-FDA1C92F8F56> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
                    0x7fff8e82c000 -     0x7fff8e82efff  com.apple.xpc.ServiceManagement (1.0 - 1) <F3E14561-5DF4-3429-98ED-8F27A87A343A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                    0x7fff8e82f000 -     0x7fff8e854ff7  libPng.dylib (1444) <47ACF98D-B5F1-3A03-B6FD-4107D5FAE5E9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                    0x7fff8e855000 -     0x7fff8e8c9ff7  com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                    0x7fff8e8ca000 -     0x7fff8e8f8ff7  libsandbox.1.dylib (460.40.33) <26158471-870A-3269-9E2B-7D7963B8E9F3> /usr/lib/libsandbox.1.dylib
                    0x7fff8e9f0000 -     0x7fff8e9fbfff  com.apple.CrashReporterSupport (10.11 - 717) <474544AD-1199-3ECC-90E5-071847BA72C6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                    0x7fff8ea2d000 -     0x7fff8ea38fff  libcsfde.dylib (517.20.1) <6FFC376E-E141-37EE-800A-004080A50091> /usr/lib/libcsfde.dylib
                    0x7fff8eaa7000 -     0x7fff8eab2fff  com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                    0x7fff8eaf5000 -     0x7fff8eb0cff7  libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
                    0x7fff8eb0d000 -     0x7fff8eb10fff  com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                    0x7fff8eb27000 -     0x7fff8eb49ff7  com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                    0x7fff8eb69000 -     0x7fff8ebc5fff  com.apple.Suggestions (5.0 - 180) <450BCB58-786F-37DC-9AC7-2E3D13198032> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
                    0x7fff8ebc6000 -     0x7fff8ec18fff  com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                    0x7fff8ec45000 -     0x7fff8ec83ff7  libGLImage.dylib (12.0.40.6) <734B133F-E789-3A25-9DE6-1CCBA4896D4D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                    0x7fff8ec85000 -     0x7fff8ecd1fff  com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                    0x7fff8ecd7000 -     0x7fff8ece3fff  com.apple.CacheDelete (1.0 - 1) <82285D20-6E49-3463-9271-92239A6EDB81> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
                    0x7fff8ee07000 -     0x7fff8ee0cff3  libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
                    0x7fff8ee0d000 -     0x7fff8ee60ff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
                    0x7fff8ee69000 -     0x7fff8ef3fffb  com.apple.DiskImagesFramework (10.11.3 - 417.2) <7412BC0B-A895-350D-B829-1E3A6FF5EC3F> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                    0x7fff8ef9c000 -     0x7fff8efa2fff  com.apple.IOAccelerator (205.3 - 205.3) <851B6BF8-5B7F-3FB5-9E45-10AAE3BF7438> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                    0x7fff8efa3000 -     0x7fff8efa6fff  com.apple.IOSurface (108.2.1 - 108.2.1) <A0037B0A-277A-393E-9BF6-688595BD564D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                    0x7fff8efa7000 -     0x7fff8efc3ff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
                    0x7fff8f0fa000 -     0x7fff8f390fff  libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
                    0x7fff8f391000 -     0x7fff8f3baff7  libxpc.dylib (765.40.36) <2CC7CF36-66D4-301B-A6D8-EBAE7405B008> /usr/lib/system/libxpc.dylib
                    0x7fff8f3bb000 -     0x7fff8f430fff  com.apple.framework.IOKit (2.0.2 - 1179.40.20) <FB2AD43B-905D-3BD0-BE17-ACE7D4D13E24> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                    0x7fff8f431000 -     0x7fff8f434ff7  com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                    0x7fff8f435000 -     0x7fff8f4c2fff  libsystem_c.dylib (1082.20.4) <CDEBF2BB-A578-30F5-846F-96274951C3C5> /usr/lib/system/libsystem_c.dylib
                    0x7fff8f4c6000 -     0x7fff8f54efff  com.apple.CoreSymbolication (3.1 - 58048.1) <4730422E-4178-34F9-8550-BB92F2A4F44B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                    0x7fff8f54f000 -     0x7fff8f7e9fff  com.apple.security (7.0 - 57337.40.85) <7C5B8DEF-3D02-3410-9BD3-2B1251F84D4B> /System/Library/Frameworks/Security.framework/Versions/A/Security
                    0x7fff8f7ea000 -     0x7fff8f7ecffb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
                    0x7fff8f844000 -     0x7fff8f85bff7  libsystem_asl.dylib (323.40.3) <007F9094-317A-33EA-AF62-BAEAAB48C0F7> /usr/lib/system/libsystem_asl.dylib
                    0x7fff8f867000 -     0x7fff8f892ffb  libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
                    0x7fff8f8e1000 -     0x7fff8f8e3fff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
                    0x7fff8f8e4000 -     0x7fff8f8e7ff7  libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                    0x7fff8f8e8000 -     0x7fff8f8ebff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                    0x7fff8f8ec000 -     0x7fff8f8f4fef  libcldcpuengine.dylib (2.7.3) <B385841A-B573-3A91-9BEB-CC89CB2716B3> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                    0x7fff8f8f5000 -     0x7fff8f8f7fff  libCGXType.A.dylib (957) <B901C222-E779-32EB-96C2-5A707A09FC5B> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
                    0x7fff90342000 -     0x7fff9034afef  libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
                    0x7fff9034b000 -     0x7fff90356fff  libGL.dylib (12.0.40.6) <4FC6D3F9-6582-3E7D-A7D1-E035F0E26697> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                    0x7fff9035a000 -     0x7fff90373fff  com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                    0x7fff903ec000 -     0x7fff9075ffff  com.apple.FinderKit (1.4.4 - 1.4.4) <76E52C7F-CA82-337E-BF8E-9961F11C4B8D> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
                    0x7fff90760000 -     0x7fff90770ff3  com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                    0x7fff90917000 -     0x7fff90919fff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                    0x7fff90921000 -     0x7fff90c61fff  com.apple.WebKit (11601 - 11601.5.17.1) <6FA46AD7-3DF1-3654-A642-D9C5BE613ED7> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                    0x7fff90c62000 -     0x7fff90c81ff7  com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
                    0x7fff90c8f000 -     0x7fff90c91ff7  libRadiance.dylib (1444) <A5EFA292-AFD4-3FCE-8802-958AD60F75DA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                    0x7fff90c92000 -     0x7fff9100dffb  com.apple.VideoToolbox (1.0 - 1731.15.202) <B839BE14-9503-3B5E-A54A-C7FCEED34EA3> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                    0x7fff9103e000 -     0x7fff910cbdd7  com.apple.AppleJPEG (1.0 - 1) <558ACADA-C41F-3EEF-82A0-C2D7B13C5428> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                    0x7fff910cc000 -     0x7fff9111dff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <3D62A9B3-67A8-3F8A-A102-05E310249075> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                    0x7fff9111e000 -     0x7fff9111eff7  liblaunch.dylib (765.40.36) <1CD7619D-AF2E-34D1-8EC6-8021CF473D9B> /usr/lib/system/liblaunch.dylib
                    0x7fff9111f000 -     0x7fff9220dff7  com.apple.WebCore (11601 - 11601.5.17) <01B1DEA6-A07A-367B-84C0-E264EEFBBA1F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                    0x7fff929b0000 -     0x7fff929b0fff  com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                    0x7fff929b1000 -     0x7fff929b2fff  libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
                    0x7fff929b3000 -     0x7fff929bbfff  libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
                    0x7fff92a75000 -     0x7fff92b15fff  com.apple.Metadata (10.7.0 - 972.29.1) <F19E0200-6937-3799-9C67-D26C2CE5AA5F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                    0x7fff92b16000 -     0x7fff92b1efff  com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                    0x7fff92b32000 -     0x7fff92b6cfff  com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                    0x7fff92cc5000 -     0x7fff92ccafff  com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                    0x7fff92cf9000 -     0x7fff92d57fff  com.apple.SystemConfiguration (1.14 - 1.14) <10082F58-6190-3A7C-8B6C-C12B16DC793A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                    0x7fff92fec000 -     0x7fff93002ff7  libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                    0x7fff93003000 -     0x7fff93051ff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
                    0x7fff93052000 -     0x7fff9305efff  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                    0x7fff9306c000 -     0x7fff93199ff3  com.apple.CoreText (352.0 - 494.11) <08E8640E-6602-3A00-BC28-94235FD311B4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                    0x7fff935de000 -     0x7fff93607fff  libsystem_info.dylib (477.40.5) <6B01C09E-A3E5-3C71-B370-D0CABD11A436> /usr/lib/system/libsystem_info.dylib
                    0x7fff93620000 -     0x7fff936f9fff  com.apple.CoreMedia (1.0 - 1731.15.202) <D2A49E52-9D26-35A8-BDDC-3BCDBEC5A19E> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                    0x7fff93707000 -     0x7fff9370affb  libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
                    0x7fff9370b000 -     0x7fff93830ff7  com.apple.LaunchServices (728.8 - 728.8) <FDA38B17-82E2-322F-A008-B9207A6EA668> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                    0x7fff93831000 -     0x7fff93861ff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                    0x7fff93896000 -     0x7fff93897fff  libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
                    0x7fff93898000 -     0x7fff93987ffb  libxml2.2.dylib (29.5) <4096C2EA-6659-3F22-AC60-1E2F30BDD2B7> /usr/lib/libxml2.2.dylib
                    0x7fff93abc000 -     0x7fff93b19fff  com.apple.CoreServices.OSServices (728.8 - 728.8) <4CE49D8A-8304-3347-9379-6075CB906419> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                    0x7fff93b1a000 -     0x7fff93cc5ffb  GLEngine (12.0.40.6) <32029589-A64E-3E6B-A024-F985765766A2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
                    0x7fff93d3e000 -     0x7fff93d9afff  libTIFF.dylib (1444) <2A22E6B7-213B-3253-838F-C3EC3C8F2727> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                    0x7fff93d9b000 -     0x7fff93da1ff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                    0x7fff93da2000 -     0x7fff9423dff3  com.apple.GeoServices (1.0 - 1151.47.0.1) <928294E7-6897-3D5B-9D2E-BC092B6C25DE> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                    0x7fff94383000 -     0x7fff943d4ff7  libcups.2.dylib (435.1) <4198A94D-A46C-39AA-92B6-83D0BA507D6C> /usr/lib/libcups.2.dylib
                    0x7fff943d8000 -     0x7fff94930ff7  com.apple.MediaToolbox (1.0 - 1731.15.202) <A19F9D25-5333-3AA0-90FB-97F3F420A7EA> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                    0x7fff94931000 -     0x7fff94932ffb  libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
                    0x7fff94970000 -     0x7fff949befff  libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
                    0x7fff949cf000 -     0x7fff949f8ffb  libRIP.A.dylib (957) <5F18F20D-5921-3314-A9F8-F1B1CB62C83D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                    0x7fff94a54000 -     0x7fff94ce4ff7  com.apple.RawCamera.bundle (6.18.1 - 831) <A39B930C-387F-373D-865B-DED7F492B5CF> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                    0x7fff94d63000 -     0x7fff94df2ff7  libCoreStorage.dylib (517.20.1) <EC540EAA-089C-36D9-BBAA-0684EDE098AB> /usr/lib/libCoreStorage.dylib
                    0x7fff94df3000 -     0x7fff94df3fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <185EC96A-5AF0-3620-A4ED-4D3654D25B39> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                    0x7fff95071000 -     0x7fff950a0ffb  com.apple.datadetectors (5.0 - 308) <1949868C-BDCD-3772-BDBD-D7E9F2CC1451> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
                    0x7fff950a1000 -     0x7fff950a5fff  com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                    0x7fff950a6000 -     0x7fff950a7fff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
                    0x7fff950a8000 -     0x7fff950d6ff7  com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                    0x7fff950d7000 -     0x7fff950dcfff  com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                    0x7fff950dd000 -     0x7fff950ebff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
                    0x7fff950ec000 -     0x7fff950fafff  com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
                    0x7fff95124000 -     0x7fff954b9fdb  com.apple.vImage (8.0 - 8.0) <4BAC9B6F-7482-3580-8787-AB0A5B4D331B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                    0x7fff95553000 -     0x7fff95558ff7  libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
                    0x7fff957d5000 -     0x7fff957e1fff  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                    0x7fff95834000 -     0x7fff95850ff7  libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
                    0x7fff9592b000 -     0x7fff9592dfff  com.apple.CoreDuetDebugLogging (1.0 - 1) <7659CACF-3B08-3AF3-8FAC-24FAF18EF114> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
                    0x7fff9592e000 -     0x7fff95940fff  libsasl2.2.dylib (209) <2F81C8C9-11A3-3581-B2C1-D8C03AB7D39C> /usr/lib/libsasl2.2.dylib
                    0x7fff95965000 -     0x7fff95979fff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <D0A5B9A7-A247-37CD-A8F7-64DC635F9C9B> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
                    0x7fff95a29000 -     0x7fff95a46ff7  com.apple.pluginkit.framework (1.0 - 1) <0BA96479-0451-3DA9-A2AC-FE1D86D383AB> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
                    0x7fff95a47000 -     0x7fff95a55fff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
                    0x7fff95ad4000 -     0x7fff95b20ff7  com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                    0x7fff95b21000 -     0x7fff95f4ffff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                    0x7fff95f50000 -     0x7fff95ff7fff  com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                    0x7fff96099000 -     0x7fff960affff  com.apple.CoreMediaAuthoring (2.2 - 953) <06C2E0E2-BA5C-3BB1-8DD7-55613EDD654D> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                    0x7fff960b0000 -     0x7fff960b0fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <93C1D642-37D4-3692-AD35-DCAD04F9610B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                    0x7fff9612c000 -     0x7fff962faff3  com.apple.QuartzCore (1.11 - 410.14) <0283748A-8318-36AC-8B30-8A951FEB305A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                    0x7fff962fb000 -     0x7fff96307fff  com.apple.HelpData (2.1.4 - 90) <10608EEC-B613-309C-96E6-5A40AB951FA4> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                    0x7fff9630a000 -     0x7fff96329ff7  com.apple.framework.Apple80211 (11.0 - 1121.34) <AE7795B8-4590-3714-999D-3FBFF6BF5D93> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                    0x7fff9632a000 -     0x7fff9632aff7  libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
                    0x7fff96350000 -     0x7fff96430ff7  unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba .dylib
                    0x7fff96431000 -     0x7fff96458fff  com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                    0x7fff9645f000 -     0x7fff96468fff  com.apple.IOAccelMemoryInfo (1.0 - 1) <AFDEDCD0-9F6F-30F8-B4D7-F1143180CB10> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInf o
                    0x7fff96469000 -     0x7fff96841fef  com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                External Binary Images:
                0xffffffff00000000 - 0xffffffffffffffff + (???) <00000000-0000-0000-0000-000000000000>
                External Modification Summary:
                  Calls made by other processes targeting this process:
                    task_for_pid: 3
                    thread_create: 0
                    thread_set_state: 0
                  Calls made by this process:
                    task_for_pid: 0
                    thread_create: 0
                    thread_set_state: 0
                  Calls made by all processes on this machine:
                    task_for_pid: 4705
                    thread_create: 0
                    thread_set_state: 0
                VM Region Summary:
                ReadOnly portion of Libraries: Total=455.8M resident=0K(0%) swapped_out_or_unallocated=455.8M(100%)
                Writable regions: Total=3.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=3.7G(100%)
                                                VIRTUAL   REGION
                REGION TYPE                        SIZE    COUNT (non-coalesced)
                Accelerate.framework               256K        3
                Activity Tracing                  2048K        2
                CG backing stores                 85.1M       15
                CG image                          6152K       93
                CG shared images                   720K       20
                CoreAnimation                     9960K       60
                CoreUI image data                 6444K       35
                CoreUI image file                  192K        4
                Dispatch continuations            8192K        2
                Foundation                          20K        3
                Image IO                          30.2M      126
                Kernel Alloc Once                    8K        3
                MALLOC                             3.5G      999
                MALLOC guard page                   32K        7
                Memory Tag 242                      12K        2
                Memory Tag 251                      12K        2
                OpenCL                              24K        4
                OpenGL GLSL                        256K        4
                Process Corpse Info               2048K        2
                STACK GUARD                       56.1M       37
                Stack                             25.3M       38
                VM_ALLOCATE                       1256K       14
                __DATA                            36.7M      367
                __GLSLBUILTINS                    2588K        2
                __IMAGE                            528K        2
                __LINKEDIT                       104.1M       67
                __TEXT                           351.7M      351
                __UNICODE                          552K        2
                mapped file                       93.5M      115
                shared memory                     16.3M       11
                TOTAL                              4.4G     2362
                Model: iMac17,1, BootROM IM171.0105.B07, 4 processors, Intel Core i5, 3.3 GHz, 64 GB, SMC 2.34f2
                Graphics: AMD Radeon R9 M395, AMD Radeon R9 M395, PCIe, 2048 MB
                Memory Module: BANK 0/DIMM0, 16 GB, DDR3, 1867 MHz, 0x00, -
                Memory Module: BANK 0/DIMM1, 16 GB, DDR3, 1867 MHz, 0x00, -
                Memory Module: BANK 1/DIMM0, 16 GB, DDR3, 1867 MHz, 0x00, -
                Memory Module: BANK 1/DIMM1, 16 GB, DDR3, 1867 MHz, 0x00, -
                AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x14A), Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
                Bluetooth: Version 4.4.4f4 17685, 3 services, 27 devices, 1 incoming serial ports
                Network Service: Wi-Fi, AirPort, en1
                PCI Card: pci1b21,625, AHCI Controller, Thunderbolt@193,0,0
                Serial ATA Device: APPLE HDD ST2000DM001, 2 TB
                Serial ATA Device: APPLE SSD SM0128G, 121.33 GB
                Serial ATA Device: G-RAID  with Thunderbolt, 8 TB
                USB Device: USB 3.0 Bus
                USB Device: Bluetooth USB Host Controller
                USB Device: FaceTime HD Camera (Built-in)
                Thunderbolt Bus: iMac, Apple Inc., 28.1
                Thunderbolt Device: G-RAID with Thunderbolt, G-Technology, 1, 25.1
                • 5. Re: Crashing on Export
                  jalleystudios Level 1
                  I have hard time thinking it's hardware on two computers.  It's now pretty much repeating same thing from my LR catalog.  I try and simply export 50 JPEGS and it crashes through black to white text to restart.  It happens in old catalog, and just for testing I created a new catalog and it crashes with that catalog too.
                  COmputer doesn't crash when not in LR.
                  New crash:
                  Didn’t crash to restart.  Just to desktop.
                  Process:               Adobe Lightroom [269]
                  Path:                  /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                  Identifier:            com.adobe.Lightroom6
                  Version:               Adobe Lightroom [1083169] (6.6.1)
                  Code Type:             X86-64 (Native)
                  Parent Process:        ??? [1]
                  Responsible:           Adobe Lightroom [269]
                  User ID:               501
                  Date/Time:             2016-08-11 07:11:02.893 -0700
                  OS Version:            Mac OS X 10.11.4 (15E65)
                  Report Version:        11
                  Anonymous UUID:        49A5FC3A-B706-C00D-6EA4-45DF559E0645
                  Time Awake Since Boot: 230 seconds
                  System Integrity Protection: enabled
                  Crashed Thread:        37  GetWarpedSourcePipe_A (thread index 2)
                  Exception Type:        EXC_BAD_ACCESS (SIGBUS)
                  Exception Codes:       KERN_PROTECTION_FAILURE at 0x000070000073a4e0
                  Exception Note:        EXC_CORPSE_NOTIFY
                  What's going on Adobe!!  I can't live like this!
                  • 6. Re: Crashing on Export
                    dj_paige Level 10
                    I'm wondering if there's a problem with one of the photos somehow (although I can't imagine what). Try splitting the export in half, export in two 25 photo batches; if one of them crashes, continue splitting that group in half until you identify the photo.
                    • 7. Re: Crashing on Export
                      dj_paige After isolating the issue to this computer with this RAM, and reading some other forums for similar issue, seemed like the only logical problem was the RAM from OWC.  I used app called Rember to test all of them together and individually and after hours and hours and days seems like 2 sticks of 16gb from OWC were bad.  Along with 2 replacements they sent.  After getting successful tests with two pieces of RAM, I kept those in, and sending others back.
                      Downside is that it kept crashing and wasting days of my time.  UPside is it's not in the software and I can export until the cows come home now...
                      • 8. Re: Crashing on Export
                        justing53277757
                        I have been having a similar problem with my iMac (late 2015 Retina 5k, 3.2ghz intel core 5, 32gb from OWC) when exporting photos. I usually export a couple hundred to a thousand photos at a time and it would constantly crash (it would also crash when creating previews, but not as often). I would get to about 100 to 300 photos before Lightroom would quit or my computer would crash and restart (mouse with be unresponsive and it would just restart, sometimes lightroom would just quit). So I decided to test out each individual strip of ram (8gb each) and export photos. Each strip worked fine, it was able to export a thousand photos without crashing (I was also working on photos in Lightroom at the same time as well).  So I just tried putting all the ram back, thinking maybe I didn't insert one of them properly, it's still crashing.
                        I just ran the Rember app after reading this thread and it says I have failure. I'm not sure what this means but if anyone can figure out what's wrong and help me out, that would be great.
                        Here is the log from Rember
                        Memtest version 4.22 (64-bit)
                        Copyright (C) 2004 Charles Cazabon
                        Copyright (C) 2004-2008 Tony Scaminaci (Macintosh port)
                        Licensed under the GNU General Public License version 2 only
                        Mac OS X 10.11.6 (15G1421) running in multiuser mode
                        Memory Page Size: 4096
                        System has 4 Intel core(s) with SSE
                        Requested memory: 14201MB (14891548672 bytes)
                        Available memory: 14201MB (14891548672 bytes)
                        Allocated memory: 14201MB (14891548672 bytes) at local address 0x0000000101000000
                        Attempting memory lock... locked successfully
                        Partitioning memory into 2 comparison buffers...
                        Buffer A: 7100MB (7445774336 bytes) starts at local address 0x0000000101000000
                        Buffer B: 7100MB (7445774336 bytes) starts at local address 0x00000002bccd8000
                        Running 1 test sequence... (CTRL-C to quit)
                        Test sequence 1 of 1:
                        Running tests on full 14201MB region...
                          Stuck Address       :                                 setting  1 of 16                                                ok
                          Linear PRN          :       setting  1 of 16                                                ok
                        Running comparison tests using 7100MB buffers...
                          Random Value        :       \   ok
                          Compare XOR         :             ok
                          Compare SUB         :             ok
                          Compare MUL         :             ok
                          Compare DIV         :             ok
                          Compare OR          :             ok
                          Compare AND         :             ok
                          Sequential Increment:             ok
                          Solid Bits          :                                 setting  1 of 64                                                ok
                          Block Sequential    :                                     setting   1 of 256                                                          ok
                          Checkerboard        :                                 setting  1 of 64                                                ok
                          Bit Spread          :                                     setting   1 of 128                                                      ok
                          Bit Flip            :                                     setting   1 of 512
                        FAILURE! Data mismatch at local BUFA address 0x000000012982c340, BUFB address 0x00000002e5504340
                        BUFA Data: 0x0000000000000800, BUFB Data: 0x0000000000200800
                          Walking Ones        :                                     setting   1 of 128
                        • 9. Re: Crashing on Export
                          dj_paige Level 10
                          Just a thought ... if you've got 4 memory strips in the computer, and most of the motherboards I have ever seen have them quite close together, could it be heat build-up causing the crash when the 4 memory strips are in place? With only a single memory strips there's more air flow and the heat doesn't build up as much and so there's no crash? This is pure speculation, but who knows?
                          • 10. Re: Crashing on Export
                            justing53277757 Level 1
                            I just ran another test with Rember (I ran it wrong the last time) and it said everything was fine.  This thing is really boggling my mind, the only thing that I can think of now it's either an issue with my computer or it's a problem with OWC ram working together...I'll run a test again tomorrow with just 3 strips and see how that goes. I'll give an update on my situation when I try out different things, right now I just need to get some work done
