2 Replies Latest reply on Aug 11, 2016 5:26 AM by johnpredmore
    Apply Export Tag to Paragraph Style
    johnpredmore
      I'm learning basic scripting and today I need to apply an export tag to a paragraph style for PDF export (see screenshot) across dozens of documents. I thought this would be the perfect opportunity to use a script to automatize this time intensive process.
      Does anybody have any tips on how to do that?Screen Shot 2016-08-10 at 1.22.55 PM.png
        • 1. Re: Apply Export Tag to Paragraph Style
          Look in to InDesign's DOM (Document Object Model), and specifically at Paragraph Style properties: ParagraphStyle
          In there you can find a property "styleExportTagMaps" – a plural, probably because you can add multiple tags to a single style (?). Browsing to that, you get StyleExportTagMap , which, in turn, has a simple string property called "exportTag".
          So if style points to a valid Paragraph Style, you can do this to add either a tagName or a className to it (only one of these; you must set the other to an empty string):
          style.styleExportTagMaps.add({exportType:"PDF", exportAttributes:'', exportTag:tagName, exportClass:className});
          I've only used this with an exportType of "EPUB", but if I'm remembering correctly "PDF" is 'the' other option.
          I haven't used those exportAttributes before. If you want to find out what it can contain, set a number of options in the user interface for a random style and then read out the styleExportTagMap of that style to see what values it holds.
          • 2. Re: Apply Export Tag to Paragraph Style
            johnpredmore Level 1
            Thanks Jongware,
            You pointed me in the right direction; here's what I came up with:
                        // Body Text
                        var body = myDoc.paragraphStyles.itemByName("Body Text");
                            body.styleExportTagMaps.add({exportType: "EPUB", exportTag: "p", exportClass: "", exportAttributes: ""});
                            body.styleExportTagMaps.add({exportType: "PDF", exportTag: "P", exportClass: "", exportAttributes: ""});
                        // H1
                        var h1 = myDoc.paragraphStyles.itemByName("H1");
                            h1.styleExportTagMaps.add({exportType: "EPUB", exportTag: "h1", exportClass: "", exportAttributes: ""});
                            h1.styleExportTagMaps.add({exportType: "PDF", exportTag: "H1", exportClass: "", exportAttributes: ""});
                        // H2
                        var h2 = myDoc.paragraphStyles.itemByName("H2");
                            h2.styleExportTagMaps.add({exportType: "EPUB", exportTag: "h2", exportClass: "", exportAttributes: ""});
                            h2.styleExportTagMaps.add({exportType: "PDF", exportTag: "H2", exportClass: "", exportAttributes: ""});
                        // H3
                        var h3 = myDoc.paragraphStyles.itemByName("H3");
                            h3.styleExportTagMaps.add({exportType: "EPUB", exportTag: "h3", exportClass: "", exportAttributes: ""});
                            h3.styleExportTagMaps.add({exportType: "PDF", exportTag: "H3", exportClass: "", exportAttributes: ""});
                        // Tables - Body Text
                        var tablesBody = myDoc.paragraphStyles.itemByName("Tables - Body Text");
                            tablesBody.styleExportTagMaps.add({exportType: "EPUB", exportTag: "p", exportClass: "", exportAttributes: ""});
                            tablesBody.styleExportTagMaps.add({exportType: "PDF", exportTag: "P", exportClass: "", exportAttributes: ""});
                        // Student Version
                            // Student MS - Body Text
                            var StudentBody = myDoc.paragraphStyleGroups.item("Student Version").paragraphStyles.item("Student MS - Body Text");
                                StudentBody.styleExportTagMaps.add({exportType: "EPUB", exportTag: "p", exportClass: "", exportAttributes: ""});
                                StudentBody.styleExportTagMaps.add({exportType: "PDF", exportTag: "P", exportClass: "", exportAttributes: ""});
                            // Student Cover - H1
                            var StudentCoverH1 = myDoc.paragraphStyleGroups.item("Student Version").paragraphStyles.item("Student Cover - H1");
                                StudentCoverH1.styleExportTagMaps.add({exportType: "EPUB", exportTag: "h1", exportClass: "", exportAttributes: ""});
                                StudentCoverH1.styleExportTagMaps.add({exportType: "PDF", exportTag: "H1", exportClass: "", exportAttributes: ""});
                            // Student Cover - H2
                            var StudentCoverH2 = myDoc.paragraphStyleGroups.item("Student Version").paragraphStyles.item("Student Cover - H2");
                                StudentCoverH2.styleExportTagMaps.add({exportType: "EPUB", exportTag: "h2", exportClass: "", exportAttributes: ""});
                                StudentCoverH2.styleExportTagMaps.add({exportType: "PDF", exportTag: "H2", exportClass: "", exportAttributes: ""});
