0 Replies Latest reply on Jun 4, 2006 1:30 PM by Jak14713
    Problem with the menu bar component
    Jak14713
      I have created an application that has a menu bar on it.
      It uses this code to be created:
      stop();
      import mx.controls.Menu;
      import mx.controls.MenuBar;
      var my_mb:MenuBar;
      var my_menu:Menu = my_mb.addMenu("Menu");
      my_menu.addMenuItem({label:"File", instanceName:"File"});
      my_menu.addMenuItem({label:"Open", instanceName:"Open"});
      my_menu.addMenuItem({label:"Settings", instanceName:"Settings"});
      //Create listener object.
      var mbListener bject = new Object();
      mbListener.change = function(evt_obj bject) {
      var menuItem_obj bject = evt_obj.menuItem;
      switch (menuItem_obj.attributes.instanceName) {
      case "About":
      trace("Open menu item");
      break;
      case "Services":
      break;
      case "Settings":
      trace("Close menu item");
      break;
      trace(menuItem_obj);
      //Add listener.
      my_menu.addEventListener("change", mbListener);
      Does anybody know how to put actions to the sub menu buttons?
      Example - Click here
      Jak -Cheers if you can help!
