1 Reply Latest reply on Aug 10, 2016 3:55 PM by Captiv8r
    Is it possible to edit the ToC style directly?
    dlamkin
      Hi there,
      I was curious if it's possible to edit the ToC style directly and have the changes persist after republishing?
      I see TocWriteClassStyle in whthost.js and if I edit it, the changes are visible in the ToC. However if I then generate the project again, whthost.js is recreated blowing away any edits.
      I am curious if there is a way to edit the source for whthost.js so that when a new whthost is rendered, it is rendered with the edits? Alternately, if this is not possible, is it possible to have the ToC include an additional custom style sheet?
      Ultimately what I'm trying to do is have more icons available within the ToC than just the 3 currently available. Book, Open Book, Page so that we can use custom icons that are associated with the topics, as well as flag icons for translated help files. I have all the control I could want within the topics, but the skin itself seems to be a bit too locked down.
      Thank you for taking the time to read, and for any possible leads you may have for me.
      Cheers,
      Duane
        • 1. Re: Is it possible to edit the ToC style directly?
          Hi there
          There is a group of what I call "seed" files that are installed. I'm unsure of the exact file you need, but you might investigate the files inside this folder location. For me, the easiest way to get there is to right-click the shortcut that you use to start RoboHelp. From there you should be able to either click a button or copy the install folder location for easy reference.
          So you could modify the seed file in this location and it might provide what you need.
          I'd certainly make sure to save a backup for our friend Justin.
          Cheers... Rick
