1 Reply Latest reply on Aug 11, 2016 3:57 PM by RoninEdits
    With Mercury Playback engine on, timeline is slow
    smm4774
      Machine Specs below....with the Mercury Playback engine enabled, I get picture on my client monitor through an AJA IO Xpress BUT my timeline is very sticky.  There's a significant lag when hitting play or stop....probably a couple of seconds.  It's very annoying!  If I turn the mercury playback engine OFF, the timeline lag disappears but of course I have no client monitor.
      Has anyone found a fix or is this a problem that people are living with?  It drives me crazy so I've started working without a client monitor.
      2009 Mac Pro 8 Core
      64gb RAM
      SSD OS Drive
      SSD Project Drive
      GTX680 Graphics Card
      AJA IO Xpress
      Hardware controlled RAID 5 for media
        • 1. Re: With Mercury Playback engine on, timeline is slow
          RoninEdits Most Valuable Participant
          for other readers, here are your other threads
          Timeline Lag
          Best Hardware IO Card for 4k
          i think there are some older posts with other folks having playback problems with aja devices, so looking into other devices like in your other thread may be a valid way to fix it. depending on what you need from an i/o device, some of the pcie add-in-cards from blackmagic are much cheaper than the ultrastudio 4k extreme/dnxio, even if just to test out.
          if you disable or remove the aja software/hardware it should help determine if its a aja + premiere mercury playback problem or if its only a premiere mercury playback problem. something else you might try is to install the nvidia web driver and try cuda vs opencl mercury playback acceleration.
          some other forums such as creativecow, blackmagic or avid may have more help on the aja/premiere problem and/or info about the bm/avid dnxio.
