2 Replies Latest reply on Aug 12, 2016 9:56 PM by bazilg73245766
    footnotes... footnotes...
    bazilg73245766
      How to make a footnotes at two-column compose text on two column format
        • 1. Re: footnotes... footnotes...
          TᴀW Adobe Community Professional & MVP
          You can't make 2-column footnotes right now in InDesign. That feature is coming in the next update, apparently (as mentioned by an Adobe employee on the main InDesign forum a while ago).
          Right now, all footnotes appear under the column in which the reference to them appears. So if the text frame has 3 columns, the footnotes will too (though each of differing depth). And if the main text is in a single column only, there is no way to have the footnotes in multiple columns.
          Our Footwork product, which allows this, works by separating the footnotes into a separate, regular InDesign story, and then synchronizing the layout of both the main text and footnote text on the page.
          Ariel
          • 2. Re: footnotes... footnotes...
            bazilg73245766 Level 1
            it turns
            necessary
