1 Reply Latest reply on Aug 12, 2016 8:15 AM by Roei Tzoref
    Basic key frame start, stop and loop animations
    johnh36533375
      Hi, I am new to After Effects so apologies in advance if my questions are very basic or obvious to expert users.
      In a composition I have created animations using keyframes and some background animations using the loopOut cycle expression.
      1. How do I get the keyframes animations to play once, stop and remain visible and the loop animations to keep animating in the background?
      2. With the loop animations how do I control the length of time before it animates back into its loop cycle again? For example if I want the loop cycle to start every 15 seconds rather than immediately after it has finished (i.e. 2-3 seconds).
        • 1. Re: Basic key frame start, stop and loop animations
          Roei Tzoref Adobe Community Professional
          I am not sure what do you mean. it seems there are 2 questions here.
          you can use the loopIn() instead of loopOut(). then put your keyframes at the end. this way the loop will finish at the keyframes.
          I don't understand. try explaining this in another way
          you have loopOutDuration expression
          loopOutDuration(type = "cycle", duration = 0). you can set the duration and at that time the loop will repeat it self. for example
          loopOutDuration(type = "cycle", duration = 15) means that at the 15 seconds of your timeline, the layer will repeat the keyframes again.
