2 Replies Latest reply on Apr 28, 2006 11:22 AM by wiseguy21
    Need help with tables for this code
    Shane930
      Hi, I am having all kinds of trouble controlling this code when it comes to placing it in a table. I have tried CSS and it doesn't help either. I have tried nested tables but it seems to have a mind of its own when I try to place it on a page. I hope someone can help me understand why this code is so hard to format on a page.
      Here is the code: I want it to be in three uniform boxes like below.
      Vehicle Search
      Select Make "dropdown list 1"
      Select Model "dropdown list 2"
      Submit Search "Button"
      <p align="center"><strong>Vehicle Search</strong></p>
      <!--- store the selected make variable after the first select boxes submits itself --->
      <cfif isDefined('form.select_make')>
      <cfset page.select_make = form.select_make>
      </cfif>
      <cfoutput>
      <form name="DropDown" method="post">
      <!--- query DB for the first drop down list --->
      <cfquery name="get_make" datasource="saa">
      SELECT * FROM saa.vehicle_make
      </cfquery>
      <!--- first drop down list --->
      <!--- NOTICE the onChange javascript event in the select tag, this is what submits the form after the first selection --->
      <th><div align="right">Vehicle Make:</div></th>
      <select name="select_make" required="yes" onchange="this.form.submit()">
      <option>Select Make</option>
      <!--- dynamically populate the first drop down list based on the get_make query --->
      <cfloop query="get_make">
      <option value="#make#" <cfif isDefined('form.select_make')><cfif form.select_make eq "#make#">selected</cfif></cfif>>#make#</option>
      </cfloop>
      </select>
      <!--- if the first selection has been made, display the second drop down list with the appropriate results --->
      <!--- query DB for second drop down list, based on the selected item from the first list --->
      <cfquery name="get_model" datasource="saa">
      SELECT * FROM saa.vehicle_make WHERE make = '#FORM.select_make#'
      </cfquery>
      <!--- second drop down list --->
      <th>Vehicle Model:</th>
      </cfif>
      </cfoutput>
      </form>
      <form action="file:///F|/wwwroot/SpringsAutoAds1/masterDetail.cfm" method="POST">
      <cfoutput>
      <select name="model" required="no">
      <option>Select Model</option>
      <!--- dynamically populate the second drop down list based on the get_make query --->
      <cfloop query="get_model">
      <option value="#model_1#">#model_1#</option>
      <option value="#model_2#">#model_2#</option>
      <option value="#model_3#">#model_3#</option>
      <option value="#model_4#">#model_4#</option>
      <option value="#model_5#">#model_5#</option>
      <option value="#model_6#">#model_6#</option>
      <option value="#model_7#">#model_7#</option>
      <option value="#model_8#">#model_8#</option>
      <option value="#model_9#">#model_9#</option>
      <option value="#model_10#">#model_10#</option>
      </cfloop>
      </select>
      <td><div align="right">Submit Vehicle Search: </div></td>
      <td><input type="submit" name="Submit" value="Submit"></td>
      </form>
      </cfoutput>
      Thanks for your input in advance
      Shane
