16 Replies Latest reply on Sep 7, 2016 11:06 AM by Carl Von Stetten
    Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
    trenab83858724
      I have five (5) applications that are using Coldfusion 10.  Each application is using the same Default Pool because I don't know how to separate the Default Pools. How do I get the service to stop going down?
        • 1. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
          haxtbh Level 4
          Have a look at the coldfusion-out.log/coldfusion-error.log file in the cfusion/logs folder. This should give you more of a clue as to what the services is doing before its shuts down
          • 2. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
            trenab83858724 Level 1
            Okay. This is from the coldfusion-out.log but, I don't know what it means.
            Aug 1, 2016 08:00:00 AM Information [DefaultQuartzScheduler_Worker-10] - Task DEFAULT.CFUPDATER - AUTO UPDATES triggered.
            Aug 1, 2016 08:00:00 AM Information [DefaultQuartzScheduler_Worker-10] - Starting HTTP request {URL='http://localhost:80/CFIDE/administrator/cfupdater/Update.cfc?method=autoInternalUpdate&Req uestTimeout=40', method='get'}
            Aug 1, 2016 08:00:00 AM Information [DefaultQuartzScheduler_Worker-10] - HTTP request completed  {Status Code=404 ,Time taken=15 ms}
            Aug 1, 2016 08:21:35 AM Information [scheduler-0] - Run Client Storage Purge
            Aug 1, 2016 08:49:17 AM Information [pool-2-thread-2] - Stopping Event Gateways.
            Aug 1, 2016 08:49:22 AM Information [pool-2-thread-2] - ColdFusion stopped
            • 3. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
              haxtbh Level 4
              What about the coldfusion-error.log.
              Is that all of the coldfusion-out log?
              What update level do you have on these CF10 servers?
              • 4. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
                That is not all that is in the log.  I just chose a portion where the shutdown took place.
                Here is the error log for Aug. 1st:
                Aug 01, 2016 8:50:20 AM org.apache.catalina.core.AprLifecycleListener init
                INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\\ColdFusion10\\cfusion\lib;C:\\ColdFusion10\\cfusion\jintegra\bin;C:\\ColdFusion10\\cf usion\jintegra\bin\international;C:\\ColdFusion10\\cfusion\lib\oosdk\classes\win
                Aug 01, 2016 8:50:23 AM org.apache.coyote.AbstractProtocol init
                INFO: Initializing ProtocolHandler ["ajp-bio-8012"]
                Aug 01, 2016 8:50:23 AM org.apache.catalina.core.StandardService startInternal
                INFO: Starting service Catalina
                Aug 01, 2016 8:50:23 AM org.apache.catalina.core.StandardEngine startInternal
                INFO: Starting Servlet Engine: Apache Tomcat/7.0.23
                Aug 01, 2016 8:50:25 AM org.apache.catalina.util.SessionIdGenerator createSecureRandom
                INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [1,047] milliseconds.
                Aug 01, 2016 8:48:28 AM org.apache.catalina.core.ApplicationContext log
                INFO: ColdFusionStartUpServlet: ColdFusion: Starting application services
                INFO: ColdFusionStartUpServlet: ColdFusion: VM version = 23.7-b01
                Aug 01, 2016 8:48:35 AM org.apache.catalina.core.ApplicationContext log
                INFO: CFMxmlServlet: Macromedia Flex Build: 87315.134646
                Aug 01, 2016 8:48:43 AM org.apache.coyote.AbstractProtocol start
                INFO: Starting ProtocolHandler ["ajp-bio-8012"]
                Aug 01, 2016 8:48:43 AM com.adobe.coldfusion.launcher.Launcher run
                INFO: Server startup in 33587 ms
                Aug 01, 2016 8:58:46 AM org.apache.catalina.core.AprLifecycleListener init
                Aug 01, 2016 8:58:48 AM org.apache.coyote.AbstractProtocol init
                Aug 01, 2016 8:58:49 AM org.apache.catalina.core.StandardService startInternal
                Aug 01, 2016 8:58:49 AM org.apache.catalina.core.StandardEngine startInternal
                Aug 01, 2016 8:58:50 AM org.apache.catalina.util.SessionIdGenerator createSecureRandom
                INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [859] milliseconds.
                Aug 01, 2016 8:59:05 AM org.apache.catalina.core.ApplicationContext log
                Aug 01, 2016 8:59:12 AM org.apache.catalina.core.ApplicationContext log
                Aug 01, 2016 8:59:20 AM org.apache.coyote.AbstractProtocol start
                Aug 01, 2016 8:59:20 AM com.adobe.coldfusion.launcher.Launcher run
                INFO: Server startup in 36785 ms
                Aug 01, 2016 9:12:19 AM org.apache.catalina.core.AprLifecycleListener init
                Aug 01, 2016 9:12:21 AM org.apache.coyote.AbstractProtocol init
                Aug 01, 2016 9:12:22 AM org.apache.catalina.core.StandardService startInternal
                Aug 01, 2016 9:12:22 AM org.apache.catalina.core.StandardEngine startInternal
                Aug 01, 2016 9:12:23 AM org.apache.catalina.util.SessionIdGenerator createSecureRandom
                INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [719] milliseconds.
                Aug 01, 2016 9:12:37 AM org.apache.catalina.core.ApplicationContext log
                Aug 01, 2016 9:12:45 AM org.apache.catalina.core.ApplicationContext log
                Aug 01, 2016 9:12:52 AM org.apache.coyote.AbstractProtocol start
                Aug 01, 2016 9:12:54 AM com.adobe.coldfusion.launcher.Launcher run
                INFO: Server startup in 37405 ms
                Aug 01, 2016 9:31:46 AM org.apache.catalina.core.AprLifecycleListener init
                Aug 01, 2016 9:31:49 AM org.apache.coyote.AbstractProtocol init
                Aug 01, 2016 9:31:49 AM org.apache.catalina.core.StandardService startInternal
                Aug 01, 2016 9:31:49 AM org.apache.catalina.core.StandardEngine startInternal
                Aug 01, 2016 9:31:51 AM org.apache.catalina.util.SessionIdGenerator createSecureRandom
                Aug 01, 2016 9:32:03 AM org.apache.catalina.core.ApplicationContext log
                Aug 01, 2016 9:32:10 AM org.apache.catalina.core.ApplicationContext log
                Aug 01, 2016 9:32:17 AM org.apache.coyote.AbstractProtocol start
                Aug 01, 2016 9:32:17 AM com.adobe.coldfusion.launcher.Launcher run
                INFO: Server startup in 35100 ms
                I cannot make heads or tails of the error log.
                I don't know what the update level is?  Where do I find that?
                • 5. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
                  haxtbh Level 4
                  If you log into the coldfusion admin and click the Settings Summary from the menu.
                  Copy and paste the full version number.
                  What you posted is just the logs for coldfusion starting up. It looks like you are still just showing portions. Really need the whole log.
                  Did you find the coldfusion-error.log?
                  • 6. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
                    carl type3 Level 4
                    Not to be forgotten with CF10 update level is if you have performed the manual step WSCONFIG to increment the tomcat webserver connector to match CF10 update?
                    Perhaps some tomcat tuning is required?
                    Here are some notes on tomcat tuning from a talk I did a few years back. Many folks have commented that connection_pool_timeout and connectionTimeout setting have helped their performance.
                    Note "properties" changes require webserver (IIS perhaps) restart. Server.xml changes require CF10 restart.
                    Tomcat – Pool
                    ● connection_pool_size
                    The number of connections made to the AJP backend that are maintained as a
                    connection pool. Tomcat strongly recommend adjusting this value for IIS to the
                    number of requests one web server process should be able to send to a backend in
                    parallel. You should measure how many connections you need during peak activity
                    without performance problems, and then add some percentage depending on your
                    growth rate. For IIS the default value is 250.
                    ● connection_pool_minsize
                    Minimum size of the connection pool that will be maintained. Its default value is
                    (connection_pool_size+1)/2.
                    ● connection_pool_timeout
                    Each thread could open an ajp13 connection if it has to forward a request to Tomcat,
                    creating a new ajp13 thread on Tomcat side. Keep this time interval in sync with the
                    connectionTimeout attribute of your AJP connector in Tomcat's server.xml. Note the
                    value for connector is given in seconds, the one in server.xml use milliseconds.
                    Default value 0
                    refer http://tomcat.apache.org/connectors-doc/reference/workers.html
                    Tomcat – workers.properties
                    ● ColdFusion10\config\wsconfig\N\
                    worker.list=cfusion
                    worker.cfusion.type=ajp13
                    worker.cfusion.host=localhost
                    worker.cfusion.port=8012
                    worker.cfusion.max_reuse_connections=250
                    worker.cfusion.connection_pool_size = n00
                    worker.cfusion.connection_pool_minsize=size+1 / 2
                    worker.cfusion.connection_pool_timeout = n0
                    Tomcat - Threads
                    ● maxThreads
                    The maximum number of request processing threads to be created by
                    this Connector, which therefore determines the maximum number of
                    simultaneous requests that can be handled. If not specified, this
                    attribute is set to 200.
                    ● minSpareThreads
                    The number of request processing threads that will be created when
                    this Connector is first started. The connector will also make sure it
                    has the specified number of idle processing threads available. This
                    attribute should be set to a value smaller than that set for
                    maxThreads. The default value is 10.
                    ● ConnectionTimeout
                    The number of milliseconds this Connector will wait, after accepting a
                    connection, for the request URI line to be presented. The default
                    value for AJP protocol connectors is -1 (i.e. infinite)
                    refer http://tomcat.apache.org/tomcat-7.0-doc/config/ajp.html
                    tomcat server.xml AJP13
                    ● \ColdFusion10\cfusion\runtime\conf
                    <!-- Define an AJP 1.3 Connector on port 8009
                    <Connector port="8012" protocol="AJP/1.3"
                    redirectPort="8445"
                    tomcatAuthentication="false"
                    maxThreads="n00"
                    minSpareThreads="max+1 / 2"
                    connectionTimeout="n0000" />
                    Where n = number.
                    HTH, Carl.
                    • 7. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
                      Hi Carl,
                      I made the changes you suggested and now one of the users is having an issue with downloading their Excel reports.  Could this be the cause of the problem?
                      Thanks.
                      • 8. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
                        carl type3 Level 4
                        Did the 5002 or 5009 events cease?
                        I think the user excel download problem is a whole other matter. Suggest respond to this thread if original problem is solved or not. Create a new thread about the excel issue with some diagnostic about what the excel issue is and how it relates to the backend CF.
                        Regards, Carl.
                        • 9. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
                          I thought it was probably another issue but, I'm still having an issue with the 5002 and 5009.  It's not happening as often but, it's still a problem.
                          • 10. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
                            carl type3 Level 4
                            Please note there were some Microsoft July security updates to desktops win 7,8 and 10 that effected excel downloads. If the resultant excel sheet is a light grey colour (color) then it could be related to the way excel download happens and recent MS update.
                            Back to 5002 5009.
                            - What update level did you find CF10 is at?
                            - Was WSCONFIG run to match tomcat IIS connector with CF tomcat level that some updates increment?
                            - What values did you use for "n" in workers.properties and server.xml tomcat configuration files?
                            Not discussed yet but could relate. What Java version is CF10 using? Have you done any CF Java and JVM changes?
                            Regards, Carl.
                            • 11. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
                              BKBK Adobe Community Professional & MVP
                              I think those are Event IDs for errors resulting from IIS Application Pool Availability. Microsoft gives you suggestions on how to debug or solve Event 5002 and Event 5009.
                              • 12. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
                                I am still having this issue.  I agree that it has something to do with the IIS Application Pool Availability.  I have 5 (five) applications sharing the same Default Pool.  These are Cold Fusion 10 applications but, I don't know how to separate the Default Pools to allow each application to have it's own default pool.  Does anyone have any suggestions?
                                • 13. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
                                  carl type3 Level 4
                                  This official CF blog entry and the comments within might be helpful:
                                  ColdFusion 11 IIS Connector Tuning » Adobe ColdFusion Blog
                                  Regards, Carl/
                                  • 14. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
                                    Carl Von Stetten Adobe Community Professional & MVP
                                    Are your 5 applications running as separate "sites" in IIS, or through one main "site"?
                                    • 16. Re: Coldfusion Service keeps stopping with these two errors Event 5002 or 5009
                                      Each site can be configured to use a different IIS App Pool.  There are some helpful suggestions on how to do this in the ColdFusion Lockdown Guide.  Basically, click on the Application Pools heading in the left pane of IIS Manager.  Create a pool for each site.  You should be able to set the .NET CLR version to "No Managed Code", unless you do .NET stuff too.
                                      Then go to each site, click on Basic Settings... in the right pane of IIS Manager.  Click the Select... button on the dialog to choose an application pool.  Then click OK buttons to finish.  You might need to restart each site after switching the app pool.
                                      HTH,
                                      -Carl V.
