5 Replies Latest reply on Aug 17, 2016 3:15 AM by Mylenium
    shape layer ghost line
    msongz Level 1
      two shape with uncolsed path and using merge method in one layer
      there is a hiding closed line in the shape
      and I just want the intersect part
      is it a bug ?
        • 1. Re: shape layer ghost line
          I have no idea what you are talking about, but it seems you do not understand how shape layers work. These operations do not modify the input paths, they modify the rendered results. You actual paths will always be visible. There is nothing wrong.
          Mylenium
          • 2. Re: shape layer ghost line
            Roei Tzoref Adobe Community Professional
            Its not clear to me whats the problem or what are you trying to accomplish. Please show step by step of your process and show also the screenshots of the timeline too.
            • 3. Re: shape layer ghost line
              msongz Level 1
              sorry about that , what I want looks like this: ◇ ◇  but it works like two 5-vecter-points shape
              • 4. Re: shape layer ghost line
                I tried to get this to work exactly how you want it with merge paths and I see this specific scenario is not possible. I am not sure exactly why you need it to work in this specific setup. why not just make 2 diamonds as two separate paths? but if there is a reason, remember you can combine shapes and masks in the same layer (both vector) and force a shape to behave
                • 5. Re: shape layer ghost line
                  You will need to reveal the properties of your layer then. As Roei illustrated, this works just as intendend when set up properly, so you are doing something with your shape layer that you are not telling us. Perhaps your grouping is awry, perhaps you have transformed it in some way. Impossible to tell.
                  Mylenium
