1 Reply Latest reply on Aug 16, 2016 9:58 PM by philippanmei
    Export pdf fields to excel
    darwin.brewer
      Is it possible to take a scanned document such as a tax return and export the data in each field to specific cells in excel ?
        • 1. Re: Export pdf fields to excel
          philippanmei Level 4
          It will be very hard to get as a originally but you can do a bit by running OCR and Export PDF to Excel
          In Adobe Acrobat 9 Pro
          == Go to Document Menu > OCR Text Recognise > Recognize text using OCR
          In Adobe Acrobat DC Pro
          1. Click on "Tools tab" and select "Enhance Scans", In the Enhance Scans properties bar choose "Recognise Text" from the drop down menu choose "In This File"
          After the REcognize text is complete
          2. In the Enhance Scans properties bar choose Reconize Text from the drop down menu select "Correct Recognize Text"
          After complete the workdone in PDF file, now Export to Excel
          It will help you a bit
