1 Reply Latest reply on Aug 16, 2016 11:38 PM by Nanaky
    How to read an ACSM file?!
    julia ovando
      I need help! I bought a book (document ending is .acsm) and I'm not able to add it to the library, it says it can't download. "Error getting License. License Server Communication Problem: E_ACT_NOT_READY"
      So, I was told by Kobo, to deauthorize Adobe Digitial Editions from my macpro, following the steps below:
      1) Launch Adobe Digital Editions
      2) To Deauthorize the Computer hit Command+Shift+D
      Which I have done but it tells me "Unable to erase authorization. Please try after some time." What should be doing? HELP!
        • 1. Re: How to read an ACSM file?!
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
