7 Replies Latest reply on Aug 18, 2016 6:41 AM by o-marat
    Save for Web Action that retains specific image size
    NinjaPuss Level 1
      I need to create an action that saves for web at a 850 x 655px.
      When testing my action for the first time,  it shows in the save as dialog box, that the image has been reduced to that size in percentage. So it works ok.
      However when testing the action on an image of different original ratio, it still reduces the percentage that was originally recorded, rather than just saving the image at 850 x 655, which gives me a different image size.
      Does anyone know how I can retain the 850x655 image size each time?
        • 1. Re: Save for Web Action that retains specific image size
          o-marat Level 3
          Maybe is possible to try write a script like this:
          1. calculate the required image scale based on its size
          2. run action, substituting calculated values
          • 2. Re: Save for Web Action that retains specific image size
            Silly-V Adobe Community Professional
            Are all your images proportional to your final size? It's possible to make your export that size, but if your h/w ratio is different than your final size, you will have some kind of extra whitespace.
            • 3. Re: Save for Web Action that retains specific image size
              o-marat Level 3
              NinjaPuss, is this what you need?
               * ai.jsx (c)MaratShagiev m_js@bk.ru 17.08.2016.
              (function act_saveForWeb () {
                var d     = activeDocument;
                var dW    = d.width;
                var dH    = d.height;
                var wTmpl = 850;
                var hTmpl = 655;
                var wScale = ( wTmpl / dW ) * 100 + '';
                var hScale = ( hTmpl / dH) * 100 + '';
                  var actStr = '' +
                    '/version 3' +
                    '/name [ 10' +
                    ' 73617665466f72576562' +
                    '/isOpen 1' +
                    '/actionCount 1' +
                    '/action-1 {' +
                    ' /name [ 10' +
                    ' /keyIndex 0' +
                    ' /colorIndex 0' +
                    ' /isOpen 1' +
                    ' /eventCount 1' +
                    ' /event-1 {' +
                    ' /useRulersIn1stQuadrant 0' +
                    ' /internalName (adobe_SaveForWeb)' +
                    ' /localizedName [ 12' +
                    ' 5361766520666f7220576562' +
                    ' /isOpen 0' +
                    ' /isOn 1' +
                    ' /hasDialog 1' +
                    ' /showDialog 1' +
                    ' /parameterCount 16' +
                    ' /parameter-1 {' +
                    ' /key 1181578272' +
                    ' /showInPalette -1' +
                    ' /type (enumerated)' +
                    ' /name [ 4' +
                    ' 4a504547' +
                    ' /value 1246774599' +
                    ' /parameter-2 {' +
                    ' /key 1231975538' +
                    ' /type (boolean)' +
                    ' /value 0' +
                    ' /parameter-3 {' +
                    ' /key 1366062201' +
                    ' /type (integer)' +
                    ' /value 60' +
                    ' /parameter-4 {' +
                    ' /key 1332769901' +
                    ' /value 1' +
                    ' /parameter-5 {' +
                    ' /key 1348563827' +
                    ' /value 1' +
                    ' /parameter-6 {' +
                    ' /key 1651275122' +
                    ' /type (real)' +
                    ' /value 0.0' +
                    ' /parameter-7 {' +
                    ' /key 1299477536' +
                    ' /value 1' +
                    ' /parameter-8 {' +
                    ' /key 1299477586' +
                    ' /value 255' +
                    ' /parameter-9 {' +
                    ' /key 1299477575' +
                    ' /value 255' +
                    ' /parameter-10 {' +
                    ' /key 1299477570' +
                    ' /value 255' +
                    ' /parameter-11 {' +
                    ' /key 1213424492' +
                    ' /type (unit real)' +
                    ' /value ' + wScale +
                    ' /unit 592474723' +
                    ' /parameter-12 {' +
                    ' /key 1448305516' +
                    ' /value ' + hScale +
                    ' /parameter-13 {' +
                    ' /key 1097757761' +
                    ' /type (ustring)' +
                    ' /value [ 13' +
                    ' 417274204f7074696d697a6564' +
                    ' /parameter-14 {' +
                    ' /key 1131180097' +
                    ' /value 1' +
                    ' /parameter-15 {' +
                    ' /key 1399608180' +
                    ' /showInPalette 0' +
                    ' /type (raw)' +
                    ' /value < 1574' +
                    ' 0000000300000001000000000000000700000001000000000001000000000000' +
                    ' 000001010000003c000000010000006400000000000000000000000000000002' +
                    ' 00000000ffffffff0000000004ffffffff00000000ffffffff00000000ffffff' +
                    ' ff00000000ffffffff0000000000000000ff000000ff000000ff000000ff0000' +
                    ' 00ff000000ff000000ff000000ff000000ff000000ff000000ff000000ff0000' +
                    ' 00ff000000ff000000ff000000ff000000000000000000000000000001a80000' +
                    ' 00100000000100000000000e54617267657453657474696e67730000000a0000' +
                    ' 00004d7474434f626a630000000100000000000a4e6174697665517561640000' +
                    ' 000300000000426c20206c6f6e67000000ff0000000047726e206c6f6e670000' +
                    ' 00ff00000000526420206c6f6e67000000ff000000004f70746d626f6f6c0100' +
                    ' 000000516c74796c6f6e670000003c0000000b6164644d65746164617461626f' +
                    ' 6f6c010000000a626c7572416d6f756e74646f75620000000000000000000000' +
                    ' 0f656d62656449434350726f66696c65626f6f6c000000000a66696c65466f72' +
                    ' 6d6174656e756d0000000a46696c65466f726d6174000000004a504547000000' +
                    ' 0c6e6f4d61747465436f6c6f72626f6f6c000000000b70726f67726573736976' +
                    ' 65626f6f6c000000000c7a6f6e65645175616c6974794f626a63000000010000' +
                    ' 000000095a6f6e6564496e666f00000004000000096368616e6e656c49446c6f' +
                    ' 6e67ffffffff0000000d656d70686173697a6554657874626f6f6c0000000010' +
                    ' 656d70686173697a65566563746f7273626f6f6c0000000005666c6f6f726c6f' +
                    ' 6e6700000000' +
                    ' /size 1574' +
                    ' /parameter-16 {' +
                    ' /key 1231953952' +
                    ' /value [ 28' +
                    ' 433a5c55736572735c6d2e736861676965765c4465736b746f705c40' +
                var f = new File ('~/ScriptAction.aia');
                f.open ('w');
                f.write (actStr);
                f.close ();
                app.loadAction (f);
                f.remove ();
                app.doScript ("saveForWeb", "saveForWeb", false); // action name, set name
                app.unloadAction ("saveForWeb", ""); // set name
              • 4. Re: Save for Web Action that retains specific image size
                NinjaPuss Level 1
                Thanks for your reply. The images I'm starting with are the same in ratio (I have ensured this when cropping)  just bigger in size.
                • 5. Re: Save for Web Action that retains specific image size
                  NinjaPuss Level 1
                  Thanks, will give this a go....
                  • 6. Re: Save for Web Action that retains specific image size
                    NinjaPuss Level 1
                    That did the trick, Thank you so much
                    • 7. Re: Save for Web Action that retains specific image size
                      o-marat Level 3
                      You are welcome. I am glad to help
