Build error
javierv860545 Aug 17, 2016 4:09 AMHello everybody,
I am getting an error when building the app, is extrange because yesterday it worked correctly and I was able to build correctly, now the log shows this error:
Fetching plugin "cordova-plugin-whitelist" via npm
Installing "cordova-plugin-whitelist" at "1.2.2" for android
This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
COMPILE OUTPUT
ERROR: Invalid filename / directory found in package -
Ultima
Versiвn
At first I thought that could be because of I was using the default version of PhoneGap, which was just updated from cli-5.2.0 to cli-6.3.0.
So I changed the line:
<preference name="phonegap-version" value="cli-6.3.0" /> to this:
<preference name="phonegap-version" value="cli-5.2.0" />
But the error in the log is the same...
Any idea why is this happening or how to solve it?
Thank you very much for your help
For more information I attach my config.xml:
<?xml version="1.0" encoding="UTF-8"?>
<!-- config.xml reference: https://build.phonegap.com/docs/config-xml -->
<widget xmlns = "http://www.w3.org/ns/widgets"
xmlns:gap = "http://phonegap.com/ns/1.0"
xmlns:android = "http://schemas.android.com/apk/res/android"
id = "com.test.TestApp"
version = "1.0.0">
<name>Test App</name>
<description>
App de Test
</description>
<author href="http://www.test.com/" email="info@test.com">
Test
</author>
<!-- Customize your app and platform with the preference element. -->
<preference name="phonegap-version" value="cli-5.2.0" /> <!-- all: current version of PhoneGap -->
<preference name="orientation" value="default" /> <!-- all: default means both landscape and portrait are enabled -->
<preference name="target-device" value="universal" /> <!-- all: possible values handset, tablet, or universal -->
<preference name="fullscreen" value="true" /> <!-- all: hides the status bar at the top of the screen -->
<preference name="webviewbounce" value="true" /> <!-- ios: control whether the screen 'bounces' when scrolled beyond the top -->
<preference name="prerendered-icon" value="true" /> <!-- ios: if icon is prerendered, iOS will not apply it's gloss to the app's icon on the user's home screen -->
<preference name="stay-in-webview" value="false" /> <!-- ios: external links should open in the default browser, 'true' would use the webview the app lives in -->
<preference name="ios-statusbarstyle" value="black-opaque" /> <!-- ios: black-translucent will appear black because the PhoneGap webview doesn't go beneath the status bar -->
<preference name="detect-data-types" value="true" /> <!-- ios: controls whether data types (such as phone no. and dates) are automatically turned into links by the system -->
<preference name="exit-on-suspend" value="false" /> <!-- ios: if set to true, app will terminate when home button is pressed -->
<preference name="show-splash-screen-spinner" value="true" /> <!-- ios: if set to false, the spinner won't appear on the splash screen during app loading -->
<preference name="auto-hide-splash-screen" value="true" /> <!-- ios: if set to false, the splash screen must be hidden using a JavaScript API -->
<preference name="disable-cursor" value="false" /> <!-- blackberry: prevents a mouse-icon/cursor from being displayed on the app -->
<preference name="android-minSdkVersion" value="14" /> <!-- android: MIN SDK version supported on the target device. MAX version is blank by default. -->
<preference name="android-installLocation" value="auto" /> <!-- android: app install location. 'auto' will choose. 'internalOnly' is device memory. 'preferExternal' is SDCard. -->
<!-- Eliminar el OverScroll-->
<preference name="DisallowOverscroll" value="true" />
<!-- Preferencias de control de splahscreen-->
<preference name="AutoHideSplashScreen" value="false" />
<preference name="SplashScreenDelay" value="2000" />
<preference name="FadeSplashScreenDuration" value="750"/>
<!-- Preferencias de control para que espere al menos un minuto si la url no carga-->
<preference name="loadUrlTimeoutValue" value="60000" />
<!-- Necesario para instalar Pushwoosh-->
<preference name="android-build-tool" value="gradle" />
<!-- Plugins -->
<!-- Core plugins -->
<gap:plugin name="org.apache.cordova.battery-status" />
<gap:plugin name="org.apache.cordova.camera" />
<gap:plugin name="org.apache.cordova.media-capture" />
<gap:plugin name="org.apache.cordova.console" />
<gap:plugin name="org.apache.cordova.contacts" />
<gap:plugin name="org.apache.cordova.device" />
<gap:plugin name="org.apache.cordova.device-motion" />
<gap:plugin name="org.apache.cordova.device-orientation" />
<gap:plugin name="org.apache.cordova.dialogs" />
<gap:plugin name="org.apache.cordova.file" />
<gap:plugin name="org.apache.cordova.file-transfer" />
<gap:plugin name="org.apache.cordova.geolocation" />
<gap:plugin name="org.apache.cordova.globalization" />
<gap:plugin name="org.apache.cordova.inappbrowser" />
<gap:plugin name="org.apache.cordova.media" />
<gap:plugin name="org.apache.cordova.network-information" />
<gap:plugin name="org.apache.cordova.splashscreen" />
<gap:plugin name="org.apache.cordova.vibration" />
<!--Eliminar Status Bar -->
<plugin name="de.appplant.cordova.plugin.hidden-statusbar-overlay" spec="1.2.0" source="pgb" />
<!-- Chromium webview -->
<plugin name="org.crosswalk.engine" spec="1.3.0" source="pgb" />
<!-- Pushwoosh plugin -->
<gap:plugin name="pushwoosh-pgb-plugin" source="npm" />
<!-- Define app icon for each platform. -->
<icon src="icon.png" />
<icon src="res/icon/android/icon-36-ldpi.png" gap:platform="android" gap:density="ldpi" />
<icon src="res/icon/android/icon-48-mdpi.png" gap:platform="android" gap:density="mdpi" />
<icon src="res/icon/android/icon-72-hdpi.png" gap:platform="android" gap:density="hdpi" />
<icon src="res/icon/android/icon-96-xhdpi.png" gap:platform="android" gap:density="xhdpi" />
<icon src="res/icon/blackberry/icon-80.png" gap:platform="blackberry" />
<icon src="res/icon/blackberry/icon-80.png" gap:platform="blackberry" gap:state="hover"/>
<icon src="res/icon/ios/icon-57.png" gap:platform="ios" width="57" height="57" />
<icon src="res/icon/ios/icon-72.png" gap:platform="ios" width="72" height="72" />
<icon src="res/icon/ios/icon-57-2x.png" gap:platform="ios" width="114" height="114" />
<icon src="res/icon/ios/icon-72-2x.png" gap:platform="ios" width="144" height="144" />
<icon src="res/icon/webos/icon-64.png" gap:platform="webos" />
<icon src="res/icon/windows-phone/icon-48.png" gap:platform="winphone" />
<icon src="res/icon/windows-phone/icon-173.png" gap:platform="winphone" gap:role="background" />
<!-- Define app splash screen for each platform. -->
<gap:splash src="res/screen/android/screen-ldpi-portrait.png" gap:platform="android" gap:density="ldpi" />
<gap:splash src="res/screen/android/screen-mdpi-portrait.png" gap:platform="android" gap:density="mdpi" />
<gap:splash src="res/screen/android/screen-hdpi-portrait.png" gap:platform="android" gap:density="hdpi" />
<gap:splash src="res/screen/android/screen-xhdpi-portrait.png" gap:platform="android" gap:density="xhdpi" />
<gap:splash src="res/screen/blackberry/screen-225.png" gap:platform="blackberry" />
<gap:splash src="res/screen/ios/screen-iphone-portrait.png" gap:platform="ios" width="320" height="480" />
<gap:splash src="res/screen/ios/screen-iphone-portrait-2x.png" gap:platform="ios" width="640" height="960" />
<gap:splash src="res/screen/ios/screen-ipad-portrait.png" gap:platform="ios" width="768" height="1024" />
<gap:splash src="res/screen/ios/screen-ipad-landscape.png" gap:platform="ios" width="1024" height="768" />
<gap:splash src="res/screen/windows-phone/screen-portrait.jpg" gap:platform="winphone" />
Define access to external domains.
<access /> - a blank access tag denies access to all external resources.
<access origin="*" /> - a wildcard access tag allows access to all external resource.
Otherwise, you can specify specific domains:
<access origin="*"/> <!-- allow all pages -->
<access origin="*.pushwoosh.com"/> <!-- allow pushwoosh service -->
<!-- Added the following intents to support the removal of whitelist code from base cordova to a plugin -->
<!-- Whitelist configuration. Refer to https://cordova.apache.org/docs/en/edge/guide_appdev_whitelist_index.md.html -->
<plugin name="cordova-plugin-whitelist" version="1" />
<allow-intent href="http://*/*" />
<allow-intent href="https://*/*" />
<allow-intent href="tel:*" />
<allow-intent href="sms:*" />
<allow-intent href="mailto:*" />
<allow-intent href="geo:*" />
<platform name="android">
<allow-intent href="market:*" />
</platform>
<platform name="ios">
<allow-intent href="itms:*" />
<allow-intent href="itms-apps:*" />
</platform>
<!-- Para eliminar el title bar antes del splashscreen -->
<!-- Y esta otra linea al principio: xmlns:android = "http://schemas.android.com/apk/res/android" -->
<gap:config-file platform="android" parent="/manifest">
<supports-screens
android:xlargeScreens="true"
android:largeScreens="true"
android:smallScreens="true" />
<application android:theme="@android:style/Theme.NoTitleBar" >
<activity android:theme="@android:style/Theme.NoTitleBar.Fullscreen" >
</activity>
</application>
</gap:config-file>
</widget>
