2 Replies Latest reply on Aug 19, 2016 4:30 AM by Heimdaal
    File browsing on OSX using openDlg() - Why are all folders greyed out?
    Heimdaal Level 1
      I'm trying to setup a file and folder browsing dialog that works for both Win/OSX and with filters for restricting the dialog  search to specific file types. I got a lot of help from another user on the forum (Matias Kiviniemi) in order to get the filter function working - but now I have another problem: a rather strange one.
      You can still navigate (somewhat) via the Favorites -list and directory tree button at the top center, but actually clicking in the folders doesn't work at all.
      I've also tried saveDlg() for browsing files but I get exactly the same problem with greyed out folders. Also, saveDlg() doesn't have the second parameter (the filter function) for restricting the dialog to a specific file type - which is something that I need.
      // Utility functions for checking if the OS is Win/OSX
      function isWindows(){
          return app.systemInformation.indexOf("Operating System: Windows") >= 0
      function isMac(){
          return app.systemInformation.indexOf("Operating System: Mac") >= 0
      // All params below are strings
      function promptFile(dialogMessage, dialogType, extFilter, oldPath){
      // Description: Opens up a file or older dialog window for browsing (Win/OSX)
      // Returns: Absolute path (string) to the file or folder that was picked by the user
          // File
          if (dialogType == "file"){
              // Create filter function for the File.saveDlg -function
              var filter = null
              if (isMac()){ // OSX
                  if (extFilter){
                      var filter_regex = new RegExp("[^\.]*\."+extFilter+"$")
                      filter = function (file_entry){
                          return filter_regex.test(file_entry.name)
                  }else{
                      filter = function(){ return true } // All and any file(s)
              }else if (isWindows()){ // Win
                  if (extFilter){
                      filter = extFilter.charAt(0).toUpperCase() + extFilter.slice(1)+"-files:*."+extFilter
                  }else{
                      filter = "All files:*.*" // All and any file(s)
              }else{
                  filter = null
              // Create file dialog
              var path = new File(oldPath);
              // var dialog = path.saveDlg(dialogMessage, filter); // Same kind of error with saveDlg
              var dialog = path.openDlg(dialogMessage, filter, false);
          // Folder
          }else if(dialogType == "folder"){
              alert("folder diag:\n" + oldPath);
              // Create folder dialog
              var path = new Folder(oldPath);
              var dialog = path.selectDlg(dialogMessage);
              while (dialog.alias){
                  dialog = dialog.resolve.selectDlg(dialogMessage);
          if (dialog){
              return dialog.fsName.replace(/\\/g, "/") // Back to Front slashes
        • 1. Re: File browsing on OSX using openDlg() - Why are all folders greyed out?
          matias.kiviniemi Level 3
          I'll cross post since my last answer in the other went through moderation and released after you posted this (and it's relevant for this topic)
          There seems to be _SEVERAL_ versions of the save dialogs
          • file_entry.saveDlg(): Content of file_entry is the default value but not sure if it's locked to it
          • File.saveDialog(): same as file_entry.saveDlg, but no preselect value. Maybe it's not locked to original dir
          • folder_entry.saveDlg(): seems identical to file_entry.saveDlg, not sure if there is a difference.
          • Folder.selectDialog: seems most general purpose, "just pick a file"
          You probably have to just do some trial and error to pick the best one, what rules each has. As far as I see Mac has no option to "create a new file, but only this extension". Extension filter only seems to apply to opening existing and Win (although even there it's just hiding, you can actually set different extension by typing it).
          Confusing part is that the "all folders grayed" would implicate it actually wants the filter even though docs say it does not. I.e. youd have to make a filter function that accepts either folders or files with right extension like below (not tested)
          filter = function (fileSystemEntry){
            if (fileSystemEntry instanceof Folder) {
            return true
            } else {
            return filter_regex.test(fileSystemEntry.name)
          • 2. Re: File browsing on OSX using openDlg() - Why are all folders greyed out?
            Heimdaal Level 1
            Many thanks!
            I added your snippet to row 25 and now things are working!
