11 Replies Latest reply on Aug 19, 2016 6:16 AM by Kai Rübsamen
    Create an UI for a script! …
    Obi-wan Kenobi Level 5
      Hi all,
      I think I had to split this topic part!
      [ see:  How to quickly change cell stroke weight  ]
      Here's 2 variants of a tool thought by Uwe Laubender, Skemicle and your servant!
      This 1rst script allows the op to change to 0.5 pt the cell stroke weights in all the tables in a document if they are not equal to zero.
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
      app.doScript
          main,
          ScriptLanguage.JAVASCRIPT,
          UndoModes.ENTIRE_SCRIPT,
          "Change Tables Stroke Weights!"
      function main()
          var newWeight = 0.5;
          if(app.documents.length == 0){return};
          if(app.documents[0].stories.length == 0){return};
          if(app.documents[0].stories.everyItem().tables.length == 0){return};
          var doc = app.documents[0];
          var allStories = doc.stories.everyItem();
          var allCells = allStories.tables.everyItem().cells.everyItem().getElements();
          for(var n=0;n<allCells.length;n++)
                  if(allCells[n].topEdgeStrokeWeight != 0){
                      if(allCells[n].topEdgeStrokeWeight != newWeight){
                         allCells[n].topEdgeStrokeWeight = newWeight
                  if(allCells[n].bottomEdgeStrokeWeight != 0){
                      if(allCells[n].bottomEdgeStrokeWeight != newWeight){
                         allCells[n].bottomEdgeStrokeWeight = newWeight
                  if(allCells[n].leftEdgeStrokeWeight != 0){
                      if(allCells[n].leftEdgeStrokeWeight != newWeight){
                         allCells[n].leftEdgeStrokeWeight = newWeight
                  if(allCells[n].rightEdgeStrokeWeight != 0){
                      if(allCells[n].rightEdgeStrokeWeight != newWeight){
                         allCells[n].rightEdgeStrokeWeight = newWeight
      This second script allows the op to choose what cell stroke weights in all the tables in a document he wants to change (to 0.5 pt):
      app.doScript
          main,
          "Change Stroke Weight"
      function main()
      var weight = Number(prompt("What is your starting weight?", 1,"Current Stroke Weight"));
          if(allCells[n].bottomEdgeStrokeWeight != weight){continue};
          allCells[n].bottomEdgeStrokeWeight = newWeight;
          if(allCells[n].leftEdgeStrokeWeight != weight){continue};
          allCells[n].leftEdgeStrokeWeight = newWeight;
          if(allCells[n].rightEdgeStrokeWeight != weight){continue};
          allCells[n].rightEdgeStrokeWeight = newWeight;
          if(allCells[n].topEdgeStrokeWeight != weight){continue};
          allCells[n].topEdgeStrokeWeight = newWeight;
      I think it would be cooler to have this UI and this game:
      • type * if the op wants to treat all the strokes (except 0);
      • type a number if he wants to treat a specific stroke weight.
      I get this UI like this:
      app.doScript
          main,
      // Here's the UI
      var w = new Window ('dialog {alignChildren: "right"}', 'Change Tables Stroke Weights!');
        var group1 = w.add ('group');
        group1.add ('statictext {text: "Cells stroke to be replaced:"}');
        var UIWeight = group1.add ("edittext", undefined, 1);
         UIWeight.minimumSize.width = 50;
          UIWeight.maximumSize.width = 50;
        UIWeight.active = true;
        var group2 = w.add ('group');
        group2.add ('statictext {text: "… by:"}');
        var UINewWeight = group2.add ("edittext", undefined, 0.5);
         UINewWeight.minimumSize.width = 50;
        UINewWeight.maximumSize.width = 50;
        var buttons = w.add ('group {alignment: "center"}');
        buttons.add ('button {text: "OK"}');
        buttons.add ('button {text: "Cancel"}');
      if (w.show() == 2) {  // Cancel pressed
        exit();
      // Now the script:
      function main()
      … But, at this step, I'm totally unable to continue! …
      Thanks for all your help and your nice advices to not to sink in the dark side of The Force!
      MTFBWY!
        • 1. Re: Create an UI for a script! …
          Skemicle Level 3
          The script will now enable the op to select a starting stroke weight and choose to either change all stroke weights of that value or keep that weight and change all other stroke weights to a specified value. Hopefully this works.
          Scripted and idealised by:
              Obi-wan Kenobi
              Laubender
              Skemicle
          var myDialog = app.dialogs.add({name:"Change Stroke Weight"});
          with(myDialog.dialogColumns.add()){
              with(dialogRows.add()){
                  staticTexts.add({staticLabel:"Stroke Weight to:"});
                  var myVerticalAlignmentButtons = radiobuttonGroups.add();
                  with(myVerticalAlignmentButtons){
                      var changeButton = radiobuttonControls.add({staticLabel:"Change", checkedState: true});
                      var keepButton = radiobuttonControls.add({staticLabel:"Keep"});
                  var strokeWeightField1 = textEditboxes.add({editContents:"1"});
                      staticTexts.add({staticLabel:"Stroke Weight to change to:"});
                      var strokeWeightField2 = textEditboxes.add({editContents:"0.5"});
              if(myDialog.show() == 1){
                  if(changeButton.checkedState == true){
                      app.doScript(changeSpecifiedWeight,ScriptLanguage.JAVASCRIPT,[],UndoModes.ENTIRE_SCRIPT," Change Tables Stroke Weights!");
                  if(keepButton.checkedState == true){
                      app.doScript(keepSpecifiedWeight,ScriptLanguage.JAVASCRIPT,[],UndoModes.ENTIRE_SCRIPT,"Ke ep One Table Stroke Weight!");
          function keepSpecifiedWeight(){
              var Weight = strokeWeightField1.editContents;
              var newWeight = strokeWeightField2.editContents;
              for(var n=0;n<allCells.length;n++){
                  if(allCells[n].topEdgeStrokeWeight != Weight){
                  if(allCells[n].bottomEdgeStrokeWeight != Weight){
                  if(allCells[n].leftEdgeStrokeWeight != Weight){
                  if(allCells[n].rightEdgeStrokeWeight != Weight){
          function changeSpecifiedWeight(){
                      continue
                      continue
                      continue
                      continue
          • 2. Re: Create an UI for a script! …
            Cool!  It works very fine! Thanks a lot!
            The "keepSpecifiedWeight()" function is a very clever!
            Skemicle, I let you finish the adding of Uwe's script?
            I think about something: It could interesting to "isolate" the "0 pt" stroke (using a checkbox).
            Same thing with Uwe's part (checkbox).
            … and why not: color + stroke style!?
            • 3. Re: Create an UI for a script! …
              Skemicle Level 3
              What do you mean?
              and when i get some time i will definetely look into adding uwe's "only if all four sides are the same" and possibly the stroke styles/colors
              • 4. Re: Create an UI for a script! …
                About 0 pt stroke, it's a particular case because if 0, we have no stroke (of course, aha!).
                If, like in the first screenshot, we have 5 pts, 3 pts, 1 pt, 0,5 pt (by default) and 0 pt, and want 2 pts for the three first, we can't use: "Keep 0" because all we have in 0,5 pt will disappear! Actually, we need to launch the script 3 times to "change" 5 pts, 3 pts and 1 pt.
                It's not really a problem!
                About the last point, see the last screenshot, the script can't do this! …
                (^/)   Good night!
                • 5. Re: Create an UI for a script! …
                  Skemicle Level 3
                  Oh i think i understand now. You are wanting to keep both '0' and '0.5' weights and change everything except those two?
                  • 6. Re: Create an UI for a script! …
                    Yep!
                    "0 pt" is a very particular case because we can use it to build a table [as "no color" stroke].
                    • 7. Re: Create an UI for a script! …
                      Skemicle Level 3
                      Here is the UI I have..
                      Obi-wan Kenobi
                      Laubender
                      Skemicle
                      var userStrokeStyles = [];
                      var userSwatches = [];
                                  checkboxControls.add({staticLabel:"Only if all four strokes are the same", checkedState:false});
                                  checkboxControls.add({staticLabel:"Keep \"0pt\" Stroke", checkedState:true});
                                  staticTexts.add({staticLabel:"Apply new stroke styles"});
                              staticTexts.add({staticLabel:"Select stroke style to apply:"});
                              dropdowns.add();
                              staticTexts.add({staticLabel:"Select stroke color to apply:"});
                              dropdowns.add();
                      I'm not entirely sure how to save the user's swatches/stroke styles to an array to use in the dropdowns, but i will get it eventually I'm sure =P. Anything else that should be added?
                      • 8. Re: Create an UI for a script! …
                        Cool! The UI truly becomes to be … Pro! Thanks for the work!
                        The last features I think it would be interesting to add:
                        the capacity for the script to apply (or not // via a checkbox) "Cell styles"!
                        the capacity to play with: all tables (doc), all tables (story), selected table and tables defined by a table style (drop list)!
                        I know it's a big deal and nobody will pay us for this (but a lot will play with the script if it's finished one day)!
                        • 9. Re: Create an UI for a script! …
                          Kai Rübsamen Level 4
                          Guys,
                          Obi used Script-Ui, Skemicle changed this to a normal dialog. So, the result of 'dialog.show()' is either true or false, not 1 or 2!
                          Beside this: I’m astonished, that there is a need of the same for-loop 4 times?
                          • 10. Re: Create an UI for a script! …
                            Skemicle Level 3
                            Is true/false not equivalent to 1/0?
                            • 11. Re: Create an UI for a script! …
                              Skemicle, you’re right. I did not know that before. So thanks for clarification and sorry for confusion …
