7 Replies Latest reply on Aug 6, 2017 6:13 PM by corym79940771
    Locked lightroom catalog
    Neophrom
      Hello!
      After a system reinstall i realized that I cant open my lightroom catalog because it's locked, backup file locked too, obviously.
      Does the legal methods exist to unlock the catalog?
      I even don't know how i locked my catalog, never faced with such type of problem.
        • 1. Re: Locked lightroom catalog
          Open the folder that contains your catalog and look for a file with the lock. extension. After you delete that file then Lightroom should start normally. This lock file is the ONLY file you should delete.
          • 2. Re: Locked lightroom catalog
            Neophrom Level 1
            unfotunaly, it doesn't work. I tried to delete that file, in some cases it appears again. I delete it again, but Lightroom still tells me the same. Maybe there are another ways to unlock the catalog?
            omg it works! after I moved it to another hard drive, and instantly deleted .lock file that just appeared while I was opening catalog. Very interesting...
            Thank you JimHess
            • 3. Re: Locked lightroom catalog
              Per Berntsen Adobe Community Professional
              Please quote the exact, word-for-word error message you are receiving, or better yet, post a screenshot of it.
              • 4. Re: Locked lightroom catalog
                Neophrom Level 1
                Thanks, but the JimHess's method finally helped me.
                • 5. Re: Locked lightroom catalog
                  Thank you JimHess
                  Whenever Lightroom is open, there will ALWAYS be a lock file. And if Lightroom is open you will not be able to delete that file. The file is created by the catalog, which is a database. When Lightroom closes normally the log file is deleted automatically. If there is a problem with Lightroom shutting down that lock file can be left behind. And that's what causes the problem you were facing.
                  • 6. Re: Locked lightroom catalog
                    Lufthansen Level 1
                    This does NOT work for me. I had a bsod due to a faulty Lightroom catalog - of course it happened on deadline. When I tried to relaunch, my catalog file would not open due to the lock-file. Deleted the lock-file, but no dice. To make matters worse, all my presets, smart collections, tailored smart folders for photoshelter and my clients ftp servers: gone.
                    Adobe: I sure could use your help now. I have had serious issues with you guys before, but please help! Unless you help me fix your dodgy software, you are forcing to re-do my work over and over and over again, all the while you hold my 200.000 images hostage
                    • 7. Re: Locked lightroom catalog
                      corym79940771
                      How did you move it to a different hard drive?
