2 Replies Latest reply on Aug 18, 2016 8:41 AM by HaraldLoeffler
    Weird stripes in black background in Develop when GPU is activated on current Mac Pro
      Hello everyone,
      I have a problem with Lightroom, that could be a bug in the current version. In a photo with a black background I happen to see vertical stripes in the development module, but only if I tell LR to use the GPU. As the eye-dropper in LR and PS show, the background is 100% black. the same stripes appear in a completely black image generated in PS, when viewed in LR's Develop module. Exported files do not show the stripes. If I move the photo around with the "hand tool" in the Develop module, the stripes stay in one place and do not move with the photo. The problem only appears on my Mac Pro (D300 GPU) and not on my Macbook Pro. Please have a look at the screenshots and let me know, what you think.
      GPU is on...vertical stripes appear. They may not be visible on every screen, poor screens might not differentiate +-1 in L*AB.
      GPU is off...stripes are gone.
      GPU is on, but no stripes in the Library...expected, as it does not use the GPU
      No stripes in PS, either. The info palette definitely shows a continuous 0/0/0 when the mouse is moved over the black background...just in case ;-)
      I haven't noticed this problem in older versions of LR 6, only after updating from 6.5.1 to 6.6.1.
      Does anyone have an idea what is going on? I can only come up with two explanations: 1. A bug in LR or 2. My Mac happens to have a hardware problem that appeared between my initial shooting/editing of this photo and revisiting it in the current LR release.
      Thanks in advance for your help!
      Here is the output from the SYSTEM INFO:
      Lightroom version: CC 2015.6.1 [ 1083169 ]
      License: Creative Cloud
      Operating system: Mac OS 10
      Version: 10.10 [5]
      Application architecture: x64
      Logical processor count: 8
      Processor speed: 3,7 GHz
      Built-in memory: 24.576,0 MB
      Real memory available to Lightroom: 24.576,0 MB
      Real memory used by Lightroom: 2.717,5 MB (11,0%)
      Virtual memory used by Lightroom: 4.154,6 MB
      Memory cache size: 804,5 MB
      Maximum thread count used by Camera Raw: 8
      Camera Raw SIMD optimization: SSE2,AVX
      Displays: 1) 2560x1600
      Graphics Processor Info:
      AMD Radeon HD - FirePro D300 OpenGL Engine
      Check OpenGL support: Passed
      Vendor: ATI Technologies Inc.
      Version: 4.1 ATI-1.32.25
      Renderer: AMD Radeon HD - FirePro D300 OpenGL Engine
      LanguageVersion: 4.10
      Application folder: /Applications/Adobe Lightroom
      Library Path: /Users/HL/Lightroom/EOTT/EOTT.lrcat
      Settings Folder: /Users/HL/Library/Application Support/Adobe/Lightroom
      Installed Plugins:
      1) Show Focus Points
      Config.lua flags: None
      AudioDeviceIOBlockSize: 512
      AudioDeviceName: Bose USB Audio
      AudioDeviceNumberOfChannels: 6
      AudioDeviceSampleRate: 48000
      Build: LR5x102
      CoreImage: true
      GL_ALPHA_BITS: 8
      GL_BLUE_BITS: 8
      GL_DEPTH_BITS: 24
      GL_GREEN_BITS: 8
      GL_MAX_3D_TEXTURE_SIZE: 16384
      GL_MAX_TEXTURE_SIZE: 16384
      GL_MAX_VIEWPORT_DIMS: 16384,16384
      GL_RED_BITS: 8
      GL_RENDERER: AMD Radeon HD - FirePro D300 OpenGL Engine
      GL_VENDOR: ATI Technologies Inc.
      GL_VERSION: 2.1 ATI-1.32.25
      OGLEnabled: true
      GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_blend_equation_separate GL_ATI_blend_weighted_minmax GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
