0 Replies Latest reply on Aug 18, 2016 6:57 AM by Androiddeveloper
    I can not delete database operation?where  do i have error?
    Androiddeveloper
      Hello
      I can't delete database operation.i wrote  delete database queries kind of 3 format codes.source code 1:
      protected function buton_clickHandler(event:MouseEvent):void   {
      // TODO Auto-generated method stub
      function seckayit():void{
      var sec:SQLStatement=new SQLStatement;
        sec
      .sqlConnection=conn;
        sec
      .text="SELECT * FROM deneme";
        sec
      .execute();
        sec
      .addEventListener(SQLEvent.RESULT,silkayit);
      function silkayit(event:SQLResult):void{
        stmt
      .sqlConnection = conn;
        stmt
      .text="";
      //contactList.removeAll();
        stmt
      .text="DELETE FROM deneme WHERE id='"+liste.selectedItem.id+"'";
        stmt
      .execute();
      that's The source code 2:
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
        xmlns:s="library://ns.adobe.com/flex/spark" title="HomeView" contentCreationComplete="{selectContacts()}">
        <fx:Script source="../sec.as"/>
        <fx:Script>
        <![CDATA[
        import spark.events.GridSelectionEvent;
        import spark.events.IndexChangeEvent;
                protected function liste_changeHandler(event:IndexChangeEvent):void
        buton.enabled=true;
        protected function silkayit(event:MouseEvent):void{
        sec.sqlConnection = this.isDbConnected(conn);
        sec.text="SELECT * FROM deneme";
        sec.execute();
        var i:int=0;
        var data1:Array=sec.getResult().data;
        var row:Object=data1.data;
        var rid:int=row.sid;
        var stmt1:SQLStatement=new SQLStatement;
        stmt1.sqlConnection = this.isDbConnected(conn);
        stmt1.text="DELETE FROM deneme where id='"+liste.selectedItem.rid+"'";
        stmt1.execute();
        </fx:Script>
        <fx:Declarations>
        <!-- Place non-visual elements (e.g., services, value objects) here -->
        </fx:Declarations>
      <s:List id="liste" width="300" height="253" change="liste_changeHandler(event)"
        dataProvider="{contactList}" fontSize="12" horizontalCenter="0" labelFunction="displayFunc"
        selectedIndex="-1" verticalCenter="0">
        </s:List>
        <s:Button id="buton" x="206" y="-2" label="Kayıt Sil" click="silkayit(event)"   enabled="false"/>
      </s:View>
      Finally the source code 3 is:
        <fx:Script>
        <![CDATA[
        buton.enabled=true;
        stmt1.text="DELETE FROM deneme where id='"+liste.selectedItem.data.id+"'";
        stmt1.execute();
        </fx:Script>
        <fx:Declarations>
        </fx:Declarations>
          </s:List>
      </s:View>
      Although i have worked 3 formats,i could not run delete database operations.Where are my error?How must i write code correctly?i usuallay my error  below rows at:
      stmt.text="DELETE FROM deneme WHERE id='"+liste.selectedItem.id+"'";
      Also when i have worked ,i have error below at:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
        at views
      ::listviewHomeView/silkayit()[C:\Users\mobil-developer\Adobe Flash Builder 4.6\veri-islem\src\sec.as:68]
        at views
      ::listviewHomeView/___listviewHomeView_Button1_click()[C:\Users\mobil-developer\Adobe Flash Builder 4.6\veri-islem\src\views\listviewHomeView.mxml:16]
      my database is not null.What can i do?would you like to help me?
