1 Reply Latest reply on Aug 23, 2016 1:33 AM by Nanaky
    Error! Check Authorization when downloading a book from Google Books
    billf98599911
      I have an Adobe account with my regular email name. I downloaded and installed Digital Editions and did the authorization but can't remember the password that I used when I initially created the authorization. Now when I download a new book from Google Books I get a Check Authorization error. My registartion on Google Play uses a different email than my Adobe account. Is this an issue.
      I tried removing my Authorization from Digital Editions but I can't because it appears to not accept my password (in any case it fails) I thought it would be the same as my Adobe account password.
      I'd like to blow the whole thing away and start over does simply uninstalling Digital Editions accomplish this?
        • 1. Re: Error! Check Authorization when downloading a book from Google Books
          Nanaky Level 5
          Check actvation say that the authoirze are not right in the system save. To solved it used this:
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
