0 Replies Latest reply on Aug 29, 2016 10:13 AM by Obi-wan Kenobi
    Remove a Column in Tab Text …
    Obi-wan Kenobi Level 5
      Hi All,
      How are you today?
      My last night game:
      How to remove a "text-column" in tab text? … and how to do it with [JS] just entering the number of the column to be deleted in an UI?
      A special mention to Peter Kahrel for his amazing pdf on ScriptUI [revision in may 2016]:  ScriptUI for dummies | Peter Kahrel
      Maybe the script I wrote below is not really "orthodox" but it works nice playing with Grep researches.
      If (surely) better, tell me [totally appreciated]!
      Actually, the script works on text selection without UI:
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
      app.doScript
          main,
          ScriptLanguage.JAVASCRIPT,
          UndoModes.ENTIRE_SCRIPT,
          "Remove a Column in Tab Text!"
      function main()
          var myParagraphs = app.selection[0].paragraphs;
          for (var i = 0; i < myParagraphs.length; i++){
          app.findGrepPreferences = app.changeGrepPreferences = null;
          app.findGrepPreferences.findWhat = /(?s)^([^\t\r]*(\t|$)){3}\K(?1)/.source;   //  Define the colum number as: 0, for the column 1; 1, for the column 2; 2, for the column 3 …
          app.changeGrepPreferences.changeTo = "";
          app.selection[0].changeGrep();
          app.findGrepPreferences.findWhat = /\t+$/.source;
      As I said, I would like to play with an UI [made with ScriptUI].
      The code I wrote to create it is:
      // Here's the UI
      var w = new Window ('dialog {alignChildren: "right"}', 'Remove a Column in Tab Text!');
        var group = w.add ('group');
        group.add ('statictext {text: "Remove the Column:" }');
        var myCol = group.add ("edittext", undefined, "1");
         myCol.minimumSize.width = 50;
          myCol.maximumSize.width = 50;
        myCol.active = true;
        var buttons = w.add ('group {alignment: "center"}');
        buttons.add ('button {text: "OK"}');
        buttons.add ('button {text: "Cancel"}');
      if (w.show() == 2) {  // Cancel pressed
        exit();
      … But I'm always unable to continue: How to merge the 2 script parts!
      Last comment: as I said in my first script comment, "0" targets the first column, "1", the second, "2" the third, …
      in the UI, "1" (by default) will target the first column, "2", the second, "3" the third, …
      So, I will need a calculation! …
      Thanks a lot for any help and comment!
      Next future step for me:
      Include the capacity to choose the target: selected text (as here), doc, story, para style and para style + "based on" para styles!  cool!
