5 Replies Latest reply on Aug 20, 2016 7:41 PM by Steve Grisetti
    Premiere elements 9 vs Premiere elements 14
    shirleyw92681605
      HELP!  My premiere elements 9 is old and so I thought I'd go to 14.  Seemst that 14 doesn't open the files in the same ways and so all the effects are not transfered, which means a clip by clip update.  Also, 14 froze and died on me.  So, I tried to reopen the file in 9 and it is now "corrupted".  Any solution other than starting from scratch?  Fortunately, I've only opened one of my "9" files this way.  In trying out 14 I copied a file to try, as suggested.  When that worked I went on to the original and now have a corrupted file.  I'm not sure why 14 froze and died, but I don't want to risk my other files if this is the norm.  Any ideas on how to restore or how to work this situation?
      Shirley
        • 1. Re: Premiere elements 9 vs Premiere elements 14
          You can not open a version 9 project in version 14. The program is very different and is not backwards compatible. Also, as you've seen, attempting to open a version 9 project in a later version of the program will corrupt the project file and make it usable.
          You can try to open one of the version 9 auto-saves -- in VERSION 9, of course! But don't try to do it with version 14.
          Start new projects in version 11. Finish older projects in the version they were started in.
          • 2. Re: Premiere elements 9 vs Premiere elements 14
            shirleyw92681605 Level 1
            I was able to get a backup version that was close to finished.  Thankfully!
            However, it seems I cannot have both PE 9 and PE 14 on the same computer.  Perhaps it will work if I specify which program to open things in, but trying to open PE 9 files when PE 14 was installed only showed up as corrupt.  I uninstalled PE 14 and can now open my files in PE 9 again, if they hadn't been opened in PE 14.
            I did not have any problem opening PE 9 files in PE 14, except that not all of the effects showed up, so it doesn't work for "reviving" my old files unless I want to put them together almost from scratch.
            Not making me an Adobe fan!
            • 3. Re: Premiere elements 9 vs Premiere elements 14
              There is absolutely no reason you can't have Premiere Elements 9 and 14 on your computer at the same time. For reference sake, I've had versions 7 through 14 all on my computer at the same time.
              They are completely separate programs and they do not interfere with each other. (Though I don't know if you can have two versions open at the same time.)
              • 4. Re: Premiere elements 9 vs Premiere elements 14
                goldentrails4u
                When a company releases a software version it should pretty much be bug free, not with PRE 14.  I just bought it this past week thinking it was better than 8. To my surprise it gets to 25% when rendering and crashes everytime.  I shouldn't have to have a degree in computer engineering to troubleshoot and re-engineer a product that is supposed run flawlessly out of the box.  Granted it was only $80.00 but still that could have gone toward a program that worked properly. Trying to get answers is like pulling teeth, unless you spend hundreds of dollars you can't even find a phone number for tech support.  You are not the only person having issues with crashes, I think Adobe released an inferior product, at least in Elements 8 I had a ton of effects, transitions and title templates, 14 has squat.  I am totally frustrated with 14 and probably will never buy another Adobe product.  I don't know if this helped or if it will even post once the censors read it.
                • 5. Re: Premiere elements 9 vs Premiere elements 14
                  I've been using version 14 for a year now and I've never had so much as a hiccup -- so maybe the problem is with your machine. I've also edited on it a wide variety of video formats, from standard def to high-def, miniDV to AVCHD to GoPro to generic action cam -- all of it without the slightest problem. And that's on two different Windows computers and one Mac.
                  Regardless, if you contact Adobe or whoever you bought the software from, I'm sure they will arrange a refund.
