0 Replies Latest reply on Apr 19, 2006 8:54 AM by Judge Schmells
    Flash Video interacting with PHP help.
    Judge Schmells
      Hi, I am trying to figure out how to configure a flash video player created in flash 8 so that it will play several different flash movies of diff. resolutions and sizes called in with a php token.
      Here is the code I have on my webpage:
      <object type="application/x-shockwave-flash" data="flvplayer.swf?&file=uploads/flv/<?=$res['FileName']?>.flv" width="<?=$res['width']*2;?>" height="<?=$res['height']*2+22;?>" wmode="transparent"><param name="movie" value="flvplayer.swf?autoStart=false&file=uploads/flv/<?=$res['FileName']?>.flv" /><param name="wmode" value="transparent" /></object>
      Then I created my flash player by just opening an already transcoded video in Flash 8 Prof. It sent me to the Flash Video Player wizard where I picked my skin, etc. etc. My first question was, what do I put in the parameters under "content path" if I am determining the path in the PHP script? Do I delete that parameter or something?
      Does this look like it will work or am I doing something wrong?
      Thanks so much for your help.
      Craig L.
