2 Replies Latest reply on Apr 17, 2006 7:54 AM by aniebel
    target path issue
    aniebel Level 2
      Can anyone tell me why this function is not working from the main timeline (frame 1)? The movie has a stop action on frame 2 and on the main movie is the MC with an instance name of "newsNav_mc". In that MC is a frame label "openR" and it has a tween from that frame to frame 34 which has a stop on it.
      It's not advancing the movie clip to "openR". What have I done wrong?
      onEnterFrame = function () {
      if (this._currentframe == 2) {
      this.newsNav_mc.gotoAndPlay("openR");
      if (this.newsNav_mc._currentframe == 34) {
      delete onEnterFrame;
        • 1. Re: target path issue
          Level 7
          aniebel,
          I'll try.
          Okay, so that means the SWF will hit frame 1 first, execute the code you
          put there, then advance to frame 2 and stop. Frame 1's code sets in motion
          an onEnterFrame event, which fires at approximately the speed of your
          movie's frame rate. So ...
          ... when the playhead advances to frame 2 and stops, the above condition
          will be true -- perhaps for a long time. At the default 12fps, your
          onEnterFrame event is firing approximlately once every 88 milliseconds (12
          times a second).
          So what are you asking Flash to do so often? The following line.
          So the playhead inside newsNav_mc is almost constantly being sent to
          that "openR" frame. It never has the chance to actually *play* that
          timeline, because every time it starts -- every 88 milliseconds, perhaps! --
          you're telling it to go back to the "openR" label and start again.
          Why not try something like this?
          // on frame 2 of the main timeline
          this.stop();
          this.newsNav_mc.onEnterFrame = function () {
          if (this._currentframe == 34) {
          trace("arrived at frame 34");
          Do you see how that's different?
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: target path issue
            aniebel Level 2
            Yes, that makes total sense. I was having trouble before calling the mc from another frame but I must have had something else going on.
            Thanks!
