5 Replies Latest reply on Aug 23, 2016 6:08 AM by karthiks94217840
    find all line last character and fill color
    karthiks94217840 Level 2
      Dear friend,
      I need to find all line last character and fill color (No need to words last character).
      My code problem: Without space in the last character is not fill color.
      My code is below:
      var myDocument = app.activeDocument;
      var myLine = myDocument.stories.everyItem().lines.everyItem().getElements();
      for(i=0; i<myLine.length; i++)
          var myCon = myLine[i].texts[0].contents;
          if(myCon.match(/\n| /gi) != null){
              try{
                  if(myLine[i].characters.item(-2).fillColor = myDocument.colors[2]);
                  }catch(e){}
      My screenshot also below:
      Please suggest friend,
      Thanks in Advance
      KS
        • 1. Re: find all line last character and fill color
          I need output file. Please see below screen shot:
          Thanks in Advance
          KS
          • 2. Re: find all line last character and fill color
            Skemicle Level 3
            add an 'if else' statement to apply the fill color to the second to last character only if the last character is a space. else apply the fill color to the last character.
                    try{
                        if(myLine[i].characters.item(-1).contents == " "){
                            myLine[i].characters.item(-2).fillColor = myDocument.colors[2];
                        }else myLine[i].characters.item(-1).fillColor = myDocument.colors[2];
                    }catch(e){};
            • 3. Re: find all line last character and fill color
              Hi Skemicle,
              Thanks to your replay,
              Your coding working fine.
              One more question: How to match 1st line last character, 2nd line last characters and 3rd line last characters?
              Exp:
              Last 1st line character >> a
              Last 2nd line character >> a
              Last 3rd line character >> a
              Thanks in Advance
              Ks
              • 4. Re: find all line last character and fill color
                Skemicle Level 3
                Your lines are scripted as  myLine[i] for each individual line you will replace the [i] with the index number of each line (keep in mind that javascript starts with an index of 0. (eg. line 1 would be myLine[0],  line 2 would be myLine[1], etc.) This will specify that everything in this line of code will be confined to that line. (eg. myLine[1].characters matches all characters but only within line 2. To determine which character is the same as determining the line, myLine[1].characters[0] being 1st character, to get to the end of a line use the [- ] since javascript is confined to this  line it will loop backwards to the end of the line and you can then set how far from the end of the line you want to match the character (myLine[1].characters[-1] will be the last character, [-2] the second to last, etc.)
                • 5. Re: find all line last character and fill color
                  Hi SK,
                  Thanks to your suggestion.
                  Quick Replay: please go my link and see my code. i am going right way? please suggest.
                  Match last line characters
                  Thanks in Advance
                  KS
