5 Replies Latest reply on Aug 23, 2016 11:55 AM by innerspaceouterspace
    Attach Proxies arguments
    innerspaceouterspace Level 1
      clip.attachProxy(path, true/false)
      What's the true/false?
      If it's true, it looks like it's replacing in the bin. The clip gets renamed, shot timing gets altered (we're using metadata), and the path gets replaced.
      If false, acts as one would expect - it's attaching to the file, not replacing it.
        • 1. Re: Attach Proxies arguments
          Bruce Bullis Adobe Employee
          The second param is a 0 or 1; 0 = new path is proxy res, 1 = it's hi res.
          • 2. Re: Attach Proxies arguments
            Cool. Seems a bit weird that if it's a high res proxy, it would change the clipName and reread the metadata and adjust shottiming on the clip. I can't think of a reason why you'd want that to happen.
            Correlated: Doesn't look like there's a way to remove proxies on a clip either through jsx or manually at all.
            If this is an available feature, where would it be? The methods I see on a clip are canProxy, hasProxy, and attachProxy.
            I can definitely update the proxies by running attachProxy and feeding in the new path, but there are cases where one might want to remove the proxy.
            Edit: It would also be cool to be able to query the proxy that's attached. Don't really see a way to get the path of the current proxy attached to a clip.
            Thanks Bruce.
            • 3. Re: Attach Proxies arguments
              It's a bit of an abuse of terminology, on our part; if you're setting the hi-res path for a projectItem, you are effectively calling replaceMedia(). You still need the hi-res option, because in some workflows you start with only the proxy, and have to attach to full-res later.
              Completely reasonable API feature requested (B-122341).
              • 4. Re: Attach Proxies arguments
                Makes sense. Thanks!
                • 5. Re: Attach Proxies arguments
                  I think I'll just keep tailing onto the end of this post so as not to flood the forum with topics.
                  I noticed something that should throw an error. Using clip.attachProxy() with a path that points to a proxy that doesn't work never shows an error dialog, it just fails silently. For instance, if I manually attach the proxy through the right click menu, I can get the following dialog to pop up:
                  But attaching a proxy through the API causes the same error on the same clip to fail silently.
                  It doesn't return anything back through JSX, either, so I can't check the result of attachProxy().
                  And I don't know if you saw this above for the API request, I did a ninja-edit and you might have missed it since our posts were close to each other in time:
