12 Replies Latest reply on Oct 14, 2016 6:43 AM by davidc26358293
    Major InDesign CC2015 Issues
    gaeilge Level 1
      Hello all,
           I have a user with a slew of issues with only InDesign CC2015 including placing pictures from one InDesign project to another.  Other people can use the same pictures and files and they are good.  The program is also having issues where it will randomly crash when trying to open the program directly from the app folder as well as a file directly.  We are using network related files, but again others who use the same files are fine so it is not the files themselves as far as I know.  This will happen on a wired connection as well as Wi-Fi for her.  It will crash when exporting to PDF's on all projects, sometimes the PDF's will complete, but it takes almost an hour to do so when it does.  Below is the error message she sent me and all the info on the machine and everything I can think of that I have done to try to fix it already.  I uninstall/re-installed the program, but it took 3 attempts to finally get it to open up for her today (error listed below).  Anyone have an ideas on how to stop these issues from happening?  I have 25 other people with the same setup and updates and they all seem to be good to go minus a few crashes here or there, but nothing major like this.  Any fix I do works for maybe a day or 2 if I'm lucky.  If you need any more info please let me know.  Thanks.
      Attempted fixes:
      -Cleared her preferences with the button combo and deleted needed files as instructed on site.
      -Uninstalled and re-installed the application and cloud program serval times.  Used the suggested application removal tools from Adobe site and deleted needed folders as instructed.
      -Refreshed her user profile and only moved desktop and documents files in case something under her user name was corrupt.
      -Updated all CC and OS that the machine had avaiable.  Although on the Adobe site it says InDesign 2015.4 is the newest I can only get (2015).  Not sure if the update is even working properly just for InDesign.  All other programs are updated to the same listed as on the Adobe site.  http://www.adobe.com/products/indesign/features.html.
      -Went as far as to re-install the OS El Capitan from scratch on a completely different machine (with same specs).  Didn't move her user files just in case, but same issues popped up soon after.
      -Ran checks on the disks and no errors are showing on either machine.
      -Signed in as the local admin to check the profile, but the same issues happened for that admin user name as well.
      -For the PDF issue I uninstalled the older Pro X version and replaced it with DC, but that only fixed it for a short time.  The DC program on it's own is working fine, only InDesign has issues with it.
      -Signed out of her Adobe account and logged back in.
      -Updated the Windows based server for the whole department by adding Acronis Access Connect for AFP connection fixes and changed the way she was connecting to the servers to match this.
      -Moved a few files locally to the MAC so I could test out if network issues were causing the errors.
      -Told the MAC that PC's are better to guilt it into working.  Think that made it worse.
      Machine and Adobe version info
      OS X El Capitan
      Version: 10.11.6
      Macbook Pro (Retina, 15-icn, mid 2014)
      Processor: 2.8 GHz Intel Core i7
      Memory: 16GB 1600 MHz DDR3
      Graphics: NVIDIA GeForce GT 750M 2048 MB
      Creative Cloud Version: 3.7.0.272 (no more updates show).
      Indesign Version: 11.0.0.72 (no more updates listed).
      Cloud login type: Cloud for team.
      Error after re-install attempt #1 and #2, 3rd time allowed the program to open:
      Configuration error
      Please uninstall and reinstall the product.
      If this problem still occurs, please contact Adobe techincall support for help, and mention the error code shown at the bottom of this screen.
      Error: 16
      Original error message before reinstall:
      Process:               Adobe InDesign CC 2015 [15205]
      Path:                  /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015
      Identifier:            com.adobe.InDesign
      Version:               11.0.0.72 (11000)
      Code Type:             X86-64 (Native)
      Parent Process:        ??? [1]
      Responsible:           Adobe InDesign CC 2015 [15205]
      User ID:               1562196708
      Date/Time:             2016-08-22 11:10:48.062 -0400
      OS Version:            Mac OS X 10.11.6 (15G31)
      Report Version:        11
      Anonymous UUID:        7C98A497-0521-C80D-DE2A-2D462D22EF8E
      Time Awake Since Boot: 11000 seconds
      System Integrity Protection: enabled
      Crashed Thread:        0  Main Thread  Dispatch queue: com.apple.main-thread
      Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
      Exception Note:        EXC_CORPSE_NOTIFY
      VM Regions Near 0:
          __TEXT                 0000000109d29000-0000000109d2e000 [   20K] r-x/rwx SM=COW  /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015
      Global Trace Buffer (reverse chronological seconds):
      1366.366857  CFNetwork                     0x00007fff9bfb8db3 TCP Conn 0x7f904f223360 SSL Handshake DONE
      1366.387397  CFNetwork                     0x00007fff9bfb8c8f TCP Conn 0x7f904f223360 starting SSL negotiation
      1366.387503  CFNetwork                     0x00007fff9bfb7659 TCP Conn 0x7f904f223360 complete. fd: 83, err: 0
      1366.387865  CFNetwork                     0x00007fff9c045f33 TCP Conn 0x7f904f223360 event 1. err: 0
      1366.516724  CFNetwork                     0x00007fff9bfb692b TCP Conn 0x7f904f223360 started
      1379.364009  CFNetwork                     0x00007fff9bfb8db3 TCP Conn 0x7f905873daf0 SSL Handshake DONE
      1379.421088  CFNetwork                     0x00007fff9bfb8c8f TCP Conn 0x7f905873daf0 starting SSL negotiation
      Thread 0 Crashed:: Main Thread  Dispatch queue: com.apple.main-thread
      0   com.adobe.InDesign.Group          0x000000011e1cb0ed 0x11e1c5000 + 24813
      1   com.adobe.InDesign.Group          0x000000011e1ca81f 0x11e1c5000 + 22559
      2   PublicLib.dylib                   0x000000010b199251 Command::DoImmediate(short) + 65
      3   com.adobe.InDesign.Utilities      0x0000000123c08197 0x123c06000 + 8599
      4   com.adobe.InDesign.Utilities      0x0000000123c08345 0x123c06000 + 9029
      5   com.adobe.InDesign.AppFramework    0x000000011bd99815 0x11bd8b000 + 59413
      6   PublicLib.dylib                   0x000000010b198170 CmdUtils::ProcessCommand(ICommand*) + 64
      7   com.adobe.InDesign.Document Framework    0x000000011cf44648 0x11cf28000 + 116296
      8   PublicLib.dylib                   0x000000010b199251 Command::DoImmediate(short) + 65
      9   com.adobe.InDesign.Utilities      0x0000000123c08197 0x123c06000 + 8599
      10  com.adobe.InDesign.Utilities      0x0000000123c08345 0x123c06000 + 9029
      11  com.adobe.InDesign.AppFramework    0x000000011bd99815 0x11bd8b000 + 59413
      12  PublicLib.dylib                   0x000000010b198170 CmdUtils::ProcessCommand(ICommand*) + 64
      13  com.adobe.InDesign.Generic Page Item    0x000000011df13971 0x11dd94000 + 1571185
      14  com.adobe.InDesign.Layout UI      0x000000011ebbf327 0x11eafe000 + 791335
      15  com.adobe.InDesign.Application UI    0x000000011c012c5e 0x11bff2000 + 134238
      16  com.adobe.InDesign.Application UI    0x000000011c0117f2 0x11bff2000 + 129010
      17  com.adobe.InDesign.Application UI    0x000000011c074937 0x11bff2000 + 534839
      18  com.adobe.InDesign.Actions        0x000000011bd30a98 0x11bd1b000 + 88728
      19  com.adobe.InDesign.Actions        0x000000011bd1ffc6 0x11bd1b000 + 20422
      20  com.adobe.InDesign.Application UI    0x000000011c135aca 0x11bff2000 + 1325770
      21  com.adobe.InDesign.Application UI    0x000000011c1357fa 0x11bff2000 + 1325050
      22  DV_WidgetBinLib.dylib             0x0000000109d89a45 dv_utils::RouteEventToAppWindow(dvaui::ui::KeyboardEvent const&) + 53
      23  com.adobe.InDesign.Application UI    0x000000011c132d31 0x11bff2000 + 1314097
      24  com.adobe.InDesign.Application UI    0x000000011c134abc 0x11bff2000 + 1321660
      25  DV_WidgetBinLib.dylib             0x0000000109d9004f DVEventHandler::Call_UI_DoKeyboardEvent(IEvent*) + 175
      26  DV_WidgetBinLib.dylib             0x0000000109d77c55 DVHostedWidgetEH::BaseHandleKeyboardEvent(IEvent*) + 85
      27  DV_WidgetBinLib.dylib             0x0000000109d77cad DVHostedWidgetEH::KeyDown(IEvent*) + 13
      28  DV_WidgetBinLib.dylib             0x0000000109d8f7de DVEventHandler::DVKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&, bool&) + 270
      29  DV_WidgetBinLib.dylib             0x0000000109d78e33 DVHostedWidgetView::PrivateImpl::KeyboardEventCallback(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&, bool&) + 83
      30  DV_WidgetBinLib.dylib             0x0000000109d7d663 0x109d6a000 + 79459
      31  com.adobe.dvaui.framework         0x000000010aa923a7 dvaui::ui::UI_Node::UI_DispatchCustomKeyboardEventToNode(dvaui::ui::UI_Node*, boost::intrusive_ptr<dvaui::ui::UI_Node>, dvaui::ui::KeyboardEvent const&, bool&) + 167
      32  com.adobe.dvaui.framework         0x000000010aa92876 dvaui::ui::UI_Node::UI_DispatchKeyboardEventToNode(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 70
      33  com.adobe.dvaui.framework         0x000000010aa9491f dvaui::ui::UI_Node::UI_DispatchKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 415
      34  com.adobe.dvaui.framework         0x000000010ab0d717 dvaui::ui::OS_Node::UI_DispatchKeyboardEventFromOS(dvaui::ui::OS_Event*) + 151
      35  com.adobe.dvaui.framework         0x000000010ab13a0e dvaui::ui::OS_View::UI_DispatchPlatformKeyDownEvent(dvaui::ui::OS_Event&) + 126
      36  com.adobe.dvaui.framework         0x000000010ab1322f dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 303
      37  com.adobe.dvaui.framework         0x000000010ab130d6 dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 22
      38  com.adobe.dvaui.framework         0x000000010ab148a5 dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 69
      39  com.adobe.dvacore.framework       0x000000010a448ebc int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 28
      40  com.adobe.InDesign.Application UI    0x000000011c1315e2 0x11bff2000 + 1308130
      41  com.adobe.dvacore.framework       0x000000010a449010 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 144
      42  com.adobe.dvacore.framework       0x000000010a44a505 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 165
      43  com.adobe.dvaui.framework         0x000000010ab21daa dvaui::ui::OS_NodeTimerData::RemoveTimer() + 37530
      44  DV_WidgetBinLib.dylib             0x0000000109e07e3a 0x109d6a000 + 646714
      45  com.apple.AppKit                  0x00007fff990d8b15 -[NSWindow _reallySendEvent:isDelayedEvent:] + 2108
      46  com.apple.AppKit                  0x00007fff98b17539 -[NSWindow sendEvent:] + 517
      47  com.adobe.owl                     0x000000010a21989d 0x10a1de000 + 243869
      48  com.apple.AppKit                  0x00007fff98a9816a -[NSApplication sendEvent:] + 4382
      49  com.adobe.dvaui.framework         0x000000010ab18eeb dvaui::ui::OS_NodeTimerData::RemoveTimer() + 987
      50  com.adobe.exo.framework           0x000000010c7ad98a exo::app::OS_AppBase::SetResetMenuShortcutsOnClose(bool) + 842
      51  DV_WidgetBinLib.dylib             0x0000000109e04ca5 0x109d6a000 + 634021
      52  com.adobe.InDesign.Application UI    0x000000011c13850e 0x11bff2000 + 1336590
      53  com.apple.AppKit                  0x00007fff988fedf2 -[NSApplication run] + 796
      54  com.adobe.exo.framework           0x000000010c7ad3b8 exo::app::OS_AppBase::RunEventLoop() + 56
      55  com.adobe.InDesign.AppFramework    0x000000011bed96d3 0x11bd8b000 + 1369811
      56  com.adobe.InDesign.AppFramework    0x000000011bed859c 0x11bd8b000 + 1365404
      57  com.adobe.InDesign                0x0000000109d2a68d main + 285
      58  libdyld.dylib                     0x00007fff955935ad start + 1
      Thread 1:: Dispatch queue: com.apple.libdispatch-manager
      0   libsystem_kernel.dylib            0x00007fff9a488efa kevent_qos + 10
      1   libdispatch.dylib                 0x00007fff8d7dd165 _dispatch_mgr_invoke + 216
      2   libdispatch.dylib                 0x00007fff8d7dcdcd _dispatch_mgr_thread + 52
      Thread 2:: com.apple.CFSocket.private
      0   libsystem_kernel.dylib            0x00007fff9a48807a __select + 10
      1   com.apple.CoreFoundation          0x00007fff9f0bf4fa __CFSocketManager + 762
      2   libsystem_pthread.dylib           0x00007fff95c3199d _pthread_body + 131
      3   libsystem_pthread.dylib           0x00007fff95c3191a _pthread_start + 168
      4   libsystem_pthread.dylib           0x00007fff95c2f351 thread_start + 13
      Thread 3:: IPCClient rcvr: FMClient.1562196708.15205.140735281971200.1
      1   com.extensis.FontManagement.plugin-interface    0x0000000117987826 GIPCReceiver::OSWaitForData() + 2846
      2   com.extensis.FontManagement.plugin-interface    0x000000011797c31a GIPCClient::ReceiverThreadProc(GThread*) + 798
      3   com.extensis.FontManagement.plugin-interface    0x000000011799cb2b GThread::PthreadInternal(void*) + 223
      4   libsystem_pthread.dylib           0x00007fff95c3199d _pthread_body + 131
      5   libsystem_pthread.dylib           0x00007fff95c3191a _pthread_start + 168
      6   libsystem_pthread.dylib           0x00007fff95c2f351 thread_start + 13
      Thread 4:: Agent IF Message Handler
      0   libsystem_kernel.dylib            0x00007fff9a487db6 __psynch_cvwait + 10
      1   libsystem_pthread.dylib           0x00007fff95c32728 _pthread_cond_wait + 767
      2   com.extensis.FontManagement.plugin-interface    0x00000001179967dc GSemaphore::TimedWait(unsigned int) + 76
      3   com.extensis.FontManagement.plugin-interface    0x0000000117980ae3 GIPCClient::GIPCMTDataAccumulator::WaitForData(unsigned int, std::vector<char, std::allocator<char> >&, bool) + 37
      4   com.extensis.FontManagement.plugin-interface    0x0000000117e85179 GAgentIFMessageHandlerThread::RunMessageHandlerThread() + 445
      5   com.extensis.FontManagement.plugin-interface    0x0000000117e85896 GAgentIFMessageHandlerThread::AgentIFMessageHandlerThreadFunc(GThread*) + 42
      6   com.extensis.FontManagement.plugin-interface    0x000000011799cb2b GThread::PthreadInternal(void*) + 223
      7   libsystem_pthread.dylib           0x00007fff95c3199d _pthread_body + 131
      8   libsystem_pthread.dylib           0x00007fff95c3191a _pthread_start + 168
      9   libsystem_pthread.dylib           0x00007fff95c2f351 thread_start + 13
      Thread 5:
      1   com.extensis.FontManagement.plugin-interface    0x0000000117983b7e -[IPCDataHandler handleDataFromSocket:] + 2086
      2   com.apple.Foundation              0x00007fff92f48e64 __NSThread__start__ + 1351
      3   libsystem_pthread.dylib           0x00007fff95c3199d _pthread_body + 131
      4   libsystem_pthread.dylib           0x00007fff95c3191a _pthread_start + 168
      5   libsystem_pthread.dylib           0x00007fff95c2f351 thread_start + 13
      Thread 6:: com.apple.NSURLConnectionLoader
      0   libsystem_kernel.dylib            0x00007fff9a481f72 mach_msg_trap + 10
      1   libsystem_kernel.dylib            0x00007fff9a4813b3 mach_msg + 55
      2   com.apple.CoreFoundation          0x00007fff9f0821c4 __CFRunLoopServiceMachPort + 212
      3   com.apple.CoreFoundation          0x00007fff9f08168c __CFRunLoopRun + 1356
      4   com.apple.CoreFoundation          0x00007fff9f080ed8 CFRunLoopRunSpecific + 296
      5   com.apple.CFNetwork               0x00007fff9bf7da6d +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
      6   com.apple.Foundation              0x00007fff92f48e64 __NSThread__start__ + 1351
      Thread 7:
      0   libsystem_kernel.dylib            0x00007fff9a487fba __recvfrom + 10
      1   VulcanMessage5.dylib              0x000000010e84b446 0x10e826000 + 152646
      2   VulcanMessage5.dylib              0x000000010e84987d 0x10e826000 + 145533
      3   VulcanMessage5.dylib              0x000000010e847ae0 0x10e826000 + 137952
      4   VulcanMessage5.dylib              0x000000010e847a26 0x10e826000 + 137766
      5   VulcanMessage5.dylib              0x000000010e840740 0x10e826000 + 108352
      6   VulcanMessage5.dylib              0x000000010e840bd0 0x10e826000 + 109520
      7   VulcanMessage5.dylib              0x000000010e840b99 0x10e826000 + 109465
      8   VulcanMessage5.dylib              0x000000010e846712 0x10e826000 + 132882
      9   VulcanMessage5.dylib              0x000000010e846439 0x10e826000 + 132153
      10  VulcanMessage5.dylib              0x000000010e8460ba 0x10e826000 + 131258
      11  VulcanMessage5.dylib              0x000000010e84600d 0x10e826000 + 131085
      12  VulcanMessage5.dylib              0x000000010e833c02 0x10e826000 + 56322
      13  VulcanMessage5.dylib              0x000000010e83467d 0x10e826000 + 59005
      14  VulcanMessage5.dylib              0x000000010e8472dc 0x10e826000 + 135900
      15  VulcanMessage5.dylib              0x000000010e84ad19 0x10e826000 + 150809
      16  libsystem_pthread.dylib           0x00007fff95c3199d _pthread_body + 131
      17  libsystem_pthread.dylib           0x00007fff95c3191a _pthread_start + 168
      18  libsystem_pthread.dylib           0x00007fff95c2f351 thread_start + 13
      Thread 8:: UxTech Queue ThreadController
      2   libtypekitC4Release.dylib         0x000000010ce556eb 0x10ce51000 + 18155
      3   libtypekitC4Release.dylib         0x000000010ceabe6b 0x10ce51000 + 372331
      4   libtypekitC4Release.dylib         0x000000010ceaa32b 0x10ce51000 + 365355
      5   libtypekitC4Release.dylib         0x000000010ce534a4 0x10ce51000 + 9380
      Thread 9:: UxTech Queue ThreadController
      Thread 10:: UxTech Queue ThreadController
      Thread 11:: UxTech Queue ThreadController
      Thread 12:: UxTech Queue ThreadController
      Thread 13:: UxTech Queue ThreadController
      Thread 14:: UxTech Queue ThreadController
      Thread 15:: UxTech Queue ThreadController
      Thread 16:
      2   com.adobe.InDesign.AppFramework    0x000000011bec2a01 0x11bd8b000 + 1276417
      3   com.adobe.InDesign.AppFramework    0x000000011bec1ed8 0x11bd8b000 + 1273560
      4   com.adobe.InDesign.AppFramework    0x000000011bebf270 0x11bd8b000 + 1262192
      5   com.adobe.InDesign.AppFramework    0x000000011bec38b2 0x11bd8b000 + 1280178
      6   com.adobe.boost_threads.framework    0x000000010b1298d4 boost::thread::start_thread_noexcept() + 388
      Thread 17:
      Thread 18:
      0   libsystem_kernel.dylib            0x00007fff9a48810a __semwait_signal + 10
      1   libsystem_c.dylib                 0x00007fff8c796d0f nanosleep + 199
      2   com.adobe.InDesign.Support for JavaScript    0x0000000122b19658 0x122abf000 + 370264
      3   com.adobe.InDesign.Support for JavaScript    0x0000000122afeeac 0x122abf000 + 261804
      4   com.adobe.InDesign.Support for JavaScript    0x0000000122b19135 0x122abf000 + 368949
      5   libsystem_pthread.dylib           0x00007fff95c3199d _pthread_body + 131
      6   libsystem_pthread.dylib           0x00007fff95c3191a _pthread_start + 168
      7   libsystem_pthread.dylib           0x00007fff95c2f351 thread_start + 13
      Thread 19:
      5   com.apple.Foundation              0x00007fff93050075 -[NSConnection run] + 149
      Thread 20:
      5   com.apple.Foundation              0x00007fff92fe1d99 -[NSConcreteTask waitUntilExit] + 205
      6   com.adobe.PlugPlugOwl             0x000000010cb9fd12 0x10caf4000 + 703762
      7   com.apple.Foundation              0x00007fff92f48e64 __NSThread__start__ + 1351
      8   libsystem_pthread.dylib           0x00007fff95c3199d _pthread_body + 131
      9   libsystem_pthread.dylib           0x00007fff95c3191a _pthread_start + 168
      10  libsystem_pthread.dylib           0x00007fff95c2f351 thread_start + 13
      Thread 21:
      Thread 22:: MPSupport Worker
      2   MultiProcessor Support            0x000000012aef294b 0x12aeab000 + 293195
      3   MultiProcessor Support            0x000000012aef284b 0x12aeab000 + 292939
      4   MultiProcessor Support            0x000000012af12d84 0x12aeab000 + 425348
      Thread 23:: MPSupport Worker
      Thread 24:: MPSupport Worker
      Thread 25:: MPSupport Worker
      Thread 26:: MPSupport Worker
      Thread 27:: MPSupport Worker
      Thread 28:: MPSupport Worker
      Thread 29:
      0   libsystem_kernel.dylib            0x00007fff9a481fae semaphore_wait_trap + 10
      1   libtbb.dylib                      0x000000010cfbde16 tbb::internal::concurrent_queue_base_v3::internal_pop(void*) + 598
      2   com.adobe.InDesign.Layout UI      0x000000011ec0b0f9 0x11eafe000 + 1102073
      3   com.adobe.boost_threads.framework    0x000000010b1298d4 boost::thread::start_thread_noexcept() + 388
      Thread 30:
      Thread 31:
      Thread 32:: UxTech Queue ThreadController
      Thread 33:: UxTech Queue ThreadController
      Thread 34:: UxTech Queue ThreadController
      Thread 35:: UxTech Queue ThreadController
      Thread 36:: UxTech Queue ThreadController
      Thread 37:: UxTech Queue ThreadController
      Thread 38:: UxTech Queue ThreadController
      Thread 39:: UxTech Queue ThreadController
      Thread 40:
      3   com.adobe.InDesign.AppFramework    0x000000011bec1e30 0x11bd8b000 + 1273392
      Thread 41:
      Thread 42:
      Thread 43:: com.apple.NSEventThread
      5   com.apple.AppKit                  0x00007fff98a60d95 _NSEventThread + 149
      Thread 44:
      Thread 45:
      Thread 46:
      Thread 47:
      Thread 48:
      0   libsystem_kernel.dylib            0x00007fff9a4885e2 __workq_kernreturn + 10
      1   libsystem_pthread.dylib           0x00007fff95c31578 _pthread_wqthread + 1283
      2   libsystem_pthread.dylib           0x00007fff95c2f341 start_wqthread + 13
      Thread 49:
      Thread 50:
      Thread 51:
      Thread 52:
      Thread 53:
      Thread 54:
      Thread 55:
      Thread 56:
      Thread 0 crashed with X86 Thread State (64-bit):
        rax: 0x0000000000000000  rbx: 0x00007f904677c6c8  rcx: 0x00007f9038cf8d70  rdx: 0x0000000000000100
        rdi: 0x00007fff55ed3240  rsi: 0x00000000ffffffff  rbp: 0x00007fff55ed3440  rsp: 0x00007fff55ed31b0
         r8: 0x0000000000000208   r9: 0x0000000000000166  r10: 0x000000010b5fdd01  r11: 0x000000010b2c7f20
        r12: 0x00007f904677c6a0  r13: 0x0000000000000000  r14: 0x0000000000000000  r15: 0x00007f9046dc6ec0
        rip: 0x000000011e1cb0ed  rfl: 0x0000000000010202  cr2: 0x0000000000000000
      Logical CPU:     0
      Error Code:      0x00000004
      Trap Number:     14
      Binary Images:
             0x109d29000 -        0x109d2dffe +com.adobe.InDesign (11.0.0.72 - 11000) <902BE96D-62DD-3707-9C82-E6206BB08FA2> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015
             0x109d37000 -        0x109d37ff7 +com.adobe.InDesign.InDesignModelAndUI (9.0 - 0) <FB61F9A6-DE48-3A5E-A074-B023C1686C20> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/InDesignModelAndUI.framework/Versions/A/InDesignModelAndUI
             0x109d42000 -        0x109d48fff +com.adobe.coretech.adobesplashkit (AdobeSplashKit Version 1.0 - 1.0) <F988DF04-5A94-3960-81C2-217D3A0051D8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSplashKit.framework/Versions/A/AdobeSplashKit
             0x109d54000 -        0x109d5effd +ASLSupportLib.dylib (0) <E212D47A-07C8-31E6-A790-413B0646F302> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/ASLSupportLib.dylib
             0x109d6a000 -        0x109e5bff0 +DV_WidgetBinLib.dylib (0) <BDC09A7C-3FDF-3F79-B3F3-B729CF3E5613> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/DV_WidgetBinLib.dylib
             0x109f84000 -        0x109fc4fff +TextPanelLib.dylib (0) <4C541531-FC63-3EC5-B7AB-25C88726E634> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/TextPanelLib.dylib
             0x109fe0000 -        0x10a123ff7 +WidgetBinLib.dylib (0) <F3AF96AF-DEA8-36EF-A7D4-08351F3F1B91> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/WidgetBinLib.dylib
             0x10a1de000 -        0x10a3daff7 +com.adobe.owl (AdobeOwl version 5.2.6 - 5.2.6) <DE167205-9D3F-3375-A6D0-A21C4017C43A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
             0x10a426000 -        0x10a6cfff7 +com.adobe.dvacore.framework (8.0.849323 - 8.0.849323.0) <545690D9-D86F-3829-ACA9-1F5CBE1CD1B1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
             0x10a7a6000 -        0x10ad1aff7 +com.adobe.dvaui.framework (8.0.849323 - 8.0.849323.0) <B5D118CA-1F2E-3A9F-9FAF-50968338125C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
             0x10b11d000 -        0x10b11dff7 +com.adobe.InDesign.InDesignModel (9.0 - 0) <A9C36234-F5A9-30E4-8C8F-6FAD52ED3FA3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/InDesignModel.framework/Versions/A/InDesignModel
             0x10b128000 -        0x10b136ff7 +com.adobe.boost_threads.framework (8.0.849323 - 8.0.849323.0) <EBAAC8B1-42F3-3374-B2F4-3C5EEF8B81D6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
             0x10b14c000 -        0x10b14dff7 +com.adobe.boost_system.framework (8.0.849323 - 8.0.849323.0) <87DE3714-5B63-36F8-9C80-A6D1708AD4FC> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
             0x10b156000 -        0x10b15bff7 +com.adobe.boost_date_time.framework (8.0.849323 - 8.0.849323.0) <F009B658-6063-3989-A418-04C79A3C6F69> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
             0x10b16d000 -        0x10b59aff1 +PublicLib.dylib (0) <3108F934-693A-306E-A2C1-FD5DE2E1195E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/PublicLib.dylib
             0x10b6ec000 -        0x10b6f5ff7 +PMRuntime.dylib (0) <B473E542-1734-38D7-9ADA-EB0866E96E4B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/PMRuntime.dylib
             0x10b701000 -        0x10b712ff7 +com.adobe.AFL (AdobeAFL 2.0.0 - 2.0) <A59C27D7-65E2-30DB-BE0B-BF723FA796BD> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAFL.framework/Versions/A/AdobeAFL
             0x10b721000 -        0x10b722ffe +com.adobe.InDesign.Metadata Database Filter (11.0.0.72 - 0) <E4128E3B-04B9-3A72-970B-ECEC5E678197> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Metadata Database Filter.InDesignPlugin/Metadata Database Filter
             0x10b727000 -        0x10ba4cfff +com.adobe.CoolType (AdobeCoolType 5.15.00.34494 - 5.15.00.34494) <83E40C9D-DD09-3FEF-B984-AB834D72C32A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
             0x10ba94000 -        0x10bab3fff +com.adobe.BIB (AdobeBIB 1.2.03.34494 - 1.2.03.34494) <644F8DE0-3E61-374D-B17D-44ED3BD10D60> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
             0x10bac1000 -        0x10bc0fff7 +com.adobe.ACE (AdobeACE 2.20.02.34494 - 2.20.02.34494) <DCD064B8-A43A-3D41-B499-15E602F69CDA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
             0x10bc25000 -        0x10c208ff7 +com.adobe.AGM (AdobeAGM 4.30.51.34494 - 4.30.51.34494) <FFAB6016-0486-359D-A1FA-869928FDBA02> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
             0x10c2aa000 -        0x10c2e7ff7 +com.adobe.ARE (AdobeARE 1.5.02.34494 - 1.5.02.34494) <3623F0E2-8311-359D-98E8-7EB1A2FFF181> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
             0x10c2ef000 -        0x10c2f0ff6 +com.adobe.InDesign.Global Preferences Panel (11.0.0.72 - 0) <9F993B33-64F2-311A-A489-02183FB5C38F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Global Preferences Panel.InDesignPlugin/Global Preferences Panel
             0x10c2f6000 -        0x10c31cff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <3318FE3E-8AB8-3821-A1FB-8A8D62C20303> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
             0x10c329000 -        0x10c6e0fff +com.adobe.MPS (AdobeMPS 5.8.1.34307 - 5.8.1.34307) <CD7908A7-8CB5-3AA3-8AE7-87C7F20D282D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
             0x10c754000 -        0x10c77afff +com.adobe.dvaflashview.framework (8.0.849323 - 8.0.849323.0) <212D72A3-4C74-3673-B69E-86CCFD98F363> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
             0x10c797000 -        0x10c79bff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
             0x10c7a4000 -        0x10c876ff7 +com.adobe.exo.framework (8.0.849323 - 8.0.849323.0) <442B93C2-DF4A-36CE-8D2A-B296812E9998> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/exo.framework/Versions/A/exo
             0x10c93c000 -        0x10ca1eff7 +com.adobe.dvaworkspace.framework (8.0.849323 - 8.0.849323.0) <F00C89AF-7EE1-3EDF-94D8-94A75AC93000> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
             0x10caf4000 -        0x10cdefff7 +com.adobe.PlugPlugOwl (6.0.0.96 - 6.0.0.96) <10483D94-E469-33E1-BEF1-FCB4561041C8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
             0x10ce51000 -        0x10cf9cffe +libtypekitC4Release.dylib (0) <67B27521-6200-3B13-91E6-791F99557488> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/libtypekitC4Release.dylib
             0x10cfbc000 -        0x10cfecfef +libtbb.dylib (0) <D41FA1F0-4921-308A-93DF-4D16F8913472> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/libtbb.dylib
             0x10d00d000 -        0x10d032fff +libtbbmalloc.dylib (0) <60EF4F46-298B-38B6-A6CD-9B168072EAB7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/libtbbmalloc.dylib
             0x10d05e000 -        0x10dda3fff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
             0x10ddbd000 -        0x10def8fff +com.adobe.ICUInternationalization (4.0 - 3.61) <CEAE369B-B601-30D5-9563-6C2AB781AF27> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/ICUInternatio nalization
             0x10df51000 -        0x10e054ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
             0x10e090000 -        0x10e1c3fff +com.winsoft.wrservices (WRServices 10.0.0 - 10.0.0) <BDACB6B1-F867-3FB2-84F7-3020326D24CF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
             0x10e225000 -        0x10e326fff +com.adobe.amtlib (9.0.0.21 - 9.0.0.21) <BAE71CEB-B622-38DB-A0A2-796C0BEB4E03> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
             0x10e339000 -        0x10e33cfff +com.adobe.AdobeCrashReporter (7.1 - 7.1.4) <A33546D9-3E26-38A2-88FE-C7C46B4CD989> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
             0x10e347000 -        0x10e40fff7 +com.adobe.boost_regex.framework (8.0.849323 - 8.0.849323.0) <63917B23-C82F-3B2A-BE24-20FB0B7BC928> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
             0x10e48b000 -        0x10e521fff +com.adobe.adobe_caps (adobe_caps 9.0.0.5 - 9.0.0.5) <71BDFB88-91D4-35B1-9860-82F31ACBDE38> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
             0x10e534000 -        0x10e540ff7 +com.adobe.boost_signals.framework (8.0.849323 - 8.0.849323.0) <10D19241-C273-3F9B-AC55-233D74206BF1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
             0x10e556000 -        0x10e69efff +com.adobe.AIDE (1.5.0 - 1.5.0.34359) <A2CAF6C5-8C39-3019-9899-7C966BD74F5F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
             0x10e714000 -        0x10e7bdff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
             0x10e7e2000 -        0x10e811fff +VulcanControl.dylib (5.1.0.47 - 5.1.0.47 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <95291F3A-89F6-33FB-B231-920C4A646676> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/VulcanControl.dylib
             0x10e826000 -        0x10e86eff7 +VulcanMessage5.dylib (5.1.0.47 - 5.1.0.47 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <68F20709-5A9C-3360-9517-A6AA2493CB47> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/VulcanMessage5.dylib
             0x10e88a000 -        0x10e8e2ffc +DataBaseLib.dylib (0) <042BCEE6-62F6-3575-962B-D68096EBAE6B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/DataBaseLib.dylib
             0x10e8f6000 -        0x10e953ff7 +ObjectModelLib.dylib (0) <4C0C473E-09CF-369E-B634-C02736B71CE6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/ObjectModelLib.dylib
             0x10e96e000 -        0x10e992ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.34320 - 3.8.0.34320) <674F1792-D790-3E12-8C0F-85CAF9D848B1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
             0x11370e000 -        0x11374eff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 9.0.0.3 - 9.0.0.3) <2F5B40E6-812C-34E0-A8AC-02F55D770D49> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotificatio ns
             0x113f12000 -        0x113f17ff7 +com.adobe.InDesign.Data Services UI (11.0.0.72 - 0) <9262186D-E075-36C5-B827-A3016012FF27> /Applications/Adobe InDesign CC 2015/*/Data Services UI
             0x113f1f000 -        0x113f25ff4 +com.adobe.InDesign.Data Services (11.0.0.72 - 0) <B07286D0-7F16-36E1-B3EC-1C51597828D1> /Applications/Adobe InDesign CC 2015/*/Data Services
             0x113f2b000 -        0x113f36ff0 +com.adobe.InDesign.DTTransform (11.0.0.72 - 0) <907FE07B-72F1-34C5-BE6C-98A40BE44B71> /Applications/Adobe InDesign CC 2015/*/DTTransform
             0x113f3f000 -        0x113f75ff6 +com.adobe.InDesign.Dictionary Editor Dialog (11.0.0.72 - 0) <BB3584D6-67B4-32F8-87A0-8596201B4629> /Applications/Adobe InDesign CC 2015/*/Dictionary Editor Dialog
             0x113f95000 -        0x113fb8fff +com.adobe.InDesign.LILO (11.0.0.72 - 0) <8C4CBAC8-DB1D-325A-B351-63291D9EA788> /Applications/Adobe InDesign CC 2015/*/LILO
             0x113fc6000 -        0x113fdaff2 +com.adobe.InDesign.EasyCatalog File Data Provider UI (11.0.1 Build 20150617[10300] Copyright 2003-2015 65bit Software Ltd. All Rights Reserved. - 0) <EF206274-3673-33AD-9DA0-0113E0BA90FC> /Applications/Adobe InDesign CC 2015/*/EasyCatalog File Data Provider UI
             0x113ffb000 -        0x11402affa +com.adobe.InDesign.EasyCatalog File Data Provider (11.0.1 Build 20150617[10300] Copyright 2003-2015 65bit Software Ltd. All Rights Reserved. - 0) <667A407E-BCDF-3702-A10B-D99A298F5061> /Applications/Adobe InDesign CC 2015/*/EasyCatalog File Data Provider
             0x114084000 -        0x11408cff4 +com.adobe.InDesign.PNG Import Filter UI (11.0.0.72 - 0) <7865D087-8235-3D93-A013-61E9AE4CD1A6> /Applications/Adobe InDesign CC 2015/*/PNG Import Filter UI
             0x114094000 -        0x114096ffe +com.adobe.InDesign.SimpleTextImportFilter (11.0.0.72 - 0) <1B37191F-E611-3CA8-87D5-BF3055CC6863> /Applications/Adobe InDesign CC 2015/*/SimpleTextImportFilter
             0x11409c000 -        0x1140a2ff1 +com.adobe.InDesign.JPEG Export UI (11.0.0.72 - 0) <F7343854-389F-3E7C-AB7F-199E85FF33C5> /Applications/Adobe InDesign CC 2015/*/JPEG Export UI
             0x1140aa000 -        0x1140acff7  com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
             0x1142f2000 -        0x1143d9fff +com.adobe.linguistic.LinguisticManager (9.0.0 - 21429) <7C403E13-460B-3576-B7BB-E2A88287B15D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
             0x1143f6000 -        0x1151fbfff +LibXL (0) <51651AE8-94E3-4C72-58DB-2CF4D46347CD> /Applications/Adobe InDesign CC 2015/*/LibXL.framework/LibXL
             0x115a40000 -        0x115be6ff4 +com.adobe.InDesign.EasyCatalog UI (11.0.1 Build 20150617[10300] Copyright 2003-2015 65bit Software Ltd. All Rights Reserved. - 0) <1AA49417-380C-3302-84F0-15E77FE14096> /Applications/Adobe InDesign CC 2015/*/EasyCatalog UI
             0x115dc8000 -        0x1164cefff +com.adobe.InDesign.EasyCatalog (11.0.1 Build 20150617[10300] Copyright 2003-2015 65bit Software Ltd. All Rights Reserved. - 0) <42D5BFEE-8BF6-31C0-901E-F84F33A6DE32> /Applications/Adobe InDesign CC 2015/*/EasyCatalog
             0x116e1f000 -        0x11705fffa +com.adobe.InDesign.EBookExport (11.0.0.72 - 0) <C3900B93-5532-3D92-9633-F5E761C012B2> /Applications/Adobe InDesign CC 2015/*/EBookExport
             0x117092000 -        0x1170ddff7 +com.adobe.InDesign.Media Import Filter (11.0.0.72 - 0) <45761337-6CBA-3075-8850-1F3502DE1C0A> /Applications/Adobe InDesign CC 2015/*/Media Import Filter
             0x1170f0000 -        0x117114ff4 +com.adobe.InDesign.Sangam Preferences UI (11.0.0.72 - 0) <64B3D31C-E307-368E-B47D-910DCF5E53D3> /Applications/Adobe InDesign CC 2015/*/Sangam Preferences UI
             0x117127000 -        0x1171a0ff7 +com.adobe.AdobeSangam (AdobeSangam 5.65.0.34575 - 5.65.0.34575) <A06D5A9E-FB78-38A7-B6F6-13511E389A31> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSangam.framework/Versions/A/AdobeSangam
             0x1171f0000 -        0x11734cff6 +com.adobe.InDesign.SangamServicer-Mapper (11.0.0.72 - 0) <0DBC0DF2-C5EA-3DCD-90AC-9E971C159368> /Applications/Adobe InDesign CC 2015/*/SangamServicer-Mapper
             0x11737b000 -        0x117390ff3 +com.adobe.InDesign.SaveBack (11.0.0.72 - 0) <7C2465DE-530E-3202-9A4E-BE948D735619> /Applications/Adobe InDesign CC 2015/*/SaveBack
             0x11739e000 -        0x117429ff9 +com.adobe.InDesign.Tagged Text Attributes (11.0.0.72 - 0) <2CC31F7B-D3B1-3E2D-8A1F-46D12E3377D4> /Applications/Adobe InDesign CC 2015/*/Tagged Text Attributes
             0x117458000 -        0x117461ff6 +com.adobe.InDesign.Tagged Text Filters UI (11.0.0.72 - 0) <746A9030-E937-3708-AB3D-B3A985FE9971> /Applications/Adobe InDesign CC 2015/*/Tagged Text Filters UI
             0x11746b000 -        0x117508ff2 +com.adobe.InDesign.Tagged Text Filters (11.0.0.72 - 0) <7C147A5F-2272-3AA8-B001-165D31AABACE> /Applications/Adobe InDesign CC 2015/*/Tagged Text Filters
             0x11751c000 -        0x117750ff7 +com.extensis.AutoActivationPlugin.ID10 (6.0.2.639239 - 6.0.2.639239) <12B0D7FB-F071-3776-939B-A6243C639733> /Applications/Adobe InDesign CC 2015/*/ExtensisFontManagementIDCC2015
             0x1178fc000 -        0x11819fff7 +com.extensis.FontManagement.plugin-interface (6.0.2.638877 - 638877) <F3F35265-404C-34E4-88D7-2E08A14FAA18> /Applications/Universal Type Client.app/Contents/Resources/ExtensisPluginInterface.framework/ExtensisPluginInterface
             0x118392000 -        0x11839cff3 +com.adobe.InDesign.Clipping Path Dialog (11.0.0.72 - 0) <B381B439-A3A5-3953-9D2B-14C95B686678> /Applications/Adobe InDesign CC 2015/*/Clipping Path Dialog
             0x1183ac000 -        0x1183ebff9 +com.adobe.InDesign.Color Management UI (11.0.0.72 - 0) <1313C8E8-AF93-39C2-8AA5-A5265EE4BF08> /Applications/Adobe InDesign CC 2015/*/Color Management UI
             0x1183fa000 -        0x11846effb +com.adobe.InDesign.Color Picker Panel (11.0.0.72 - 0) <593F3335-7882-3BE6-AABC-C312456751AC> /Applications/Adobe InDesign CC 2015/*/Color Picker Panel
             0x118495000 -        0x1184a0fff +com.adobe.InDesign.Digital Publishing UI (11.0.0.1 - 0) <0F9DDE23-6152-3D12-BCD7-0CADCFB6F0AD> /Applications/Adobe InDesign CC 2015/*/Digital Publishing UI
             0x1184b2000 -        0x1184c0fff +com.adobe.boost_filesystem.framework (8.0.849323 - 8.0.849323.0) <3D20399B-8243-3387-99CA-8E923498B8C5> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
             0x1184cd000 -        0x118544ff0 +com.adobe.InDesign.DynamicDocumentsUI (11.0.0.72 - 0) <7C453EAD-78C1-3BEC-B265-70B0FBC4502C> /Applications/Adobe InDesign CC 2015/*/DynamicDocumentsUI
             0x11856a000 -        0x118582ff7 +com.adobe.InDesign.EPS UI (11.0.0.72 - 0) <C6118E48-0C96-3A7D-BC5C-487E0853F9CC> /Applications/Adobe InDesign CC 2015/*/EPS UI
             0x118592000 -        0x11859aff4 +com.adobe.InDesign.Generic Style Editor (11.0.0.72 - 0) <136BE8D8-1CF8-35F2-AEFA-5321F333BF36> /Applications/Adobe InDesign CC 2015/*/Generic Style Editor
             0x1185a7000 -        0x1185daffb +com.adobe.InDesign.Gradient Panel (11.0.0.72 - 0) <9D54AD05-2367-360A-9056-0BC28BF2E138> /Applications/Adobe InDesign CC 2015/*/Gradient Panel
             0x1185f0000 -        0x118696ffb +com.adobe.InDesign.Graphic Panels (11.0.0.72 - 0) <7EB972D3-BCFC-3C17-9C20-6E396BE56984> /Applications/Adobe InDesign CC 2015/*/Graphic Panels
             0x1186bf000 -        0x1186d6ff7 +com.adobe.InDesign.JPEG Export (11.0.0.72 - 0) <5B4D6628-033F-30F7-BB44-589E5FDBF8C5> /Applications/Adobe InDesign CC 2015/*/JPEG Export
             0x1186e7000 -        0x118731ff3 +com.adobe.InDesign.Output Preview (11.0.0.72 - 0) <5BD80201-86F5-3B1E-8789-28CD66003549> /Applications/Adobe InDesign CC 2015/*/Output Preview
             0x11874a000 -        0x11875eff4 +com.adobe.InDesign.OutputMiscUI (11.0.0.72 - 0) <3F570B59-D710-3AD7-A7C6-37EDB913D303> /Applications/Adobe InDesign CC 2015/*/OutputMiscUI
             0x11876f000 -        0x1187e5ffb +com.adobe.InDesign.PDF UI (11.0.0.72 - 0) <C76BF747-5795-347C-8FD7-F5C2F115EF81> /Applications/Adobe InDesign CC 2015/*/PDF UI
             0x118808000 -        0x118926fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 67 - 79.157747) <E20FA9C9-CEFC-3D6F-A1F8-E6D6629151CE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
             0x11896c000 -        0x11897fff8 +com.adobe.InDesign.Printer Styles (11.0.0.72 - 0) <B21E6A4A-6A56-35B4-9913-F347B5DB8AF2> /Applications/Adobe InDesign CC 2015/*/Printer Styles
             0x11898d000 -        0x118a5dffb +com.adobe.InDesign.PrintUI (11.0.0.72 - 0) <1E4387F1-941A-39DF-A039-89352EAE98C9> /Applications/Adobe InDesign CC 2015/*/PrintUI
             0x118a87000 -        0x118a96ff8 +com.adobe.InDesign.PS Import UI (11.0.0.72 - 0) <33F2213D-54FD-3A6D-85DE-50F4E6D91232> /Applications/Adobe InDesign CC 2015/*/PS Import UI
             0x118aa4000 -        0x118ac5ffc +com.adobe.InDesign.Swatch Library Panel (11.0.0.72 - 0) <6BE96B7C-2191-3220-8F89-315082A74BC1> /Applications/Adobe InDesign CC 2015/*/Swatch Library Panel
             0x118ad3000 -        0x118ba2ff5 +com.adobe.InDesign.Swatches Panel (11.0.0.72 - 0) <BC869E6A-C547-3BE6-BBCF-916ABE214F16> /Applications/Adobe InDesign CC 2015/*/Swatches Panel
             0x118bd9000 -        0x118c74ffb +com.adobe.InDesign.Transparency UI (11.0.0.72 - 0) <A651F6B0-0301-37FA-A677-EEBC7E0FAA92> /Applications/Adobe InDesign CC 2015/*/Transparency UI
             0x118ca6000 -        0x118d01ff9 +com.adobe.InDesign.Assignment UI (11.0.0.72 - 0) <9C03C4E0-FB00-30AC-AD88-C3B42BE31496> /Applications/Adobe InDesign CC 2015/*/Assignment UI
             0x118d22000 -        0x118d41ff0 +com.adobe.InDesign.InCopy Bridge UI (11.0.0.72 - 0) <B39498F0-4B14-36EA-A4AF-0351EAEDFD42> /Applications/Adobe InDesign CC 2015/*/InCopy Bridge UI
             0x118d4d000 -        0x118d85ffa +com.adobe.InDesign.InCopy Bridge (11.0.0.72 - 0) <D6614C50-D753-36D4-A773-AB9ED00D515B> /Applications/Adobe InDesign CC 2015/*/InCopy Bridge
             0x118d95000 -        0x118d9cff8 +com.adobe.InDesign.InCopyExport (11.0.0.72 - 0) <390FA732-55AD-3F1B-9E08-B610E43D9940> /Applications/Adobe InDesign CC 2015/*/InCopyExport
             0x118da5000 -        0x118daaffe +com.adobe.InDesign.InCopyExportUI (11.0.0.72 - 0) <BF7D6B89-1D11-3FDD-BE57-2B1BF199BB09> /Applications/Adobe InDesign CC 2015/*/InCopyExportUI
             0x118db1000 -        0x118db7ff3 +com.adobe.InDesign.InCopyImport (11.0.0.72 - 0) <A0D42192-714D-32FE-9831-16B13985C322> /Applications/Adobe InDesign CC 2015/*/InCopyImport
             0x118dbe000 -        0x118dc3ff1 +com.adobe.InDesign.InCopyWorkflow UI (11.0.0.72 - 0) <D0BC0F3B-257F-3D37-8B0B-18E5C2903696> /Applications/Adobe InDesign CC 2015/*/InCopyWorkflow UI
             0x118dcc000 -        0x118e1dff6 +com.adobe.InDesign.Note (11.0.0.72 - 0) <65FB7DBE-8B2F-3DDC-8535-2340558FC9DB> /Applications/Adobe InDesign CC 2015/*/Note
             0x118e3c000 -        0x118e44ff5 +com.adobe.InDesign.NotePref (11.0.0.72 - 0) <46FAA1C2-256B-39F5-A60E-2B6B8EAF898C> /Applications/Adobe InDesign CC 2015/*/NotePref
             0x118e51000 -        0x118e54ffe +com.adobe.InDesign.Username UI (11.0.0.72 - 0) <3EB2CFF1-8B7E-344D-91EB-DF69AA730AF3> /Applications/Adobe InDesign CC 2015/*/Username UI
             0x118e5c000 -        0x118ee9ff3 +com.adobe.InDesign.ButtonUI (11.0.0.72 - 0) <DECF1FF1-A1CE-30F4-BC8D-B1002FA9E6A4> /Applications/Adobe InDesign CC 2015/*/ButtonUI
             0x118f17000 -        0x118f3affa +com.adobe.InDesign.MediaUI (11.0.0.72 - 0) <8704E7E5-45C5-3723-B70D-6708B2CB6797> /Applications/Adobe InDesign CC 2015/*/MediaUI
             0x118f4e000 -        0x118f5aff1 +com.adobe.InDesign.Alignment Panel (11.0.0.72 - 0) <A05B7FAB-03B0-3A98-BF3F-6E5E0C5C5880> /Applications/Adobe InDesign CC 2015/*/Alignment Panel
             0x118f62000 -        0x118fa9ff8 +com.adobe.InDesign.Asset Library Panel (11.0.0.72 - 0) <A0D4BD54-9539-32A0-AEF8-B004A84DF262> /Applications/Adobe InDesign CC 2015/*/Asset Library Panel
             0x118fce000 -        0x11902fffc +com.adobe.InDesign.Asset PubLibrary (11.0.0.72 - 0) <0DEEAF3B-BD4C-36E1-ADAA-AA80DBFC3916> /Applications/Adobe InDesign CC 2015/*/Asset PubLibrary
             0x11904d000 -        0x119094ff8 +com.adobe.InDesign.Book Panel (11.0.0.72 - 0) <8DAC1E54-638B-3232-A32C-1E975F9ED1F1> /Applications/Adobe InDesign CC 2015/*/Book Panel
             0x1190b6000 -        0x1190cdfff +com.adobe.InDesign.Bookmark Panel (11.0.0.72 - 0) <84E74197-C4DE-3A8D-B89C-7676185EEA62> /Applications/Adobe InDesign CC 2015/*/Bookmark Panel
             0x1190e2000 -        0x119111ff3 +com.adobe.InDesign.ContentDropper Tool (11.0.0.72 - 0) <6446C088-ADCE-39BE-AF32-13FE1E4353D7> /Applications/Adobe InDesign CC 2015/*/ContentDropper Tool
             0x11912f000 -        0x119168ff7 +com.adobe.InDesign.Control Panel (11.0.0.72 - 0) <50FD32C6-D906-3C51-A7F2-357CECE3DB86> /Applications/Adobe InDesign CC 2015/*/Control Panel
             0x119183000 -        0x11918bffb +com.adobe.InDesign.Create Guides Dialog (11.0.0.72 - 0) <1E5AF1C1-3312-3F07-AE9E-20957A030BF8> /Applications/Adobe InDesign CC 2015/*/Create Guides Dialog
             0x119194000 -        0x119219fff +com.adobe.InDesign.Eyedropper Tool (11.0.0.72 - 0) <47A1A146-60ED-3B79-B656-C9CBFBBFE857> /Applications/Adobe InDesign CC 2015/*/Eyedropper Tool
             0x11923d000 -        0x1192d9ff0 +com.adobe.InDesign.Hyperlinks Panel (11.0.0.72 - 0) <A9FA4E5F-DABB-31D6-99BC-1FD33BCCF00C> /Applications/Adobe InDesign CC 2015/*/Hyperlinks Panel
             0x119302000 -        0x119389ff4 +com.adobe.InDesign.Index Panel (11.0.0.72 - 0) <16B5C862-FF98-350A-B1FC-0868FC1A2ACE> /Applications/Adobe InDesign CC 2015/*/Index Panel
             0x1193a7000 -        0x1193b3ff7  com.apple.carbonframeworktemplate (1.0 - 1.0) <6F5D8218-7BB8-378F-A9EA-EF46B665DC63> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/unihan.framework/Versions/A/unihan
             0x1193be000 -        0x11941afff +com.adobe.InDesign.Info Panel (11.0.0.72 - 0) <68CC319D-3D4C-3F8E-A301-A4603B389D0C> /Applications/Adobe InDesign CC 2015/*/Info Panel
             0x119431000 -        0x1194deffc +com.adobe.InDesign.Knowledge Base (11.0.0.72 - 0) <111747F0-F814-3337-A90E-745D20B20BF4> /Applications/Adobe InDesign CC 2015/*/Knowledge Base
             0x1194e8000 -        0x119531ff0 +com.adobe.InDesign.Layers Panel (11.0.0.72 - 0) <94BBEE02-953F-3D34-9506-DD06417BF6BB> /Applications/Adobe InDesign CC 2015/*/Layers Panel
             0x119551000 -        0x119553ffa +com.adobe.InDesign.Layout Adjustment Panel (11.0.0.72 - 0) <652F7EDE-CD52-3543-808D-E7A87FBD11C7> /Applications/Adobe InDesign CC 2015/*/Layout Adjustment Panel
             0x11955b000 -        0x119576ffc +com.adobe.InDesign.Layout Adjustment (11.0.0.72 - 0) <E59F1011-B274-3F6E-94EC-6095A5895BB0> /Applications/Adobe InDesign CC 2015/*/Layout Adjustment
             0x119584000 -        0x1195c9ff4 +com.adobe.InDesign.Links UI (11.0.0.72 - 0) <8F11F04C-D588-3F64-9D95-4BD62C693646> /Applications/Adobe InDesign CC 2015/*/Links UI
             0x1195e9000 -        0x119682ff2 +com.adobe.InDesign.ObjectStylesUI (11.0.0.72 - 0) <FD9605C8-A203-3E51-8B7C-810735C06132> /Applications/Adobe InDesign CC 2015/*/ObjectStylesUI
             0x1196b0000 -        0x1196d5ff4 +com.adobe.InDesign.Page Setup Dialog (11.0.0.72 - 0) <1EE15992-D013-3996-94AD-4F9E2C7C1086> /Applications/Adobe InDesign CC 2015/*/Page Setup Dialog
             0x1196e1000 -        0x11979dffa +com.adobe.InDesign.Pages Panel (11.0.0.72 - 0) <ABDAFA1E-F89F-3574-A6DB-5FDA9E8539B7> /Applications/Adobe InDesign CC 2015/*/Pages Panel
             0x1197cd000 -        0x1197d8ff6 +com.adobe.InDesign.Sections UI (11.0.0.72 - 0) <CAF08BF7-324B-3AC5-97EC-C562F251678B> /Applications/Adobe InDesign CC 2015/*/Sections UI
             0x1197e1000 -        0x1197e9ffc +com.adobe.InDesign.StepRepeat (11.0.0.72 - 0) <79C88226-E5CF-38F3-AF2E-8C7B89782964> /Applications/Adobe InDesign CC 2015/*/StepRepeat
             0x1197f3000 -        0x11982cff3 +com.adobe.InDesign.Text Wrap Panel (11.0.0.72 - 0) <D25B6D20-48B7-306B-B224-AB9E22BC0605> /Applications/Adobe InDesign CC 2015/*/Text Wrap Panel
             0x119843000 -        0x11987fffe +com.adobe.InDesign.TOC UI Dialog (11.0.0.72 - 0) <E7B6CC83-4444-3EEF-ADA0-D3F630EEF5D5> /Applications/Adobe InDesign CC 2015/*/TOC UI Dialog
             0x119897000 -        0x1198ccffe +com.adobe.InDesign.Transform Panel (11.0.0.72 - 0) <F205DC10-F310-3EA9-8F0D-751D689B8674> /Applications/Adobe InDesign CC 2015/*/Transform Panel
             0x1198e0000 -        0x1198f7ffc +com.adobe.InDesign.Image Import UI (11.0.0.72 - 0) <867AD080-D8A7-394B-A2DF-4BD74B66A0A4> /Applications/Adobe InDesign CC 2015/*/Image Import UI
             0x119908000 -        0x11991affa +com.adobe.InDesign.Scotch Rules (11.0.0.72 - 0) <5955BAC7-39E3-31D7-9B03-051BB3316C73> /Applications/Adobe InDesign CC 2015/*/Scotch Rules
             0x119925000 -        0x11997fffe +com.adobe.InDesign.BNUI (11.0.0.72 - 0) <E35106D8-2908-37E9-A84C-6E4AE596B519> /Applications/Adobe InDesign CC 2015/*/BNUI
             0x11999d000 -        0x119a3fff0 +com.adobe.InDesign.DataMerge (11.0.0.72 - 0) <B930A604-F0B0-3EEF-A9E4-86C9D0F9F8AB> /Applications/Adobe InDesign CC 2015/*/DataMerge
             0x119a5f000 -        0x119a8fff1 +com.adobe.InDesign.DataMergeUI (11.0.0.72 - 0) <A7EAE645-C379-3487-8600-C9E866686808> /Applications/Adobe InDesign CC 2015/*/DataMergeUI
             0x119aa9000 -        0x119ba1ffb +com.adobe.InDesign.Package and Preflight UI (11.0.0.72 - 0) <EC7FAB88-1C8C-310F-BC35-1E974CE3364D> /Applications/Adobe InDesign CC 2015/*/Package and Preflight UI
             0x119be0000 -        0x119e1fff1 +com.adobe.InDesign.Package and Preflight (11.0.0.72 - 0) <9A4C0B7F-4163-3239-9352-310A99EC7270> /Applications/Adobe InDesign CC 2015/*/Package and Preflight
             0x119e63000 -        0x119f33ffe +com.adobe.InDesign.JBX (11.0.0.72 - 0) <4C91F483-2A46-3713-9DBF-6831F8655A94> /Applications/Adobe InDesign CC 2015/*/JBX
             0x119f5d000 -        0x119f77ffb +com.adobe.InDesign.SavebackService (10.0.0 - 0) <4D2E9D2D-30CC-397C-8D87-5AA8DBA7150B> /Applications/Adobe InDesign CC 2015/*/SavebackService
             0x119f85000 -        0x119f89ff2 +com.adobe.InDesign.Script Label Panel (11.0.0.72 - 0) <12860D29-31C9-38C3-B035-A5A02B24F757> /Applications/Adobe InDesign CC 2015/*/Script Label Panel
             0x119f93000 -        0x119f9eff0 +com.adobe.InDesign.Scripts Panel (11.0.0.72 - 0) <CEC32465-A5F0-369B-9AB6-ACD7C545E72F> /Applications/Adobe InDesign CC 2015/*/Scripts Panel
             0x119fac000 -        0x119fe7ff4 +com.adobe.InDesign.SettingsInCloud (11.0.0.72 - 0) <7CCCC3FE-72B2-3089-951E-899AF27CC122> /Applications/Adobe InDesign CC 2015/*/SettingsInCloud
             0x119ffa000 -        0x11a0e4ffc +com.adobe.InDesign.Tables UI (11.0.0.72 - 0) <FD24D99E-21AA-3AA4-87FF-DCF64EF6527D> /Applications/Adobe InDesign CC 2015/*/Tables UI
             0x11a114000 -        0x11a1afffc +com.adobe.InDesign.TableStylesUI (11.0.0.72 - 0) <9D129556-4DDC-302A-A8E8-4B50A972FF27> /Applications/Adobe InDesign CC 2015/*/TableStylesUI
             0x11a1da000 -        0x11a258ffc +com.adobe.InDesign.Character Panel (11.0.0.72 - 0) <545326E0-936A-3F5C-815A-ADBA09A8E176> /Applications/Adobe InDesign CC 2015/*/Character Panel
             0x11a29d000 -        0x11a2c9ff4 +com.adobe.InDesign.Conditional Text UI (11.0.0.72 - 0) <067148F0-A550-3721-AF77-A1F3909FDC58> /Applications/Adobe InDesign CC 2015/*/Conditional Text UI
             0x11a2e3000 -        0x11a2fdff8 +com.adobe.InDesign.Create Outlines (11.0.0.72 - 0) <37926E4F-71DE-3030-B7E7-70B355ACA1CA> /Applications/Adobe InDesign CC 2015/*/Create Outlines
             0x11a30a000 -        0x11a41affa +com.adobe.InDesign.Find and Change Panel (11.0.0.72 - 0) <0B8A815E-F073-3C9C-902E-73B1276C0F5F> /Applications/Adobe InDesign CC 2015/*/Find and Change Panel
             0x11a456000 -        0x11a47affa +com.adobe.InDesign.Find Change Format Panel (11.0.0.72 - 0) <22340FDF-C98B-3348-B7BF-426E6266BBFD> /Applications/Adobe InDesign CC 2015/*/Find Change Format Panel
             0x11a48c000 -        0x11a4d2ff4 +com.adobe.InDesign.Font Usage Dialog (11.0.0.72 - 0) <9C86C604-117E-30AF-8A4E-4D207AA73EB6> /Applications/Adobe InDesign CC 2015/*/Font Usage Dialog
             0x11a4e9000 -        0x11a58bff4 +com.adobe.InDesign.Glyphs Panel (11.0.0.72 - 0) <98E8AFC5-4C3B-3B6A-A0C8-A45B85E765C2> /Applications/Adobe InDesign CC 2015/*/Glyphs Panel
             0x11a5ad000 -        0x11a5b4ff4 +com.adobe.InDesign.Hyphenation Panel (11.0.0.72 - 0) <D04F3822-8BE1-36C9-8519-2BED01BB103F> /Applications/Adobe InDesign CC 2015/*/Hyphenation Panel
             0x11a5c1000 -        0x11a5d1ff0 +com.adobe.InDesign.Indents and Tabs (11.0.0.72 - 0) <6527CCE2-91DF-3A21-9B45-560E50B7D49E> /Applications/Adobe InDesign CC 2015/*/Indents and Tabs
             0x11a5df000 -        0x11a5e5ff1 +com.adobe.InDesign.Justification Panel (11.0.0.72 - 0) <39141624-236D-3D47-93A5-909AA5F485C0> /Applications/Adobe InDesign CC 2015/*/Justification Panel
             0x11a5ef000 -        0x11a5f4ffb +com.adobe.InDesign.Keeps Panel (11.0.0.72 - 0) <D3586F8B-612B-3FB2-8CA2-448A34B51A38> /Applications/Adobe InDesign CC 2015/*/Keeps Panel
             0x11a5fc000 -        0x11a619ff1 +com.adobe.InDesign.Optical Kerning (11.0.0.72 - 0) <0BC5BC26-BE89-3AAC-9404-571F264ECE15> /Applications/Adobe InDesign CC 2015/*/Optical Kerning
             0x11a625000 -        0x11a65affc +com.adobe.InDesign.Paragraph Panel (11.0.0.72 - 0) <3586E5A6-16D4-3749-B8C6-2443DBFB3F76> /Applications/Adobe InDesign CC 2015/*/Paragraph Panel
             0x11a66f000 -        0x11a67eff3 +com.adobe.InDesign.Paragraph Rules Panel (11.0.0.72 - 0) <6BDCF9F6-2C7F-31F8-8565-8F5825C348C5> /Applications/Adobe InDesign CC 2015/*/Paragraph Rules Panel
             0x11a687000 -        0x11a69aff8 +com.adobe.InDesign.Path Type UI (11.0.0.72 - 0) <787841B4-A27C-3302-A127-9AC35CDA3C8C> /Applications/Adobe InDesign CC 2015/*/Path Type UI
             0x11a6a9000 -        0x11a6b1ffb +PathTypeLib.dylib (0) <02ABE533-5966-3126-8F57-07C8D9A9BFE4> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/PathTypeLib.dylib
             0x11a6b9000 -        0x11a6e0ff9 +com.adobe.InDesign.RunIn Styles Panel (11.0.0.72 - 0) <28DECD76-7FD2-3C9C-A905-FA77465F7AE1> /Applications/Adobe InDesign CC 2015/*/RunIn Styles Panel
             0x11a6f1000 -        0x11a6ffff1 +com.adobe.InDesign.SING (11.0.0.72 - 0) <5486350D-0BCD-3C4C-841E-5391F6471D49> /Applications/Adobe InDesign CC 2015/*/SING
             0x11a708000 -        0x11a70fffe +com.adobe.InDesign.Span Columns Panel (11.0.0.72 - 0) <F50860E0-A04B-30A9-BFBE-9E2AFEA96654> /Applications/Adobe InDesign CC 2015/*/Span Columns Panel
             0x11a717000 -        0x11a75eff4 +com.adobe.InDesign.Spelling Panel (11.0.0.72 - 0) <2586BA96-0C59-3ACD-8AD1-AA73D528ACAF> /Applications/Adobe InDesign CC 2015/*/Spelling Panel
             0x11a777000 -        0x11a787ffd +com.adobe.InDesign.Story Panel (11.0.0.72 - 0) <221F257E-E3F2-3BAE-9744-32BF52693918> /Applications/Adobe InDesign CC 2015/*/Story Panel
             0x11a794000 -        0x11a804ff1 +com.adobe.InDesign.Style Panel (11.0.0.72 - 0) <9049DA76-8EB0-3CE4-839F-8125216BA920> /Applications/Adobe InDesign CC 2015/*/Style Panel
             0x11a82c000 -        0x11a836ffa +com.adobe.InDesign.Text Color Panel (11.0.0.72 - 0) <4AD1728B-631C-34DC-9747-0CE5DE29B91A> /Applications/Adobe InDesign CC 2015/*/Text Color Panel
             0x11a83e000 -        0x11a866ff1 +com.adobe.InDesign.Text Frame Options (11.0.0.72 - 0) <FC5142AA-3767-3D40-910C-5600785DD767> /Applications/Adobe InDesign CC 2015/*/Text Frame Options
             0x11a876000 -        0x11a8cbff4 +com.adobe.InDesign.Text Panel (11.0.0.72 - 0) <2F6D2F6C-6C74-3FED-820B-E172AE225515> /Applications/Adobe InDesign CC 2015/*/Text Panel
             0x11a8f1000 -        0x11a90eff7 +com.adobe.InDesign.Text Preferences (11.0.0.72 - 0) <67B124AD-CC4A-3982-AF89-C4AD3ADD80A8> /Applications/Adobe InDesign CC 2015/*/Text Preferences
             0x11a91d000 -        0x11a93cff0 +com.adobe.InDesign.Text Ruler (11.0.0.72 - 0) <71D227E5-3DFF-3A57-8825-47730BEA669D> /Applications/Adobe InDesign CC 2015/*/Text Ruler
             0x11a94c000 -        0x11a96fffb +com.adobe.InDesign.Text Style Panel (11.0.0.72 - 0) <455C168C-B3DB-34F1-A77F-FC914CA29A9E> /Applications/Adobe InDesign CC 2015/*/Text Style Panel
             0x11a97f000 -        0x11a9a7fff +com.adobe.InDesign.Article Panel (11.0.0.72 - 0) <4FA081C4-249C-311F-BDAF-FB94D4058C1E> /Applications/Adobe InDesign CC 2015/*/Article Panel
             0x11a9bf000 -        0x11aa2fff5 +com.adobe.InDesign.CSXS (11.0.0.72 - 0) <095DB65F-3AC6-3717-B243-E60D6E314BC7> /Applications/Adobe InDesign CC 2015/*/CSXS
             0x11aa53000 -        0x11aa85fff +com.adobe.InDesign.Galley Preferences (11.0.0.72 - 0) <81C71095-F9C2-3655-8C7B-CFD516CF373D> /Applications/Adobe InDesign CC 2015/*/Galley Preferences
             0x11aa9e000 -        0x11aabcffe +com.adobe.InDesign.GapTool (11.0.0.72 - 0) <813FB85B-D79A-3509-AC8E-E2800C8068EB> /Applications/Adobe InDesign CC 2015/*/GapTool
             0x11aaca000 -        0x11aad3ff6 +com.adobe.InDesign.General Preferences Panel (11.0.0.72 - 0) <4670C792-F793-3E25-A2FA-B571BF0271C4> /Applications/Adobe InDesign CC 2015/*/General Preferences Panel
             0x11aadd000 -        0x11aadfff2 +com.adobe.InDesign.Help (11.0.0.72 - 0) <6C6D85B5-B6B4-373F-A4B9-FDF2A4DDC788> /Applications/Adobe InDesign CC 2015/*/Help
             0x11aae5000 -        0x11aaf8ff7 +com.adobe.ahclientframework (1.8.0.31 - 1.8.0.31) <58BB943C-98EC-3812-AAAB-74F66630D1D4> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
             0x11aaff000 -        0x11ab16ff9 +com.adobe.InDesign.Performance UI (11.0.0.72 - 0) <FEAF52BD-B11A-37F5-81C6-E27810BD0491> /Applications/Adobe InDesign CC 2015/*/Performance UI
             0x11ab2a000 -        0x11ab4aff5 +com.adobe.InDesign.SharedContentUI (11.0.0.72 - 0) <DE68C4DC-7E26-356B-A327-2760B07B025A> /Applications/Adobe InDesign CC 2015/*/SharedContentUI
             0x11ab58000 -        0x11ab78ffc +com.adobe.InDesign.Shortcut Editor Dialog (11.0.0.72 - 0) <76248687-C16F-38FA-A0C5-71727B65A45B> /Applications/Adobe InDesign CC 2015/*/Shortcut Editor Dialog
             0x11ab8b000 -        0x11aba7ff8 +com.adobe.InDesign.Tool Box (11.0.0.72 - 0) <2384625C-368A-355C-A317-098DC7E3E680> /Applications/Adobe InDesign CC 2015/*/Tool Box
             0x11abd2000 -        0x11abd7ffe +com.adobe.InDesign.Tool Tips (11.0.0.72 - 0) <A4359FFB-4F2C-303F-8EEF-2DF37AEFE8CA> /Applications/Adobe InDesign CC 2015/*/Tool Tips
             0x11abde000 -        0x11abe5ff1 +com.adobe.InDesign.Track Changes Preferences (11.0.0.72 - 0) <FD324128-30C2-3570-8498-B4C736601930> /Applications/Adobe InDesign CC 2015/*/Track Changes Preferences
             0x11abed000 -        0x11ac01ffe +com.adobe.InDesign.Track Changes UI (11.0.0.72 - 0) <A2425458-0FD4-3E80-B420-E6297DBD1D88> /Applications/Adobe InDesign CC 2015/*/Track Changes UI
             0x11ac0a000 -        0x11ac14ffe +com.adobe.InDesign.PerformanceMetrics (11.0.0.72 - 0) <7B9B8827-5189-32CB-9983-D2191C2DA47C> /Applications/Adobe InDesign CC 2015/*/PerformanceMetrics
             0x11ac1e000 -        0x11ac28ffb +com.adobe.InDesign.Metadata UI (11.0.0.72 - 0) <E41A4F47-1A0D-3D63-888F-089D495D8F16> /Applications/Adobe InDesign CC 2015/*/Metadata UI
             0x11ac32000 -        0x11af86ff7 +com.adobe.dvaadameve.framework (8.0.849323 - 8.0.849323.0) <6AB91160-0EAB-3DFA-8CC9-83108B8FA86B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
             0x11b4c4000 -        0x11b58eff7 +com.adobe.dvametadata.framework (8.0.849323 - 8.0.849323.0) <096B16F8-0DD8-385C-B43C-ECD2F0DF55B6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
             0x11b5e5000 -        0x11b6efff7 +com.adobe.dvametadataUI.framework (8.0.849323 - 8.0.849323.0) <76DD817C-CE6D-3EB9-8CD4-147A47E2AE49> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
             0x11b77f000 -        0x11b8d1ff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 146 - 79.157747) <05DAE5E2-BCF5-376D-900C-546BABAB1B8F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
             0x11b90a000 -        0x11b9cdff7 +com.adobe.dvaeve.framework (8.0.849323 - 8.0.849323.0) <F18CB9BD-EC06-3057-9CA0-236D588D22E8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
             0x11ba7b000 -        0x11bad8fff +com.adobe.dvatemporalxmp.framework (8.0.849323 - 8.0.849323.0) <47AA1FBB-0620-3422-B990-AE2F718E1E6A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
             0x11baf7000 -        0x11bb2cff7 +com.adobe.dvamediatypes.framework (8.0.849323 - 8.0.849323.0) <326743D3-5188-303E-92F7-CB0172A6D92F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
             0x11bb45000 -        0x11bb4cff6 +com.adobe.InDesign.Workgroup UI (11.0.0.72 - 0) <8C39529A-4571-3D96-8CCB-3297129B8472> /Applications/Adobe InDesign CC 2015/*/Workgroup UI
             0x11bb54000 -        0x11bb9effd +com.adobe.InDesign.Snippet (11.0.0.72 - 0) <84580034-45EC-3343-8811-7E02EA84351F> /Applications/Adobe InDesign CC 2015/*/Snippet
             0x11bbb7000 -        0x11bcd2ffa +com.adobe.InDesign.XMedia UI (11.0.0.72 - 0) <B9E001B2-CF15-3CB1-B2D0-63C4677AEBE1> /Applications/Adobe InDesign CC 2015/*/XMedia UI
             0x11bd1b000 -        0x11bd70ff1 +com.adobe.InDesign.Actions (11.0.0.72 - 0) <A987372C-F8BA-3DD1-8B17-88E8D777E8C9> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Actions.InDesignPlugin/Actions
             0x11bd8b000 -        0x11bf56ff4 +com.adobe.InDesign.AppFramework (11.0.0.72 - 0) <6D3CE096-55E4-3B34-A147-D53FA3343952> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/AppFramework.InDesignPlugin/AppFramework
             0x11bff2000 -        0x11c1edfef +com.adobe.InDesign.Application UI (11.0.0.72 - 0) <6A4741EF-4E74-351D-8BB4-4507D7E4F6CA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Application UI.InDesignPlugin/Application UI
             0x11c2a6000 -        0x11c333ff7 +com.adobe.headlights.LogSessionFramework (7.2.1.3600) <F329BF2F-FD3D-342A-AA38-14922C6C21DC> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
             0x11c35a000 -        0x11c405ff7 +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.1) <79B05FB3-724B-3679-A9B7-E96511405E4F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
             0x11c42c000 -        0x11c4c7fff +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.1) <B8F6ECB6-E6F8-3117-8CEF-BC00B5C924FE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
             0x11c4f0000 -        0x11c525fff +AgoraLib.dylib (1.0.0.0) <73697218-E690-371D-9728-7883DA2051A7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AgoraLib.dylib
             0x11c558000 -        0x11c6a7ff7 +com.adobe.dvascriptui.framework (7.0.6 - 7.0.6.0) <663D10E8-D919-3A9A-B2DF-5250C25CAA71> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvascriptui.framework/Versions/A/dvascriptui
             0x11c7cd000 -        0x11c7eeff9 +com.adobe.InDesign.Article (11.0.0.72 - 0) <B6AE7DDF-A440-3B5F-B182-E89958FD5EEA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Article.InDesignPlugin/Article
             0x11c7fd000 -        0x11c88eff0 +com.adobe.InDesign.Assignments (11.0.0.72 - 0) <02058ECA-E32B-3074-BF29-1C7604272F0E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Assignments.InDesignPlugin/Assignments
             0x11c8af000 -        0x11c8e9fff +com.adobe.InDesign.AWS (11.0.0.72 - 0) <399EF2A6-BBCE-33DD-827B-61F82B2F7296> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/AWS.InDesignPlugin/AWS
             0x11c903000 -        0x11c928ff7 +com.adobe.InDesign.AWSUI (11.0.0.72 - 0) <B085960F-C85F-314B-B2CC-B472E2ADB808> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/AWSUI.InDesignPlugin/AWSUI
             0x11c93c000 -        0x11c96dff5 +com.adobe.InDesign.Basic Tools (11.0.0.72 - 0) <CBDEFB70-5FE5-30DB-960F-75C3BA1FBBEC> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Basic Tools.InDesignPlugin/Basic Tools
             0x11c987000 -        0x11c9d9ff6 +com.adobe.InDesign.Behavior (11.0.0.72 - 0) <8FCC42D0-E6F3-33A1-9C56-E0674F052EBD> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Behavior.InDesignPlugin/Behavior
             0x11c9f6000 -        0x11ca88ff1 +com.adobe.InDesign.BNCore (11.0.0.72 - 0) <E65FD00C-AAB3-3710-B32E-D1A4DCB09DF0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/BNCore.InDesignPlugin/BNCore
             0x11caa6000 -        0x11cb04ff6 +com.adobe.InDesign.Book (11.0.0.72 - 0) <161E94FB-D79B-315B-A464-78B45CE34594> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Book.InDesignPlugin/Book
             0x11cb1b000 -        0x11cb4fffa +com.adobe.InDesign.CellStyles (11.0.0.72 - 0) <FAD5CC3B-4882-3919-8E86-E27E6F17A418> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/CellStyles.InDesignPlugin/CellStyles
             0x11cb62000 -        0x11cbd8ff5 +com.adobe.InDesign.CJK Text Attributes (11.0.0.72 - 0) <CAC2FA42-E16D-30AC-897A-D9826118F228> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/CJK Text Attributes.InDesignPlugin/CJK Text Attributes
             0x11cbfb000 -        0x11cc79ffa +com.adobe.InDesign.CJKGrid (11.0.0.72 - 0) <3A96DF13-850A-31EA-87FE-2EA90131C6DB> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/CJKGrid.InDesignPlugin/CJKGrid
             0x11cc95000 -        0x11cd74fff +com.adobe.InDesign.Color Management (11.0.0.72 - 0) <FAD14066-44E5-397F-B99E-F394C2FF829C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Color Management.InDesignPlugin/Color Management
             0x11cda1000 -        0x11ce03ff7 +com.adobe.InDesign.CompFontMgr (11.0.0.72 - 0) <E95B294C-1209-340B-87CA-6302B842A4D4> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/CompFontMgr.InDesignPlugin/CompFontMgr
             0x11ce1d000 -        0x11ce6dff0 +com.adobe.InDesign.Conditional Text (11.0.0.72 - 0) <DEDD64B1-D889-3EB3-87F0-FDE2CF48BE0D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Conditional Text.InDesignPlugin/Conditional Text
             0x11ce86000 -        0x11ceb3ffe +com.adobe.InDesign.ContentDropper (11.0.0.72 - 0) <868B9084-98B3-3AED-9248-25C300A2B2F2> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/ContentDropper.InDesignPlugin/ContentDropper
             0x11cec6000 -        0x11cee7ff0 +com.adobe.InDesign.Dialog Layout (11.0.0.72 - 0) <EE17ADE6-ED7E-3082-9502-65FD5A45FFD8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Dialog Layout.InDesignPlugin/Dialog Layout
             0x11cef8000 -        0x11cf1bff8 +com.adobe.InDesign.Document Actions (11.0.0.72 - 0) <FF6AC2B6-2E0B-3360-A41C-D030B4822243> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Document Actions.InDesignPlugin/Document Actions
             0x11cf28000 -        0x11d0f8ffa +com.adobe.InDesign.Document Framework (11.0.0.72 - 0) <A71ABA6E-2B15-3357-96A0-01F1431EDEDA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Document Framework.InDesignPlugin/Document Framework
             0x11d138000 -        0x11d140ff6 +com.adobe.InDesign.Document UI (11.0.0.72 - 0) <E5386234-9821-3637-A854-331A0A827FD1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Document UI.InDesignPlugin/Document UI
             0x11d148000 -        0x11d189ff2 +com.adobe.InDesign.DV_Widgets (11.0.0.72 - 0) <7F20144D-129A-3512-B4C3-FD3F1DB8977E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/DV_Widgets.InDesignPlugin/DV_Widgets
             0x11d1d0000 -        0x11d4e5fff +com.adobe.InDesign.Dynamic Documents (11.0.0.72 - 0) <6850B576-F04F-3C04-8635-28A5449DDC79> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Dynamic Documents.InDesignPlugin/Dynamic Documents
             0x11d52f000 -        0x11d626fff +com.adobe.AGMFL (AdobeAGMFL 2.1.0.32362 - 2.1.0.32362) <C93FF155-AA80-34F1-A785-42BC0D8D3909> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ADBE_AGMFL.framework/Versions/A/ADBE_AGMFL
             0x11d643000 -        0x11d820ff7 +com.adobe.AFlamingo (AFlamingo 2.4.402.31977 - 2.4.402.31977) <B90D5CA4-DA52-39A1-95DD-8011764655A1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
             0x11d844000 -        0x11d964ffe +com.adobe.InDesign.EPS Page Item (11.0.0.72 - 0) <7768DB02-2270-3FC4-B8C2-15B20F701ABA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/EPS Page Item.InDesignPlugin/EPS Page Item
             0x11d9a4000 -        0x11daadff2 +com.adobe.InDesign.Font Manager (11.0.0.72 - 0) <6D17EE9A-4015-3194-B781-141EBB06ACF9> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Font Manager.InDesignPlugin/Font Manager
             0x11dacf000 -        0x11db96ff5 +com.adobe.InDesign.FormField (11.0.0.72 - 0) <24F3127D-6B92-3A18-AE4D-D4E197F1E269> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/FormField.InDesignPlugin/FormField
             0x11dbbb000 -        0x11dc13ff4 +com.adobe.InDesign.Galley (11.0.0.72 - 0) <8E7E2B93-E960-3E57-8C69-7D968FD8C096> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Galley.InDesignPlugin/Galley
             0x11dc27000 -        0x11dd65ff6 +com.adobe.InDesign.GalleyUI (11.0.0.72 - 0) <86965E14-4B03-3FD9-B64A-A6C656DF455D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/GalleyUI.InDesignPlugin/GalleyUI
             0x11dd94000 -        0x11dfe0ff4 +com.adobe.InDesign.Generic Page Item (11.0.0.72 - 0) <5DD9540F-2C66-38F6-B66C-A849C93970F7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Generic Page Item.InDesignPlugin/Generic Page Item
             0x11e02b000 -        0x11e036ff5 +com.adobe.InDesign.GenericSettings (11.0.0.72 - 0) <E5C4D5B1-66EE-3DE1-A192-31F482F3ACC0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/GenericSettings.InDesignPlugin/GenericSettings
             0x11e03f000 -        0x11e0a2ff0 +com.adobe.InDesign.Gradient Fill (11.0.0.72 - 0) <3CE9151A-D1B0-3310-A8EE-6668A4D9126C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Gradient Fill.InDesignPlugin/Gradient Fill
             0x11e0bd000 -        0x11e1a2ff8 +com.adobe.InDesign.Graphics (11.0.0.72 - 0) <A650F4DA-B157-39D3-ABA7-87B7470B4D07> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Graphics.InDesignPlugin/Graphics
             0x11e1c5000 -        0x11e1d0ffa +com.adobe.InDesign.Group (11.0.0.72 - 0) <8613CBCA-C337-3902-B5A8-C22B944B48D1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Group.InDesignPlugin/Group
             0x11e1dc000 -        0x11e1faff6 +com.adobe.InDesign.Guides (11.0.0.72 - 0) <40EAEADE-6F58-3F43-8EAB-BA7828284AEF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Guides.InDesignPlugin/Guides
             0x11e20b000 -        0x11e2d8ff2 +com.adobe.InDesign.HTMLPGT (11.0.0.72 - 0) <66B28AC0-DE14-3A9E-8D02-7AFD39AEA5CC> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/HTMLPGT.InDesignPlugin/HTMLPGT
             0x11e332000 -        0x11e425ff8 +com.adobe.InDesign.Hyperlinks (11.0.0.72 - 0) <4E29E71F-76BB-3733-A4AB-D66D06A8878F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Hyperlinks.InDesignPlugin/Hyperlinks
             0x11e44f000 -        0x11e49bffd +com.adobe.InDesign.Image Filters (11.0.0.72 - 0) <D6FE8938-62A9-3DFC-9DEF-62659EE0C052> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Image Filters.InDesignPlugin/Image Filters
             0x11e4a8000 -        0x11e5a0ff8 +com.adobe.InDesign.Image (11.0.0.72 - 0) <188AA6B4-1509-3FBA-BF43-7E7BECC5BE1E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Image.InDesignPlugin/Image
             0x11e5cc000 -        0x11e5e1ff2 +com.adobe.InDesign.IME (11.0.0.72 - 0) <0BFC7D5D-D4F2-34A7-BDF1-824BBFDB254B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/IME.InDesignPlugin/IME
             0x11e5f0000 -        0x11e695ff9 +com.adobe.InDesign.Import Export UI (11.0.0.72 - 0) <85180406-A874-359B-8C01-0F0798BFF6DC> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Import Export UI.InDesignPlugin/Import Export UI
             0x11e6c3000 -        0x11e7b4ff7 +com.adobe.InDesign.InCopyShared (11.0.0.72 - 0) <D5760908-3649-3BB1-867B-8A76973981E0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/InCopyShared.InDesignPlugin/InCopyShared
             0x11e7df000 -        0x11e7faffc +com.adobe.InDesign.InCopySharedUI (11.0.0.72 - 0) <848250DA-18C3-31F1-AB99-78CB5F549116> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/InCopySharedUI.InDesignPlugin/InCopySharedUI
             0x11e809000 -        0x11e8a3ff6 +com.adobe.InDesign.InCopyWorkflow (11.0.0.72 - 0) <E3046740-DA7F-3972-AF0F-6DD3ED13C7A7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/InCopyWorkflow.InDesignPlugin/InCopyWorkflow
             0x11e8c8000 -        0x11e9bcff1 +com.adobe.InDesign.Indexing (11.0.0.72 - 0) <1D1C538F-15B4-3757-8762-5927F8FB3696> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Indexing.InDesignPlugin/Indexing
             0x11e9dd000 -        0x11ea9aff8 +com.adobe.InDesign.INXCore (11.0.0.72 - 0) <2CA26566-5B59-3995-ACA5-554E24835886> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/INXCore.InDesignPlugin/INXCore
             0x11eac2000 -        0x11eaebffc +com.adobe.InDesign.Layer (11.0.0.72 - 0) <6D89057A-197C-3ED2-92FA-50476EEF0238> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Layer.InDesignPlugin/Layer
             0x11eafe000 -        0x11ed23ff5 +com.adobe.InDesign.Layout UI (11.0.0.72 - 0) <66082291-6B89-3F56-ABE7-622C39825A7A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Layout UI.InDesignPlugin/Layout UI
             0x11ed8f000 -        0x11edb4fff +com.adobe.InDesign.Layout (11.0.0.72 - 0) <48C5D529-5805-390E-B8B8-9189D3D8DC75> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Layout.InDesignPlugin/Layout
             0x11edc2000 -        0x11ee08ffc +com.adobe.InDesign.Linguistics (11.0.0.72 - 0) <7B8AA788-8477-31FA-B61E-465DD179C733> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Linguistics.InDesignPlugin/Linguistics
             0x11ee21000 -        0x11ef6bff0 +com.adobe.InDesign.Links (11.0.0.72 - 0) <4B1738CC-5080-34C8-B0D1-8FE13B12F4CF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Links.InDesignPlugin/Links
             0x11efa7000 -        0x11f040ff0 +com.adobe.InDesign.Master Page (11.0.0.72 - 0) <0CDFA6F0-1A23-3C3E-B48A-CA5035E5648D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Master Page.InDesignPlugin/Master Page
             0x11f05a000 -        0x11f0aaff3 +com.adobe.InDesign.Media (11.0.0.72 - 0) <77DA8414-D987-32D7-88D2-7BFF9225F071> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Media.InDesignPlugin/Media
             0x11f0bf000 -        0x11f13dff8 +com.adobe.InDesign.Metadata (11.0.0.72 - 0) <DEF29C8E-56DC-382C-8A3B-83A978FB764B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Metadata.InDesignPlugin/Metadata
             0x11f159000 -        0x11f16effc +com.adobe.InDesign.Movie (11.0.0.72 - 0) <C60CF123-0B78-3903-84AA-683A7C645F05> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Movie.InDesignPlugin/Movie
             0x11f17d000 -        0x11f1bdffc +com.adobe.InDesign.Open Place (11.0.0.72 - 0) <38CD9059-90BE-3503-B604-13A9BE244009> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Open Place.InDesignPlugin/Open Place
             0x11f1d3000 -        0x11f278ffd +com.adobe.InDesign.Paragraph Composer (11.0.0.72 - 0) <B3BA73F7-C682-3F8C-91E9-E2C071044327> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Paragraph Composer.InDesignPlugin/Paragraph Composer
             0x11f288000 -        0x11f2c3ff4 +com.adobe.InDesign.Path Type (11.0.0.72 - 0) <6D5B4EA1-3922-3F6B-A06D-4326F032B835> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Path Type.InDesignPlugin/Path Type
             0x11f2dc000 -        0x11f527ff0 +com.adobe.InDesign.PDF (11.0.0.72 - 0) <F8A8AFCB-609F-3CFF-BB49-FB62F1A62825> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/PDF.InDesignPlugin/PDF
             0x11f56c000 -        0x11f625ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.34491) <574A97AF-0EA2-3FB9-BE6B-7E02C76EC6F2> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
             0x11f649000 -        0x11f74efff +com.adobe.PDFPort (AdobePDFPort 2.1.0.34494 - 2.1.0.34494) <B722768C-5135-32EC-9B39-1545486E4F78> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
             0x11f761000 -        0x11f789fff +com.adobe.PDFSettings (AdobePDFSettings 1.05.0 - 1.5) <B3E9E172-6207-3100-B476-D207FC103094> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
             0x11f792000 -        0x11f7cfff8 +com.adobe.InDesign.Photoshop Import Filter (11.0.0.72 - 0) <985C6C69-87B9-35A8-9AAD-B1A309135247> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Photoshop Import Filter.InDesignPlugin/Photoshop Import Filter
             0x11f7e0000 -        0x121cc1f1f +com.adobe.psl (AdobePSL 15.1.0.34656 - 15.1.0.34656) <FB80F116-67E6-3D56-AE40-52E0961F5578> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
             0x12215a000 -        0x12215efff  com.apple.agl (3.3.1 - AGL-3.3.1) <4E401980-0F4F-33E2-A0CF-8C7CCF375F24> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
             0x122386000 -        0x1223beff6 +com.adobe.InDesign.PNG Import Filter (11.0.0.72 - 0) <BAD98EA2-EC03-322B-8EA0-ACF6DD8B74E6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/PNG Import Filter.InDesignPlugin/PNG Import Filter
             0x1223ce000 -        0x122543ff0 +com.adobe.InDesign.Print (11.0.0.72 - 0) <201D2400-87E0-33EE-AFEA-3B72C6373975> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Print.InDesignPlugin/Print
             0x122570000 -        0x122595ffe +com.adobe.InDesign.Rulers (11.0.0.72 - 0) <C598E21A-D373-307E-AB5D-CDBB17974A10> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Rulers.InDesignPlugin/Rulers
             0x1225a7000 -        0x12263bff8 +com.adobe.InDesign.Scripting (11.0.0.72 - 0) <F37ED324-CD8F-35A5-B5F5-A80A311C7E9F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Scripting.InDesignPlugin/Scripting
             0x12265c000 -        0x12267eff8 +com.adobe.InDesign.Sections (11.0.0.72 - 0) <49111487-C9E9-3729-B42E-CB7271A2835F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Sections.InDesignPlugin/Sections
             0x12268f000 -        0x12270aff8 +com.adobe.InDesign.SharedContent (11.0.0.72 - 0) <536BA009-EB2B-33B8-833C-25EBC138E194> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/SharedContent.InDesignPlugin/SharedContent
             0x122729000 -        0x122735ffc +com.adobe.InDesign.Sound (11.0.0.72 - 0) <EED21E72-2A80-3612-A998-382216C8856D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Sound.InDesignPlugin/Sound
             0x122741000 -        0x122751ff3 +com.adobe.InDesign.Spelling Service (11.0.0.72 - 0) <C1A7BBA0-F5A3-3878-A695-C6DDBC9D141F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spelling Service.InDesignPlugin/Spelling Service
             0x12275f000 -        0x1227a2ff8 +com.adobe.InDesign.Spline UI (11.0.0.72 - 0) <DE53B1A6-D092-32AB-BF14-B1F31EB9D443> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spline UI.InDesignPlugin/Spline UI
             0x1227bd000 -        0x122801ffe +com.adobe.InDesign.Spline (11.0.0.72 - 0) <0443C46D-D0E0-3946-A872-75EA7227BE18> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spline.InDesignPlugin/Spline
             0x122819000 -        0x122874ff8 +com.adobe.InDesign.Spread UI (11.0.0.72 - 0) <8E41E6A6-C10F-3FA7-9076-5FAAD002872D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spread UI.InDesignPlugin/Spread UI
             0x12288e000 -        0x1229bcff0 +com.adobe.InDesign.Spread (11.0.0.72 - 0) <3B30B5B4-CB5A-3639-93D6-9DC8E408B29B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spread.InDesignPlugin/Spread
             0x1229ed000 -        0x122a3dff2 +com.adobe.InDesign.Stroke and Fill (11.0.0.72 - 0) <3790FC66-ADF3-3C04-9109-ABA057762C54> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Stroke and Fill.InDesignPlugin/Stroke and Fill
             0x122a54000 -        0x122aa9ff8 +com.adobe.InDesign.Support for AppleScript (11.0.0.72 - 0) <35F62800-271B-37FD-B6D7-AE23EE6B6193> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Support for AppleScript.InDesignPlugin/Support for AppleScript
             0x122abf000 -        0x122b54ffe +com.adobe.InDesign.Support for JavaScript (11.0.0.72 - 0) <6A327852-C96C-3ECE-84BF-83CDE8B5A6B3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Support for JavaScript.InDesignPlugin/Support for JavaScript
             0x122b7d000 -        0x122bfbfff +com.adobe.InDesign.SVGExport (11.0.0.72 - 0) <5E2755EE-9FE2-3104-8BB8-BF3F0FFA422B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/SVGExport.InDesignPlugin/SVGExport
             0x122c14000 -        0x122cd2fff +com.adobe.SVGExport (AdobeSVGExport 6.0 - 6.0) <2FAB4B9A-EDB9-0FF9-55B2-52DEC380D2BF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSVGExport.framework/Versions/A/AdobeSVGExport
             0x122cf5000 -        0x122f27ffd +com.adobe.InDesign.Table Model (11.0.0.72 - 0) <B820366D-4AD6-3FC5-9512-73223060629D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Table Model.InDesignPlugin/Table Model
             0x122f6a000 -        0x122fc2ff0 +com.adobe.InDesign.TableStyles (11.0.0.72 - 0) <17EC27FE-71E5-3914-A038-9B1F6E9DB78D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/TableStyles.InDesignPlugin/TableStyles
             0x122fd4000 -        0x12301aff0 +com.adobe.InDesign.Text Attributes (11.0.0.72 - 0) <B9DCACA6-51CE-3346-934A-93D54F849587> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Attributes.InDesignPlugin/Text Attributes
             0x123035000 -        0x123048ffb +com.adobe.InDesign.Text Editor Model (11.0.0.72 - 0) <E112C73E-86D4-3B78-AEB1-B32D9F52062D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Editor Model.InDesignPlugin/Text Editor Model
             0x123053000 -        0x12311effd +com.adobe.InDesign.Text Editor (11.0.0.72 - 0) <3BC59DEB-BDEC-3432-A68C-0735CE49A4F8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Editor.InDesignPlugin/Text Editor
             0x12314d000 -        0x1232e0ff0 +com.adobe.InDesign.Text Walker (11.0.0.72 - 0) <25C204A6-FE2A-39BE-B2B9-A38BB6C2A983> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Walker.InDesignPlugin/Text Walker
             0x123334000 -        0x123353ff3 +com.adobe.InDesign.Text Wrap Path (11.0.0.72 - 0) <8ED70C29-F038-33F2-AA32-656B87884E4C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Wrap Path.InDesignPlugin/Text Wrap Path
             0x12335c000 -        0x1233c6ffe +com.adobe.InDesign.Text Wrap (11.0.0.72 - 0) <9221662B-323F-39BA-AE57-9911281A9054> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Wrap.InDesignPlugin/Text Wrap
             0x1233df000 -        0x12399cffb +com.adobe.InDesign.Text (11.0.0.72 - 0) <DE959996-11FF-3B26-BFE7-F5FA93D6BBDA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text.InDesignPlugin/Text
             0x123a3d000 -        0x123a9affa +com.adobe.InDesign.TOC (11.0.0.72 - 0) <59AD8DC9-DE13-3E5B-AF02-96B90B22DFE2> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/TOC.InDesignPlugin/TOC
             0x123aae000 -        0x123bdcffa +com.adobe.InDesign.Transparency (11.0.0.72 - 0) <9CDD0357-79CE-35A4-942B-72D16A35A639> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Transparency.InDesignPlugin/Transparency
             0x123c06000 -        0x123c27ff4 +com.adobe.InDesign.Utilities (11.0.0.72 - 0) <9D5CFD13-9C78-36DB-937B-E5EA32C1EDAA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Utilities.InDesignPlugin/Utilities
             0x123c41000 -        0x123d27ff5 +com.adobe.InDesign.Widgets (11.0.0.72 - 0) <6D76EEE8-EF10-325E-93D1-B3216334850E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Widgets.InDesignPlugin/Widgets
             0x123d9d000 -        0x123da5ff0 +com.adobe.InDesign.Workgroup Client UI (11.0.0.72 - 0) <3485211D-31C0-3E0F-9577-FE940F0E45E3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Workgroup Client UI.InDesignPlugin/Workgroup Client UI
             0x123dab000 -        0x123dc9fff +com.adobe.InDesign.Workgroup Client (11.0.0.72 - 0) <89217833-BB02-341C-96D9-B5372F82D1EA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Workgroup Client.InDesignPlugin/Workgroup Client
             0x123dd7000 -        0x123e0dff8 +com.adobe.InDesign.Workgroup (11.0.0.72 - 0) <5B95A55C-241B-3720-9FBF-211D4F85E525> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Workgroup.InDesignPlugin/Workgroup
             0x123e1c000 -        0x123e43ffe +com.adobe.InDesign.WorldReady (11.0.0.72 - 0) <2EF2D33B-7B65-39BD-8155-18297E36DF25> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/WorldReady.InDesignPlugin/WorldReady
             0x123e53000 -        0x12405aff9 +com.adobe.InDesign.XML (11.0.0.72 - 0) <012089FD-1CDB-38D6-BAC7-AAD928C2EAC4> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/XML.InDesignPlugin/XML
             0x1240a3000 -        0x12419ffff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.34320 - 3.8.0.34320) <AFDCC2CF-EF73-323E-A2FA-3034F26F97B9> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
             0x1241b4000 -        0x12420dffa +com.adobe.InDesign.XMLParser (11.0.0.72 - 0) <D0F710ED-FEE9-38B2-B26C-1C074EFEF27D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/XMLParser.InDesignPlugin/XMLParser
             0x124222000 -        0x1242fefff +com.adobe.AXEXSLT (AdobeAXSLE 3.8.0.34320 - 3.8.0.34320) <DB2B9E7A-210B-3981-BBD7-2CE7B5827CC8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAXSLE.framework/Versions/A/AdobeAXSLE
             0x124a95000 -        0x124aadff7 +com.eSellerate.EWSMac83886082 (5.0.0.2 - 5.0.0.2) <317E3289-05ED-7B7E-615A-ECC13868AF5E> /Users/USER/Library/Frameworks/EWSMac-GC.framework/EWSMac-GC83886082
             0x124ac1000 -        0x124b3bff7  com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
             0x124e82000 -        0x124e87ff7  com.apple.URLMount.CIFSPlugin (7.0.1 - 7.0.1) <1A277865-92E5-3AE6-8C3C-21072D92C7CA> /System/Library/Filesystems/NetFSPlugins/smb.bundle/Contents/MacOS/smb
             0x124ec1000 -        0x124eeeff7 +com.adobe.Reader for DOCX (Reader for DOCX 5.65.0.34575 - 5.65.0.34575) <4E2D3BF8-093E-366A-AA6B-712D619F56DF> /Applications/Adobe InDesign CC 2015/*/Reader for DOCX
             0x124ef9000 -        0x124f64ff7 +com.adobe.AdobeSangamML (AdobeSangamML 5.65.0.34575 - 5.65.0.34575) <5B4E44CA-7953-37FF-B884-81C2E6F91C5B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSangamML.framework/Versions/A/AdobeSangamML
             0x124f88000 -        0x124fe5ff7 +com.adobe.Reader for Excel (Reader for Excel 5.65.0.34575 - 5.65.0.34575) <B029F765-C8CC-309B-91AA-3F1A64A5CEDF> /Applications/Adobe InDesign CC 2015/*/Reader for Excel
             0x124ff8000 -        0x12500cff7 +com.adobe.AdobeSFL (AdobeSFL 1.1.0.33621 - 1.1.0.33621) <4C5F9909-758F-36AF-B72C-29BE5770D9F7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
             0x125014000 -        0x125106ff7 +com.adobe.Reader for Quark (Reader for Quark 5.65.0.34575 - 5.65.0.34575) <9C0D973E-9B87-30D6-9633-B21683334B1B> /Applications/Adobe InDesign CC 2015/*/Reader for Quark
             0x12511f000 -        0x12517aff7 +com.adobe.Reader for RTF (Reader for RTF 5.65.0.34575 - 5.65.0.34575) <D64BE815-E575-3A39-92D2-14EF36774BE7> /Applications/Adobe InDesign CC 2015/*/Reader for RTF
             0x125193000 -        0x125200ff7 +com.adobe.Reader for Word (Reader for Word 5.65.0.34575 - 5.65.0.34575) <909E4D4C-00BE-3CE4-AC11-BA2C98094E51> /Applications/Adobe InDesign CC 2015/*/Reader for Word
             0x125215000 -        0x12527eff7 +com.adobe.Reader for XLSX (Reader for XLSX 5.65.0.34575 - 5.65.0.34575) <BD80C93E-6213-3ACD-8514-3F1BC33EEF39> /Applications/Adobe InDesign CC 2015/*/Reader for XLSX
             0x125298000 -        0x1252a0ff7 +com.adobe.ZTextReader (ZTextReader 5.65.0.34575 - 5.65.0.34575) <8A3C6488-24D4-3DF6-AA70-DF04AB508B50> /Applications/Adobe InDesign CC 2015/*/ZTextReader
             0x125327000 -        0x12534dff7 +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <40A59819-7A57-0E9F-658D-1803B2A461AE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/adbeapecore.framework/adbeapecore
             0x125360000 -        0x12536dfff +com.extensis.fontplugins (6.0.2.639239 - 6.0.2.639239) <BDA6498B-6B87-38AA-A89F-8BFC0A9FAA72> /Applications/Universal Type Client.app/Contents/Resources/PluginFiles/ExtensisPlugins.framework/ExtensisPlugins
             0x125522000 -        0x12566dfff +IMSLib.dylib (10.0.0.7 - 10.0.0.7) <1DD294BF-3FEB-3BBF-A27C-94D2445CB4B4> /Library/Application Support/Adobe/*/IMSLib.dylib
             0x1257c2000 -        0x1257c2fff +DTraceSupport.dylib (1) <E54DF20B-C169-68CF-A3F5-0470DEFF1C8A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/DTraceSupport.dylib
             0x1257e5000 -        0x1257e5fe7 +cl_kernels (???) <2AE5AA66-B90B-4603-BC03-65DBE3914342> cl_kernels
             0x1258db000 -        0x1258dcfff  libCyrillicConverter.dylib (68) <79F5CFEF-92E4-30FE-A650-41F07B6D31B9> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
             0x125acb000 -        0x125adaff7  libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
             0x125ea8000 -        0x125ea8fff  com.apple.applescript.component (2.5 - 377) <D205C65F-E27A-3D14-9F22-B8224F2C657C> /System/Library/Components/AppleScript.component/Contents/MacOS/AppleScript
             0x12724a000 -        0x1272effff  ColorSyncDeprecated.dylib (470.3) <A30CB963-667F-39D0-8537-66FCC820F5A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
             0x127926000 -        0x127942ff7  libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
             0x127948000 -        0x12794bff3 +FastCore (16.0.0 - 16.0.0) <F2C2654A-7864-39D2-B4F5-B72EEC5AB62D> /Applications/Adobe InDesign CC 2015/*/FastCore.plugin/Contents/MacOS/FastCore
             0x1283fc000 -        0x128401fff  libgermantok.dylib (17) <B230A9A9-EC4C-306C-8C65-7143285DA142> /usr/lib/libgermantok.dylib
             0x128430000 -        0x128442fff  libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
             0x1287c1000 -        0x128849fff  com.apple.applescript (2.5 - 377) <B280DAC6-E614-3AC0-81B5-C2F1E994514B> /System/Library/PrivateFrameworks/AppleScript.framework/Versions/A/AppleScript
             0x129554000 -        0x129576ff7  libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
             0x12ae06000 -        0x12ae33ff3 +MMXCore (16.0.0 - 16.0.0) <993AF7A0-E5B5-3B32-BB70-2D4EB336A61C> /Applications/Adobe InDesign CC 2015/*/MMXCore.plugin/Contents/MacOS/MMXCore
             0x12aeab000 -        0x12af22ff9 +MultiProcessor Support (16.0.0 - 16.0.0) <8C511939-EF04-383C-BEDC-1502FE2960F6> /Applications/Adobe InDesign CC 2015/*/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
             0x12c3e7000 -        0x12cb80fff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.34348) <4D649496-C10E-351F-B665-ABB0BD0C9FC3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePDFL.framework/AdobePDFL
             0x12cc89000 -        0x12d1e0ff7  com.apple.driver.AppleIntelHD5000GraphicsGLDriver (10.14.73 - 10.1.4) <24A49E09-E89A-381F-BF8A-DBC03C28AF7A> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIn telHD5000GraphicsGLDriver
             0x1400a9000 -        0x1400e2fff +com.adobe.pip (7.2.1.3600) <C47C1485-4832-3DFA-9729-528A935CD7C9> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
             0x141d81000 -        0x141de7ff7  com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (10.14.73 - 10.1.4) <A0579BDA-B818-3A73-8951-8D4243D27AA4> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleI ntelHD5000GraphicsMTLDriver
             0x144f4c000 -        0x14504ffff  com.apple.GeForceMTLDriver (10.10.13 - 10.1.0) <08673D69-59E2-3769-8B3C-452140CC4C65> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
          0x7fff69340000 -     0x7fff69377a47  dyld (360.22) <DC81CC9D-651A-3A45-8809-928282052BD3> /usr/lib/dyld
          0x7fff8b24c000 -     0x7fff8b269ff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <41378C0B-B56A-3A73-9BD0-E06FA1F87B8C> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
          0x7fff8b271000 -     0x7fff8b2e5ff7  com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
          0x7fff8b30e000 -     0x7fff8b3f4fef  unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
          0x7fff8b41f000 -     0x7fff8b459ff7  com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
          0x7fff8b4c7000 -     0x7fff8b4deff7  libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
          0x7fff8b508000 -     0x7fff8b53cff7  com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x7fff8b53d000 -     0x7fff8b542fff  com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
          0x7fff8b581000 -     0x7fff8b5d3fff  com.apple.AppleVAFramework (5.0.32 - 5.0.32) <271ED7A9-73E5-3595-A8D6-28594C9F3C9D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
          0x7fff8b5d4000 -     0x7fff8b5eafff  com.apple.CoreMediaAuthoring (2.2 - 953) <5103EF2E-BB0A-302B-B8BB-CED301BC746B> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
          0x7fff8b5eb000 -     0x7fff8b5edfff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
          0x7fff8b5ee000 -     0x7fff8b61dfff  com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
          0x7fff8bf53000 -     0x7fff8bf5bfff  com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
          0x7fff8bf75000 -     0x7fff8bf91ff7  libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
          0x7fff8c3bd000 -     0x7fff8c3c5fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
          0x7fff8c3c6000 -     0x7fff8c3c7ffb  libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
          0x7fff8c3c8000 -     0x7fff8c43cff3  com.apple.securityfoundation (6.0 - 55126) <DAA4FDD0-7F84-30AA-BE6F-96BB9F871F07> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
          0x7fff8c572000 -     0x7fff8c585fff  com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
          0x7fff8c586000 -     0x7fff8c5d7fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
          0x7fff8c5d8000 -     0x7fff8c5eeff7  libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
          0x7fff8c5ef000 -     0x7fff8c6c5ffb  com.apple.DiskImagesFramework (10.11.4 - 417.4) <B9525D22-6F0D-39C5-BA9B-9DF195FE1968> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
          0x7fff8c6c6000 -     0x7fff8c6cafff  libGIF.dylib (1459) <7C84B660-04BC-3D05-8C02-A7FBE51FD77B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
          0x7fff8c717000 -     0x7fff8c7a4fef  libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
          0x7fff8c7a5000 -     0x7fff8c7cfff7  GLRendererFloat (12.1) <BE957AC5-82C2-3620-A625-56C9BE7B853F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
          0x7fff8c886000 -     0x7fff8c8e4fff  com.apple.CoreServices.OSServices (728.13 - 728.13) <27C12B92-7845-38DD-B82D-DC5B678352D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x7fff8c8e5000 -     0x7fff8c904ff7  com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
          0x7fff8c969000 -     0x7fff8c974fff  com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
          0x7fff8c975000 -     0x7fff8cb82fff  libicucore.A.dylib (551.51.4) <3899B146-3840-3D4A-8C4A-FE391D5D25C7> /usr/lib/libicucore.A.dylib
          0x7fff8cb83000 -     0x7fff8cb88ff7  com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
          0x7fff8cb89000 -     0x7fff8cb8bff7  com.apple.xpc.ServiceManagement (1.0 - 1) <D96D7A6D-EDEB-35EE-B5D9-E33A3BF011B5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
          0x7fff8cb8c000 -     0x7fff8d0aefff  com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
          0x7fff8d692000 -     0x7fff8d6e2ff7  com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
          0x7fff8d6e3000 -     0x7fff8d6e5fff  com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
          0x7fff8d6e6000 -     0x7fff8d6eefef  libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
          0x7fff8d6ef000 -     0x7fff8d6f7fff  libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
          0x7fff8d735000 -     0x7fff8d748fff  com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersis tence
          0x7fff8d749000 -     0x7fff8d778ffb  libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
          0x7fff8d779000 -     0x7fff8d789ff3  com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
          0x7fff8d7d5000 -     0x7fff8d802fff  libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
          0x7fff8d803000 -     0x7fff8d805fff  libCVMSPluginSupport.dylib (12.1) <D81B3D8D-B83F-3918-BD4B-6C794A30AF9F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
          0x7fff8d806000 -     0x7fff8da73fff  com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
          0x7fff8da83000 -     0x7fff8dccfff7  com.apple.AddressBook.framework (9.0 - 1679.10) <24F823D3-C3FC-3AF9-B8B3-C166539DBD11> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
          0x7fff8dcd0000 -     0x7fff8dcdcfff  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x7fff8ddde000 -     0x7fff8de02fff  com.apple.MultitouchSupport.framework (304.12 - 304.12) <65CB7653-EACD-3ADB-ABB6-2E0671708301> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
          0x7fff8de03000 -     0x7fff8de05ff7  libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
          0x7fff8de08000 -     0x7fff8de18fff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
          0x7fff8de61000 -     0x7fff8de61fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x7fff8de7a000 -     0x7fff8dee5ff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
          0x7fff8df68000 -     0x7fff8dfb9ff7  libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
          0x7fff8dfba000 -     0x7fff8dfd1ff7  libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
          0x7fff8dfd2000 -     0x7fff8e34dffb  com.apple.VideoToolbox (1.0 - 1731.15.206) <19DD020F-128A-32B0-96A4-A51F111B549F> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
          0x7fff8e351000 -     0x7fff8e4acff3  com.apple.WebKitLegacy (11601 - 11601.7.7) <17A2118E-168F-312C-B083-81DC0BFA3C83> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
          0x7fff8e4ad000 -     0x7fff8e5d1fff  libsqlite3.dylib (216.4) <280D67B8-F93D-3587-A146-19F36C817548> /usr/lib/libsqlite3.dylib
          0x7fff8e5d2000 -     0x7fff8e6abfff  com.apple.CoreMedia (1.0 - 1731.15.206) <DE407384-39D5-3727-A78D-D22849D816C7> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
          0x7fff8e6ac000 -     0x7fff8e6b6fff  com.apple.KerberosHelper (4.0 - 1.0) <67D88B2C-A54B-34FF-ABF3-2D3736879730> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
          0x7fff8e6b7000 -     0x7fff8f902feb  com.apple.CoreGraphics (1.600.0 - 960.3) <407FA367-204F-389E-8E33-0435E3B56D40> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
          0x7fff8f903000 -     0x7fff8f918fff  com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
          0x7fff8f9d8000 -     0x7fff8fabeff7  libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
          0x7fff8fb61000 -     0x7fff8fbacff7  com.apple.CoreMediaIO (703.0 - 4791) <D8BC511D-0C1E-3686-9829-C874FDBE94CB> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
          0x7fff8fbb2000 -     0x7fff8fbf7ff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
          0x7fff8fc95000 -     0x7fff8ff7affb  com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x7fff90040000 -     0x7fff9057eff7  com.apple.MediaToolbox (1.0 - 1731.15.206) <119FFD0E-947D-3103-9221-458439F5764D> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
          0x7fff9057f000 -     0x7fff905aeffb  com.apple.datadetectors (5.0 - 308) <1949868C-BDCD-3772-BDBD-D7E9F2CC1451> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
          0x7fff905af000 -     0x7fff90653fff  com.apple.Bluetooth (4.4.6 - 4.4.6f1) <F8E54D34-DAAB-319F-8AE7-F3C55CA0CC68> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
          0x7fff90718000 -     0x7fff9071bfff  com.apple.IOSurface (108.2.3 - 108.2.3) <52E51D16-42E9-3DDB-A16C-48225EF262C4> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
          0x7fff9071c000 -     0x7fff90a5aff7  com.apple.WebKit (11601 - 11601.7.7) <29B8BA84-D78E-393B-BB36-4B9605372A5F> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
          0x7fff90a6b000 -     0x7fff90d05ff3  com.apple.security (7.0 - 57337.60.2) <E2E553E7-28C4-3296-B3B6-BB1B3CA73943> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x7fff90d06000 -     0x7fff90d75fff  com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x7fff90ef9000 -     0x7fff90efeff3  libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
          0x7fff90f8b000 -     0x7fff90f8dffb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
          0x7fff913d8000 -     0x7fff913e3fff  libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x7fff913e4000 -     0x7fff9148ffff  com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
          0x7fff914e5000 -     0x7fff915d4ff7  libxml2.2.dylib (29.10) <B3B03292-7E1A-34AB-888C-3D49D63D60C6> /usr/lib/libxml2.2.dylib
          0x7fff915d5000 -     0x7fff915d5ff7  libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
          0x7fff915d6000 -     0x7fff915dbff7  libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
          0x7fff915dc000 -     0x7fff915defff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
          0x7fff91618000 -     0x7fff9161bfff  libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
          0x7fff916a5000 -     0x7fff916a6fff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
          0x7fff91843000 -     0x7fff91847fff  com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
          0x7fff91848000 -     0x7fff91902fff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
          0x7fff9283d000 -     0x7fff92890ff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
          0x7fff928b3000 -     0x7fff928bbffb  libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
          0x7fff928bc000 -     0x7fff928c1fff  com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x7fff928c2000 -     0x7fff92d5dffb  com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
          0x7fff92e77000 -     0x7fff92e92fff  com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
          0x7fff92f13000 -     0x7fff93267fff  com.apple.Foundation (6.9 - 1259) <71A9D3A0-0B1F-3E3A-86F3-1486365A6EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x7fff932c9000 -     0x7fff9356fff7  com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x7fff93570000 -     0x7fff9357bfff  com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
          0x7fff9357c000 -     0x7fff9357eff7  com.apple.securityhi (9.0 - 55006) <1E7BE52B-97EA-371A-AECA-1EE2AD246D8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
          0x7fff9357f000 -     0x7fff935d4fff  com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x7fff93cca000 -     0x7fff93eebff7  com.apple.CoreImage (11.4.0 - 366.4.19) <F5B7B115-E43A-3C61-A6AD-EFCDE7FC43A1> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
          0x7fff93eec000 -     0x7fff93ef4fff  libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
          0x7fff93ef5000 -     0x7fff93f0ffff  com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x7fff93f10000 -     0x7fff93f10fff  libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
          0x7fff93f4a000 -     0x7fff95033ff3  com.apple.WebCore (11601 - 11601.7.5) <9153DA7E-1625-382A-8257-8D4293F06F7F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
          0x7fff95034000 -     0x7fff951c0ff7  libGLProgrammability.dylib (12.1) <BCFFBF6B-9717-3456-B6F9-6AE46644B076> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
          0x7fff951c1000 -     0x7fff951f0ff7  com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x7fff95215000 -     0x7fff95215fff  com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
          0x7fff95216000 -     0x7fff95301ff7  com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
          0x7fff953a9000 -     0x7fff953c8ff7  com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
          0x7fff9542f000 -     0x7fff95434fff  com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
          0x7fff95435000 -     0x7fff95438fff  libspindump.dylib (197.1) <48F4C673-9F0C-38BE-B550-88241E812518> /usr/lib/libspindump.dylib
          0x7fff95439000 -     0x7fff9543fff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
          0x7fff95440000 -     0x7fff9547eff7  libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x7fff95493000 -     0x7fff954c6ff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
          0x7fff954c7000 -     0x7fff9550dff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
          0x7fff9550e000 -     0x7fff95519ff7  libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
          0x7fff9551a000 -     0x7fff95548ff7  com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
          0x7fff95566000 -     0x7fff95572ff7  com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
          0x7fff95583000 -     0x7fff9558ffff  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
          0x7fff95590000 -     0x7fff95593ffb  libdyld.dylib (360.22) <1F9FCF2C-5E94-3F2D-B4A5-1238587AA5C6> /usr/lib/system/libdyld.dylib
          0x7fff95594000 -     0x7fff955a5fff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
          0x7fff955ac000 -     0x7fff955aefff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
          0x7fff95618000 -     0x7fff95664fff  com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0x7fff95665000 -     0x7fff95690ff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
          0x7fff95691000 -     0x7fff9569ffff  com.apple.opengl (12.1.0 - 12.1.0) <0718DB60-BA4F-3CF7-A117-10A2515D931F> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x7fff956a5000 -     0x7fff95797ff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
          0x7fff957a5000 -     0x7fff957a5fff  com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
          0x7fff95a9a000 -     0x7fff95c18fff  com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
          0x7fff95c22000 -     0x7fff95c2dff7  libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
          0x7fff95c2e000 -     0x7fff95c37ff7  libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
          0x7fff95c38000 -     0x7fff95c79ff7  libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x7fff95ec7000 -     0x7fff95ed5fff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
          0x7fff95ed6000 -     0x7fff95ed8ff7  libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
          0x7fff95ed9000 -     0x7fff95edafff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
          0x7fff95edb000 -     0x7fff95f15fff  com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
          0x7fff95f1b000 -     0x7fff95f24ff7  com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
          0x7fff95f25000 -     0x7fff95f36fff  libSparseBLAS.dylib (1162.2) <EBEB3848-3468-342A-91A6-5C47F2369CD9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
          0x7fff95f37000 -     0x7fff96142fff  libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
          0x7fff96145000 -     0x7fff96225ff7  unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba .dylib
          0x7fff96496000 -     0x7fff9649fff3  libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
          0x7fff964a0000 -     0x7fff96835fdb  com.apple.vImage (8.0 - 8.0) <4BAC9B6F-7482-3580-8787-AB0A5B4D331B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x7fff96836000 -     0x7fff96852ff7  libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
          0x7fff96890000 -     0x7fff96891fff  libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
          0x7fff96892000 -     0x7fff9698eff7  libFontParser.dylib (158.6) <267A9AE4-4138-3112-8D73-BDFDC96568FF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
          0x7fff96ac6000 -     0x7fff96ac9ff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
          0x7fff96b48000 -     0x7fff96b6dff7  libPng.dylib (1459) <F3A3BCAD-244C-3014-9D44-5ED179BD391D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
          0x7fff96b6e000 -     0x7fff96b7cfff  com.apple.IntlPreferences (2.0 - 192) <0108A3F2-6A11-30B1-965D-A167CC8131EC> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
          0x7fff96d11000 -     0x7fff96d13fff  com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
          0x7fff96d95000 -     0x7fff96e22dd7  com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
          0x7fff96e23000 -     0x7fff96e28fff  com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
          0x7fff96e49000 -     0x7fff96e7bff7  libTrueTypeScaler.dylib (158.6) <469A7620-3B6F-3E06-80A7-8D89E5DD9C81> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
          0x7fff96e7c000 -     0x7fff96f2cfff  com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
          0x7fff96f2d000 -     0x7fff96f7bff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
          0x7fff96f7c000 -     0x7fff96fa5fff  libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
          0x7fff96fa6000 -     0x7fff970ebfff  com.apple.QTKit (7.7.3 - 2943.12) <79EA2D04-09EC-3266-A5F7-A4AACA97FE1E> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
          0x7fff970ec000 -     0x7fff970f2fff  com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
          0x7fff970f6000 -     0x7fff970f9ff7  com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
          0x7fff970ff000 -     0x7fff970fffff  libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
          0x7fff9710b000 -     0x7fff97219ff3  com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x7fff9721a000 -     0x7fff972a9ff7  libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
          0x7fff9747f000 -     0x7fff97b1eff7  com.apple.JavaScriptCore (11601 - 11601.7.2) <4A888404-501D-38DE-921D-BA9AEEAC8243> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
          0x7fff97b1f000 -     0x7fff97b6dfff  libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
          0x7fff97ba5000 -     0x7fff97baefff  com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
          0x7fff97baf000 -     0x7fff97c3efff  com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
          0x7fff97cb7000 -     0x7fff97cbdfff  com.apple.IOAccelerator (205.11 - 205.11) <C51BF724-F8E8-3B9F-806E-A00C65056445> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
          0x7fff97cbe000 -     0x7fff97cbeff7  libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
          0x7fff97cbf000 -     0x7fff97cbfff7  liblaunch.dylib (765.50.8) <834ED605-5114-3641-AA4D-ECF31B801C50> /usr/lib/system/liblaunch.dylib
          0x7fff97cc0000 -     0x7fff97d78ff7  com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
          0x7fff97d82000 -     0x7fff97e22fff  com.apple.Metadata (10.7.0 - 972.34) <A58195C5-5D5C-32D5-8BBB-F4D32201E5AA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x7fff9807a000 -     0x7fff980c6ffb  com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x7fff980e6000 -     0x7fff98448f3f  libobjc.A.dylib (680) <7489D2D6-1EFD-3414-B18D-2AECCCC90286> /usr/lib/libobjc.A.dylib
          0x7fff9846b000 -     0x7fff98470ff7  libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
          0x7fff9853e000 -     0x7fff987cfff7  com.apple.RawCamera.bundle (6.20 - 856) <C66E7CF9-0352-3A5A-AD2B-DE16136EA6B1> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
          0x7fff987d0000 -     0x7fff98859ff7  com.apple.PerformanceAnalysis (1.0 - 1) <1BC106BB-3C7F-37C9-8496-43F584A6F304> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
          0x7fff98861000 -     0x7fff98861fff  com.apple.CoreServices (728.13 - 728.13) <E3DFECD2-ECEA-3242-972D-95B9646B57B8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
          0x7fff988c2000 -     0x7fff994ebff7  com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x7fff99515000 -     0x7fff99531ff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
          0x7fff99576000 -     0x7fff995a1ffb  libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
          0x7fff995a2000 -     0x7fff99611fff  com.apple.datadetectorscore (7.0 - 460) <E8616F01-90AC-3863-B18C-426E6DD1ACDE> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
          0x7fff99671000 -     0x7fff99761ff7  libJP2.dylib (1459) <5212E346-B7FC-31F4-B4F7-CF1DD9BBAFBB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
          0x7fff99762000 -     0x7fff99ff2ff7  libclh.dylib (4.0.3 - 4.0.3) <E7C2EC5E-42F9-321E-AFE8-D715FF9471D9> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
          0x7fff99ff3000 -     0x7fff9a061ff7  com.apple.ApplicationServices.ATS (377 - 394.4) <9779E916-0788-3CAC-B1EC-F68BCB12A2B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x7fff9a26f000 -     0x7fff9a280ff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
          0x7fff9a2b5000 -     0x7fff9a2d9fff  com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
          0x7fff9a36d000 -     0x7fff9a3bffff  com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
          0x7fff9a3c0000 -     0x7fff9a470fe7  libvMisc.dylib (563.5) <6D73C20D-D1C4-3BA5-809B-4B597C15AA86> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x7fff9a471000 -     0x7fff9a48fff7  libsystem_kernel.dylib (3248.60.10) <C1A6A0B9-1869-36AB-B4A2-D862EB09A4BE> /usr/lib/system/libsystem_kernel.dylib
          0x7fff9a490000 -     0x7fff9a492ff7  libRadiance.dylib (1459) <43B09AB2-B747-3EA0-A0AF-9A33B3A449D2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
          0x7fff9a493000 -     0x7fff9a4effff  libTIFF.dylib (1459) <1E1839C3-2C99-38B8-A729-788459576858> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
          0x7fff9a513000 -     0x7fff9a535ff7  com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
          0x7fff9a538000 -     0x7fff9a540fff  libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
          0x7fff9a541000 -     0x7fff9a542fff  libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
          0x7fff9a964000 -     0x7fff9a964fff  com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x7fff9a965000 -     0x7fff9a9c8fff  libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
          0x7fff9a9c9000 -     0x7fff9a9cafff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
          0x7fff9a9e7000 -     0x7fff9a9fefff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
          0x7fff9aa6c000 -     0x7fff9aacafff  com.apple.SystemConfiguration (1.14 - 1.14) <D801FAD7-5A2D-3E5E-9F44-B6C9B8BEA747> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x7fff9b32d000 -     0x7fff9b3b5fff  com.apple.CoreSymbolication (3.1 - 58048.1) <4730422E-4178-34F9-8550-BB92F2A4F44B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
          0x7fff9b3b6000 -     0x7fff9b3b9ff7  libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
          0x7fff9b3e3000 -     0x7fff9b40cff7  libxslt.1.dylib (14.4) <72CD1CA4-1FBD-3672-ADCE-A89AB741689A> /usr/lib/libxslt.1.dylib
          0x7fff9b40d000 -     0x7fff9b4b4fff  com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
          0x7fff9b4b5000 -     0x7fff9b4deff7  libxpc.dylib (765.50.8) <54D1328E-054E-3DAA-89E2-375722F9D18F> /usr/lib/system/libxpc.dylib
          0x7fff9b552000 -     0x7fff9b553fff  libffi.dylib (18.1) <5BA9612C-747E-33CE-9DB1-3C01ECF3041D> /usr/lib/libffi.dylib
          0x7fff9bf76000 -     0x7fff9c1fdfff  com.apple.CFNetwork (760.6.3 - 760.6.3) <8CB9CB2E-D0FB-31D4-A1AE-2A5FE028AD6B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
          0x7fff9c203000 -     0x7fff9c21cfff  com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
          0x7fff9c298000 -     0x7fff9c2c1fff  com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
          0x7fff9c2c2000 -     0x7fff9c69afef  com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
          0x7fff9c69b000 -     0x7fff9c6c4ffb  libRIP.A.dylib (960.3) <702967FB-D16C-38C7-A3CC-0EC336740A69> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
          0x7fff9c6c5000 -     0x7fff9c82cfff  libBLAS.dylib (1162.2) <A1398FE0-39D2-33EA-9A0F-B2644EEA29A0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x7fff9c82d000 -     0x7fff9c864ff7  com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
          0x7fff9c865000 -     0x7fff9c866ffb  libSystem.B.dylib (1226.10.1) <ECAA07BE-A114-3461-AA13-C57838775FC2> /usr/lib/libSystem.B.dylib
          0x7fff9c867000 -     0x7fff9c871fff  com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
          0x7fff9ca1e000 -     0x7fff9ca70fff  com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
          0x7fff9ce5e000 -     0x7fff9ce78ff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
          0x7fff9ce79000 -     0x7fff9ce89fff  com.apple.AppleScriptObjC (1.4 - 32) <0C137AF5-9086-3205-9895-F3B8DF3B47FF> /System/Library/Frameworks/AppleScriptObjC.framework/Versions/A/AppleScriptObjC
          0x7fff9cef4000 -     0x7fff9cf69fff  com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x7fff9cf6a000 -     0x7fff9cf91fff  com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
          0x7fff9d113000 -     0x7fff9d115ff7  com.apple.SafariServices.framework (11601 - 11601.7.7) <4BCAFAC2-CB87-31A1-A27B-B4794B2F8535> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
          0x7fff9d116000 -     0x7fff9d125ffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
          0x7fff9d128000 -     0x7fff9d130fff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
          0x7fff9d131000 -     0x7fff9d55ffff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
          0x7fff9d5de000 -     0x7fff9d62aff7  com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
          0x7fff9d7be000 -     0x7fff9d7cfff7  libsystem_trace.dylib (201.10.3) <1DD0C1FD-74E2-3949-9C2C-B81D19C2CA5E> /usr/lib/system/libsystem_trace.dylib
          0x7fff9d7ef000 -     0x7fff9d866ff7  com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
          0x7fff9d8e5000 -     0x7fff9d901fff  com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
          0x7fff9d907000 -     0x7fff9d907fff  com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
          0x7fff9d908000 -     0x7fff9dbfdfff  com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
          0x7fff9dcc3000 -     0x7fff9dcccff7  com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
          0x7fff9dccd000 -     0x7fff9dcdbfff  com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
          0x7fff9dce0000 -     0x7fff9dce1ff3  com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x7fff9dce2000 -     0x7fff9dce2fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <054DFE32-737D-3211-9A14-0FC5E1A880E3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x7fff9e057000 -     0x7fff9e05bfff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
          0x7fff9e05c000 -     0x7fff9e458fff  libLAPACK.dylib (1162.2) <987E42B0-5108-3065-87F0-9DF7616A8A06> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x7fff9e459000 -     0x7fff9e45cffb  libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
          0x7fff9e477000 -     0x7fff9e48cfff  com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
          0x7fff9e48d000 -     0x7fff9e5b4fff  com.apple.LaunchServices (728.13 - 728.13) <DF9A69C3-06AD-3062-A40A-50ED12CA18CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x7fff9e5b5000 -     0x7fff9e5ceff7  com.apple.SMBClient (3.0.1 - 3.0.1) <60C2DAC8-19DA-3B92-9568-30469403AE7A> /System/Library/PrivateFrameworks/SMBClient.framework/Versions/A/SMBClient
          0x7fff9e5cf000 -     0x7fff9e6defe7  libvDSP.dylib (563.5) <9AB6CA3C-4F0E-35E6-9184-9DF86E7C3DAD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x7fff9e792000 -     0x7fff9e960ff3  com.apple.QuartzCore (1.11 - 410.14) <076BDE58-8AED-3D47-84FD-548CF8E8EDB9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x7fff9e993000 -     0x7fff9e99aff7  com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
          0x7fff9e99b000 -     0x7fff9e9d3ff7  com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
          0x7fff9e9e1000 -     0x7fff9e9e8ff7  libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
          0x7fff9e9e9000 -     0x7fff9eaa2ff7  com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
          0x7fff9eab0000 -     0x7fff9eb21fff  com.apple.DCERPC (2.0 - 61) <955FC8B6-1867-3FDA-8C14-7A51493F3C53> /System/Library/PrivateFrameworks/DCERPC.framework/Versions/A/DCERPC
          0x7fff9eb22000 -     0x7fff9ecceff7  com.apple.avfoundation (2.0 - 1046.9.12) <2D241BC4-A619-3382-BABD-C4E4490BD638> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
          0x7fff9eccf000 -     0x7fff9ed1eff7  com.apple.opencl (2.7.0 - 2.7.0) <39581F1A-04FE-3CCA-9118-E9BB9053F7A1> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
          0x7fff9ed1f000 -     0x7fff9ed27fff  libGFXShared.dylib (12.1) <5A0C2493-200C-30BE-97D5-8E8C0B8E604D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
          0x7fff9ed28000 -     0x7fff9edc8fff  com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
          0x7fff9ee6e000 -     0x7fff9ee86fef  libcompression.dylib (28) <E7601B62-1053-369D-8A9E-91CF86239220> /usr/lib/libcompression.dylib
          0x7fff9ee87000 -     0x7fff9ef1cfff  com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
          0x7fff9ef1d000 -     0x7fff9ef41fff  libJPEG.dylib (1459) <B274689A-56C5-3DBE-9E4E-049608BBD50B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
          0x7fff9ef43000 -     0x7fff9efbafeb  libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
          0x7fff9efbb000 -     0x7fff9efecfff  com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
          0x7fff9eff8000 -     0x7fff9f46efff  com.apple.CoreFoundation (6.9 - 1258.1) <943A1383-DA6A-3DC0-ABCD-D9AEB3D0D34D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x7fff9f481000 -     0x7fff9f48fff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
          0x7fff9f490000 -     0x7fff9f4f7fff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
          0x7fff9f4f8000 -     0x7fff9f58efff  com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x7fff9f6c3000 -     0x7fff9f6d7fff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
          0x7fff9f6da000 -     0x7fff9f6ecfff  libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
          0x7fff9f6ed000 -     0x7fff9f6f1fff  libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
          0x7fff9f756000 -     0x7fff9f759fff  com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
          0x7fff9f75a000 -     0x7fff9f762fef  libcldcpuengine.dylib (2.7.3) <385BE8CE-16D8-3FCB-8558-8EB744D3DFE6> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
          0x7fff9f763000 -     0x7fff9f76efff  libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
          0x7fff9f76f000 -     0x7fff9f777fff  com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
          0x7fff9f7b9000 -     0x7fff9f7fbff7  com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
          0x7fff9f8d2000 -     0x7fff9fb68fff  libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
          0x7fff9fccb000 -     0x7fff9fccbfff  libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
          0x7fff9fe8e000 -     0x7fff9fef4ff7  libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
          0x7fff9fef5000 -     0x7fffa00bbff7  com.apple.ImageIO.framework (3.3.0 - 1459) <228306DC-0C7F-3D69-92FA-B2E46E47AA9F> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
          0x7fffa00bc000 -     0x7fffa0262ff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x7fffa0263000 -     0x7fffa0285fff  com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
          0x7fffa0820000 -     0x7fffa084aff7  libc++abi.dylib (307.2) <922EFB36-0E9E-315B-8270-E81AC43472C0> /usr/lib/libc++abi.dylib
          0x7fffa084e000 -     0x7fffa0859fff  libkxld.dylib (3248.60.10) <991CDFE9-AB87-321B-A4B2-5EFE64DDCF74> /usr/lib/system/libkxld.dylib
          0x7fffa0a39000 -     0x7fffa0a3cfff  libsystem_sandbox.dylib (460.60.2) <2A68B39C-B786-3A05-87A2-56E688469FB8> /usr/lib/system/libsystem_sandbox.dylib
          0x7fffa0a3d000 -     0x7fffa0b87ff7  com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x7fffa0b90000 -     0x7fffa0b92fff  libCGXType.A.dylib (960.3) <70FA6D91-53BC-3DA6-92F3-7FEB33C73948> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
          0x7fffa0c06000 -     0x7fffa0c06fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <185EC96A-5AF0-3620-A4ED-4D3654D25B39> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x7fffa0c0c000 -     0x7fffa0d39ff3  com.apple.CoreText (352.0 - 494.12) <ADBE8355-D4F5-3316-A6C4-D641D615CEC4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
          0x7fffa0d4d000 -     0x7fffa0d61fe3  libCGInterfaces.dylib (317.9) <5079DE4F-3717-32FF-B76A-77F53236D17D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
          0x7fffa0d62000 -     0x7fffa0d7dff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
          0x7fffa0d89000 -     0x7fffa15e7fff  com.apple.GeForceGLDriver (10.10.13 - 10.1.0) <605ABECA-7059-3D44-9877-9BE07D675D95> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
          0x7fffa15e8000 -     0x7fffa1618ff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
          0x7fffa162d000 -     0x7fffa1672ff3  libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
          0x7fffa16b0000 -     0x7fffa16c9fff  com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
          0x7fffa16ca000 -     0x7fffa1875ffb  GLEngine (12.1) <299D9296-2984-3967-9049-A842B99E5D43> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
          0x7fffa1884000 -     0x7fffa188ffff  libGPUSupportMercury.dylib (12.1) <9D35C668-4F21-31C8-890C-CC1F45905194> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
          0x7fffa1890000 -     0x7fffa18f0fff  com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
          0x7fffa18f1000 -     0x7fffa18fcfff  com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
          0x7fffa1904000 -     0x7fffa1932ff7  libsandbox.1.dylib (460.60.2) <DAB5D6F4-CDA9-3AEB-83FF-88F003D5B5E5> /usr/lib/libsandbox.1.dylib
      External Modification Summary:
        Calls made by other processes targeting this process:
          task_for_pid: 11
          thread_create: 0
          thread_set_state: 0
        Calls made by this process:
          task_for_pid: 0
          thread_create: 0
          thread_set_state: 0
        Calls made by all processes on this machine:
          task_for_pid: 30929
          thread_create: 0
          thread_set_state: 0
      VM Region Summary:
      ReadOnly portion of Libraries: Total=642.7M resident=0K(0%) swapped_out_or_unallocated=642.7M(100%)
      Writable regions: Total=1.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.2G(100%)
                                      VIRTUAL   REGION
      REGION TYPE                        SIZE    COUNT (non-coalesced)
      ATS (font support)                32.7M        8
      ATS (font support) (reserved)        8K        3         reserved VM address space (unallocated)
      Accelerate.framework               128K        2
      Activity Tracing                  2048K        2
      CG backing stores                 19.0M       14
      CG image                           768K       50
      CG shared images                   592K       15
      CoreAnimation                       60K       12
      CoreUI image data                  856K       11
      CoreUI image file                  192K        4
      Dispatch continuations            16.0M        2
      Foundation                          20K        3
      Image IO                          2916K      104
      Kernel Alloc Once                    8K        3
      MALLOC                           928.7M     1557
      MALLOC guard page                   32K        7
      MALLOC_LARGE (reserved)           7692K        2         reserved VM address space (unallocated)
      Memory Tag 242                      12K        2
      Memory Tag 249                     156K        3
      OpenCL                               8K        2
      Process Corpse Info               2048K        2
      STACK GUARD                       56.2M       58
      Stack                             36.1M       66
      VM_ALLOCATE                      195.1M       12
      __DATA                            64.5M      854
      __GLSLBUILTINS                    2588K        2
      __IMAGE                            528K        2
      __LINKEDIT                       150.0M      351
      __TEXT                           492.7M      629
      __UNICODE                          552K        2
      mapped file                       81.3M       65
      shared memory                     16.4M       15
      TOTAL                              2.1G     3832
      TOTAL, minus reserved VM space     2.1G     3832
      Model: MacBookPro11,3, BootROM MBP112.0138.B17, 4 processors, Intel Core i7, 2.8 GHz, 16 GB, SMC 2.19f12
      Graphics: Intel Iris Pro, Intel Iris Pro, Built-In
      Graphics: NVIDIA GeForce GT 750M, NVIDIA GeForce GT 750M, PCIe, 2048 MB
      Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
      Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
      Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
      Network Service: AX88179 USB 3.0 to Gigabit Ethernet, Ethernet, en5
      Serial ATA Device: APPLE SSD SM0512F, 500.28 GB
      USB Device: USB 3.0 Bus
      USB Device: USB3.0 Hub
      USB Device: AX88179
      USB Device: Apple Internal Keyboard / Trackpad
      USB Device: BRCM20702 Hub
      USB Device: Bluetooth USB Host Controller
      USB Device: USB2.0 Hub
      USB Device: Keyboard Hub
      USB Device: Apple Keyboard
      USB Device: USB PnP Sound Device
      Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
        • 1. Re: Major InDesign CC2015 Issues
          kstohlmeyer1 Adobe Community Professional
          There is a new patch out today (11.4.1.102) to address several issues with the latest InDesign CC update.
          • 2. Re: Major InDesign CC2015 Issues
            gaeilge Level 1
            Thanks.  I'll see if that pops up on her machine tomorrow.  Hopefully it does and corrects the issues.
            • 3. Re: Major InDesign CC2015 Issues
              gaeilge Level 1
              So far no new updates still just says (2015) for InDesign on all the users machines.
              • 4. Re: Major InDesign CC2015 Issues
                Try going into InDesign's Help Menu and check for updates there. Not sure why you aren't seeing it in the CC desktop app. It's been out for days.
                • 5. Re: Major InDesign CC2015 Issues
                  gaeilge Level 1
                  Nothing, the updates option is blocked out for the user with the issue and if you run it from the cloud app nothing comes back as needing an update.  Same for all other users I asked to check for updates.  Under the admin name I can't even open the program with out the Error 16 coming up on her machine.  I have uninstalled and re-installed InDesign and the Cloud App countless times.  She can open InDesign just fine under her name which is odd.  You would think if the install is busted no one would be able to open it up on the machine at all.  InDesign has always seemed to have issue with updates for all the users and I have no clue why.  I even uninstalled the program completely and went to the Adobe site to run the install to make sure it's the newest one I can get, but it just comes back as the (2015) version every time even on a brand new machine.  Is there a offline installer somewhere for MAC that I could try?  I'm wondering if the version of our subscription won't allow it or something is messed up with our subscription on the Adobe side that is not allowing us to catch the update since it is the same for all 25 users.
                  • 6. Re: Major InDesign CC2015 Issues
                    Do you have single user accounts for each person? The problems you are describing makes me think you have an enterprise or teams managed account for people. 2015 is the latest version.
                    • 7. Re: Major InDesign CC2015 Issues
                      gaeilge Level 1
                      I'm not sure exactly what they call it.  It's the one where I can administer all the users and invite them to join, but they use their own company e-mail to actually sign into the cloud.  I assume teams managed in that case....
                      • 8. Re: Major InDesign CC2015 Issues
                        gaeilge Level 1
                        Sorry, when you said 2015 is the latest version, did you mean the team subscriptions can only update to that version?  Or were you just saying that CC2015 is the newest?  I assume from going off their website which doesn't looks like it's updated with that newest info that InDesign (2015.5) or something similar to that should be the newest version available.  Says the last update was in June for 2015.4, but ours are listed as just InDesign (2015).  Added a pic to show you what I am referring to and this link: InDesign CC new features | New modern and customizable UI  is what I'm going of off for the updates.  As you can see the Photoshop and Illustrator have the 2015 with the .# after it, but InDesign doesn't.
                        • 9. Re: Major InDesign CC2015 Issues
                          Do you allow users to individually update their own software? Normally with a managed account, you would create a packaged deployment from the administration console to push to users.
                          • 10. Re: Major InDesign CC2015 Issues
                            gaeilge Level 1
                            They cannot update the programs without a local or domain admin password.  We originally were using the Adobe Packager to create the installs and used SSCM with Parallel's to push the installs and updates.  We stopped doing that when we started to notice that it was causing too many issues with the programs crashing too often and sometimes it would install the program twice, but neither would open.  It took more time to fix everything and re-install then it did to just update them manually so we now just have them hit update all and type in the admin password for them in person or remotely using DameWare.
                            • 11. Re: Major InDesign CC2015 Issues
                              Beth@little-engine
                              I have this version (11.4.1.102) installed and still having the consistent crashes whenever copying and pasting.
                              • 12. Re: Major InDesign CC2015 Issues
                                davidc26358293
                                Did you look at that user's fonts? Whenever I have issues with InDy, esp when trying to make PDFs, a corrupt font or font cache is usually the issue for me. Is that user's email also crashing? Is this person using a 3rd party font management program like Suitcase?
                                Anyway I would recommend running a program like Font Nuke to clear the user's font caches and then if that doesn't improve the situation, deactivate all non-Apple fonts and try running Indesign and creating PDF, and see if you get better results.
