3 Replies Latest reply on Aug 22, 2016 10:14 AM by JimHess
    sorting images
    scotto66890384
      How do you sort images using the star. Each time I select an image and rate the image it moves the location of the image to the end of the film strip and the I have to look through all the images again to get back to the location in the film strip.
        • 1. Re: sorting images
          dj_paige Level 10
          There is no sort available by star ratings.
          You can filter by star ratings, which is different than sorting. You would use the Filter Bar to do this.
          The reason the photos move to the end of the film strip is because you have set the sort order to something that causes this, you might want to change the sort order to capture date. Use the menu command View->Sort
          • 2. Re: sorting images
            Axel Matt Adobe Community Professional
            You have to change the sort order to the "recording time" for example.
            Axel
            • 3. Re: sorting images
              The sort order is changed on the toolbar in the library module. It seems that Lightroom always defaults to "added order" whenever I import new images. I prefer to have my images in filename order. So I have to remember to adjust the sort order whenever I import.
