8 Replies Latest reply on Aug 31, 2016 12:49 AM by Ten A
    How to create and update thumbnail of each Layer on extension panel on every action of user on artboard
    dnyaneshlb Level 1
      I am in process of creating an extension where I need to show thumbnails of all the artboards and layers.
      Additionaly I want to update the thumbnails on every action user performs on artboard. ( just the way in standard layers dialog ).
      As of now, I am using imagecapture() API to get the images of artboards and layers. Please suggest if there is any faster and easier way to achieve this.
      Any help is highly appriciated.
        • 1. Re: How to create and update thumbnail of each Layer on extension panel on every action of user on artboard
          CarlosCanto Adobe Community Professional & MVP
          that might be your only option, I can't think of anything else.
          • 2. Re: How to create and update thumbnail of each Layer on extension panel on every action of user on artboard
            Alexander Ladygin Level 2
            Perhaps this technique will be useful to you..
            This method only works when the user activates extension:
            Create a <input type="hidden" id="isActiveExt" value="0" />
            And add 2 events:
            window.addEventListener( 'focus', function ( event ) {
                var obj = document.querySelector('#isActiveExt');
                if ( !parseInt( obj.value ) ) {
                    obj.value = 1;
                    // Re-enumerates all layers and artboards
            window.addEventListener( 'blur', function ( event ) {
                if ( parseInt( obj.value ) ) {
                    obj.value = 0;
            Description of the method:
            When the user activates expansion, there should automatically update all layers and artboards.
            As a complement, function create thumbnails layers and artboards, you can add in the following events:
            new CSinterface().addEventListener('documentAfterActivate');
            new CSinterface().addEventListener('documentAfterDeactivate');
            new CSinterface().addEventListener('applicationActivate');
            • 3. Re: How to create and update thumbnail of each Layer on extension panel on every action of user on artboard
              dnyaneshlb Level 1
              Thanks Alexander Ladygin. This helps a lot.
              Perhaps the end user will  be more happy to see effect as soon as he performs action rather than clicking on extension(to gain foucus).
              CarlosCanto - I tried to add  kAIDocumentChangedNotifier(Sent when the contents of a document have changed - as per adobe docs) in my plugin code(.aip) to recieve notification as soon as document is modified. But the notifier handle is activated only on document open, close and save event.
              My perception is I should get notified as soon as document gets modified. Surprisingly, there are similar notfiers like kAIDocumentClosedNotifier , kAIDocumentOpenedNotifier,  kAIDocumentSavedNotifier , kAIDocumentNewNotifier which does the same work.
              Can someone please point me to correct API?
              • 4. Re: How to create and update thumbnail of each Layer on extension panel on every action of user on artboard
                Ten A Adobe Community Professional
                You need to build custom CSXS event and dispatch it.
                Here is an sample codes:
                void samplePluginController::notifyMessage(CustomObject* customObject)
                    stringstream myString; //Build notifiers payload
                    myString << "<payload><message>" << customObject->GetFullString() << "</message></payload>";
                    std::string xmlstring = myString.str();
                    csxs::event::Event event = {"com.adobe.csxs.events.notifyMessage",
                        csxs::event::kEventScope_Application,
                        "notifyMessage",
                        NULL,
                        xmlstring.c_str()};
                    htmlPPLib.DispatchEvent(&event);
                You can reference Marked Objects sample in AI SDK.
                2 people found this helpful
                • 5. Re: How to create and update thumbnail of each Layer on extension panel on every action of user on artboard
                  dnyaneshlb Level 1
                  Can you briefly explain how can I get control to dispatch event ( when user draws a line on artboard)?
                  I am  confused here.
                  • 6. Re: How to create and update thumbnail of each Layer on extension panel on every action of user on artboard
                    In MarkedObjectsPlugin.cpp, Add notifyer and capture it like below.
                    //MarkedObjectsPlugin.cpp
                    CHECK_ERROR
                    error = sAINotifier->AddNotifier( fPluginRef, "MarkedObjectsPlugin",
                      kAIDocumentChangedNotifier , &documentChangedNotifier);
                    ASErr MarkedObjectsPlugin::Notify( AINotifierMessage *message )
                      ASErr error = kNoErr;
                      try
                      if ( message->notifier == documentChangedNotifier )
                      fMarkedObjectsPanelController->Clear();
                      fMarkedObjectsPanelController->UpdateMarkedObjectSelected();
                      GetMarkedObjects();
                    You can find function to call previouse notifyer function.
                    //MarkedObjectsPanelController.cpp
                    void MarkedObjectsPanelController::UpdateMarkedObjectSelected( void )
                      // Construct XML string
                      if ( fMarkedObjectManager == NULL)
                      return;
                      int count = fMarkedObjectManager->GetMarkedObjectSize();
                      if ( count <= 0 )
                      return;
                      for(int i = count -1; i >= 0; i--)
                      MarkedObject* markedObject = fMarkedObjectManager->GetMarkedObject(i);
                      if ( markedObject == NULL ) return;
                      if ( markedObject->IsSelected() )
                      UpdatePanelByMarkedObject(markedObject, i);
                      break;
                    void MarkedObjectsPanelController::UpdatePanelByMarkedObject(MarkedObject *markedObject, int index)
                      AIRealPoint location = markedObject->GetLocation();
                      myString << "<payload><item>" << index << "</item><label>" << markedObject->GetLabel()
                      << "</label><ID>" << markedObject->GetID() << "</ID>" << "<locx>"  << location.h
                      << "</locx>" << "<locy>" << location.v << "</locy></payload>";
                      //Make custom event and dispatch it
                      csxs::event::Event event = {"com.adobe.csxs.events.MarkedObjectsUpdatePanel",
                      "MarkedObjectsUpdatePanel",
                      NULL,
                      xmlstring.c_str()};
                      fPPLib.DispatchEvent(&event);
                    You can catch dispatched message in CEP Extension like below.
                    csInterface.addEventListener("com.adobe.csxs.events.MarkedObjectsUpdatePanel", updatePanel);
                    function updatePanel(event) {
                        var xmlData = $.parseXML(event.data);
                        var $xml = $(xmlData);
                      if ($xml.find('item').text() != -1) {
                      var x = $xml.find('locx').text();
                      var y = $xml.find('locy').text();
                      var label = $xml.find('label').text();
                      var id = $xml.find('ID').text();
                      var itemIndex = $xml.find('item').text();
                      $('#homeX').val(x);
                      $('#homeY').val(y);
                      $('#id').val(id);
                      $('#label').val(label);
                      $('input[name="submit"]').removeAttr('disabled');
                    • 7. Re: How to create and update thumbnail of each Layer on extension panel on every action of user on artboard
                      dnyaneshlb Level 1
                      Thanks Ten A for in detail explanation. I got your point. It really helps.
                      integrated above things in my code - added kAIDocumentChangedNotifier(Sent when the contents of a document have changed - as per adobe docs) in my plugin code(.aip) to recieve notification as soon as document is modified. But the notifier handle is activated only on document open, close and save event whereas I want a notifier which notifies me as soon as document is edited(not saved, opened, closed etc).
                      kAIDocumentChangedNotifier appears a bottleneck here.
                      Does this works for you?
                      However I found one notifier while skimming through docs. kAIArtSelectionChangedNotifier does exactly as expected. I can live with that.
                      I am still want to know why kAIDocumentChangedNotifier behaves the way its behaving (it should not as per docs). I must be writing terrible code.
                      • 8. Re: How to create and update thumbnail of each Layer on extension panel on every action of user on artboard
                        Probably, DOCUMENT_CHANGED event fired when activeDocument switched.
                        However, I found below in ai_hostadapter helper script.
                        *  Sent when either a change in the selected art objects occurs or an artwork modification such as moving a point on a path occurs. You cannot distinguish a selection change from an artwork modification change. There is no notifier than means just one or the other. Receiving this does not necessarily mean that the set of selected objects, as returned AIMatchingArtSuite::GetSelectedArt(), is different.
                        AIEvent.ART_SELECTION_CHANGED = 'AI Art Selection Changed Notifier';
                        I think you can catch event using kAIArtSelectionChangedNotifier when document contents changed.
