3 Replies Latest reply on Aug 24, 2016 6:48 AM by Roei Tzoref
    Error message when trying to render
    birkirá30479581
      Hi
      I am trying to render out a 45 sec long sequence. I am using the Media Encoder but I have also tried the After Effects render engine but I get the same error.
      This error message when I try to render out the sequence:
      Export Error
      Error compiling movie.
      Render Error
      Render returned error.
      Writing with exporter: DNxHR/DNxHD MXF OP1a
      Writing to file: /Birkir Asgeirsson/RENDER/Sjonvarp i 50 ar/INTRO/Background NOTA.mxf
      Around timecode: 00:00:01:04
      Rendering at offset: 0,960 seconds
      Component: DNxHR/DNxHD MXF OP1a of type Exporter
      Selector: 9
      Error code: -1609629695
      I found out that there is a composition in my main composition that is creating this error.
          The layer (composition) called "Final TV" is the problem because it works when I turn it off.
      This is the bad guy. This error started to happen when I duplicated "Screen - Episode Name" composition to make it longer. This still happens if I take them away. I dont have any third party plugins in that composition. I only have Trapcode Particular and Optical Flares in the main comp.
      And inside the error composition is this composition.
      Sometimes this error message pop up but I have no idea what this means.
      My computer:
      iMac, Late 2014 with El Capitan
      Prosessor: 4GHz Intel Core i7
      Memory: 32 GB 1600 MHz DDR3
      Graphics card:  AMD Radeon R9 M295X 4096 MB
      After Effects CC 2015.3
      Version 13.8.1.38
