2 Replies Latest reply on Aug 24, 2016 6:33 AM by rob day
    Working in RGB in InDesign
    Klash Royale Level 1
      Good evening,
      I am trying to put together a web - RGB - version of an Annual Report I've just wrapped up. The report was created in CMYK and now, when I bring in Illustrator files with updated color profiles (switched from CMYK to RGB), the swatches and display colors are converted to CMYK regardless. I'm having trouble figuring out how to keep them in RGB.
      As in, if in the Illustrator doc the colors are set up as RGB spot color swatch with an RGB overall document profile. When I place it into inDesign, it converts the doc and imported swatch to CMYK. If I create a new swatch via InDesign, it shows up in RGB no problem. Ugg... I don't often fell like a dumb-dumb in InDesign, but this is very frustrating. Any help would be appreciated.
      Thank you!
      KR.
        • 1. Re: Working in RGB in InDesign
          philippanmei Level 4
          Press Alt+E+B and choose Document RGB. Hope this is the option you are looking for...
          3 people found this helpful
          • 2. Re: Working in RGB in InDesign
            Unlike Illustrator, InDesign allows you to have a mix of different color modes on a page—RGB, Lab, CMYK, or placed grayscale. A document has two profiles assigned—an RGB profile to handle the preview of RGB colors, swatches, and placed RGB objects with no profile, and a CMYK profile to handle the preview of CMYK colors, swatches, placed CMYK with no profile, and grayscale objects.
            Is there a reason for defining a spot color? Does the annual report print with extra spot plates? Try setting the AI RGB color to process not spot, and if there is transparency on the ID page set your Transparency Blend Space to RGB. Also turn off Overprint Preview, which forces the preview of all color into your document's CMYK profile.
            When you export the report to PDF you can convert all color into a single RGB space, so you can have a mix of color spaces and export to a uniform color space. Something like this which would convert everything into sRGB:
