8 Replies Latest reply on Jan 9, 2018 3:04 PM by Kieren Smith
    Banners running slow on Wordpress
    nsaneo
      Hi Adobe,
      We create ads with Animate CC.
      Unfortunately, when we preview a bannerset on Wordpress for our client, the animation is running slow, especially on PC.
      Bannerset with custom eases
      When we preview a banner separately, it runs normal:
      Single banner with custom eases
      Can somebody help us out? Thank you!
      The animation isn't complicate:
      What we've tried:
      1. We compared the Animate CC banners with banners we created with Greensock.
      The Greensock banners are running normal: ABN Amro – Kortlopende Reisverzekering |  De Franse Kamer
      The Animate CC banners are running slow: ABN Amro – Ondernemen |  De Franse Kamer
      2. We tried different FPS settings in Animate CC.
      3. We tried this solution that increases the number of connections that are made.
      4. We don't use sprite sheets or filters.
      5. We noticed the bannerset runs faster in Firefox.
      Extra info:
      Browsers are updated
      Animate CC 2015.2
      Wordpress and its plugins are updated
        • 1. Re: Banners running slow on Wordpress
          just.emma Level 4
          Why are you loading the Enabler and including code for DCRM for a simple standard banner?  I see you also have the clicktag for DCM; if the banners are being trafficked through DCM you should get rid of the enabler and any references to it.
          Why are you loading TweenMax if you're using timeline animation in Animate CC?
          I would try cleaning up your HTML file and seeing if that improves the performance.
          Also, you should publish your file instead of just doing a publish preview, to get rid of the cache-busting variable (extra numbers) appended to the name of the animation JavaScript file.
          2 people found this helpful
          • 2. Re: Banners running slow on Wordpress
            just.emma Level 4
            Also, why aren't you using Animate's built-in high DPI support?  The newer templates in Animate CC 2015.2 and up have that built in so you don't need to add extra code for that.
            If I was you, I would scrap the whole template you're using and start fresh with Animate's newer templates.
            • 3. Re: Banners running slow on Wordpress
              marjantrajkovski Level 4
              You have problem with site (PAGE) - RESOURSES (CPU, GPU, RAM).
              • 4. Re: Banners running slow on Wordpress
                nsaneo Level 1
                Thanks Emma! We're going to start from scratch and see wat it does. We'll get back and post the result.
                • 5. Re: Banners running slow on Wordpress
                  nsaneo Level 1
                  Hi Marjan,
                  Thanks for helping us too. Are you saying that the banners are asking too much CPU which causes the slow animation?
                  • 6. Re: Banners running slow on Wordpress
                    nsaneo Level 1
                    Hi Emma,
                    I did what you said. The banners still preview slow: Bannerset
                    The banner on its own: Single banner
                    What I did
                    1. I created a new HTML5 canvas document
                    2. I copied the layers from the previous .fla into this new one
                    3. I copied only the DCM clicktag, the style and the rollOverFunctions.
                    What I noticed
                    1. The .JS file got smaller with 30kb, which is great
                    2. The CPU jumps to 104% when I play the Animate CC banner. The Greensock banners sticks at 60% CPU. (Macbook Pro)
                    2. In Firefox (48) or Internet Explorer (11) the banners seem to play a bit faster than Chrome (52).
                    3. Its not the template, uploaded a test on my website: MISU › ABN Amro
                    What else can I try?
                    Thank you
                    _________
                    Update
                    Greensocks template for Animate CC seems to fix my problem.
                    Something in their index file fixes the CPU problem.
                    I'll get back when it's fully working.
                    • 7. Re: Banners running slow on Wordpress
                      nsaneo Level 1
                      So after weeks I figured out that AdHelper fixed my problem.
                      This code should be added in a next update to any Animate CC html file:
                      var ad = new createjs.AdHelper(stage)
                        .setSleep(15,0,0)
                        .timeSync()
                        .watchFPS(15, 1);
                        var failCount = 1;
                        ad.on("slow", function(evt) {
                        if (failCount === 0) {
                        evt.preventDefault();
                        failCount++;
                        this.watchFPS(15, 1);
                        // else if (failCount === 1){
                        // createjs.AdHelper.showAltImage(canvas, "images/backup_300x250.jpg", "javascript:doClickthrough(this)", "BannerWave", "_blank");
                        function changeFPS(framerate){
                        createjs.Ticker.setFPS(framerate);
                      Cheers
                      • 8. Re: Banners running slow on Wordpress
                        Kieren Smith Level 1
                        Did you end up getting a fix for this? I'm noticing that banners loaded into an iFrame play slowly in safari. but normal speed in chrome and firefox.
