30 Replies Latest reply on Aug 25, 2016 10:27 AM by Laubender
    Language Id's wont change
    funkturmmitte Level 1
      Hi!
      I'm poking around with the attemp to set the language ID for simplified Chinese by Javascript.
      It does work when i use, for example, french but I couldnt find a way to do this for an asian language.
      I also tried it with an installation of InDesign CC in chinese.
      May anyone have an idea how to get this to work?
      var _ps = app.documents.firstItem().allParagraphStyles;
      for (var i = 1; i < _ps.length; i++)    {
          _ps[i].composer = 'Adobe Japanese Paragraph Composer';
           _ps[i].appliedLanguage = '$ID/Chinese: Simplified';
      Thomas
        • 2. Re: Language Id's wont change
          tpk1982 Level 4
          I hope we don't need $ID, give straight away the name
          _ps[i].appliedLanguage = 'Chinese: Simplified';
          • 3. Re: Language Id's wont change
            I already saw the mentioned thread but even after reading it i couldn't get it done.
            • 4. Re: Language Id's wont change
              tpk1982 Level 4
              try _ps[i].appliedLanguage = 'Chinese: Simplified';
              or just post the screen shot of your desired language in indesign
              • 5. Re: Language Id's wont change
                also doesn't work.
                I'm testing this on a german version of  InDesign as well as an chinese version.
                • 6. Re: Language Id's wont change
                  tpk1982 Level 4
                  So that i asked to post the screenshot like mine
                  • 8. Re: Language Id's wont change
                    tpk1982 Level 4
                    give this
                    _ps[i].appliedLanguage = 'Chinesisch: vereinfacht';
                    • 9. Re: Language Id's wont change
                      Same result as before.
                      Do you have any idea how to copy the error message from the botton of the estk-window?
                      The console doesn't show this message.
                      • 10. Re: Language Id's wont change
                        tpk1982 Level 4
                        use try catch method
                        • 11. Re: Language Id's wont change
                          tpk1982 Level 4
                          try{var _ps = app.documents.firstItem().allParagraphStyles;
                          catch(e){alert(e)}
                          • 12. Re: Language Id's wont change
                            Error: Ungültiger Wert für Einrichtung der Eigenschaft „appliedLanguage“. LanguageWithVendors, Language or String erwartet, aber „Chinesisch: vereinfacht“ erhalten.
                            The translation should be like this:
                            Invalid value for set property 'appliedLanguage'. Expected LanguageWithVendors, Language or String but received "Chinesisch: vereinfacht".
                            • 13. Re: Language Id's wont change
                              Hi Thomas,
                              Japanese composer with language setting for Chinese Simplified?
                              How would that go together? I'm just curious, don't know a thing about the Japanese composer…
                              Adobe Japanese Paragraph Composer string is:
                              "$ID/HL Composer J"
                              Adobe Japanese Single-line Composer string is:
                              "$ID/HL Single J"
                              And what about the Chinese Simplified string?
                              Maybe appliedLanguage is looking for a native Chinese string?
                              ( Just a wild guess )
                              Since your screenshot is showing "Chinesisch: vereinfacht" as available language for a paragraph style what would that style return, if you ask about its appliedLanguage value?
                              // Index 1 is the [Basic Paragraph Style] / German: [Einf. Abs.]
                              app.documents[0].paragraphStyles[1].appliedLanguage.name;
                              Regards,
                              Uwe
                              • 14. Re: Language Id's wont change
                                Or if you set the language in your UI to "Chinesisch: vereinfacht", what will happen if you retrieve the ID of the language and try to apply the language by its ID?
                                // Get the ID:
                                var myChineseLanguageID = app.documents[0].paragraphStyles[1].appliedLanguage.id;
                                // Target a DIFFERENT paragraph style in the SAME document:
                                app.documents[0].paragraphStyles[2].appliedLanguage = app.languagesWithVendors.itembyID(myChineseLanguageID);
                                // Target a DIFFERENT paragraph style in a SECOND document that is open:
                                app.documents[1].paragraphStyles[1].appliedLanguage = app.languagesWithVendors.itembyID(myChineseLanguageID);
                                Regards,
                                Uwe
                                • 15. Re: Language Id's wont change
                                  Well, as I know the Japanese paragraph composer is used for all CJK (Korean, Japanese, Chinese) languages.
                                  The result is, according to native speakers, correct.
                                  With the Chinese version of indesign there is only a string "Chinese: simplified" in the idml file (can't check the correct spelling right now as I am out out the office).
                                  • 16. Re: Language Id's wont change
                                    Thank you Uwe, I'm gonna try it tomorrow.
                                    • 17. Re: Language Id's wont change
                                      This returns "Chinesisch: vereinfacht"
                                      And
                                      Simply returns this error message:
                                      ReferenceError: app.languagesWithVendors.itembyID is not a function
                                      About the Japanese Paragraph Composer: https://helpx.adobe.com/indesign/using/composing-cjk-characters.html
                                      • 18. Re: Language Id's wont change
                                        Sorry. There is a typo on my side.
                                        itemByID, not: itembyID. I typed too fast.
                                        Uwe
                                        • 19. Re: Language Id's wont change
                                          By the way, the list of of available languages in the chinese Version of InDesign reads like this:
                                          [未指定语言] => $ID/[No Language]  OR  $ID/[No language]
                                          中文: 简体 => $ID/Chinese: Simplified
                                          中文: 繁体 => $ID/Chinese: Traditional
                                          丹麦语 => $ID/Danish
                                          乌克兰语 => $ID/Ukrainian  OR  $ID/IDX_Ukrainian
                                          俄语 => $ID/Russian  OR  $ID/IDX_Russian
                                          保加利亚语 => $ID/Bulgarian  OR  $ID/IDX_Bulgarian
                                          克罗地亚语 => $ID/Croatian  OR  $ID/IDX_Croatian
                                          加泰罗尼亚语 => $ID/Catalan
                                          匈牙利语 => $ID/Hungarian  OR  $ID/IDX_Hungarian
                                          印地文 (印度) =>
                                          古加拉提文 (印度) =>
                                          土耳其语 => $ID/Turkish  OR  $ID/IDX_Turkish
                                          埃纳德文 (印度) =>
                                          奥里亚语(印度) =>
                                          孟加拉文 (印度) =>
                                          希伯来语 => $ID/PlaceHolder_Hebrew  OR  $ID/Hebrew  OR  $ID/kWRIndexGroup_HebrewAlphabet
                                          希腊语 => $ID/PlaceHolder_Greek  OR  $ID/Greek  OR  $ID/kWRIndexGroup_GreekAlphabet
                                          德语: 1996 年改革后的规则 => $ID/German: Reformed
                                          德语: 2006 年改革后的规则 => $ID/de_DE_2006
                                          德语: 旧规则 => $ID/German: Traditional
                                          德语: 瑞士 => $ID/German: Swiss
                                          德语: 瑞士(2006 年改革后的规则) => $ID/de_CH_2006
                                          意大利语 => $ID/Italian
                                          拉脱维亚语 => $ID/Latvian  OR  $ID/IDX_Latvian
                                          挪威语: 博克马尔 => $ID/Norwegian: Bokmal
                                          挪威语: 尼诺斯克 => $ID/Norwegian: Nynorsk
                                          捷克语 => $ID/Czech  OR  $ID/IDX_Czech
                                          斯洛伐克语 => $ID/Slovak  OR  $ID/IDX_Slovak
                                          斯洛文尼亚语 => $ID/Slovenian  OR  $ID/IDX_Slovenian
                                          旁遮普文 (印度) =>
                                          日文 => $ID/PlaceHolder_Japanese  OR  $ID/Japanese
                                          法语 => $ID/French
                                          法语: 加拿大 => $ID/French: Canadian
                                          波兰语 => $ID/Polish  OR  $ID/IDX_Polish
                                          泰卢固文 (印度) =>
                                          泰米尔文 (印度) =>
                                          爱沙尼亚语 => $ID/Estonian  OR  $ID/IDX_Estonian
                                          瑞典语 => $ID/Swedish
                                          立陶宛语 => $ID/Lithuanian  OR  $ID/IDX_Lithuanian
                                          罗马尼亚语 => $ID/Romanian  OR  $ID/IDX_Romanian
                                          芬兰语 => $ID/Finnish
                                          英语: 加拿大 => $ID/English: Canadian
                                          英语: 美国 => $ID/English: USA
                                          英语: 美国医学 => $ID/English: USA Medical
                                          英语: 美国法律 => $ID/English: USA Legal
                                          英语: 英国 => $ID/English: UK
                                          荷兰语: 2005 年改革后的规则 => $ID/nl_NL_2005
                                          荷兰语: 旧规则 => $ID/Dutch
                                          葡萄牙语 => $ID/Portuguese
                                          葡萄牙语: 巴西 => $ID/Portuguese: Brazilian
                                          葡萄牙语: 拼字协议 => $ID/Portuguese: Orthographic Agreement
                                          西班牙语 => $ID/Spanish  OR  $ID/Spanish: Castilian  OR  $ID/IDX_Spanish
                                          阿拉伯语 => $ID/Arabic  OR  $ID/PlaceHolder_Arabic  OR  $ID/kWRIndexGroup_ArabicAlphabet
                                          韩文 => $ID/hngl  OR  $ID/Korean  OR  $ID/Hangul
                                          马拉地文 (印度) =>
                                          马拉雅拉姆语(印度) =>
                                          • 20. Re: Language Id's wont change
                                            The result is "Ergebnis: [object LanguageWithVendors]"
                                            • 21. Re: Language Id's wont change
                                              Hi Thomas,
                                              the result of where exactly? I guess you mean the contents of the JavaScript Console of your ESTK.
                                              So check your paragraph style, not the JavaScript Console of the ESTK, if the right language is now applied.
                                              Explanation:
                                              You just ran a code snippet from the ESTK, that is not wrapped into any function or is terminated with an exit(); command.
                                              So the message in the JavaScript console would reflect the last returned object of your snippet.
                                              And that indeed should be a [object LanguageWithVendors] if all goes well.
                                              Regards,
                                              Uwe
                                              • 22. Re: Language Id's wont change
                                                Hi Uwe!
                                                Yes, i meant the content of the console.
                                                Thank you a lot for your effort, but actually there has been no effect in the paragraph styles – nothing changed.
                                                The chinese language is not accessible in the german InDesign version - but if i edit the content of idml files it shows up in the menu. Also i can use the entry in the menu in documents in which the language has been selected before.
                                                Quiete the same for the paragraph composer. The Japanese one is not accessible with the german GUI but it can be activated by a script or the import of definitions from another document.
                                                Regards
                                                Thomas
                                                • 23. Re: Language Id's wont change
                                                  funkturmmitte wrote:
                                                  … The chinese language is not accessible in the german InDesign version - but if i edit the content of idml files it shows up in the menu. Also i can use the entry in the menu in documents in which the language has been selected before.
                                                  Hm. Then you need the original Chinese language version to get what you want.
                                                  For this: Do not uninstall your German InDesign.
                                                  Do a second install with InDesign through the Adobe CC Desktop App where you first set your system language to Chinese before, then set the language inside the CC Desktop App to Chinese and chose the Chines version to install. And after installing setting back your system language to German.
                                                  Then you should get a merge of a German UI InDesign with (some or all?) Chinese features.
                                                  Note: I never tried this.
                                                  But you could ask Willi Adelberger who once did this, if I recall that right:
                                                  https://forums.adobe.com/people/Willi+Adelberger
                                                  Best,
                                                  Uwe
                                                  • 24. Re: Language Id's wont change
                                                    Thank you Uwe, i've been aware of this, and i already did this a while ago.
                                                    I'll keep on searching for a scriptable way to set the language.
                                                    Regards
                                                    Thomas
                                                    • 25. Re: Language Id's wont change
                                                      David W. Goodrich Level 3
                                                      I'm no scripter so I'm way out of my depth here, but I dimly recall Marc Autret's discussing peculiarities of "app.LanguagesWithVendors" back in December 2011.
                                                      David
                                                      • 26. Re: Language Id's wont change
                                                        Hi David,
                                                        thank you for pointing at this thread.
                                                        However, there seems to be no real solution unless one is using—my guess—the "real" Chinese version (whatever that is).
                                                        Perhaps a Chinese version plus the system language set to Chinese and the keyboard as well?! Don't know.
                                                        Regards,
                                                        Uwe
                                                        • 27. Re: Language Id's wont change
                                                          Yeah i read this thread from Marc Autret.
                                                          But anyway for now i archieved my goal and
                                                          does finally work!
                                                          Before it works i need to import Paragraph Formats with these language settings.
                                                          Afterwards they are available in the actual document and also scriptable.
                                                          • 28. Re: Language Id's wont change
                                                            Aha!
                                                            Don't get me wrong here, but did you test, if the rules for breaking lines according to Simplified Chinese are working alright?
                                                            If yes, this is quiet a hack. The underlying technology would be there but is not exposed directly to the UI or even to straight scripting…
                                                            I wish you all the best!
                                                            Uwe
                                                            • 29. Re: Language Id's wont change
                                                              Well, the line breaks are done by the Japanese paragraph composer.
                                                              For my workmates, which are native speakers , it looks fine. And it's seems like the spellcheck does also work now.
                                                              • 30. Re: Language Id's wont change
        Good to know, Thomas.
        Thank you very much for reporting back.
        Best,
        Uwe
