10 Replies Latest reply on Aug 24, 2016 6:28 AM by Akash Sharma
    Lightroom not updating
    Nick W CB Level 1
      I have been trying to update LR CC with the latest patch with no success. I have gone as far as uninstalling and re-installing it which too me back to the 2015 version, and I am now unable to install even that patches that I had before (using the links on this page All Adobe CC 2015 Updates: The Direct Download Links for Windows | ProDesignTools ). So I have gone backwards in my capabilities. I have tried running the patches in administrator mode. The error I am getting is:
      Lightroom CC / 6 Update – June 2016
      Installation failed. Error Code: U44M2P7
      Please help!
        • 1. Re: Lightroom not updating
          Akash Sharma Adobe Employee
          HI NickWCB,
          Please follow the article below.
          Updates don't install | Update failure or U44M errors in Adobe Photoshop CS6
          Let us know if that helps.
          Regards,
          Akash
          • 2. Re: Lightroom not updating
            Nick W CB Level 1
            Windows 10 Pro all up to date.
            I do have a subscription to the Photography plan.
            • 3. Re: Lightroom not updating
              Nick W CB Level 1
              Hi Akash,
              Been there, done that.
              • 4. Re: Lightroom not updating
                Please sign out of Creative Cloud and then use Adobe Cleaner to remove Lightroom CC.
                Follow Use the Creative Cloud Cleaner Tool to solve installation problems
                • Once done restart your computer.
                • Sign back to Creative cloud app and install Lightroom CC.
                ~Akash
                • 5. Re: Lightroom not updating
                  Nick W CB Level 1
                  Oh good, now I don't have Photoshop either!
                  Photoshop installer error:
                  Exit Code: 184
                  -------------------------------------- Summary --------------------------------------
                  - 2 fatal error(s), 0 error(s), 1 warnings(s)
                  FATAL: Error (Code = 184) executing in command 'MoveFileCommand' for package: 'AdobePreview1.2.0All-win64', version:1.2.0
                  FATAL: Error occurred in install of package (Name: AdobePreview1.2.0All-win64 Version: 1.2.0). Error code: '184'
                  WARN: Unable to move file at "C:\adobeTemp\ETRC682.tmp\1\Application\preview.generate\node-usbmux\gulpfile.js" to "C:\Program Files\Common Files\Adobe\Plug-Ins\CC\Generator\preview20155.generate\node-usbmux\gulpfile.js" Error 32 The process cannot access the file because it is being used by another process.. Try setting correct permissions to the specified file/folder or parent folder, so that admin has rights to modify it.
                  Lightroom installer error:
                  Exit Code: 7
                  Please see specific errors below for troubleshooting. For example,  ERROR: DF024 ...
                  - 0 fatal error(s), 1 error(s)
                  ----------- Payload: Adobe Lightroom 6.0.0.0 {8048A5DF-8A70-5BE1-954B-E0FDE1BD0D0D} -----------
                  ERROR: DF024: Unable to move file at "C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{8048A5DF-8A70-5BE1-954B-E0FDE1BD0D0D}\_230_2119bfc4dc03 874f1f235a879eeac6e1" to "C:\Program Files\Adobe\Adobe Lightroom\Helpers\DynamicLinkMediaServer\dynamiclinkmediaserver\1.0\libmmd.dll" Error 32 The process cannot access the file because it is being used by another process.. Try setting correct permissions to the specified file/folder or parent folder, so that admin has rights to modify it.(Seq 223)
                  • 6. Re: Lightroom not updating
                    Could you please create an new admin account and install the products there?
                    This seems to be a corrupt installation and needs to be reproduced to check for permissions issue.
                    ~Akash
                    • 7. Re: Lightroom not updating
                      Nick W CB Level 1
                      I just get different errors.
                      Photoshop:
                      Exit Code: 146
                      FATAL: Error (Code = 146) executing in command 'MoveDirectoryCommand' for package: 'AdobePhotoshop17-Core_x64', version:17.0.1.159
                      FATAL: Error occurred in install of package (Name: AdobePhotoshop17-Core_x64 Version: 17.0.1.159). Error code: '146'
                      WARN: Failed to move directory 'C:\adobeTemp\ETRF97C.tmp\1\Application' to 'C:\Program Files\Adobe\Adobe Photoshop CC 2015.5'
                      Lightroom:
                      Exit Code: 7
                      ERROR: DF024: Unable to move file at "C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{8048A5DF-8A70-5BE1-954B-E0FDE1BD0D0D}\_48_af8e9aade534f 403ccd4ce383ca453d3" to "C:\Program Files\Adobe\Adobe Lightroom\dvaplayer.dll" Error 32 The process cannot access the file because it is being used by another process.. Try setting correct permissions to the specified file/folder or parent folder, so that admin has rights to modify it.(Seq 49)
                      • 8. Re: Lightroom not updating
                        Please Follow the 2 articles :
                        Issue is related to permissions, so you may need to disable antivirus,Create the required folder manually and grant Full Read/write access.
                        Resolve Error Code 146 encountered while installing Creative Cloud desktop apps... https://helpx.adobe.com/creative-cloud/kb/Error_Code_146.html
                        Error exit code 6, exit code 7 installing Adobe Creative Cloud
                        ~Akash
                        • 9. Re: Lightroom not updating
                          Nick W CB Level 1
                          Disabling Avast fixed it. Thanks for your help.
                          • 10. Re: Lightroom not updating
                            Glad to know it helped.
                            ~Akash
