8 Replies Latest reply on Aug 25, 2016 7:37 AM by Chris W. Griffith
    Windows gives me an error when uploading my app
    radedesign Level 1
      Hi all,
      I wonder if anybody else has the same problem. When I upload my app to PhoneGap it gives me an error in the windows sections. I just started doing it recently. I didn't have this problem before. I know that ios always gives me an error because I don't have a key for it yet. I contacted the support center, but haven't gotten any answer. Anybody can help please?
      Rade
      Here is the screenshot of it:
        • 1. Re: Windows gives me an error when uploading my app
          VectorP Level 4
          Well, what does the build log say?
          • 3. Re: Windows gives me an error when uploading my app
            kerrishotts Adobe Employee
            Please post it as a gist or pastebin so we can see it.
            • 4. Re: Windows gives me an error when uploading my app
              radedesign Level 1
              Sorry, here you go
              Build Date: 2016-08-23 20:35:09 +0000
              PLUGIN OUTPUT
              Fetching plugin "cordova-plugin-battery-status@~1.1.1" via npm
              Installing "cordova-plugin-battery-status" at "1.1.2" for windows
              Fetching plugin "cordova-plugin-camera@~2.1.1" via npm
              Installing "cordova-plugin-camera" at "2.1.1" for windows
              Fetching plugin "cordova-plugin-media-capture@~1.2.0" via npm
              Installing "cordova-plugin-media-capture" at "1.2.0" for windows
              Fetching plugin "cordova-plugin-file" via npm
              Installing "cordova-plugin-file" at "4.2.0" for windows
              Fetching plugin "cordova-plugin-compat" via npm
              Installing "cordova-plugin-compat" at "1.0.0" for windows
              The Android Persistent storage location now defaults to "Internal". Please check this plugins README to see if you application needs any changes in its config.xml.
              If this is a new application no changes are required.
              If this is an update to an existing application that did not specify an "AndroidPersistentFileLocation" you may need to add:
                "<preference name="AndroidPersistentFileLocation" value="Compatibility" />"
              to config.xml in order for the application to find previously stored files.
              Fetching plugin "cordova-plugin-console@~1.0.2" via npm
              Installing "cordova-plugin-console" at "1.0.3" for windows
              Fetching plugin "cordova-plugin-contacts@~2.0.1" via npm
              Installing "cordova-plugin-contacts" at "2.0.1" for windows
              Fetching plugin "cordova-plugin-device@~1.1.1" via npm
              Installing "cordova-plugin-device" at "1.1.2" for windows
              Fetching plugin "cordova-plugin-device-motion@~1.2.0" via npm
              Installing "cordova-plugin-device-motion" at "1.2.1" for windows
              Fetching plugin "cordova-plugin-device-orientation@~1.0.2" via npm
              Installing "cordova-plugin-device-orientation" at "1.0.3" for windows
              Fetching plugin "cordova-plugin-dialogs@~1.2.0" via npm
              Installing "cordova-plugin-dialogs" at "1.2.1" for windows
              Plugin "cordova-plugin-file" already installed on windows. Making it top-level.
              Fetching plugin "cordova-plugin-file-transfer@~1.5.0" via npm
              Installing "cordova-plugin-file-transfer" at "1.5.1" for windows
              Dependent plugin "cordova-plugin-file" already installed on windows.
              Fetching plugin "cordova-plugin-geolocation@~2.1.0" via npm
              Installing "cordova-plugin-geolocation" at "2.1.0" for windows
              Fetching plugin "cordova-plugin-globalization@~1.0.3" via npm
              Installing "cordova-plugin-globalization" at "1.0.3" for windows
              Fetching plugin "cordova-plugin-inappbrowser@~1.3.0" via npm
              Installing "cordova-plugin-inappbrowser" at "1.3.0" for windows
              Fetching plugin "cordova-plugin-media@~2.2.0" via npm
              Installing "cordova-plugin-media" at "2.2.0" for windows
              Fetching plugin "cordova-plugin-network-information@~1.2.0" via npm
              Installing "cordova-plugin-network-information" at "1.2.1" for windows
              Fetching plugin "cordova-plugin-splashscreen@~3.2.1" via npm
              Installing "cordova-plugin-splashscreen" at "3.2.2" for windows
              Fetching plugin "cordova-plugin-statusbar@~2.1.2" via npm
              Installing "cordova-plugin-statusbar" at "2.1.3" for windows
              Fetching plugin "cordova-plugin-vibration@~2.1.0" via npm
              Installing "cordova-plugin-vibration" at "2.1.1" for windows
              Fetching plugin "cordova-plugin-whitelist@~1.2.1" via npm
              Installing "cordova-plugin-whitelist" at "1.2.2" for windows
              Building project: C:\cygwin\tmp\gimlet\2228375\project\CordovaApp.Windows10.jsproj
              Configuration : debug
              Platform : x86
              C:\cygwin\tmp\gimlet\2228375\project\build\windows\debug\x86\win10\AppxManifest.xml : error APPX0501: Validation error. error C00CE014: App manifest validation error: The app manifest must be valid as per schema: Line 35, Column 6, Reason: Element '{http://schemas.microsoft.com/appx/manifest/uap/windows10}Capability' is unexpected according to content model of parent element '{http://schemas.microsoft.com/appx/manifest/foundation/windows10}Capabilities'. Expecting: {http://schemas.microsoft.com/appx/manifest/foundation/windows10}DeviceCapability. [C:\cygwin\tmp\gimlet\2228375\project\CordovaApp.Windows10.jsproj]
              • 5. Re: Windows gives me an error when uploading my app
                radedesign Level 1
                I solved the problem by removing all of the plugins from the config.xml page
                • 6. Re: Windows gives me an error when uploading my app
                  Chris W. Griffith Adobe Community Professional
                  I doubt you need all of those anyway in your app.
                  Let's us know if you find out which one might be the problem
                  Chris
                  • 7. Re: Windows gives me an error when uploading my app
                    radedesign Level 1
                    Hi Chris,
                    At the end I only removed this one <plugin name="cordova-plugin-geolocation" source="npm" spec="~2.1.0"/> and everything works
                    • 8. Re: Windows gives me an error when uploading my app
                      The latest version is 2.2, you might try bumping the spec and seeing if there it works.
                      cg
