7 Replies Latest reply on Aug 25, 2016 9:38 AM by upper_pachilo
    Is possible to use the GPU power with the aerender.exe command line?
    upper_pachilo Level 1
      Hello,
      am trying to get the GPU cores power advantage on a Windows machine using the aerender.exe command line tool (After Effects 2015.3)
      Although seems to detect the video card memory availability, not sure it is using the GPU to render the video because the times are the same comparing with the CPU.
      Is possible to use the GPU to render the video with the aerender.exe command line?
      Any help or clue will be appreciated.
      Cheers!
