15 Replies Latest reply on Nov 19, 2016 2:26 PM by maggieprentice
    DRM authorization issue with eReader
    j9carstock
      Hello,
      I am trying to download a book from my local library (in an EPUB format) using Adobe Digital Editions. The eBook opens correctly on my computer, but when I try to copy it over to my eReader, I get the following error:
      "This document is protected by Adobe Digital Rights Management (DRM) and is not currently authorized for use with your Adobe ID. Please sign-in with the authorized Adobe Id and try again."
      However, I have checked and the eBook is authorized under the same id as my device (I checked the authorization code). Do you have ideas about why that might be?
      I have tried re-setting my eReader to factory settings, but that has not fixed the issue.
      Thank you,
        • 1. Re: DRM authorization issue with eReader
          Nanaky Level 5
          Has you try if work with a older version: Adobe Digital Editions downloads
          • 2. Re: DRM authorization issue with eReader
            keeleyb41310847
            Did you ever get this solved?  I am having the same problem, but only with certain books.  I have had no luck getting help from Kobo or Adobe on this.
            • 3. Re: DRM authorization issue with eReader
              kitley
              Hi Keeley...yes, I did get it solved finally, with the help of a wonderful
              girl from Kobo.  Busy right now, but will send you the instructions this
              evening, that worked for me.  Do you have a Kobo ereader?  Mine is a Sony,
              but I would think it would work the same with both.  Will email you tonight.
              Kathy
              On Thu, Sep 15, 2016 at 7:47 PM, keeleyb41310847 <forums_noreply@adobe.com>
              • 4. Re: DRM authorization issue with eReader
                karenf19106783
                Will you email me too? I have the exact same problem/error message. Thank you!
                • 5. Re: DRM authorization issue with eReader
                  kitley Level 1
                  yes, I sure will Karen.  Please let me know if you receive this email...not
                  sure how to send it to you, plus the forum.  Thanks.
                  Kathy
                  On Fri, Sep 16, 2016 at 4:00 PM, karenf19106783 <forums_noreply@adobe.com>
                  • 6. Re: DRM authorization issue with eReader
                    keeleyb41310847 Level 1
                    Any help with it would be great!
                    Sent from my iPhone
                    • 7. Re: DRM authorization issue with eReader
                      kitley Level 1
                      Hi Keeley.  You will need to know your Digital Edition UserID and Password,
                      and password for whatever book site you are using.  Then, do the following
                      in order
                      1) launch Adobe Digital Edition
                      2) Deauthorize it be hitting Ctrl  shift and D
                      3) Reboot computer
                      4) Reauthorize ADE by doing the following
                      5) Launch ADE
                      6) Click drop down menu  (to right of Lib Menu)
                      7) Click Authorize Computer.  Now your computer is authorized to ADE
                      8) Reboot computer
                      9)Deauthorize your ereader from ADE, by doing the following
                      10)Launch  ADE) Connect ereader to computer
                      11) Hit  Ctrl  shift and E  to open a menu to select which device you want
                      to Deauthorze
                      12) safetly  remove and unplug ereader
                      13) Reset reader to factory settings, then rerenter date and time on
                      ereader, if needed, and resink ereader  with desktop
                      14) Reauthorize ereader, by closing ADE and unplug ereader
                      15) Plug in ereader and open ADE and it should say it has found a new
                      device to authorize
                      16) Reboot
                      This is what they told me to do...minus the reboots.  It didn't work the
                      first time, so I rebooted after each section and then it worked.  Only
                      trouble I had was resetting my ereader to factory settings, and found the
                      instructions online.  Hope this works for you...please let me know, and
                      hope you understand the way I am giving it to you..I kinda rewote them for
                      myself to understand.  Seems daunting because there are so many steps, but
                      it really isn't...took me 5 or 10 minutes
                        PS>step 13 where it says to resink ereadeader, I did not do as I could
                      not see how to do it.
                      Kathy
                      On Fri, Sep 16, 2016 at 8:09 AM, Kathy Hanes <kathyhanes2001@gmail.com>
                      • 8. Re: DRM authorization issue with eReader
                        kitley Level 1
                        Keeley...just sent instructions....did you get them, or did I send them to
                        the  help centre?
                        Kathy
                        • 9. Re: DRM authorization issue with eReader
                          kitley Level 1
                          Hi Karen...do these steps in order
                          Deauthorize Adobe Digital Edition, by launching ADE
                          - Deathorize  by hitting Ctrl shift and D
                          -Reboot computer
                          -Reauthorize by launching ADE
                          -click drop down to right of Lib Menu
                          -click Auth computer, and it should now be authorized
                          -Reboot computer
                          -Deauth e reader from ADE by
                          -Launch ADE
                          -connect ereader to computer
                          -hit Ctrl shift and E to open a menu to select which device you want to
                          Dauth
                          -safetly remove and unplug ereader
                          -reser ereader to factory settings then reenter date and time, if needed.
                          -Resink ereader with desktp ( I did not do this step as I could not see how
                          to do it)
                          To reauth ereader, close ADE and unplug ereader
                          -plug ereader back in and open ADE and it should say it has found a new
                          device to auth.
                          -Reboot
                          They gave me these instruciotns,.minus the reboots,  and it did not work
                          the first time, so the second time I rebooted after each step...and it
                          worked.  Let me know if it works for you.  Hope you understand the
                          instructions..I had rewritten so I could save them the way I interpreted
                          them.  You will need to know your  Digital Edition user id and password, as
                          well as the same for the site you use to get books.  The only trouble I
                          found was with resetting my ereader to factory settings, but found the
                          instructions online.  These instructions look daunting, but really it only
                          took 5 or 10 minutes to do.  Good luck.
                          Please let me know if this works for you.
                          Kathy
                          On Fri, Sep 16, 2016 at 7:33 PM, Kathy Hanes <kathyhanes2001@gmail.com>
                          • 10. Re: DRM authorization issue with eReader
                            karenf19106783 Level 1
                            Great, thank you!
                            Sent from my iPhone
                            • 11. Re: DRM authorization issue with eReader
                              Thanks!
                              Sent from my iPhone
                              • 12. Re: DRM authorization issue with eReader
                                johnm784224
                                Kathy ... can you send me the solution as well?
                                Many thanks
                                [Personal info removed by Mod, please send emails via PM]
                                • 13. Re: DRM authorization issue with eReader
                                  kitley Level 1
                                  yes, I will forward the steps as sent to me by Kobo.  For me, the first
                                  time it didn't work, so between each step, the next time, I rebooted my
                                  computer.  Not sure if I needed to, or if I did something wrong the first
                                  time.
                                  hmmm, on second thought I guess I can't forward them without your
                                  email...so here they are.  Feel free to post them on the forum if you know
                                  how...I can't figure it out.  Thanks
                                  you will need to know your Digital Editions user id and password
                                  -Launch Adobe Digital Editions
                                  - to deauthorize hit Ctrl shift, and D
                                  -reboot computer
                                  - Authorize by launching Dig Ed
                                  -click the drop down menu to Lib Menu on the right
                                  -click Author Comp...should now be authorized
                                  -Reboot Comp
                                  Deauthorize ereader
                                  -launch Dig E
                                  -connect reader to computer
                                  -hit ctrl, shift and E to open a menu to select which device you want to
                                  Deauth
                                  -saftly remove and unplug e reader
                                  -reset ereader to factory settings..can find instructions on line  for how
                                  to do this, then reenter date and time if needed
                                  -resink ereader to desktop...I did not do this step, as I could not figure
                                  how
                                  -Reboot
                                  To reauth ereader, close Dig Ed, and unplug ereader
                                  -plug  in ereader and open Dig Ed, and it should say it has found a new
                                  device to auth
                                  -reboot comp
                                    Hope it works...let me know please and thanks
                                  Kathy
                                  On Sat, Sep 17, 2016 at 6:46 PM, johnm784224 <forums_noreply@adobe.com>
                                  • 14. Re: DRM authorization issue with eReader
                                    kitley Level 1
                                    sorry John..had it typed and mod removed it, saying I have to pm you.
                                    Don't know how to do that.  If you email me    kathyhanes2001@hotmail.ca
                                    I will respond
                                    On Sat, Sep 17, 2016 at 8:23 PM, Kathy Hanes <kathyhanes2001@gmail.com>
                                    • 15. Re: DRM authorization issue with eReader
                                      maggieprentice
                                      i am also having this issue, it seem to be everytime I download a new book.  can't even open the book I was currently reading and am about 80% read with it, very frustrating
