2 Replies Latest reply on Apr 17, 2006 8:20 PM by Newsgroup_User
    Loading multiple consecutive .swf files in Flash 8
    dragonlilly
      I have a question and hope that someone may be able to help; this might be a piece of cake for you...
      I have a container .fla movie and would like to load consecutive external .swf files. Right now I have a play button triggering the loading of the next movie, but what I would REALLY like is a smooth transition from .swf to .swf using a listener so that the next .swf will load once the previous one has finished. I have a counter which determines the next .swf in order.
      So far, my code is this:
      Counter:
      stop();
      //SETUP OUR COUNTER
      var mcCounter:Number = 0;
      //THIS BLOCK IS ONLY TO HANDLE THE LOADER AND THE FIRST MOVIE, movie0.swf
      var myMCL:MovieClipLoader = new MovieClipLoader();
      var loadListener bject = new Object();
      myMCL.addListener(loadListener);
      myMCL.loadClip("movie" + mcCounter + ".swf", 6);
      loadListener.onLoadComplete = function():Void {
      _level0.play();
      //-------------------------<CLIP LOADERS>------------------------------\\
      function loadNextClip():Void {
      if(mcCounter < 6) {
      mcCounter++;
      var nextMCL:MovieClipLoader = new MovieClipLoader();
      nextMCL.addListener(this);
      nextMCL.loadClip("movie" + mcCounter + ".swf",6);
      //LOADS PREVIOUS CLIP , WON"T GO PAST ZERO
      function loadPrevClip():Void {
      if(mcCounter > 0) {
      mcCounter--;
      var prevMCL:MovieClipLoader = new MovieClipLoader();
      prevMCL.addListener(this);
      prevMCL.loadClip("movie" + mcCounter + ".swf",6);
      //-------------------------</CLIP LOADERS>------------------------------\\
      Any suggestions? I appreciate ANY help you can offer. I have been unsuccessfully looking for hours online, and can't find any examples, although it doesn't seem as if it should be the hardest thing in the world.
      Thanks!
        • 1. Re: Loading multiple consecutive .swf files in Flash 8
          babo_ya Level 3
          use 'OnLoadInit' instead of onLoadComplete
          • 2. Re: Loading multiple consecutive .swf files in Flash 8
            Level 7
            You need a monitor to know when one movie clip has completed play. A simple
            monitor could be adding onEnterFrame handler to the container_mc when
            MovieClipLoader onComplete or onInit is fired. In that handler a test to see
            when the loaded clip's _currentframe == the loaded clip"s _totaframes.
            Ex:
            this.createEmptyMovieClip("container_mc", this.getNextHighestDepth());
            container_mc._x = 0;
            container_mc._y = 0;
            var swfNumber:Number = 0;
            var swfNumberMax:Number = 25;
            var swfNamePrefix = "MovieClipLoaderDetectEndOfPlay_Movie";
            var mclListener bject = new Object();
            mclListener.onLoadStart = function(target_mc:MovieClip)
            target_mc.startTimer = getTimer();
            mclListener.onLoadComplete = function(target_mc:MovieClip)
            target_mc.completeTimer = getTimer();
            mclListener.onLoadInit = function(target_mc:MovieClip)
            var timerMS:Number = target_mc.completeTimer - target_mc.startTimer;
            target_mc.play();
            target_mc.onEnterFrame = function()
            trace(this._currentframe)
            if (this._currentframe == this._totalframes)
            trace("Load Next Swf")
            loadNextSwf()
            var container_mcl:MovieClipLoader = new MovieClipLoader();
            container_mcl.addListener(mclListener);
            function loadNextSwf()
            swfNumber++;
            if (swfNumber <= swfNumberMax)
            var swfSuffix = ((swfNumber<10)?"0" :"") + swfNumber;
            container_mcl.loadClip(swfNamePrefix + swfSuffix + ".swf", container_mc);
            loadNextSwf()
            Lon Hosford
            www.lonhosford.com
            May many happy bits flow your way!
            "dragonlilly" <webforumsuser@macromedia.com> wrote in message
            news:e20o1d$h5n$1@forums.macromedia.com...
            a
            .swf
            Counter:
            stop();
            //SETUP OUR COUNTER
            _level0.play();
            if(mcCounter < 6) {
            mcCounter++;
            if(mcCounter > 0) {
            mcCounter--;
            although
            Thanks!
