Is it possible to export multiple documents from Adobe Sign
Hi Markdiggitty
Please be informed the feature to bulk download documents is only possible in Adobe Sign Enterprise account through API.
Do check my private message for more details.
Regards,
Aadesh
Hi Markdiggitty
Regards,
Aadesh
Is this still true today, 2018, with adobe sign that bulk update is not possible without API?
Hi Mike,
The bulk download feature is only available through the Adobe Sign Enterprise and requires access to the API. Its very straight-forward and easy to set up (no coding required).
Hope this helps!
Kind regards,
We have an Adobe enterprise account. How do I access the API and download multiple documents? Are instructions for these available anywhere? Or can they be posted here?
Hi thee,
Please refer to this help document Integration reference guides | Adobe Sign on Integration guides.
Check if that helps.
If you still need help with API integration, I would suggest contacting the support team to get help with this.
Find below the steps to contact support:
• Login to your Adobe Sign account directly via Sign In — e-signature and e-sign Software Solution — Adobe Sign
• Once logged in, check the upper right corner of the page and click the question mark icon.
• It will re-direct you to the page where you get the option to create the support case or to start a chat with the team.
• If you've never logged in this way, use the forgot password option on the login link to set your password.
Let us know if you need any help.
Regards,
Meenakshi
