2 Replies Latest reply on Aug 25, 2016 9:15 AM by Dogspods
    Import subfolders as layers....
    Dogspods
      I need a script that will import all subfolders as layers, either as an individual PSD file for each subfolder or as a single file (first option is preferable).
      I've been using this script so far (found here: Batch subfolder images to layer stacks, then to sprites. )
      // select folder, create files with the contents of one of the subfolders each as layers and save them to the folder;
      • // use it at your own risk;
      • #target photoshop
      • // select a folder;
      • var sourceFolder = Folder.selectDialog("Select folder");
      • if (sourceFolder) {
      • // the psd options;
      • psdOpts = new PhotoshopSaveOptions();
      • psdOpts.embedColorProfile = true;
      • psdOpts.alphaChannels = false;
      • psdOpts.layers = true;
      • psdOpts.spotColors = true;
      • // get the contents as one array per folder;
      • var items = retrieveFiles(sourceFolder, [[]]);
      • // iterate through;
      • for (var m = 1; m < items.length; m++) {
      •           var thisArray = items[m];
      •           var folderName = thisArray[0].parent.name;
      • // open file;
      •           var theImage = app.open(File(thisArray[0]));
      •           for (var n = 1; n < thisArray.length; n++) {
      • // place rest of array;
      •                     var theLayer = placeScaleFile(thisArray[n], 0, 0, 100);
      • // save the stacked file;
      •           theImage.saveAs(new File(sourceFolder+"/"+folderName+".psd"),psdOpts,false);
      • // close;
      •           theImage.close(SaveOptions.DONOTSAVECHANGES);
      • ////// get from subfolders //////
      • function retrieveFiles (theFolder, theFiles) {
      •           if (!theFiles) {var theFiles = [[]]};
      •           var theContent = theFolder.getFiles();
      •           for (var n = 0; n < theContent.length; n++) {
      •                     var theObject = theContent[n];
      •                     if (theObject.constructor.name == "Folder") {
      •                               theFiles.push(new Array)
      •                               retrieveFiles(theObject, theFiles)
      •                     if (theObject.name.match(new RegExp(/\.(jpe|jpg|jpeg|gif|png|tif|tiff|bmp|psd|dng|pict|eps|raw|rw2|crw|cr2)/i)) != null) {
      •                               theFiles[theFiles.length - 1].push(theObject)
      •           return theFiles
      • ////// get psds, tifs and jpgs from files //////
      • function getFiles (theFile) {
      •     if (theFile.name.match(/\.(eps|ai|jpg|tif|psd|pdf|)$/i)) {
      •         return true
      • ////// place //////
      • function placeScaleFile (file, xOffset, yOffset, theScale) {
      • var idPlc = charIDToTypeID( "Plc " );
      •     var desc5 = new ActionDescriptor();
      •     var idnull = charIDToTypeID( "null" );
      •     desc5.putPath( idnull, new File( file ) );
      •     var idFTcs = charIDToTypeID( "FTcs" );
      •     var idQCSt = charIDToTypeID( "QCSt" );
      •     var idQcsa = charIDToTypeID( "Qcsa" );
      •     desc5.putEnumerated( idFTcs, idQCSt, idQcsa );
      •     var idOfst = charIDToTypeID( "Ofst" );
      •         var desc6 = new ActionDescriptor();
      •         var idHrzn = charIDToTypeID( "Hrzn" );
      •         var idPxl = charIDToTypeID( "#Pxl" );
      •         desc6.putUnitDouble( idHrzn, idPxl, xOffset );
      •         var idVrtc = charIDToTypeID( "Vrtc" );
      •         desc6.putUnitDouble( idVrtc, idPxl, yOffset );
      •     desc5.putObject( idOfst, idOfst, desc6 );
      •     var idWdth = charIDToTypeID( "Wdth" );
      •     var idPrc = charIDToTypeID( "#Prc" );
      •     desc5.putUnitDouble( idWdth, idPrc, theScale );
      •     var idHght = charIDToTypeID( "Hght" );
      •     desc5.putUnitDouble( idHght, idPrc, theScale );
      •     var idLnkd = charIDToTypeID( "Lnkd" );
      •     desc5.putBoolean( idLnkd, true );
      • executeAction( idPlc, desc5, DialogModes.NO );
      • return app.activeDocument.activeLayer;
      It's almost perfect for my needs but would be better if the images were imported as standard layers and not smart objects.
