4 Replies Latest reply on Dec 7, 2016 5:58 AM by Nanaky
    Error, Check Activation?
    knitpurlmama
      I am trying to download an ebook from Netgalley, and I have Adobe Digital Editions installed, but when I try to open the book, it tells me "Error! Check Activation". I am logged into Adobe Digital Editions and it's authorized to my computer. Why won't it work.
        • 1. Re: Error, Check Activation?
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
          • 2. Re: Error, Check Activation?
            Guernseycove Level 1
            Do not see adept key
            • 3. Re: Error, Check Activation?
              briank99751229 Level 1
              I already did thsi step ( necessary to de-authorize) but now won;t allow me to authorize my computer.  Says it cannot "connect to fulfillment server" and thinks I am not online (which obviously I AM).
              Don;t waste your time with chat.  They have zero clue and cannot help.
              • 4. Re: Error, Check Activation?
                Nanaky Level 5
                o.O Do found the entry untill this: HKEY_CURRENT_USER\Software\Adobe\
