3 Replies Latest reply on Aug 26, 2016 8:22 AM by Jeff Witchel, ACI
    Pasting image (bitmap - png) into InDesign renders at lower resolution
    shawninvancouver Level 2
      Hello all,
      I am encountering a problem that I have never before experienced.
      I am trying to insert an image (tried different images)... all at high resolution and when placed in the InDesign document, the image loses significant fidelity. I have tried both copying from PhotoShop and placing the image directly from a saved .png image.
      From InDesign, setting display performance to high makes a small difference but it is still pixelated. Publishing (Export) to high quality also results in a low resolution image.
      Also important to note:
      - I am editing a previously created document with other high resolution bitmaps and they all appear sharp (on-screen) and publish at high resolution.
      - I have opened a new document and still, I no success!
      It appears as though something in the InDesign configuration has changed which is now causing any new images to auto-reduce their resolution.
      Any thoughts? This is absolutely baffling.
