1 Reply Latest reply on Aug 26, 2016 5:21 AM by Steve Grisetti
    Premiere Element 14: WinTV ts file Multi Track Audio Issue
    young oh80280448
      I just downloaded trial version of PE14 to test ts file(WinTV file) editing and found out multi track audio issue.
      I recorded football match and imported ts file to PE14. The problem is, I can hear the game sound but commentary's gone. I can hear the sound from the field but broadcasting commentary's gone. I don't think there's any audio problem during the commercial, but I there's no commentary audio during the game.
      The 'Mixer Options' shows "AUDIO 1 - Foreground", "Voice - Foreground", "Music - Background", "AUDIO 2 - Background", "AUDIO 3 - Background". I have no idea which track is what.
      I tried to change the "VOICE" setting to "Background", but I got error message saying "One or more selected file(s) could not be auto analyzed". Every time I tried to change the mixer setting, I received the same error message.
      (I tested another ts file, this time recorded TV drama, but the result was same. I could hear background music but there's no voice.)
      Can you tell me how I can fix this audio issue?
      Below is my ts file info:
      Format                                   : MPEG-TS
      File size                                : 22.2 GiB
      Duration                                 : 3 h 12 min
      Start time                               : UTC 2016-08-25 23:59:51
      End time                                 : UTC 2016-08-26 03:12:35
      Overall bit rate mode                    : Variable
      Overall bit rate                         : 16.5 Mb/s
      Law rating                               : N/A
      Video
      Menu ID                                  : 3 (0x3)
      Format                                   : MPEG Video
      Format version                           : Version 2
      Format profile                           : Main@High
      Format settings, BVOP                    : Yes
      Format settings, Matrix                  : Custom
      Format settings, GOP                     : Variable
      Format settings, picture structure       : Frame
      Codec ID                                 : 2
      Bit rate mode                            : Variable
      Bit rate                                 : 15.1 Mb/s
      Maximum bit rate                         : 24.0 Mb/s
      Width                                    : 1 920 pixels
      Height                                   : 1 080 pixels
      Display aspect ratio                     : 16:9
      Frame rate                               : 29.970 (30000/1001) FPS
      Color space                              : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8 bits
      Scan type                                : Interlaced
      Scan order                               : Top Field First
      Compression mode                         : Lossy
      Bits/(Pixel*Frame)                       : 0.242
      Stream size                              : 20.3 GiB (92%)
      Audio #1
      Menu ID                                  : 3 (0x3)
      Format                                   : AC-3
      Format/Info                              : Audio Coding 3
      Mode extension                           : CM (complete main)
      Format settings, Endianness              : Big
      Codec ID                                 : 129
      Bit rate mode                            : Constant
      Bit rate                                 : 384 kb/s
      Channel(s)                               : 6 channels
      Channel positions                        : Front: L C R, Side: L R, LFE
      Sampling rate                            : 48.0 kHz
      Frame rate                               : 31.250 FPS (1536 spf)
      Delay relative to video                  : -331 ms
      Stream size                              : 529 MiB (2%)
      Language                                 : English
      Audio #2
      Menu ID                                  : 3 (0x3)
      Format                                   : AC-3
      Codec ID                                 : 129
      Bit rate                                 : 192 kb/s
      Channel(s)                               : 2 channels
      Channel positions                        : Front: L R
      Delay relative to video                  : -299 ms
      Stream size                              : 265 MiB (1%)
      Language                                 : Spanish
      Text #1
      ID                                       : 49 (0x31)-CC1
      Menu ID                                  : 3 (0x3)
      Format                                   : EIA-608
      Muxing mode                              : A/53 / DTVCC Transport
      Muxing mode, more info                   : Muxed in Video #1
      Stream size                              : 0.00 Byte (0%)
      Text #2
      Menu ID                                  : 3 (0x3)
      Format                                   : EIA-708
        • 1. Re: Premiere Element 14: WinTV ts file Multi Track Audio Issue
          If there are multiple channels of audio on your media clip, you're not going to hear all of the individual channels in Premiere Elements. Premiere Elements can not separate the audio for the commentary, football game, commercials, etc.
          The Music, Voice, Audio 1, etc., on the Smart Mixer refer to the audio tracks on your timeline. And you should be able to tell which is which just by looking at the timeline and seeing which audio clips are on each track.
          If you can't figure it out, post a screen capture of your timeline to this forum and we'll tell you.
