12 Replies Latest reply on Aug 29, 2016 2:04 PM by Ann Bens
    Still Images in Reused Video Vibrate
    The One True raywood Level 1
      I'm using PE 12. I am creating a new video. I import an old video. The old video contains still images. When I play the new video (either inside PE or as an exported video), the still images vibrate slightly. It looks like an interlacing issue, or maybe alternate frames are being blurred, at a rate of perhaps twice per second. Here is an example (starting at 8:17):
      A Wedding (July 6, 1996) - YouTube
      Whatever it is, it results in a flashing effect that detracts from the video.
      The Anti-Flicker Filter does not resolve the problem. Exporting each still image, deinterlacing them in an image editor (e.g., Photoshop), and then reassembling them in a new video, would require a great deal of work, as there are quite a few images. Smart Fix is available by right-clicking on the clip, and is apparently also invoked by answering Yes in response to the question, "Fix quality problems in clips?" when dragging the video onto the timeline. But while Smart Fix seems to fix the flickering problem, it also appears to degrade the images.
      Sometimes the layering trick solves the problem: add a duplicate of the old video in a separate track, lagging by one frame, and set both copies to half brightness. Sometimes it doesn't help.
      For some reason, a screen capture of the old video can be used in the new video without flickering. I'm presently using Debut for my screen captures. But I think this can't be good for quality, and in any case it is time-consuming and ties up the computer.
      Any other ideas?
        • 1. Re: Still Images in Reused Video Vibrate
          That looks like an interlacing issue, most caused by something in the original video.
          What is the format and what is the resolution and frame rate of the old video you imported into your project? How was this video created?
          • 2. Re: Still Images in Reused Video Vibrate
            Steve, I don't have the details on the video imported into the YouTube example. But I am currently getting the effect when importing a video of stills, and this source video is 1280x720, bitrate 4256kbps (according to Windows Explorer > Properties > Details) or 2690kbps (according to MediaTab), 24fps, 8-bit progressive scan. I haven't tried producing any output; the flashing is evident even with playback within Premiere Elements 12. PE's Project Settings says the project into which I am attempting to import this video is 1920x1280, with a timebase of 29.97fps and a video display format of 30fps drop-frame timecode.
            • 3. Re: Still Images in Reused Video Vibrate
              There is no instant fix as the problem is in the original video.
              You will have to do the images one by one.
              If the original video is 24 frames, so should your project.
              • 4. Re: Still Images in Reused Video Vibrate
                Unless I'm missing it, a key piece of information is needed. You know what the original slides were and you know what your final output is -- but the key element is the specs of the video you output from your original slides and which you used as your source video in your new project.
                Download the free program Media Info and use it to open this older video. It should give you information on this video's resolution, frame rate and audio and video codecs. (You can post the report here if you can't make sense of it.) Also, it is an MPEG, AVI, MOV, MTS, MP4 or what?
                If this video is interlaced (and I'm suspecting it is) that would account for the strange "combing" effect you're seeing.
                • 5. Re: Still Images in Reused Video Vibrate
                  Thanks for your persistence in helping me with this. I did post the details on the source video (see above), at least for another video where I'm having the same effect. I no longer have access to the source materials for the YouTube video. I'm sure the source for the YouTube video did not have those same specifications. Which leads to the prophylactic question: assuming interlacing is the culprit in diverse cases, can and should I just disable whatever it is that is producing interlaced output (which then sometimes gets reused in new videos)?
                  • 6. Re: Still Images in Reused Video Vibrate
                    You cannot fix this as its in the original. Is only the last images as the weddings stills are just fine.
                    As said before need to fix this one by one.
                    It changes every 1/2 second so just use the 1/2 good part second of the still and expand on the timeline.
                    • 7. Re: Still Images in Reused Video Vibrate
                      I've looked through this whole thread, raywood. I don't see the Media Info report on the video.
                      • 8. Re: Still Images in Reused Video Vibrate
                        Sorry, Steve. I'm a little slow. I now have the Media Info report. This is not for the video shown on the YouTube link (above). For that one, I no longer have access to the source materials. This is for another video whose still photo content produces an alternating flashing effect, when imported into a video in Premiere Elements 12.
                        General
                        Format                                   : MPEG-PS
                        File size                                : 89.4 MiB
                        Duration                                 : 4 min
                        Overall bit rate mode                    : Variable
                        Overall bit rate                         : 3 102 kb/s
                        Video
                        Format                                   : MPEG Video
                        Commercial name                          : HDV 720p
                        Format version                           : Version 2
                        Format profile                           : Main@High 1440
                        Format settings, BVOP                    : Yes
                        Format settings, Matrix                  : Default
                        Format settings, GOP                     : M=3, N=12
                        Duration                                 : 4 min
                        Bit rate mode                            : Variable
                        Bit rate                                 : 2 848 kb/s
                        Maximum bit rate                         : 4 000 kb/s
                        Width                                    : 1 280 pixels
                        Height                                   : 720 pixels
                        Display aspect ratio                     : 16:9
                        Frame rate                               : 25.000 FPS
                        Standard                                 : PAL
                        Color space                              : YUV
                        Chroma subsampling                       : 4:2:0
                        Bit depth                                : 8 bits
                        Scan type                                : Progressive
                        Compression mode                         : Lossy
                        Bits/(Pixel*Frame)                       : 0.124
                        Time code of first frame                 : 00:00:00:00
                        Time code source                         : Group of pictures header
                        GOP, Open/Closed                         : Open
                        GOP, Open/Closed of first frame          : Closed
                        Stream size                              : 82.0 MiB (92%)
                        Color primaries                          : BT.709
                        Transfer characteristics                 : BT.709
                        Audio
                        Format                                   : MPEG Audio
                        Format version                           : Version 1
                        Format profile                           : Layer 2
                        Duration                                 : 4 min
                        Bit rate mode                            : Constant
                        Bit rate                                 : 192 kb/s
                        Channel(s)                               : 2 channels
                        Sampling rate                            : 32.0 kHz
                        Stream size                              : 5.53 MiB (6%)
                        • 9. Re: Still Images in Reused Video Vibrate
                          Can you link me to the "alternating flashy effect" this video produces so I can see it?
                          Also, when you place this video as the first video on your timeline, do you see a yellow-orange "render" line along the top of the timeline above the clip?
                          • 10. Re: Still Images in Reused Video Vibrate
                            I'm not sure I've ever noticed that Render line. But I will be on the lookout for it.
                            I'm having a hard time replicating the problem with this newer video input. I am sure it will recur; it has been cropping up repeatedly. But I will have to delay a more responsive reply until I encounter it again.
                            • 11. Re: Still Images in Reused Video Vibrate
                              If you'd like to post a clip of the video of the slideshow (the one you used as source footage for your recent project) to a site like Dropbox and then share it with me (my first name at the name of the web site Muvipix dot com), I'll be glad to play with it at my end. It may be easier than asking you to do all the research.
                              • 12. Re: Still Images in Reused Video Vibrate
                                Put it on Dropbox for everyone to share.
