4 Replies Latest reply on Aug 28, 2016 12:13 AM by Barbara Ash
    Type rewrapping
    printlives Level 1
      I just opened a magazine file I created about 6 months ago, and found many pages throughout it have rewrapped.  The file was created in a previous update of ID 2015, and I am getting no missing font warnings of other obvious problems that are causing this, and I am on the same Mac as the file was created on.  Is there some known issue or incompatibility between ID updates that could be causing this? I open old files all the time, and have never seen this happen before, but its potentially very problematic to my workflow if things are changing between ID updates.
        • 1. Re: Type rewrapping
          There is always a risk of reflow when changing versions, and it isn't surprising if it happens for a dot release when one of the things modified is the text engine.
          • 2. Re: Type rewrapping
            Barbara Ash Adobe Community Professional
            If you click in a paragraph and go to the Paragraph panel menu, you can choose Adobe Single Line Composer. That will prevent lines from re-wrapping when you change versions. The default setting is Adobe Paragraph Composer, which usually does a better job of composing paragraphs, but can change with version upgrades.
            • 3. Re: Type rewrapping
              Not true, if a bug came up in a previous version and this bug is repaired you will see text recomposing also if you use the single line composer. There have been several bugs in the past according dictionaries and hyphenation. I would be very glad, if Adobe could repair them soon or has it done. Which would cause a wanted recomposition.
              There are several reasons why it could recompose. Maybe that a font has been missed on the first place, maybe that you have used a user dictionary which is not available any more, or you have changed from the document settings to the computer's settings, maybe that you have updated the font, same name but a different version, maybe a linked file was updated with a different wrap setting or a different clipping path which has been used for wrapping.
              As long as we don't have further information, we can only guess.
              • 4. Re: Type rewrapping
                All of that is true in #3 post and I'm not advocating single line composer. but if the type recomposes because Adobe has changed the text engine, it is less likely to happen with single line composer.
