Hi Pam
Just some information that may help here. In RoboHelp HTML,
if you click Tools > Options... > HTML Editors tab, you see
all the known editors listed. The default editor is normally set
for RoboHelp WYSIWYG. However, you can use any editor you like.
This is where the Auto-select comes into play.
If you have Auto-select selected, RoboHelp HTML looks for a
META tag identifying the editor before the topic is opened. So if
you have Dreamweaver and it has placed its own special META tag
identifying the topic as having been created using Dreamweaver,
then RoboHelp HTML launches Dreamweaver to edit the topic.
Now if you change the option from "Auto-select" to "Use
Default Editor", all topics, regardless of what META tag identifies
the creator will open in the RoboHelp HTML WYSIWYG editor.
The reason you see the dire warning about the topic possibly
being open in the editor, is because RoboHelp is trying to edit the
file. It has no clue whether you have the file open in Notepad,
Dreamweaver, FrontPage, HomeSite or any other editor. So it is
warning you that if you do have the file open, you should probably
close it before continuing with RoboHelp.
Hopefully this helps better clarify why this is happening and
what you can do to fix it.
Sincerely... Rick
